[Liblas-commits] hg: 6 new changesets
liblas-commits at liblas.org
Fri Oct 29 23:17:56 EDT 2010
changeset 202ed62dcb81 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=202ed62dcb81
summary: header stuff must be set before transforms like reprojection so that reprojection can use current header information
changeset ab8f50dfe8d3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ab8f50dfe8d3
summary: typo
changeset 7a77ccef6316 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7a77ccef6316
summary: use boost types instead of standard compiler types for function specification
changeset fd4b3237d7ce in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=fd4b3237d7ce
summary: provide the ability to supply a header with scaling information that will override the existing point's header as part of the ReprojectionTransform
changeset eb3b6fe033fa in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=eb3b6fe033fa
summary: start porting over the reprojection tests from the python test suite
changeset 44a7566492b5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=44a7566492b5
summary: merge
diffstat:
apps/lasinfo.cpp | 2 +-
apps/laskernel.cpp | 648 ++++++++++++++++----------------
include/liblas/detail/reader/point.hpp | 3 -
include/liblas/lasreader.hpp | 9 +-
include/liblas/lasspatialreference.hpp | 6 +-
include/liblas/lastransform.hpp | 4 +
src/detail/reader/point.cpp | 18 +-
src/laspoint.cpp | 73 ++-
src/lasreader.cpp | 105 ++--
src/lasspatialreference.cpp | 8 +-
src/lastransform.cpp | 41 +-
src/utility.cpp | 34 +-
test/unit/lasspatialreference_test.cpp | 163 ++++++++-
13 files changed, 671 insertions(+), 443 deletions(-)
diffs (truncated from 1512 to 300 lines):
diff -r a18904ebcf06 -r 44a7566492b5 apps/lasinfo.cpp
--- a/apps/lasinfo.cpp Fri Oct 29 09:29:38 2010 -0500
+++ b/apps/lasinfo.cpp Fri Oct 29 22:17:43 2010 -0500
@@ -131,7 +131,7 @@
("no-vlrs", po::value<bool>(&show_vlrs)->zero_tokens()->implicit_value(false), "Don't show VLRs")
("no-schema", po::value<bool>(&show_schema)->zero_tokens()->implicit_value(false), "Don't show schema")
("no-check", po::value<bool>(&check)->zero_tokens()->implicit_value(false), "Don't scan points")
- ("xml", po::value<bool>(&output_xml)->zero_tokens()->implicit_value(true), "Output summary as XML")
+ ("xml", po::value<bool>(&output_xml)->zero_tokens()->implicit_value(true), "Output as XML")
("point,p", po::value<boost::uint32_t>(&point), "Display a point with a given id. --point 44")
// ("json", po::value<bool>(&output_json)->zero_tokens()->implicit_value(true), "Output summary as JSON")
diff -r a18904ebcf06 -r 44a7566492b5 apps/laskernel.cpp
--- a/apps/laskernel.cpp Fri Oct 29 09:29:38 2010 -0500
+++ b/apps/laskernel.cpp Fri Oct 29 22:17:43 2010 -0500
@@ -689,6 +689,327 @@
std::vector<liblas::TransformPtr> transforms;
+ if (vm.count("offset"))
+ std::vector<double> offsets = vm["offset"].as< std::vector<double> >();
+ if (offsets.size() != 3) {
+ ostringstream oss;
+ oss << "Three arguments must be given to offset. "
+ << "--offset x y z";
+ throw std::runtime_error(oss.str());
+ if (verbose)
+ for (std::vector<double>::const_iterator i = offsets.begin();
+ i != offsets.end();
+ i++)
+ oss << *i << " ";
+ std::cout << "Setting offsets to: " << oss.str() << std::endl;
+ header.SetOffset(offsets[0], offsets[1], offsets[2]);
+ if (vm.count("scale"))
+ std::vector<double> scales = vm["scale"].as< std::vector<double> >();
+ if (scales.size() != 3) {
+ oss << "Three arguments must be given to scale. "
+ << "--scale x y z";
+ if (verbose)
+ for (std::vector<double>::const_iterator i = scales.begin();
+ i != scales.end();
+ i++)
+ oss << *i << " ";
+ std::cout << "Setting scales to: " << oss.str() << std::endl;
+ header.SetScale(scales[0], scales[1], scales[2]);
+ if (vm.count("format"))
+ std::string format_string = vm["format"].as< string >();
+ if (verbose)
+ std::cout << "Setting format to: " << format_string << std::endl;
+ boost::char_separator<char> sep(".");
+ std::vector<int> versions;
+ tokenizer tokens(format_string, sep);
