[Liblas-commits] hg: make default formatid ePointFormat3, not ePointFormat0
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Oct 1 15:28:55 EDT 2010
changeset af0e4d93cbe5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=af0e4d93cbe5
summary: make default formatid ePointFormat3, not ePointFormat0
diffstat:
 src/lasheader.cpp    |  17 +----------------
 test/unit/common.cpp |   4 ++--
 2 files changed, 3 insertions(+), 18 deletions(-)
diffs (49 lines):
diff -r 98adc5fafb38 -r af0e4d93cbe5 src/lasheader.cpp
--- a/src/lasheader.cpp	Thu Sep 30 09:37:12 2010 -0500
+++ b/src/lasheader.cpp	Fri Oct 01 14:28:46 2010 -0500
@@ -67,7 +67,7 @@
 char const* const Header::SoftwareIdentifier = "libLAS 1.2";
-Header::Header() : m_schema(ePointFormat0)
+Header::Header() : m_schema(ePointFormat3)
     Init();
@@ -652,21 +652,6 @@
     return m_schema;
-// void Header::UpdateSchema()
-//     m_schema
-//     // if (GetDataFormatId() == liblas::ePointFormat3) {
-//     //     m_schema.Color(true);
-//     //     m_schema.Time(true);
-//     // } else if (GetDataFormatId() == liblas::ePointFormat2) {
-//     //     m_schema.Time(false);
-//     // } else if (GetDataFormatId() == liblas::ePointFormat1) {
-//     //     m_schema.Color(false);
 void Header::SetSchema(const Schema& format)
diff -r 98adc5fafb38 -r af0e4d93cbe5 test/unit/common.cpp
--- a/test/unit/common.cpp	Thu Sep 30 09:37:12 2010 -0500
+++ b/test/unit/common.cpp	Fri Oct 01 14:28:46 2010 -0500
@@ -63,9 +63,9 @@
     ensure_equals("wrong default records count",
         h.GetRecordsCount(), boost::uint32_t(0));
     ensure_equals("wrong default data format id",
-        h.GetDataFormatId(), liblas::ePointFormat0);
+        h.GetDataFormatId(), liblas::ePointFormat3);
     ensure_equals("wrong default data record length",
-        h.GetDataRecordLength(), liblas::ePointSize0);
+        h.GetDataRecordLength(), liblas::ePointSize3);
     ensure_equals("wrong default point records count",
         h.GetPointRecordsCount(), boost::uint32_t(0));
More information about the Liblas-commits mailing list
