[Liblas-commits] hg-main-tree: No longer do assert() when
getDimensionIndex retur...
liblas-commits at liblas.org
Fri Apr 1 08:44:01 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/88cd7ccaa6b5
changeset: 487:88cd7ccaa6b5
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Apr 01 07:43:35 2011 -0500
description:
No longer do assert() when getDimensionIndex returns a -1. Instead, return the -1, and then have getField return a 0 if it was given a field dimension of -1
Subject: hg-main-tree: BLOB point selection now working
details: http://hg.libpc.orghg-main-tree/rev/4100e8e5a35f
changeset: 488:4100e8e5a35f
date: Fri Apr 01 07:43:52 2011 -0500
description:
diffstat:
apps/pc2pc.cpp | 6 +-
include/libpc/PointBuffer.hpp | 17 ++-
include/libpc/drivers/oci/Iterator.hpp | 3 +
include/libpc/drivers/oci/Reader.hpp | 49 +++++++++
include/libpc/drivers/oci/oci_wrapper.h | 3 +
src/Schema.cpp | 7 +-
src/drivers/oci/Iterator.cpp | 13 ++-
src/drivers/oci/Reader.cpp | 158 ++++++++++++++++++++++++++++---
src/drivers/oci/oci_wrapper.cpp | 51 ++++++++++
9 files changed, 277 insertions(+), 30 deletions(-)
diffs (truncated from 562 to 300 lines):
diff -r 712ec8b1bd73 -r 4100e8e5a35f apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Thu Mar 31 09:33:40 2011 -0500
+++ b/apps/pc2pc.cpp Fri Apr 01 07:43:52 2011 -0500
@@ -154,8 +154,8 @@
tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
tree.put("debug", true);
tree.put("verbose", true);
- // tree.put("select_sql", "select * from output");
- tree.put("select_sql", "select cloud from hobu where id = 5");
+ tree.put("select_sql", "select * from output");
+ // tree.put("select_sql", "select cloud from hobu where id = 5");
libpc::drivers::oci::Reader reader(options);
@@ -164,7 +164,7 @@
libpc::drivers::liblas::LiblasWriter writer(reader, *ofs);
- writer.setPointFormat( 3);
+ // writer.setPointFormat( 3);
writer.write(numPoints);
#else
throw configuration_error("libPC not compiled with Oracle support");
diff -r 712ec8b1bd73 -r 4100e8e5a35f include/libpc/PointBuffer.hpp
--- a/include/libpc/PointBuffer.hpp Thu Mar 31 09:33:40 2011 -0500
+++ b/include/libpc/PointBuffer.hpp Fri Apr 01 07:43:52 2011 -0500
@@ -99,8 +99,8 @@
// accessors to a particular field of a particular point in this buffer
- template<class T> T getField(std::size_t pointIndex, std::size_t fieldIndex) const;
- template<class T> void setField(std::size_t pointIndex, std::size_t fieldIndex, T value);
+ template<class T> T getField(std::size_t pointIndex, boost::int32_t fieldIndex) const;
+ template<class T> void setField(std::size_t pointIndex, boost::int32_t fieldIndex, T value);
// bulk copy all the fields from the given point into this object
// NOTE: this is only legal if the src and dest schemas are exactly the same
@@ -132,8 +132,12 @@
template <class T>
-inline void PointBuffer::setField(std::size_t pointIndex, std::size_t fieldIndex, T value)
+inline void PointBuffer::setField(std::size_t pointIndex, boost::int32_t fieldIndex, T value)
+ if (fieldIndex == -1)
+ return; // no-op in the case where fieldIndex is -1 and we don't actually have that field
std::size_t offset = (pointIndex * m_pointSize) + m_schemaLayout.getDimensionLayout(fieldIndex).getByteOffset();
assert(offset + sizeof(T) <= m_pointSize * m_capacity);
boost::uint8_t* p = m_data.get() + offset;
@@ -143,8 +147,13 @@
template <class T>
-inline T PointBuffer::getField(std::size_t pointIndex, std::size_t fieldIndex) const
+inline T PointBuffer::getField(std::size_t pointIndex, boost::int32_t fieldIndex) const
+ return T(0);
diff -r 712ec8b1bd73 -r 4100e8e5a35f include/libpc/drivers/oci/Iterator.hpp
--- a/include/libpc/drivers/oci/Iterator.hpp Thu Mar 31 09:33:40 2011 -0500
+++ b/include/libpc/drivers/oci/Iterator.hpp Fri Apr 01 07:43:52 2011 -0500
@@ -58,11 +58,14 @@
boost::uint32_t readBuffer(PointBuffer& data);
+ bool m_at_end;
private:
const Reader& m_reader;
IteratorBase& operator=(const IteratorBase&); // not implemented
IteratorBase(const IteratorBase&); // not implemented};
diff -r 712ec8b1bd73 -r 4100e8e5a35f include/libpc/drivers/oci/Reader.hpp
--- a/include/libpc/drivers/oci/Reader.hpp Thu Mar 31 09:33:40 2011 -0500
+++ b/include/libpc/drivers/oci/Reader.hpp Fri Apr 01 07:43:52 2011 -0500
@@ -40,10 +40,36 @@
#include <libpc/Stage.hpp>
#include <libpc/drivers/oci/Common.hpp>
+#include <boost/scoped_ptr.hpp>
+#include <boost/scoped_array.hpp>
