[Liblas-commits] hg: start on reprojection example
liblas-commits at liblas.org
Fri Oct 29 10:29:43 EDT 2010
changeset a18904ebcf06 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a18904ebcf06
summary: start on reprojection example
diffstat:
doc/start.txt | 39 +++++++++++++++++++++++++++++++++++++--
1 files changed, 37 insertions(+), 2 deletions(-)
diffs (61 lines):
diff -r 5fff1d2e78f6 -r a18904ebcf06 doc/start.txt
--- a/doc/start.txt Fri Oct 29 09:29:05 2010 -0500
+++ b/doc/start.txt Fri Oct 29 09:29:38 2010 -0500
@@ -38,13 +38,46 @@
:ref:`osgeo4w_install` contains information how to install libLAS on Windows.
+Unix
+Packages are available for `DebianGIS`_, but in most other cases you are
+going to have to compile libLAS yourself. :ref:`compilation` provides an
+extensive synopsis of how to do so.
Compilation
:ref:`compilation` shows how to compile libLAS for your own use on Windows,
Mac OSX, and Linux.
+Processing
+The libLAS :ref:`command-line utilities <utilities>` provide the bulk of
+user-facing operational software for libLAS, although the underlying libLAS
+library is what powers them. Below is a listing of common operations that
+you might want to do on LAS data, and the utilities and approaches to
+take to complete those tasks.
+Reproject a LAS file
+All LAS data are in some sort of coordinate system, even if that coordinate
+system is not described in the LAS file. For terrestrial LAS data, these
+coordinate system descriptions often map to coordinate systems described
+by the `EPSG`_ database. Another source of information about coordinate
+systems in http://spatialreference.org.
+The :ref:`las2las <las2las>` utility is the tool you will want to use to
+reproject LAS data. :ref:`las2las <las2las>` can take advantage of the
+existing coordinate system description that might already be specified in the
+LAS file, or you may override the coordinate system description (or supply
+one if none was specified).
+:ref:`las2las <las2las>` is very similar in behavior to another data
+translation utility for raster data -- `gdal_translate`_.
.. _`CMake`: http://www.cmake.org/
.. _`CTest`: http://cmake.org/cmake/help/ctest-2-8-docs.html
.. _`CMake 2.8.0+`: http://www.cmake.org/cmake/help/cmake-2-8-docs.html
@@ -55,4 +88,6 @@
.. _`Autoconf`: http://www.gnu.org/software/autoconf/
.. _`LLVM`: http://llvm.org/
.. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
-.. _`Boost`: http://www.boost.org/
\ No newline at end of file
+.. _`Boost`: http://www.boost.org/
+.. _`DebianGIS`: http://wiki.debian.org/DebianGis
+.. _`gdal_translate`: http://www.gdal.org/gdal_translate.html
More information about the Liblas-commits