+ for (tokenizer::iterator t = tokens.begin(); t != tokens.end(); ++t) {
+ const char* v =(*t).c_str();
+ int i = atoi(v);
+ versions.push_back(i);
+ if (versions.size() < 2)
+ oss << "Format version must dotted -- ie, '1.0' or '1.2', not " << format_string;
+ int minor = versions[1];
+ if (minor > 2){
+ header.SetVersionMinor(static_cast<boost::uint8_t>(minor));
+ if (vm.count("pad-header"))
+ std::string header_pad = vm["pad-header"].as< string >();
+ if (verbose)
+ std::cout << "Increasing header pad to: " << header_pad << std::endl;
+ boost::uint32_t offset = header.GetDataOffset();
+ if (atoi(header_pad.c_str()) == 0) {
+ oss << "Header pad was 0. It must be greater than "<<offset<< " bytes";
+ header.SetDataOffset(atoi(header_pad.c_str()));
+ if (vm.count("file-creation"))
+ std::vector<std::string> creation = vm["file-creation"].as< std::vector<std::string> >();
+ if (verbose)
+ for (std::vector<std::string>::const_iterator i = creation.begin();
+ i != creation.end();
+ i++)
+ oss << *i << " ";
+ std::cout << "Setting file creation to " << oss.str() << std::endl;
+ std::string m("now");
+ bool now = false;
+ if (creation.size() == 1 )
+ if (!(creation[0].compare(m)))
+ now = true;
+ boost::int32_t day = 0;
+ boost::int32_t year = 0;
+ if (creation.size() == 2)
+ day = atoi(creation[0].c_str());
+ year = atoi(creation[1].c_str());
+ if (day < 0 || day > 366) {
+ oss << "Day must be between 1-366, not " << day;
+ if (year < 0)
+ oss << "Year must be greater than 0, not " << year;
+ if (now == true)
+ liblas::Header h;
+ header.SetCreationDOY(h.GetCreationDOY());
+ header.SetCreationYear(h.GetCreationYear());
+ } else {
+ header.SetCreationDOY(static_cast<boost::uint16_t>(day));
+ header.SetCreationYear(static_cast<boost::uint16_t>(year));
+ if (vm.count("add-schema"))
+ liblas::VariableRecord vlr = header.GetSchema().GetVLR();
+ header.AddVLR(vlr);
+ if (vm.count("delete-vlr"))
+ std::vector<std::string> vlrs = vm["delete-vlr"].as< std::vector<std::string> >();
+ if (vlrs.size() % 2 != 0) {
+ ostringstream err;
+ err << "VLR descriptions must be in pairs of 2 -- A name and an ID";
+ throw std::runtime_error(err.str());
+ for (std::vector<std::string>::const_iterator i = vlrs.begin();
+ i != vlrs.end();
+ i++)
+ oss << *i << " ";
+ if (verbose)
+ std::cout << "Deleting VLRs with the values: " << oss.str() << std::endl;
+ for (std::vector<std::string>::size_type i = 0; i < vlrs.size(); i=i+2)
+ boost::int32_t id = atoi(vlrs[i+1].c_str());
+ if (id < 0)
+ throw std::runtime_error("VLR ID must be > 0");
+ if (id > std::numeric_limits<boost::uint16_t>::max()) {
+ oss << "ID must be less than "<< std::numeric_limits<boost::uint16_t>::max() <<", not " << id;
+ header.DeleteVLRs(vlrs[i], static_cast<boost::uint16_t>(id));
+ if (vm.count("add-vlr"))
+ std::vector<std::string> vlrs = vm["add-vlr"].as< std::vector<std::string> >();
+ if (vlrs.size() < 3) {
+ err << "VLR additions must be at least 3 arguments -- --add-vlr NAME 42 \"filename.ext\"";
+ if (vlrs.size() > 4)
+ throw std::runtime_error("Only one VLR may be added at a time");
+ i != vlrs.end();
+ i++)
+ oss << *i << " ";
+ liblas::VariableRecord v;
+ v.SetUserId(vlrs[0]);
+ boost::int32_t id = atoi(vlrs[1].c_str());
+ if (id < 0)
+ v.SetRecordId(static_cast<boost::uint16_t>(id));
+ std::vector<boost::uint8_t> data;
+ std::string data_or_filename;
+ if (vlrs.size() == 4){
+ v.SetDescription(vlrs[2]);
+ data_or_filename = vlrs[3];
+ } else {
+ data_or_filename = vlrs[2];
+ try {
+ std::vector<char> d;
+ d = TryReadRawFileData(data_or_filename);
+ for (std::vector<char>::const_iterator i = d.begin(); i != d.end(); ++i)
+ data.push_back(*i);
+ } catch (std::runtime_error const& ) {
+ std::string::const_iterator i;
+ for (i = data_or_filename.begin(); i != data_or_filename.end(); ++i)
+ if (data.size() > std::numeric_limits<boost::uint16_t>::max()) {
+ std::ostringstream oss;
+ oss << "This VLR with length " << data.size() << " does"
+ << " not fit within the maximum VLR size of "
+ << std::numeric_limits<boost::uint16_t>::max();
More information about the Liblas-commits
