[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org
Tue Oct 26 23:28:37 EDT 2010
changeset 7541133fc93c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7541133fc93c
summary: some work on the macros for generating osgeo4w packages
changeset 9a887c705c1d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9a887c705c1d
summary: more osgeo4w stuff
changeset ed8e0dca79ee in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ed8e0dca79ee
summary: add batch files for osgeo4w init and startup
changeset f918c95eb523 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f918c95eb523
summary: BUILD_TYPE stuff
changeset 4e981203ec39 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4e981203ec39
summary: merge
diffstat:
.hgignore | 3 +-
CMakeLists.txt | 17 ++++++++++++---
apps/lasindex_test.cpp | 28 +++++++++++---------------
apps/laskernel.cpp | 8 +++---
apps/laskernel.hpp | 6 ++--
apps/oci_util.cpp | 1 -
apps/oci_util.hpp | 2 +-
cmake/modules/BuildOSGeo4W.cmake | 41 +++++++++++++++++++++++++++++----------
hobu-config.bat | 4 +-
include/liblas/lasbounds.hpp | 6 +++-
include/liblas/lasindex.hpp | 1 -
liblas-osgeo4w-init.bat | 3 ++
src/CMakeLists.txt | 28 ++++++++++++++------------
src/detail/writer/point.cpp | 9 ++-----
src/lasdimension.cpp | 28 ++++++++++++--------------
src/lasheader.cpp | 7 +++--
src/lasschema.cpp | 5 +++-
test/unit/lasbounds_test.cpp | 19 ++++++++---------
test/unit/tut/tut_assert.hpp | 2 +-
19 files changed, 123 insertions(+), 95 deletions(-)
diffs (truncated from 552 to 300 lines):
diff -r db448f962223 -r 4e981203ec39 .hgignore
--- a/.hgignore Tue Oct 26 14:37:53 2010 -0500
+++ b/.hgignore Tue Oct 26 21:28:13 2010 -0600
@@ -1,6 +1,7 @@
syntax: glob
*.bak
*.dll
*.dll.manifest
diff -r db448f962223 -r 4e981203ec39 CMakeLists.txt
--- a/CMakeLists.txt Tue Oct 26 14:37:53 2010 -0500
+++ b/CMakeLists.txt Tue Oct 26 21:28:13 2010 -0600
@@ -102,8 +102,13 @@
endif()
else()
if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
+ # Recommended C++ compilation flags
+ # -Weffc++
+ set(LIBLAS_GCC_CXX_FLAGS
+ "-pedantic -ansi -Wall -Wpointer-arith -Wcast-align -Wcast-qual -Wfloat-equal -Wredundant-decls -Wno-long-long")
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC -Wall -Wno-long-long -ansi")
+ set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC ${LIBLAS_GCC_CXX_FLAGS}")
if (CMAKE_COMPILER_IS_GNUCXX)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
endif()
@@ -295,14 +300,12 @@
endif()
endif()
-#if (WIN32)
-# include(BuildOSGeo4W)
-#endif(WIN32)
# Version information
SET(CPACK_PACKAGE_VERSION_MAJOR "1")
SET(CPACK_PACKAGE_VERSION_MINOR "6")
SET(CPACK_PACKAGE_VERSION_PATCH "0b1")
+SET(OSGEO4W_UPSTREAM_RELEASE "1")
SET(CPACK_SOURCE_GENERATOR "TGZ;ZIP;TBZ2")
SET(CPACK_CMAKE_GENERATOR "Unix Makefiles")
@@ -326,6 +329,12 @@
list(APPEND CPACK_SOURCE_IGNORE_FILES "schemas")
list(APPEND CPACK_SOURCE_IGNORE_FILES "hobu-config.bat")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "liblas-osgeo4w-init.bat")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "liblas-osgeo4w-start.bat.tmpl")
include(CPack)
add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source)
+#if (WIN32)
+# include(BuildOSGeo4W)
+#endif(WIN32)
diff -r db448f962223 -r 4e981203ec39 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Tue Oct 26 14:37:53 2010 -0500
+++ b/apps/lasindex_test.cpp Tue Oct 26 21:28:13 2010 -0600
@@ -559,13 +559,11 @@
if (FilterResult.size())
// do something with the list of points
- #ifdef VISUAL_8
- fprintf(debugger, "Points within filter area %d of %d, %s\n", FilterResult.size(),
- index.GetPointRecordsCount(), "User-defined filter bounds");
- #else // VISUAL_8
- fprintf(debugger, "Points within filter area %zu of %d, %s\n", FilterResult.size(),
