[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Wed Oct 27 11:48:24 EDT 2010
changeset 4aeffcc28ed4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4aeffcc28ed4
summary: don't throw if we return no data for having an output table
changeset f8b4a00e8458 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f8b4a00e8458
summary: merge
changeset 18dceb43a3dc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=18dceb43a3dc
summary: merge
diffstat:
CMakeLists.txt | 10 ++++++--
apps/oci_util.cpp | 15 ++++++++----
cmake/modules/BuildOSGeo4W.cmake | 45 ++++++++++++++++++++++++++++++---------
hobu-config.bat | 4 +-
liblas-osgeo4w-init.bat | 3 ++
liblas-osgeo4w-postinstall.bat | 1 +
liblas-osgeo4w-start.bat.tmpl | 5 ++++
python/liblas/core.py | 2 +-
8 files changed, 63 insertions(+), 22 deletions(-)
diffs (200 lines):
diff -r 78c86d242055 -r 18dceb43a3dc CMakeLists.txt
--- a/CMakeLists.txt Tue Oct 26 21:56:29 2010 -0500
+++ b/CMakeLists.txt Wed Oct 27 10:48:13 2010 -0500
@@ -300,14 +300,12 @@
endif()
endif()
-#if (WIN32)
-# include(BuildOSGeo4W)
-#endif(WIN32)
# Version information
SET(CPACK_PACKAGE_VERSION_MAJOR "1")
SET(CPACK_PACKAGE_VERSION_MINOR "6")
SET(CPACK_PACKAGE_VERSION_PATCH "0b1")
+SET(OSGEO4W_UPSTREAM_RELEASE "1")
SET(CPACK_SOURCE_GENERATOR "TGZ;ZIP;TBZ2")
SET(CPACK_CMAKE_GENERATOR "Unix Makefiles")
@@ -331,6 +329,12 @@
list(APPEND CPACK_SOURCE_IGNORE_FILES "schemas")
list(APPEND CPACK_SOURCE_IGNORE_FILES "hobu-config.bat")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "liblas-osgeo4w-init.bat")
+list(APPEND CPACK_SOURCE_IGNORE_FILES "liblas-osgeo4w-start.bat.tmpl")
include(CPack)
add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source)
+#if (WIN32)
+# include(BuildOSGeo4W)
+#endif(WIN32)
diff -r 78c86d242055 -r 18dceb43a3dc apps/oci_util.cpp
--- a/apps/oci_util.cpp Tue Oct 26 21:56:29 2010 -0500
+++ b/apps/oci_util.cpp Wed Oct 27 10:48:13 2010 -0500
@@ -166,11 +166,16 @@
try {
statement->Execute();
} catch (std::runtime_error const& e) {
- delete statement;
- std::ostringstream oss;
- oss << "Failed select if block table "<< tableName << " exists. Do you have rights to select?"
- << std::endl << e.what() << std::endl;
- throw std::runtime_error(oss.str());
+ // Assume for now that an error returned here is OCI_NODATA, which means
+ // the table doesn't exist. If this really isn't the case, we're going
+ // to get more legit message further down the line.
+ return false;
+ // delete statement;
+ // std::ostringstream oss;
+ // oss << "Failed select if block table "<< tableName << " exists. Do you have rights to select?"
+ // << std::endl << e.what() << std::endl;
+ // throw std::runtime_error(oss.str());
return true;
diff -r 78c86d242055 -r 18dceb43a3dc cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake Tue Oct 26 21:56:29 2010 -0500
+++ b/cmake/modules/BuildOSGeo4W.cmake Wed Oct 27 10:48:13 2010 -0500
@@ -7,7 +7,11 @@
MESSAGE(STATUS "Building osgeo4w binaries")
set(OSGEO4W_DIR osgeo4w)
set(OSGEO4W_LIB_DIR ${OSGEO4W_DIR}/lib)
+set(OSGEO4W_ETC_DIR ${OSGEO4W_DIR}/etc)
+set(OSGEO4W_ETC_INI_DIR ${OSGEO4W_DIR}/etc/ini)
+set(OSGEO4W_ETC_POSTINSTALL_DIR ${OSGEO4W_DIR}/etc/postinstall)
set(OSGEO4W_LIB_BIN_DIR ${OSGEO4W_DIR}/lib/bin)
+set(OSGEO4W_BIN_DIR ${OSGEO4W_DIR}/bin)
set(OSGEO4W_DEVEL_DIR ${OSGEO4W_DIR}/devel)
set(OSGEO4W_DEVEL_INCLUDE_DIR ${OSGEO4W_DEVEL_DIR}/include)
set(OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR ${OSGEO4W_DEVEL_INCLUDE_DIR}/liblas)
@@ -20,6 +24,9 @@
set(OSGEO4W_DIRECTORIES
${OSGEO4W_DIR}
+ ${OSGEO4W_ETC_DIR}
+ ${OSGEO4W_ETC_INI_DIR}
+ ${OSGEO4W_ETC_POSTINSTALL_DIR}
${OSGEO4W_LIB_DIR}
${OSGEO4W_LIB_BIN_DIR}
@@ -28,7 +35,8 @@
${OSGEO4W_DEVEL_LIB_DIR}
${OSGEO4W_PYTHON_DIR}
${OSGEO4W_DEVEL_BIN_DIR}
- ${OSGEO4W_PACKAGES})
+ ${OSGEO4W_PACKAGES}
+ ${OSGEO4W_BIN_DIR})
@@ -78,34 +86,49 @@
endmacro(copy_files)
+macro(copy_directory SOURCE DESTINATION )
+ MESSAGE(STATUS " Copying ${SOURCE} to ${DESTINATION}")
+ add_custom_command(
+ TARGET copy
+ COMMAND ${CMAKE_COMMAND} -E copy_directory ${SOURCE} ${DESTINATION}
+endmacro(copy_directory)
add_custom_target(tar
COMMAND ${CMAKE_COMMAND} -E echo "Tarring OSGeo4W install")
add_dependencies( tar copy )
