[Liblas-commits] hg: complete lasinfo2
liblas-commits at liblas.org
Tue Oct 12 12:43:47 EDT 2010
changeset d9fb3e27ffaa in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d9fb3e27ffaa
summary: complete lasinfo2
diffstat:
apps/las2las2.cpp | 16 +-
apps/lasinfo2.cpp | 40 ++++++++-
include/liblas/lasdimension.hpp | 4 +-
src/lasdimension.cpp | 45 ++++++++++
src/lasheader.cpp | 2 +
src/lasschema.cpp | 39 +++-----
src/utility.cpp | 178 +++++++++++++++++++++++++++++++++++++--
7 files changed, 273 insertions(+), 51 deletions(-)
diffs (truncated from 454 to 300 lines):
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa apps/las2las2.cpp
--- a/apps/las2las2.cpp Tue Oct 12 17:02:41 2010 +0100
+++ b/apps/las2las2.cpp Tue Oct 12 11:43:39 2010 -0500
@@ -193,14 +193,14 @@
std::cout << std::endl;
reader.Reset();
- liblas::property_tree::ptree pts = summary->GetPTree();
- liblas::property_tree::ptree top;
- top.add_child("summary.header",reader.GetHeader().GetPTree());
- top.add_child("summary.points",pts);
- liblas::property_tree::write_xml("junk.xml", top);
- liblas::property_tree::write_xml("schema.xml", reader.GetHeader().GetSchema().GetPTree());
- std::cout << reader.GetHeader().GetSchema() << std::endl;
+ // liblas::property_tree::ptree pts = summary->GetPTree();
+ // liblas::property_tree::ptree top;
+ // top.add_child("summary.header",reader.GetHeader().GetPTree());
+ // top.add_child("summary.points",pts);
+ // liblas::property_tree::write_xml("junk.xml", top);
+ // liblas::property_tree::write_xml("schema.xml", reader.GetHeader().GetSchema().GetPTree());
+ // std::cout << reader.GetHeader().GetSchema() << std::endl;
delete writer;
delete ofs;
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa apps/lasinfo2.cpp
--- a/apps/lasinfo2.cpp Tue Oct 12 17:02:41 2010 +0100
+++ b/apps/lasinfo2.cpp Tue Oct 12 11:43:39 2010 -0500
@@ -76,7 +76,7 @@
-void PrintVLRs(std::ostream& os, liblas::Header& header)
+void PrintVLRs(std::ostream& os, liblas::Header const& header)
if (!header.GetRecordsCount())
return ;
@@ -90,9 +90,10 @@
liblas::VariableRecord const& v = header.GetVLR(i);
os << v;
- os << std::endl;
int main(int argc, char* argv[])
@@ -101,6 +102,9 @@
bool verbose = false;
bool check = true;
bool show_vlrs = true;
+ bool show_schema = true;
+ bool output_xml = false;
+ bool output_json = false;
std::vector<liblas::FilterPtr> filters;
std::vector<liblas::TransformPtr> transforms;
@@ -123,8 +127,14 @@
("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
("no-vlrs", po::value<bool>(&show_vlrs)->zero_tokens()->implicit_value(false), "Don't show VLRs")
+ ("no-schema", po::value<bool>(&show_schema)->zero_tokens()->implicit_value(false), "Don't show schema")
("no-check", po::value<bool>(&check)->zero_tokens()->implicit_value(false), "Don't scan points")
+ ("xml", po::value<bool>(&output_xml)->zero_tokens()->implicit_value(true), "Output summary as XML")
+ // ("json", po::value<bool>(&output_json)->zero_tokens()->implicit_value(true), "Output summary as JSON")
+// --xml
+// --json
+// --restructured text output
po::variables_map vm;
@@ -182,12 +192,34 @@
verbose
- liblas::Header header = reader.GetHeader();
- std::cout << header << std::endl;
+ liblas::Header const& header = reader.GetHeader();
+ if (output_xml && output_json) {
+ std::cerr << "both JSON and XML output cannot be chosen";
+ return 1;
+ if (output_xml) {
+ liblas::property_tree::ptree tree = summary.GetPTree();
+ liblas::property_tree::write_xml(std::cout, tree);
+ return 0;
+ std::cout << header << std::endl;
if (show_vlrs)
PrintVLRs(std::cout, header);
+ if (show_schema)
+ std::cout << header.GetSchema();
+ if (check) {
+ // Add the header to the summary so we can get more detailed
+ // info
+ summary.SetHeader(header);
+ std::cout << summary << std::endl;
catch(std::exception& e) {
std::cerr << "error: " << e.what() << "\n";
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa include/liblas/lasdimension.hpp
--- a/include/liblas/lasdimension.hpp Tue Oct 12 17:02:41 2010 +0100
+++ b/include/liblas/lasdimension.hpp Tue Oct 12 11:43:39 2010 -0500
@@ -186,7 +186,8 @@
return m_position > dim.m_position;
+ liblas::property_tree::ptree GetPTree() const;
private:
std::string m_name;
@@ -235,6 +236,7 @@
bool req_;
+std::ostream& operator<<(std::ostream& os, liblas::Dimension const& d);
} // namespace liblas
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa src/lasdimension.cpp
--- a/src/lasdimension.cpp Tue Oct 12 17:02:41 2010 +0100
+++ b/src/lasdimension.cpp Tue Oct 12 11:43:39 2010 -0500
@@ -144,4 +144,49 @@