- #endif // VISUAL_8
+ std::ostringstream oss;
+ oss << "Points within filter area " << FilterResult.size()
+ << " of " << index.GetPointRecordsCount()
+ << ",\nUser-defined filter bounds" << std::endl;
+ fprintf(debugger, "%s", oss.str().c_str());
else
IndexFilterNoPoints(debugger);
@@ -660,13 +658,11 @@
- #ifdef VISUAL_8
- index.GetPointRecordsCount(), CovgStr);
- #else // VISUAL_8
+ << ", " << CovgStr << std::endl;
else
@@ -693,8 +689,8 @@
if (static_cast<std::ifstream&>(*idxstrm))
static_cast<std::ifstream&>(*idxstrm).close();
} // if
- if (idxreader)
- delete idxreader;
+ delete idxreader;
delete reader;
} // if reader
diff -r db448f962223 -r 4e981203ec39 apps/laskernel.cpp
--- a/apps/laskernel.cpp Tue Oct 26 14:37:53 2010 -0500
+++ b/apps/laskernel.cpp Tue Oct 26 21:28:13 2010 -0600
@@ -1,7 +1,7 @@
#include "laskernel.hpp"
-std::istream* OpenInput(std::string filename, bool bEnd)
+std::istream* OpenInput(std::string const& filename, bool bEnd)
std::ios::openmode mode = std::ios::in | std::ios::binary;
if (bEnd == true) {
@@ -30,10 +30,10 @@
std::vector<char> data = TryReadRawFileData(filename);
// FIXME: What is this construction supposed to grab? --mloskot
- return std::string((const char*)data.front(), data.size());
+ return std::string(&data[0], data.size());
-std::vector<char> TryReadRawFileData(std::string filename)
+std::vector<char> TryReadRawFileData(std::string const& filename)
std::istream* infile = OpenInput(filename.c_str(), true);
std::ifstream::pos_type size;
@@ -63,7 +63,7 @@
static int lastTick = -1;
int tick = static_cast<int>(complete * 40.0);
- tick = std::min(40, std::max(0, tick));
+ tick = (std::min)(40, std::max(0, tick));
// Have we started a new progress run?
if (tick < lastTick && lastTick >= 39)
diff -r db448f962223 -r 4e981203ec39 apps/laskernel.hpp
--- a/apps/laskernel.hpp Tue Oct 26 14:37:53 2010 -0500
+++ b/apps/laskernel.hpp Tue Oct 26 21:28:13 2010 -0600
@@ -92,9 +92,9 @@
#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
#endif
-std::istream* OpenInput(std::string filename, bool bEnd);
-std::string TryReadFileData(std::string filename);
-std::vector<char> TryReadRawFileData(std::string filename);
+// std::istream* OpenInput(std::string const& filename, bool bEnd);
+std::string TryReadFileData(std::string const& filename);
+std::vector<char> TryReadRawFileData(std::string const& filename);
bool term_progress(std::ostream& os, double complete);
void SetStreamPrecision(std::ostream& os, double scale);
diff -r db448f962223 -r 4e981203ec39 apps/oci_util.cpp
--- a/apps/oci_util.cpp Tue Oct 26 14:37:53 2010 -0500
+++ b/apps/oci_util.cpp Tue Oct 26 21:28:13 2010 -0600
@@ -1,7 +1,6 @@
#include "oci_util.hpp"
std::string ReadSQLData(std::string filename)
diff -r db448f962223 -r 4e981203ec39 apps/oci_util.hpp
--- a/apps/oci_util.hpp Tue Oct 26 14:37:53 2010 -0500
+++ b/apps/oci_util.hpp Tue Oct 26 21:28:13 2010 -0600
@@ -33,7 +33,7 @@
std::string cloudColumnName);
std::string to_upper(const std::string&);
std::string ReadSQLData(std::string filename);
-std::istream* OpenInput(std::string filename, bool bEnd) ;
+std::istream* OpenInput(std::string const& filename, bool bEnd) ;
#ifdef _WIN32
#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
diff -r db448f962223 -r 4e981203ec39 cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake Tue Oct 26 14:37:53 2010 -0500
+++ b/cmake/modules/BuildOSGeo4W.cmake Tue Oct 26 21:28:13 2010 -0600
@@ -7,7 +7,10 @@
MESSAGE(STATUS "Building osgeo4w binaries")
set(OSGEO4W_DIR osgeo4w)
set(OSGEO4W_LIB_DIR ${OSGEO4W_DIR}/lib)
+set(OSGEO4W_ETC_DIR ${OSGEO4W_DIR}/etc)
+set(OSGEO4W_ETC_INI_DIR ${OSGEO4W_DIR}/etc/ini)
set(OSGEO4W_LIB_BIN_DIR ${OSGEO4W_DIR}/lib/bin)
