[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Oct 27 12:22:50 EDT 2010
changeset 785c93c6a621 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=785c93c6a621
summary: debug typo
changeset 30ed9749c198 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=30ed9749c198
summary: merge
diffstat:
 CMakeLists.txt                   |   6 ++--
 apps/CMakeLists.txt              |   8 +++++-
 apps/las2oci.cpp                 |   2 +-
 apps/ts2las.cpp                  |  22 ++++++++---------
 apps/ts2las.hpp                  |  49 +++++++++++++++++++--------------------
 cmake/modules/BuildOSGeo4W.cmake |  15 +++++++++++-
 6 files changed, 59 insertions(+), 43 deletions(-)
diffs (239 lines):
diff -r 18dceb43a3dc -r 30ed9749c198 CMakeLists.txt
--- a/CMakeLists.txt	Wed Oct 27 10:48:13 2010 -0500
+++ b/CMakeLists.txt	Wed Oct 27 11:22:31 2010 -0500
@@ -335,6 +335,6 @@
 add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source)
-#if (WIN32)
-#    include(BuildOSGeo4W)
-#endif(WIN32)
+if (WIN32)
+    include(BuildOSGeo4W)
+endif(WIN32)
diff -r 18dceb43a3dc -r 30ed9749c198 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Wed Oct 27 10:48:13 2010 -0500
+++ b/apps/CMakeLists.txt	Wed Oct 27 11:22:31 2010 -0500
@@ -21,6 +21,7 @@
 set(LAS2LAS_OLD las2las-old)
 set(LAS2TXT las2txt)
 set(TXT2LAS txt2las)
+set(TS2LAS ts2las)
 set(LASBLOCK lasblock )
 set(BIGFILE_TEST bigfile_test)
@@ -43,7 +44,7 @@
 set(LIBLAS_UTILITIES
     ${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
-    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} )
+    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS} )
 # TODO: Experimental and requires testing --mloskot
 # Generate user-specific settings for Visual Studio project
@@ -109,6 +110,11 @@
     target_link_libraries(${TXT2LAS} ${LIBLAS_C_LIB_NAME})
 endif()
+if(TS2LAS)
+    add_executable(${TS2LAS} ts2las.cpp )
+    target_link_libraries(${TS2LAS} ${APPS_CPP_DEPENDENCIES} )
+endif()
 # Build lasmerge
 if(LASMERGE)
     set(LASMERGE_SRC lascommon.c ${LASMERGE}.c)
diff -r 18dceb43a3dc -r 30ed9749c198 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Wed Oct 27 10:48:13 2010 -0500
+++ b/apps/las2oci.cpp	Wed Oct 27 11:22:31 2010 -0500
@@ -934,7 +934,7 @@
             if (verbose)
                 if (!used_file)
-                    std::cout << "Setting output post-sql to: " << pre_sql << std::endl;
+                    std::cout << "Setting output post-sql to: " << post_sql << std::endl;
                 else
                     std::cout << "Setting output post-sql to: " << sql << std::endl; // Tell filename instead
diff -r 18dceb43a3dc -r 30ed9749c198 apps/ts2las.cpp
--- a/apps/ts2las.cpp	Wed Oct 27 10:48:13 2010 -0500
+++ b/apps/ts2las.cpp	Wed Oct 27 11:22:31 2010 -0500
@@ -120,7 +120,6 @@
         return false;
-    return true;
 bool WritePoints(liblas::Writer* writer, std::istream* strm, ScanHdr* hdr)
@@ -136,9 +135,9 @@
                 // std::cout << "stream position is: " << strm->tellg() << std::endl;
                 if (hdr->HdrVersion == 20020715) {
-                    detail::read_n(*point, *strm, sizeof(ScanPnt));
+                    liblas::detail::read_n(*point, *strm, sizeof(ScanPnt));
                 } else{
-                    detail::read_n(*row, *strm, sizeof(ScanRow));
+                    liblas::detail::read_n(*row, *strm, sizeof(ScanRow));
                     point->Pnt.x = row->x;
                     point->Pnt.y = row->y;
                     point->Pnt.z = row->z;
@@ -149,8 +148,7 @@
                 Point p;
-                p.SetCoordinates(writer->GetHeader(),
-                                    point->Pnt.x,
+                p.SetCoordinates( point->Pnt.x,
                                     point->Pnt.y,
                                     point->Pnt.z);
@@ -160,8 +158,8 @@
                 p.SetClassification(point->Code);
                 p.SetIntensity(point->Intensity);
                 if (hdr->Time) {
-                    liblas::uint32_t t = 0xFFFFFFFF;
-                    detail::read_n(t, *strm, sizeof(t));
+                    boost::uint32_t t = 0xFFFFFFFF;
+                    liblas::detail::read_n(t, *strm, sizeof(t));
                     // Time stamps are assumed to be GPS week seconds. The
                     // storage format is a 32 bit unsigned integer where
@@ -170,15 +168,15 @@
                     p.SetTime(t*0.0002);