-macro (tar_directories source destination base_path)
+macro (tar_directories source destination base_paths)
MESSAGE(STATUS " Tarring ${source} to ${destination}")
add_custom_command(
TARGET tar
- COMMAND ${CMAKE_COMMAND} -E chdir ${source} cmake -E tar czf ${destination} ${base_path}/
+ COMMAND ${CMAKE_COMMAND} -E chdir ${source} cmake -E tar cjf ${destination} ${base_paths}
endmacro(tar_directories)
make_directories()
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las* ${OSGEO4W_DEVEL_BIN_DIR}/ )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*[.${SO_EXT}] ${OSGEO4W_DEVEL_BIN_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.exe ${OSGEO4W_BIN_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_c.dll ${OSGEO4W_BIN_DIR}/ )
+copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-start.bat.tmpl ${OSGEO4W_BIN_DIR}/liblas.bat.tmpl )
+copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-init.bat ${OSGEO4W_ETC_INI_DIR}/liblas.bat )
+copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-postinstall.bat ${OSGEO4W_ETC_POSTINSTALL_DIR}/liblas.bat )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.a ${OSGEO4W_DEVEL_LIB_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_c.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
-copy_files(./include/liblas/* ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}/ )
+copy_directory(./include/liblas/ ${OSGEO4W_DEVEL_INCLUDE_LIBLAS_DIR}/ )
copy_files(./python/liblas/*.py ${OSGEO4W_PYTHON_DIR}/ )
-tar_directories(${OSGEO4W_DEVEL_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz bin)
-tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-python-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz apps)
-tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-devel-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}.tar.gz devel)
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}-${OSGEO4W_UPSTREAM_RELEASE}.tar.bz2 "bin/;etc/")
+tar_directories(${OSGEO4W_DIR} ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-python-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}-${OSGEO4W_UPSTREAM_RELEASE}.tar.bz2 apps)
+tar_directories(${OSGEO4W_DIR}/devel ${libLAS_SOURCE_DIR}/${OSGEO4W_PACKAGES}/liblas-devel-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}-${OSGEO4W_UPSTREAM_RELEASE}.tar.bz2 "lib/;include")
add_custom_target(osgeo4w
diff -r 78c86d242055 -r 18dceb43a3dc hobu-config.bat
--- a/hobu-config.bat Tue Oct 26 21:56:29 2010 -0500
+++ b/hobu-config.bat Wed Oct 27 10:48:13 2010 -0500
@@ -6,8 +6,8 @@
set BOOST=D:\boost\boost_1_44
set ORACLE_HOME=%OSGEO4W%
# set BUILD_TYPE=RelWithDebInfo
-set BUILD_TYPE=Debug
-# set BUILD_TYPE=Release
+#set BUILD_TYPE=Debug
+set BUILD_TYPE=Release
set PATH=%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
diff -r 78c86d242055 -r 18dceb43a3dc liblas-osgeo4w-init.bat
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/liblas-osgeo4w-init.bat Wed Oct 27 10:48:13 2010 -0500
@@ -0,0 +1,3 @@
+SET GDAL_DATA=%OSGEO4W_ROOT%\apps\gdal-dev\share\gdal
+SET PYTHONPATH=%OSGEO4W_ROOT%\apps\gdal-dev\pymod;%PYTHONPATH%
+PATH=%OSGEO4W_ROOT%\apps\gdal-dev\bin;%OSGEO4W_ROOT%\bin;%PATH%
diff -r 78c86d242055 -r 18dceb43a3dc liblas-osgeo4w-postinstall.bat
+++ b/liblas-osgeo4w-postinstall.bat Wed Oct 27 10:48:13 2010 -0500
@@ -0,0 +1,1 @@
+textreplace -std -t bin/liblas.bat
\ No newline at end of file
diff -r 78c86d242055 -r 18dceb43a3dc liblas-osgeo4w-start.bat.tmpl
+++ b/liblas-osgeo4w-start.bat.tmpl Wed Oct 27 10:48:13 2010 -0500
@@ -0,0 +1,5 @@
+ at echo off
+SET OSGEO4W_ROOT=@osgeo4w@
+call "%OSGEO4W_ROOT%\etc\ini\liblas.bat"
+start "libLAS OSGeo4W Shell"
+ at echo on
diff -r 78c86d242055 -r 18dceb43a3dc python/liblas/core.py
--- a/python/liblas/core.py Tue Oct 26 21:56:29 2010 -0500
+++ b/python/liblas/core.py Wed Oct 27 10:48:13 2010 -0500
@@ -128,7 +128,7 @@
if os.name == 'nt':
# stolen from Shapely
# http://trac.gispython.org/projects/PCL/browser/Shapely/trunk/shapely/geos.py
- lib_name = 'liblas1.dll'
+ lib_name = 'liblas_c.dll'
try:
local_dlls = os.path.abspath(os.__file__ + "../../../DLLs")
original_path = os.environ['PATH']
More information about the Liblas-commits
