[Liblas-commits] hg: CMAKE_BUILD_TYPE is dedicated to
single-configuration genera...
liblas-commits at liblas.org
Tue Oct 12 06:19:12 EDT 2010
changeset 9dd9c3a2f731 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9dd9c3a2f731
summary: CMAKE_BUILD_TYPE is dedicated to single-configuration generators like Makefile, thus disable setting this variable for Visual Studio IDE for which it's meaningless. Tidy up compilation warnings.
diffstat:
CMakeLists.txt | 6 ++++--
1 files changed, 4 insertions(+), 2 deletions(-)
diffs (16 lines):
diff -r 5e45e6abee41 -r 9dd9c3a2f731 CMakeLists.txt
--- a/CMakeLists.txt Sun Oct 10 22:25:57 2010 -0500
+++ b/CMakeLists.txt Tue Oct 12 11:20:22 2010 +0100
@@ -53,8 +53,10 @@
# General build settings
# Default to release mode
-set(CMAKE_BUILD_TYPE Release CACHE STRING
- "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
+if(NOT MSVC_IDE)
+ set(CMAKE_BUILD_TYPE Release CACHE STRING
+ "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
+endif()
# TODO: Still testing the output paths --mloskot
set(LIBLAS_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin/${CMAKE_BUILD_TYPE})
More information about the Liblas-commits
