[Liblas-commits] hg: rename GetSize to GetBitSize to eliminate any confusion for ...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Sep 9 16:17:05 EDT 2010
changeset c8da6dbbfde7 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c8da6dbbfde7
summary: rename GetSize to GetBitSize to eliminate any confusion for both liblas::Dimension and liblas::Schema
diffstat:
 include/liblas/lasschema.hpp |   4 ++--
 src/lasschema.cpp            |  11 ++++++-----
 2 files changed, 8 insertions(+), 7 deletions(-)
diffs (69 lines):
diff -r cc8916dc511c -r c8da6dbbfde7 include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp	Thu Sep 09 10:57:18 2010 -0500
+++ b/include/liblas/lasschema.hpp	Thu Sep 09 15:16:44 2010 -0500
@@ -78,7 +78,7 @@
     /// Fetch byte size
     boost::uint32_t GetByteSize() const;
-    boost::uint32_t GetSize() const;
+    boost::uint32_t GetBitSize() const;
     /// Get the base size (only accounting for Time, Color, etc )
     boost::uint32_t GetBaseByteSize() const;
@@ -143,7 +143,7 @@
     std::string const& GetName() { return m_name; }
     /// bits, logical size of point record
-    std::size_t GetSize() const
+    std::size_t GetBitSize() const
         return m_bitsize;
diff -r cc8916dc511c -r c8da6dbbfde7 src/lasschema.cpp
--- a/src/lasschema.cpp	Thu Sep 09 10:57:18 2010 -0500
+++ b/src/lasschema.cpp	Thu Sep 09 15:16:44 2010 -0500
@@ -445,7 +445,7 @@
         dim.put("description", t->GetDescription());
         dim.put("position", t->GetPosition());
         dim.put("active", static_cast<boost::uint32_t>(t->IsActive()));
-        dim.put("size", t->GetSize());
+        dim.put("size", t->GetBitSize());
         dim.put("integer", static_cast<boost::uint32_t>(t->IsInteger()));
         dim.put("signed", static_cast<boost::uint32_t>(t->IsSigned()));
         dim.put("required", static_cast<boost::uint32_t>(t->IsRequired()));
@@ -575,14 +575,15 @@
     return false;
-boost::uint32_t Schema::GetSize() const
+boost::uint32_t Schema::GetBitSize() const
     std::vector<DimensionPtr>::const_iterator i;
     boost::uint32_t size=0;
     for (i = m_dimensions.begin(); i != m_dimensions.end(); ++i)
-        size += (*i)->GetSize();
+        size += (*i)->GetBitSize();
     if (size % 8 != 0) {
@@ -620,7 +621,7 @@
 boost::uint32_t Schema::GetByteSize() const
-    return GetSize() / 8;
+    return GetBitSize() / 8;
 boost::uint32_t Schema::GetBaseByteSize() const
@@ -633,7 +634,7 @@
         boost::shared_ptr<Dimension> t = *i;
         if ( t->IsRequired() == true)
-            size += t->GetSize();
+            size += t->GetBitSize();
More information about the Liblas-commits mailing list
