[Liblas-commits]
hg: support positional setting of scale and offset, min-offset, ...
liblas-commits at liblas.org
Mon Sep 27 14:53:23 EDT 2010
changeset 71134dee7fcb in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=71134dee7fcb
summary: support positional setting of scale and offset, min-offset, and file-creation for header
diffstat:
apps/las2las2.cpp | 4 +
apps/laskernel.cpp | 298 ++++++++++++++++------------------------------------
2 files changed, 97 insertions(+), 205 deletions(-)
diffs (truncated from 354 to 300 lines):
diff -r b9c673e070f9 -r 71134dee7fcb apps/las2las2.cpp
--- a/apps/las2las2.cpp Mon Sep 27 10:10:09 2010 -0500
+++ b/apps/las2las2.cpp Mon Sep 27 13:53:16 2010 -0500
@@ -423,6 +423,10 @@
if (vm.count("min-offset"))
+ if (vm.count("offset")) {
+ throw std::runtime_error("min-offset cannot be used with offets. Use one or the other");
bMinOffset = true;
diff -r b9c673e070f9 -r 71134dee7fcb apps/laskernel.cpp
--- a/apps/laskernel.cpp Mon Sep 27 10:10:09 2010 -0500
+++ b/apps/laskernel.cpp Mon Sep 27 13:53:16 2010 -0500
@@ -112,11 +112,12 @@
transform_options.add_options()
("a_srs", po::value< string >(), "Coordinate system to assign to input LAS file")
("a_vertcs", po::value< std::vector<string> >()->multitoken(), "Override vertical coordinate system information. Use --a_vertcs \"verticalCSType [citation [verticalDatum [verticalUnits]]]\"\nFor example: --a_vertcs 5703 \"North American Vertical Datum of 1988 (NAVD88)\" 5103 9001")
- ("offset", po::value< string >(), "A comma-separated list of offsets to set on the output file: \n--offset 0,0,0")
- ("scale", po::value< string >(), "A comma-separated list of scales to set on the output file: \n--scale 0.1,0.1,0.00001")
+ ("offset", po::value< std::vector<double> >()->multitoken(), "A list of offsets to set on the output file: \n--offset 0 0 0")
+ ("scale", po::value< std::vector<double> >()->multitoken(), "A list of scales to set on the output file: \n--scale 0.1 0.1 0.00001")
("format,f", po::value< string >(), "Set the LAS format of the new file (only 1.0-1.2 supported at this time): \n--format 1.2\n-f 1.1")
("pad-header", po::value< string >(), "Add extra bytes to the existing header")
("min-offset", po::value<bool>()->zero_tokens(), "Set the offset of the header to the minimums of all values in the file. Note that this requires multiple read passes through the file to achieve.")
+ ("file-creation", po::value< std::vector<string> >()->multitoken(), "Set the header's day/year. Specify either as \"1 2010\" for the first day of 2010, or as \"now\" to specify the current day/year")
@@ -594,52 +595,61 @@
- std::string offset_string = vm["offset"].as< string >();
+ std::vector<double> offsets = vm["offset"].as< std::vector<double> >();
+ if (offsets.size() != 3) {
+ ostringstream oss;
+ oss << "Three arguments must be given to offset. "
+ << "--offset x y z";
+ throw std::runtime_error(oss.str());
if (verbose)
- std::cout << "Setting offsets to: " << offset_string << std::endl;
- boost::char_separator<char> sep(SEPARATORS);
- std::vector<double> offsets;
- tokenizer tokens(offset_string, sep);
- bool mins = false;
- std::string m("min");
- for (tokenizer::iterator t = tokens.begin(); t != tokens.end(); ++t) {
- // Check if the user set --offset min,min,min
- // FIXME: make this so the user could do --offset min,min,20.00
- if (!(*t).compare(m))
- mins = true;
- continue;
- else
- mins = false;
- offsets.push_back(atof((*t).c_str()));
+ for (std::vector<double>::const_iterator i = offsets.begin();
+ i != offsets.end();
+ i++)
+ oss << *i << " ";
+ std::cout << "Setting offsets to: " << oss.str() << std::endl;
- if (offsets.size() != 3)
- throw std::runtime_error("All three values for setting the offset must be floats");
header.SetOffset(offsets[0], offsets[1], offsets[2]);
if (vm.count("scale"))
- std::string scale_string = vm["scale"].as< string >();
+ std::vector<double> scales = vm["scale"].as< std::vector<double> >();
+ if (scales.size() != 3) {
+ oss << "Three arguments must be given to scale. "
+ << "--scale x y z";
if (verbose)
- std::cout << "Setting scales to: " << scale_string << std::endl;
+ for (std::vector<double>::const_iterator i = scales.begin();
+ i != scales.end();
+ i++)
+ oss << *i << " ";
+ std::cout << "Setting scales to: " << oss.str() << std::endl;
- std::vector<double> scales;
- tokenizer tokens(scale_string, sep);
- scales.push_back(atof((*t).c_str()));
header.SetScale(scales[0], scales[1], scales[2]);
if (vm.count("format"))
std::string format_string = vm["format"].as< string >();
@@ -684,178 +694,56 @@
header.SetDataOffset(atoi(header_pad.c_str()));
+ if (vm.count("file-creation"))