return m_bit_size / 8;
+liblas::property_tree::ptree Dimension::GetPTree() const
+ using liblas::property_tree::ptree;
+ ptree dim;
+ dim.put("name", GetName());
+ dim.put("description", GetDescription());
+ dim.put("position", GetPosition());
+ dim.put("active", static_cast<boost::uint32_t>(IsActive()));
+ dim.put("size", GetBitSize());
+ dim.put("integer", static_cast<boost::uint32_t>(IsInteger()));
+ dim.put("signed", static_cast<boost::uint32_t>(IsSigned()));
+ dim.put("required", static_cast<boost::uint32_t>(IsRequired()));
+ dim.put("byteoffset", GetByteOffset());
+ dim.put("bitoffset" , GetBitOffset());
+ dim.put("bytesize", GetByteSize());
+ if (IsNumeric()) {
+ if (! (detail::compare_distance(GetMinimum(), GetMaximum() )
+ && detail::compare_distance(0.0, GetMaximum())))
+ dim.put("minimum", GetMinimum());
+ dim.put("maximum", GetMaximum());
+ return dim;
+ ptree tree = d.GetPTree();
+ std::string name = tree.get<std::string>("name");
+ os << "'" << name << "'" << " -- ";
+ os << " size: " << tree.get<boost::uint32_t>("size");
+ os << " offset: " << tree.get<boost::uint32_t>("byteoffset");
+ os << std::endl;
+ return os;
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa src/lasheader.cpp
--- a/src/lasheader.cpp Tue Oct 12 17:02:41 2010 +0100
+++ b/src/lasheader.cpp Tue Oct 12 11:43:39 2010 -0500
@@ -787,6 +787,8 @@
ptree tree = GetPTree();
+ os << "---------------------------------------------------------" << std::endl;
os << " Header Summary" << std::endl;
os << std::endl;
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa src/lasschema.cpp
--- a/src/lasschema.cpp Tue Oct 12 17:02:41 2010 +0100
+++ b/src/lasschema.cpp Tue Oct 12 11:43:39 2010 -0500
@@ -464,28 +464,7 @@
for(i = position_index.begin(); i != position_index.end(); ++i)
- ptree dim;
- Dimension const& t = *i;
- dim.put("name", t.GetName());
- dim.put("description", t.GetDescription());
- dim.put("position", t.GetPosition());
- dim.put("active", static_cast<boost::uint32_t>(t.IsActive()));
- dim.put("size", t.GetBitSize());
- dim.put("integer", static_cast<boost::uint32_t>(t.IsInteger()));
- dim.put("signed", static_cast<boost::uint32_t>(t.IsSigned()));
- dim.put("required", static_cast<boost::uint32_t>(t.IsRequired()));
- if (t.IsNumeric()) {
- if (! (detail::compare_distance(t.GetMinimum(), t.GetMaximum() )
- && detail::compare_distance(0.0, t.GetMaximum())))
- dim.put("minimum", t.GetMinimum());
- dim.put("maximum", t.GetMaximum());
- pt.add_child("LASSchema.dimensions.dimension", dim);
+ pt.add_child("LASSchema.dimensions.dimension", i->GetPTree());
pt.put("LASSchema.version", "1.0");
@@ -539,12 +518,22 @@
os << " Bit size is unaligned to byte boundaries" << std::endl;
+ os << std::endl;
+ os << " Dimensions" << std::endl;
os << " ";
- for (i = dims.begin(); i != dims.end(); ++i)
+ index_by_position const& position_index = s.GetDimensions().get<position>();
+ index_by_position::const_iterator it;
+ for(it = position_index.begin(); it != position_index.end(); ++it)
- std::string name = (*i).second.get<std::string>("name");
- os << name << " ";
+ os << *it;
+ os << " ";
os << std::endl;
return os;
diff -r 5c3ee7cacba8 -r d9fb3e27ffaa src/utility.cpp
--- a/src/utility.cpp Tue Oct 12 17:02:41 2010 +0100
+++ b/src/utility.cpp Tue Oct 12 11:43:39 2010 -0500
@@ -221,9 +221,9 @@
pt.add_child("classification.classification",klasses);
- pt.put("classification.withheld", withheld);
- pt.put("classification.keypoint", keypoint);
- pt.put("classification.synthetic", synthetic);
+ pt.put("encoding.withheld", withheld);
+ pt.put("encoding.keypoint", keypoint);
+ pt.put("encoding.synthetic", synthetic);
ptree returns;
bool have_returns = false;
@@ -269,18 +269,170 @@
liblas::property_tree::ptree tree = s.GetPTree();
- os << "---------------------------------------------------------";
- os << " Point Inspection Summary" ;
+ os << " Point Inspection Summary" << std::endl;
- BOOST_FOREACH(ptree::value_type &v,
- tree.get_child("points_by_return"))
- boost::uint32_t i = v.second.get<boost::uint32_t>("id");
- boost::uint32_t count = v.second.get<boost::uint32_t>("count");
- // header.SetPointRecordsByReturnCount(i-1, count);
+ os << " Header Point Count: " << tree.get<std::string>("summary.header.count") << std::endl;
+ os << " Actual Point Count: " << tree.get<std::string>("summary.points.count") << std::endl;
+ os << std::endl;
+ os << " Minimum and Maximum Attributes (min,max)" << std::endl;
+ boost::uint32_t x_precision = 6;
+ boost::uint32_t y_precision = 6;
More information about the Liblas-commits