+set(OSGEO4W_BIN_DIR ${OSGEO4W_DIR}/bin)
set(OSGEO4W_DEVEL_DIR ${OSGEO4W_DIR}/devel)
set(OSGEO4W_DEVEL_INCLUDE_DIR ${OSGEO4W_DEVEL_DIR}/include)
set(OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR ${OSGEO4W_DEVEL_INCLUDE_DIR}/liblas)
@@ -20,6 +23,8 @@
set(OSGEO4W_DIRECTORIES
${OSGEO4W_DIR}
+ ${OSGEO4W_ETC_DIR}
+ ${OSGEO4W_ETC_INI_DIR}
${OSGEO4W_LIB_DIR}
${OSGEO4W_LIB_BIN_DIR}
@@ -28,7 +33,8 @@
${OSGEO4W_DEVEL_LIB_DIR}
${OSGEO4W_PYTHON_DIR}
${OSGEO4W_DEVEL_BIN_DIR}
- ${OSGEO4W_PACKAGES})
+ ${OSGEO4W_PACKAGES}
+ ${OSGEO4W_BIN_DIR})
@@ -78,34 +84,47 @@
endmacro(copy_files)
+macro(copy_directory SOURCE DESTINATION )
+ MESSAGE(STATUS " Copying ${SOURCE} to ${DESTINATION}")
+ add_custom_command(
+ TARGET copy
+ COMMAND ${CMAKE_COMMAND} -E copy_directory ${SOURCE} ${DESTINATION}
+endmacro(copy_directory)
add_custom_target(tar
COMMAND ${CMAKE_COMMAND} -E echo "Tarring OSGeo4W install")
add_dependencies( tar copy )
-macro (tar_directories source destination base_path)
+macro (tar_directories source destination base_paths)
MESSAGE(STATUS " Tarring ${source} to ${destination}")
add_custom_command(
TARGET tar
- COMMAND ${CMAKE_COMMAND} -E chdir ${source} cmake -E tar czf ${destination} ${base_path}/
+ COMMAND ${CMAKE_COMMAND} -E chdir ${source} cmake -E tar czf ${destination} ${base_paths}
endmacro(tar_directories)
make_directories()
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las* ${OSGEO4W_DEVEL_BIN_DIR}/ )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*[.${SO_EXT}] ${OSGEO4W_DEVEL_BIN_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.exe ${OSGEO4W_BIN_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_c.dll ${OSGEO4W_BIN_DIR}/ )
+copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-init.bat ${OSGEO4W_ETC_INI_DIR}/liblas.bat )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.a ${OSGEO4W_DEVEL_LIB_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_c.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
-copy_files(./include/liblas/* ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}/ )
+copy_directory(./include/liblas/ ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}/ )
copy_files(./python/liblas/*.py ${OSGEO4W_PYTHON_DIR}/ )
-tar_directories(${OSGEO4W_DEVEL_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz bin)
-tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-python-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz apps)
-tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-devel-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz devel)
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}-${OSGEO4W_UPSTREAM_RELEASE}.tar.gz "bin/;etc/")
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-python-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}-${OSGEO4W_UPSTREAM_RELEASE}.tar.gz apps)
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-devel-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}-${OSGEO4W_UPSTREAM_RELEASE}.tar.gz devel)
add_custom_target(osgeo4w
diff -r db448f962223 -r 4e981203ec39 hobu-config.bat
--- a/hobu-config.bat Tue Oct 26 14:37:53 2010 -0500
+++ b/hobu-config.bat Tue Oct 26 21:28:13 2010 -0600
@@ -6,8 +6,8 @@
set BOOST=D:\boost\boost_1_44
set ORACLE_HOME=%OSGEO4W%
# set BUILD_TYPE=RelWithDebInfo
-set BUILD_TYPE=Debug
-# set BUILD_TYPE=Release
+#set BUILD_TYPE=Debug
+set BUILD_TYPE=Release
set PATH=%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
diff -r db448f962223 -r 4e981203ec39 include/liblas/lasbounds.hpp
--- a/include/liblas/lasbounds.hpp Tue Oct 26 14:37:53 2010 -0500
+++ b/include/liblas/lasbounds.hpp Tue Oct 26 21:28:13 2010 -0600
@@ -67,7 +67,9 @@
public:
T min;
T max;
+ typedef T value_type;
More information about the Liblas-commits