                 if (hdr->Color) {
-                    liblas::uint8_t r, g, b, a = 0;
+                    boost::uint8_t r, g, b, a = 0;
                     liblas::Color color;
-                    detail::read_n(r, *strm, sizeof(r));
-                    detail::read_n(b, *strm, sizeof(b));
-                    detail::read_n(g, *strm, sizeof(g));
+                    liblas::detail::read_n(r, *strm, sizeof(r));
+                    liblas::detail::read_n(b, *strm, sizeof(b));
+                    liblas::detail::read_n(g, *strm, sizeof(g));
                     // TS .bin says to read 4 bytes here for some reason.  Maybe
                     // this is an alpha value or something
-                    detail::read_n(a, *strm, sizeof(a));
+                    liblas::detail::read_n(a, *strm, sizeof(a));
                     color.SetGreen(g);
                     color.SetBlue(b);
diff -r 18dceb43a3dc -r 30ed9749c198 apps/ts2las.hpp
--- a/apps/ts2las.hpp	Wed Oct 27 10:48:13 2010 -0500
+++ b/apps/ts2las.hpp	Wed Oct 27 11:22:31 2010 -0500
@@ -2,9 +2,8 @@
 #include <liblas/detail/private_utility.hpp>
-#include <liblas/laswriter.hpp>
-#include <liblas/laspoint.hpp>
-#include <liblas/lascolor.hpp>
+#include <liblas/liblas.hpp>
 #include <iostream>
 #ifdef _WIN32
 #define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
@@ -25,13 +24,13 @@
         z(0)
-    liblas::uint8_t Code;
-    liblas::uint8_t Line;
-    liblas::uint16_t EchoInt;
+    boost::uint8_t Code;
+    boost::uint8_t Line;
+    boost::uint16_t EchoInt;
-    liblas::int32_t x;
-    liblas::int32_t y;
-    liblas::int32_t z;
+    boost::int32_t x;
+    boost::int32_t y;
+    boost::int32_t z;
@@ -44,9 +43,9 @@
         z(0)
+    boost::int32_t x;
+    boost::int32_t y;
+    boost::int32_t z;
@@ -62,12 +61,12 @@
     Point3d Pnt;
-    liblas::uint8_t Echo;
-    liblas::uint8_t Flag;
-    liblas::uint8_t Mark;
-    liblas::uint16_t Line;
-    liblas::uint16_t Intensity;
+    boost::uint8_t Echo;
+    boost::uint8_t Flag;
+    boost::uint8_t Mark;
+    boost::uint16_t Line;
+    boost::uint16_t Intensity;
@@ -87,17 +86,17 @@
         Color(0)
-    liblas::int32_t HdrSize;
-    liblas::int32_t HdrVersion;
-    liblas::int32_t Tunniste;
+    boost::int32_t HdrSize;
+    boost::int32_t HdrVersion;
+    boost::int32_t Tunniste;
     char Magic[4];
-    liblas::int32_t PntCnt;
-    liblas::int32_t Units;
+    boost::int32_t PntCnt;
+    boost::int32_t Units;
     double OrgX;
     double OrgY;
     double OrgZ;
-    liblas::int32_t Time;
-    liblas::int32_t Color;
+    boost::int32_t Time;
+    boost::int32_t Color;
     // int HdrSize;
diff -r 18dceb43a3dc -r 30ed9749c198 cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake	Wed Oct 27 10:48:13 2010 -0500
+++ b/cmake/modules/BuildOSGeo4W.cmake	Wed Oct 27 11:22:31 2010 -0500
@@ -113,7 +113,20 @@
 endmacro(tar_directories)
 make_directories()
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/*.exe ${OSGEO4W_BIN_DIR}/  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/lasinfo.exe ${OSGEO4W_BIN_DIR}/lasinfo.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/lasinfo-old.exe ${OSGEO4W_BIN_DIR}/lasinfo-old.exe   )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las2las.exe ${OSGEO4W_BIN_DIR}/las2las.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las2las-old.exe ${OSGEO4W_BIN_DIR}/las2las-old.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las2ogr.exe ${OSGEO4W_BIN_DIR}/las2ogr.exe   )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las2oci.exe ${OSGEO4W_BIN_DIR}/las2oci.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/las2txt.exe ${OSGEO4W_BIN_DIR}/las2txt.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/lasblock.exe ${OSGEO4W_BIN_DIR}/lasblock.exe   )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/lasmerge.exe ${OSGEO4W_BIN_DIR}/lasmerge.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/txt2las.exe ${OSGEO4W_BIN_DIR}/txt2las.exe  )
+copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/ts2las.exe ${OSGEO4W_BIN_DIR}/ts2las.exe  )
 copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_c.dll ${OSGEO4W_BIN_DIR}/  )
 copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-start.bat.tmpl ${OSGEO4W_BIN_DIR}/liblas.bat.tmpl )
 copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-init.bat ${OSGEO4W_ETC_INI_DIR}/liblas.bat )
More information about the Liblas-commits mailing list