+ std::vector<std::string> creation = vm["file-creation"].as< std::vector<std::string> >();
+ if (verbose)
+ for (std::vector<std::string>::const_iterator i = creation.begin();
+ i != creation.end();
+ i++)
+ oss << *i << " ";
+ std::cout << "Setting file creation to " << oss.str() << std::endl;
+ std::string m("now");
+ bool now = false;
+ if (creation.size() == 1 )
+ if (!(creation[0].compare(m)))
+ now = true;
+ boost::uint32_t day = 0;
+ boost::uint32_t year = 0;
+ if (creation.size() == 2)
+ day = atoi(creation[0].c_str());
+ year = atoi(creation[1].c_str());
+ if (now == true)
+ liblas::Header h;
+ header.SetCreationDOY(h.GetCreationDOY());
+ header.SetCreationYear(h.GetCreationYear());
+ } else {
+ header.SetCreationDOY(day);
+ header.SetCreationYear(year);
return transforms;
-// boost::property_tree::ptree SummarizePoints(liblas::Reader& reader )
-// using boost::property_tree::ptree;
-// ptree pt;
-// boost::array<boost::uint32_t, 32> classes;
-// boost::uint32_t synthetic = 0;
-// boost::uint32_t withheld = 0;
-// boost::uint32_t keypoint = 0;
-// boost::uint32_t count = 0;
-// boost::array<boost::uint32_t, 8> points_by_return;
-// boost::array<boost::uint32_t, 8> returns_of_given_pulse;
-// classes.assign(0);
-// points_by_return.assign(0);
-// returns_of_given_pulse.assign(0);
-// bool read = reader.ReadNextPoint();
-// if (!read)
-// throw std::runtime_error("Unable to read any points from file.");
-// bool first = true;
-// liblas::Point min;
-// liblas::Point max;
-// while (read)
-// count++;
-// liblas::Point const& p = reader.GetPoint();
-// if (first) {
-// min = p;
-// max = p;
-// first = false;
-// min.SetX(std::min(p.GetX(), min.GetX()));
-// max.SetX(std::max(p.GetX(), max.GetX()));
-// min.SetY(std::min(p.GetY(), min.GetY()));
-// max.SetY(std::max(p.GetY(), max.GetY()));
-// min.SetZ(std::min(p.GetZ(), min.GetZ()));
-// max.SetZ(std::max(p.GetZ(), max.GetZ()));
-// min.SetIntensity(std::min(p.GetIntensity(), min.GetIntensity()));
-// max.SetIntensity(std::max(p.GetIntensity(), max.GetIntensity()));
-// min.SetTime(std::min(p.GetTime(), min.GetTime()));
-// max.SetTime(std::max(p.GetTime(), max.GetTime()));
-// min.SetReturnNumber(std::min(p.GetReturnNumber(), min.GetReturnNumber()));
-// max.SetReturnNumber(std::max(p.GetReturnNumber(), max.GetReturnNumber()));
-// min.SetNumberOfReturns(std::min(p.GetNumberOfReturns(), min.GetNumberOfReturns()));
-// max.SetNumberOfReturns(std::max(p.GetNumberOfReturns(), max.GetNumberOfReturns()));
-// min.SetScanDirection(std::min(p.GetScanDirection(), min.GetScanDirection()));
-// max.SetScanDirection(std::max(p.GetScanDirection(), max.GetScanDirection()));
-// min.SetFlightLineEdge(std::min(p.GetFlightLineEdge(), min.GetFlightLineEdge()));
-// max.SetFlightLineEdge(std::max(p.GetFlightLineEdge(), max.GetFlightLineEdge()));
-// min.SetScanAngleRank(std::min(p.GetScanAngleRank(), min.GetScanAngleRank()));
-// max.SetScanAngleRank(std::max(p.GetScanAngleRank(), max.GetScanAngleRank()));
-// min.SetUserData(std::min(p.GetUserData(), min.GetUserData()));
-// max.SetUserData(std::max(p.GetUserData(), max.GetUserData()));
-// min.SetPointSourceID(std::min(p.GetPointSourceID(), min.GetPointSourceID()));
-// max.SetPointSourceID(std::max(p.GetPointSourceID(), max.GetPointSourceID()));
-// liblas::Classification const& cls = p.GetClassification();
-// boost::uint8_t minc = std::min(cls.GetClass(), min.GetClassification().GetClass());
-// boost::uint8_t maxc = std::max(cls.GetClass(), max.GetClassification().GetClass());
-// classes[cls.GetClass()]++;
-// if (cls.IsWithheld()) withheld++;
-// if (cls.IsKeyPoint()) keypoint++;
-// if (cls.IsSynthetic()) synthetic++;
-// min.SetClassification(liblas::Classification(minc));
-// max.SetClassification(liblas::Classification(maxc));
-// liblas::Color const& color = p.GetColor();
-// liblas::Color::value_type red;
-// liblas::Color::value_type green;
-// liblas::Color::value_type blue;
-// red = std::min(color.GetRed(), min.GetColor().GetRed());
-// green = std::min(color.GetGreen(), min.GetColor().GetGreen());
-// blue = std::min(color.GetBlue(), min.GetColor().GetBlue());
-// min.SetColor(liblas::Color(red, green, blue));
-// red = std::max(color.GetRed(), max.GetColor().GetRed());
-// green = std::max(color.GetGreen(), max.GetColor().GetGreen());
-// blue = std::max(color.GetBlue(), max.GetColor().GetBlue());
-// max.SetColor(liblas::Color(red, green, blue));
-// points_by_return[p.GetReturnNumber()]++;
-// returns_of_given_pulse[p.GetNumberOfReturns()]++;
-// read = reader.ReadNextPoint();
-// ptree pmin = min.GetPTree();
-// ptree pmax = max.GetPTree();
More information about the Liblas-commits
