[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Sep 23 16:49:22 EDT 2010
changeset 94d90bf6842c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=94d90bf6842c
summary: add a public utility dump bucket for things like liblas::Summary
changeset 27172e34ddff in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=27172e34ddff
summary: add repair feature using liblas::Summary -- now equivalent and 2x faster than las2las
diffstat:
 apps/las2las2.cpp          |  102 ++++++++++++++++------
 include/liblas/liblas.hpp  |    1 +
 include/liblas/utility.hpp |   92 +++++++++++++++++++++
 src/CMakeLists.txt         |    2 +
 src/lasreader.cpp          |  159 +----------------------------------
 src/utility.cpp            |  197 +++++++++++++++++++++++++++++++++++++++++++++
 6 files changed, 372 insertions(+), 181 deletions(-)
diffs (truncated from 708 to 300 lines):
diff -r 28eddbd39147 -r 27172e34ddff apps/las2las2.cpp
--- a/apps/las2las2.cpp	Thu Sep 23 12:27:49 2010 -0400
+++ b/apps/las2las2.cpp	Thu Sep 23 15:49:11 2010 -0500
@@ -13,17 +13,8 @@
 #include "laskernel.hpp"
 #include <boost/cstdint.hpp>
+#include <boost/foreach.hpp>
-// #include <fstream>
-// #include <iostream>
-// #include <sstream>
-// #include <string>
-// #include <vector>
-// #include <functional>
-// #include <boost/program_options.hpp>
-// #include <boost/tokenizer.hpp>
 typedef boost::tokenizer<boost::char_separator<char> > tokenizer;
@@ -38,8 +29,6 @@
 #define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
 #endif
-// #define SEPARATORS ",|"
 bool term_progress(std::ostream& os, double complete)
     static int lastTick = -1;
@@ -72,23 +61,16 @@
 liblas::Writer* start_writer(   std::ofstream* strm,
                                 std::string const& output,
                                 liblas::Header const& header)
     if (!liblas::Create(*strm, output.c_str()))
-        std::cerr << "Cannot create " << output << "for write.  Exiting...";
+        std::ostringstream oss;
+        oss << "Cannot create " << output << "for write.  Exiting...";
+        throw std::runtime_error(oss.str());
     liblas::Writer* writer = new liblas::Writer(*strm, header);
     return writer;
@@ -96,6 +78,69 @@
+void RepairHeader(liblas::Summary const& summary, std::string const& filename)
+    std::ifstream ifs;
+    if (!liblas::Open(ifs, filename.c_str()))
+        oss << "Cannot open " << filename << "for read.  Exiting...";
+    liblas::Reader reader(ifs);
+    liblas::Header header = reader.GetHeader();
+    ifs.close();
+    for (boost::uint32_t i = 0; i < 5; i++)
+        header.SetPointRecordsByReturnCount(i, 0);
+    std::ios::openmode m = std::ios::out | std::ios::in | std::ios::binary | std::ios::ate;
+    // Write a blank header first
+    std::ofstream ofs(filename.c_str(), m);
+    liblas::Writer writer(ofs, header);
+    ofs.close();
+    liblas::property_tree::ptree tree = summary.GetPTree();
+    try
+        header.SetMin(tree.get<double>("minimum.x"),
+                      tree.get<double>("minimum.y"),
+                      tree.get<double>("minimum.x"));
+        header.SetMax(tree.get<double>("maximum.x"),
+                      tree.get<double>("maximum.y"),
+                      tree.get<double>("maximum.x"));
+        BOOST_FOREACH(ptree::value_type &v,
+                tree.get_child("points_by_return"))
+            boost::uint32_t i = v.second.get<boost::uint32_t>("id");
+            boost::uint32_t count = v.second.get<boost::uint32_t>("count");
+            header.SetPointRecordsByReturnCount(i-1, count);
+    }     catch (liblas::property_tree::ptree_bad_path const& e)
+        std::cerr << "Unable to write summarized header info.  Does the outputted file have any points?";
+        return;
+    // Write our updated header with summary info
