[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org
Mon Oct 4 16:04:07 EDT 2010
changeset 37205527799d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=37205527799d
summary: regularize GetHeaderPtr/SetHeaderPtr -- dummy up a PointFactory
changeset c091fce0c6c0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c091fce0c6c0
summary: use SetHeaderPtr instead of SetHeader
changeset 9fc12e4f25ef in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9fc12e4f25ef
summary: update tests for schema changes and defaulting to pointformat3
changeset 714380d4bfe6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=714380d4bfe6
summary: schema-enabled read/write for a number of liblas::Point attributes
changeset a6e938ee4be8 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a6e938ee4be8
summary: merge
diffstat:
apps/lasblock.cpp | 13 +-
include/liblas/lasheader.hpp | 24 ++
include/liblas/laspoint.hpp | 140 ++++++--------
include/liblas/lasschema.hpp | 45 +++-
python/tests/Header.txt | 8 +-
python/tests/Schema.txt | 6 +-
src/detail/reader/point.cpp | 2 +-
src/laspoint.cpp | 413 +++++++++++++++++++++++++++++++++---------
src/lasschema.cpp | 137 ++++++++++---
test/unit/laspoint_test.cpp | 12 +-
10 files changed, 563 insertions(+), 237 deletions(-)
diffs (truncated from 1281 to 300 lines):
diff -r af0e4d93cbe5 -r a6e938ee4be8 apps/lasblock.cpp
--- a/apps/lasblock.cpp Fri Oct 01 14:28:46 2010 -0500
+++ b/apps/lasblock.cpp Mon Oct 04 15:03:54 2010 -0500
@@ -14,6 +14,15 @@
// std
#include <fstream>
#include <vector>
+// boost
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable : 4512)
+#include <boost/program_options.hpp>
+#pragma warning(pop)
+#endif
+namespace po = boost::program_options;
#ifdef _WIN32
#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
@@ -21,10 +30,6 @@
#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
#endif
-#include <boost/program_options.hpp>
-namespace po = boost::program_options;
bool term_progress(std::ostream& os, double complete)
static int lastTick = -1;
diff -r af0e4d93cbe5 -r a6e938ee4be8 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp Fri Oct 01 14:28:46 2010 -0500
+++ b/include/liblas/lasheader.hpp Mon Oct 04 15:03:54 2010 -0500
@@ -404,6 +404,30 @@
std::ostream& operator<<(std::ostream& os, liblas::Header const&);
+/// Singleton used for all empty points upon construction. If
+/// a reader creates the point, the HeaderPtr from the file that was
+/// read will be used, but all stand-alone points will have EmptyHeader
+/// as their base.
+class EmptyHeader
+public:
+ virtual ~EmptyHeader() {};
+ static Header const& get()
+ static Header object;
+ return object;
+protected:
+ EmptyHeader();
+ EmptyHeader( EmptyHeader const&);
+ EmptyHeader& operator=( EmptyHeader const&);
} // namespace liblas
#endif // LIBLAS_LASHEADER_HPP_INCLUDED
diff -r af0e4d93cbe5 -r a6e938ee4be8 include/liblas/laspoint.hpp
--- a/include/liblas/laspoint.hpp Fri Oct 01 14:28:46 2010 -0500
+++ b/include/liblas/laspoint.hpp Mon Oct 04 15:03:54 2010 -0500
@@ -63,49 +63,22 @@
namespace liblas {
-// template <typename T>
-// class Scaled
-// public:
-// Scaled(T value, double* scale, double* offset)
-// : m_value(value), m_scale(scale), m_offset(offset) {};
-// Scaled(Scaled const& other)
-// : m_value(other.m_value)
-// , m_scale(other.m_scale)
-// , m_offset(other.m_offset)
-// Scaled& operator=(Scaled<T> const& rhs)
-// if (&rhs != this)
-// m_value = rhs.m_value;
-// m_scale = rhs.m_scale;
-// m_offset = rhs.m_scale;
-// return *this;
-// operator double() const
-// double output = (m_value * *m_scale) + *m_offset;
-// std::cout << "double(): " << output << " m_value: " << m_value << " m_scale: " << *m_scale << " m_offset: " << *m_offset << std::endl;
-// return (m_value * *m_scale) + *m_offset;
-// operator T() const
-// return m_value;
-// private:
-// T m_value;
-// double* m_scale;
-// double* m_offset;
+class PointFactory
+public:
+ PointFactory();
+ static const PointFactory* getInstance();
+ PointPtr createPoint() const;
+ PointPtr createPoint(HeaderPtr hdr) const;
+ /// Destructor
+ virtual ~PointFactory();
+private:
+ HeaderPtr m_header;
/// Point data record composed with X, Y, Z coordinates and attributes.