+    std::ofstream ofs2(filename.c_str(), m);
+    liblas::Writer writer2(ofs2, header);
+    ofs2.close();
 bool process(   std::string const& input,
                 liblas::Header const& header,
@@ -114,6 +159,7 @@
         return false;
+    liblas::Summary summary;
     reader.SetFilters(filters);
     reader.SetTransforms(transforms);
@@ -146,7 +192,8 @@
     while (reader.ReadNextPoint())
-        liblas::Point const& p = reader.GetPoint();
+        liblas::Point const& p = reader.GetPoint();
+        summary.AddPoint(p);
         writer->WritePoint(p);
         if (verbose)
             term_progress(std::cout, (i + 1) / static_cast<double>(size));
@@ -175,7 +222,7 @@
         std::cout << std::endl;
     reader.Reset();
-    liblas::property_tree::ptree pts = reader.Summarize();
+    liblas::property_tree::ptree pts = summary.GetPTree();
     liblas::property_tree::ptree top;
     top.add_child("summary.header",reader.GetHeader().GetPTree());
     top.add_child("summary.points",pts);
@@ -186,6 +233,7 @@
     delete writer;
     delete ofs;
+    RepairHeader(summary, output);
     return true;
@@ -235,9 +283,6 @@
             ("output,o", po::value< string >(&output)->default_value("output.las"), "output LAS file")
             ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
         po::variables_map vm;
         po::options_description options;
@@ -253,7 +298,6 @@
             return 1;
         if (vm.count("input"))
             input = vm["input"].as< string >();
diff -r 28eddbd39147 -r 27172e34ddff include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp	Thu Sep 23 12:27:49 2010 -0400
+++ b/include/liblas/liblas.hpp	Thu Sep 23 15:49:11 2010 -0500
@@ -63,6 +63,7 @@
 #include <liblas/lasvariablerecord.hpp>
 #include <liblas/lasversion.hpp>
 #include <liblas/laswriter.hpp>
+#include <liblas/utility.hpp>
 #include <liblas/detail/endian.hpp>
 #include <liblas/detail/utility.hpp>
 #include <liblas/capi/las_version.h>
diff -r 28eddbd39147 -r 27172e34ddff include/liblas/utility.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/utility.hpp	Thu Sep 23 15:49:11 2010 -0500
@@ -0,0 +1,92 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS filter class
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_LASSUMMARY_HPP_INCLUDED
+#define LIBLAS_LASSUMMARY_HPP_INCLUDED
+#include <liblas/lasheader.hpp>
+#include <liblas/laspoint.hpp>
+#include <liblas/detail/fwd.hpp>
+#include <liblas/external/property_tree/ptree.hpp>
+// boost
+#include <boost/cstdint.hpp>
+// std
+#include <vector>
+#include <functional>
+#include <string>
+using liblas::property_tree::ptree;
+typedef boost::array<boost::uint32_t, 32> classes_type;
+namespace liblas {
+/// A summarization utililty for LAS points
+class Summary
+public:
+    Summary();
+    void AddPoint(liblas::Point const& p);
+    ptree GetPTree() const;
+private:
+    Summary(Summary const& other);
+    Summary& operator=(Summary const& rhs);
+    classes_type classes;
+    boost::uint32_t synthetic;
+    boost::uint32_t withheld;
+    boost::uint32_t keypoint;
+    boost::uint32_t count;
+    boost::array<boost::uint32_t, 8> points_by_return;
+    boost::array<boost::uint32_t, 8> returns_of_given_pulse;
+    bool first;
+    liblas::Point min;
+    liblas::Point max;
+} // namespace liblas
+#endif // ndef LIBLAS_LASSUMMARY_HPP_INCLUDED
diff -r 28eddbd39147 -r 27172e34ddff src/CMakeLists.txt
--- a/src/CMakeLists.txt	Thu Sep 23 12:27:49 2010 -0400
+++ b/src/CMakeLists.txt	Thu Sep 23 15:49:11 2010 -0500
@@ -39,6 +39,7 @@
   ${LIBLAS_HEADERS_DIR}/lasversion.hpp
   ${LIBLAS_HEADERS_DIR}/laswriter.hpp
   ${LIBLAS_HEADERS_DIR}/liblas.hpp
+  ${LIBLAS_HEADERS_DIR}/utility.hpp
   ${LIBLAS_HEADERS_DIR}/version.hpp)
 set(LIBLAS_EXTERNAL_HPP)
More information about the Liblas-commits mailing list