class Point
@@ -244,7 +217,7 @@
std::vector<boost::uint8_t> const& GetData() const {return m_format_data; }
void SetData(std::vector<boost::uint8_t> const& v) { m_format_data = v;}
- void SetHeader(HeaderPtr header);
+ void SetHeaderPtr(HeaderPtr header);
HeaderPtr GetHeaderPtr() const;
property_tree::ptree GetPTree() const;
@@ -264,6 +237,8 @@
// must account for this.
boost::array<double, 3> m_double_coords_cache;
+ std::vector<boost::uint8_t>::size_type GetDimensionPosition(std::string const& name) const;
Color m_color;
double m_gps_time;
boost::uint16_t m_intensity;
@@ -273,6 +248,7 @@
boost::int8_t m_angle_rank;
Classification m_class;
HeaderPtr m_header;
+ Header const& m_default_header;
void throw_out_of_range() const;
@@ -289,49 +265,49 @@
return (!(lhs == rhs));
-inline boost::uint16_t Point::GetIntensity() const
- return m_intensity;
+// inline boost::uint16_t Point::GetIntensity() const
+// return m_intensity;
+// inline void Point::SetIntensity(boost::uint16_t const& intensity)
+// m_intensity = intensity;
-inline void Point::SetIntensity(boost::uint16_t const& intensity)
- m_intensity = intensity;
+// inline boost::uint16_t Point::GetReturnNumber() const
+// // Read bits 1,2,3 (first 3 bits)
+// return (m_flags & 0x07);
-inline boost::uint16_t Point::GetReturnNumber() const
- // Read bits 1,2,3 (first 3 bits)
- return (m_flags & 0x07);
+// inline boost::uint16_t Point::GetNumberOfReturns() const
+// // Read bits 4,5,6
+// return ((m_flags >> 3) & 0x07);
-inline boost::uint16_t Point::GetNumberOfReturns() const
- // Read bits 4,5,6
- return ((m_flags >> 3) & 0x07);
+// inline boost::uint16_t Point::GetScanDirection() const
+// // Read 7th bit
+// return ((m_flags >> 6) & 0x01);
+// inline boost::uint16_t Point::GetFlightLineEdge() const
+// // Read 8th bit
+// return ((m_flags >> 7) & 0x01);
-inline boost::uint16_t Point::GetScanDirection() const
- // Read 7th bit
- return ((m_flags >> 6) & 0x01);
+// inline boost::uint8_t Point::GetScanFlags() const
+// return m_flags;
-inline boost::uint16_t Point::GetFlightLineEdge() const
- // Read 8th bit
- return ((m_flags >> 7) & 0x01);
-inline boost::uint8_t Point::GetScanFlags() const
- return m_flags;
-inline void Point::SetScanFlags(boost::uint8_t const& flags)
- m_flags = flags;
+// inline void Point::SetScanFlags(boost::uint8_t const& flags)
+// m_flags = flags;
inline boost::int8_t Point::GetScanAngleRank() const
diff -r af0e4d93cbe5 -r a6e938ee4be8 include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp Fri Oct 01 14:28:46 2010 -0500
+++ b/include/liblas/lasschema.hpp Mon Oct 04 15:03:54 2010 -0500
@@ -51,6 +51,7 @@
#include <boost/any.hpp>
#include <boost/shared_ptr.hpp>
#include <boost/foreach.hpp>
+#include <boost/array.hpp>
// std
#include <iosfwd>
@@ -66,7 +67,10 @@
typedef boost::shared_ptr<Dimension> DimensionPtr;
typedef std::map<std::string, DimensionPtr> DimensionMap;
+typedef std::vector<DimensionPtr> DimensionArray;
+typedef boost::array<std::size_t, 4> SizesArray;
+typedef std::map<std::string, SizesArray > SizesMap;
class Schema
@@ -104,6 +108,7 @@
std::vector<std::string> GetDimensionNames() const;
DimensionMap const& GetDimensions() const { return m_dimensions; }
liblas::property_tree::ptree GetPTree() const;
+ SizesArray GetSizes(std::string const& name) const;
boost::uint16_t GetSchemaVersion() const { return m_schemaversion; }
void SetSchemaVersion(boost::uint16_t v) { m_schemaversion = v; }
@@ -113,12 +118,12 @@
protected:
- boost::uint16_t m_size;
PointFormatName m_data_format_id;
boost::uint32_t m_nextpos;
std::size_t m_bit_size;
std::size_t m_base_bit_size;
boost::uint16_t m_schemaversion;
+ SizesMap m_sizes;
private:
@@ -172,15 +177,39 @@
/// bytes, physical/serialisation size of record
std::size_t GetByteSize() const
- if (m_bitsize % 8 != 0) {
- std::ostringstream oss;
- oss << m_name << "'s bit size, " << m_bitsize
- << ", is not a multiple of 8 and "
- << "cannot be expressed as a single byte value";
More information about the Liblas-commits