+#include <vector>
namespace libpc { namespace drivers { namespace oci {
+class Block
+public:
+ Block() {};
+ boost::int32_t obj_id;
+ boost::int32_t blk_id;
+ sdo_geometry* blk_extent;
+ sdo_orgscl_type* blk_domain;
+ double pcblk_min_res;
+ double pcblk_max_res;
+ boost::int32_t num_points;
+ boost::int32_t num_unsorted_points;
+ boost::int32_t pt_sort_dim;
+private:
+ boost::uint32_t m_capacity;
class LIBPC_DLL Reader : public libpc::Stage
@@ -59,10 +85,23 @@
return false;
+ enum QueryType
+ QUERY_SDO_PC,
+ QUERY_SDO_PC_BLK,
+ QUERY_BLK_TABLE,
+ QUERY_UNKNOWN
libpc::SequentialIterator* createSequentialIterator() const;
Connection getConnection () const { return m_connection;}
Options& getOptions() const { return m_options; }
+ sdo_pc* getPCObject() const { return m_pc; }
+ sdo_pc_blk* getPCBlockObject() const { return m_block_table_type; }
+ Block* getBlock() const { return m_block_table; }
+ bool fetchNext() const;
private:
Reader& operator=(const Reader&); // not implemented
@@ -72,11 +111,21 @@
void Debug();
void registerFields();
void fetchPCFields();
+ QueryType describeQueryType();
+ void doBlockTableDefine();
Options& m_options;
Connection m_connection;
Statement m_statement;
bool m_verbose;
+ QueryType m_qtype;
+ sdo_pc* m_pc;
+ sdo_pc_blk* m_block_table_type;
+ Block* m_block_table;
+ OCILobLocator* m_locator;
+ std::vector<boost::uint8_t> m_points;
}}} // namespace libpc::driver::oci
diff -r 712ec8b1bd73 -r 4100e8e5a35f include/libpc/drivers/oci/oci_wrapper.h
--- a/include/libpc/drivers/oci/oci_wrapper.h Thu Mar 31 09:33:40 2011 -0500
+++ b/include/libpc/drivers/oci/oci_wrapper.h Fri Apr 01 07:43:52 2011 -0500
@@ -347,6 +347,8 @@
void DestroyType( sdo_geometry** pphData );
void CreateType( sdo_pc** pphData );
void DestroyType( sdo_pc** pphData );
+ void CreateType( sdo_orgscl_type** pphData );
+ void DestroyType( sdo_orgscl_type** pphData );
void CreateType( OCIArray** phData , OCIType* type);
void DestroyType( OCIArray** phData );
OCIType* DescribeType( const char *pszTypeName );
@@ -434,6 +436,7 @@
void Define( sdo_georaster** pphData );
void Define( sdo_geometry** pphData );
void Define( sdo_pc** pphData );
+ void Define( sdo_orgscl_type** pphData );
void Define( sdo_pc_blk** pphData );
void Define( OCILobLocator** pphLocator, long nIterations );
void DefineClob( OCILobLocator** pphLocator, long nIterations );
diff -r 712ec8b1bd73 -r 4100e8e5a35f src/Schema.cpp
--- a/src/Schema.cpp Thu Mar 31 09:33:40 2011 -0500
+++ b/src/Schema.cpp Fri Apr 01 07:43:52 2011 -0500
@@ -163,15 +163,16 @@
const int index = m_indexTable[field];
- assert(index != -1);
+ // assert(index != -1);
if (index == -1)
- throw libpc_error("Requested dimension field not present");
+ return -1;
+ // throw libpc_error("Requested dimension field not present");
const Dimension& dim = m_dimensions[index];
- assert(dim.getDataType() == datatype);
+ // assert(dim.getDataType() == datatype);
if (dim.getDataType() != datatype)
throw libpc_error("Requested dimension field present, but with different datatype");
diff -r 712ec8b1bd73 -r 4100e8e5a35f src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp Thu Mar 31 09:33:40 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp Fri Apr 01 07:43:52 2011 -0500
@@ -44,7 +44,8 @@
IteratorBase::IteratorBase(const Reader& reader)
- : m_reader(reader)
+ : m_at_end(false)
+ , m_reader(reader)
oci::Options& options = m_reader.getOptions();
@@ -68,7 +69,15 @@
boost::uint32_t numPoints = data.getCapacity();
+ bool read = m_reader.fetchNext();
+ Block* block = m_reader.getBlock();
+ if (!read)
+ m_at_end = true;
+ return 0;
+ std::cout << "fetched" << std::endl;
// boost::uint32_t i = 0;
// const Schema& schema = data.getSchema();
@@ -213,7 +222,7 @@
bool SequentialIterator::atEndImpl() const
- return true;
+ return m_at_end;
// return getIndex() >= getStage().getNumPoints();
diff -r 712ec8b1bd73 -r 4100e8e5a35f src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp Thu Mar 31 09:33:40 2011 -0500
+++ b/src/drivers/oci/Reader.cpp Fri Apr 01 07:43:52 2011 -0500
@@ -48,6 +48,7 @@
: libpc::Stage()
, m_options(options)
, m_verbose(false)
+ , m_qtype(QUERY_UNKNOWN)
Debug();
@@ -55,7 +56,6 @@
m_connection = Connect(m_options);
std::string sql = options.GetPTree().get<std::string>("select_sql");
if (sql.size() == 0 )
@@ -67,32 +67,138 @@
m_statement->Execute(0);
- fetchPCFields();
+ m_qtype = describeQueryType();
// int foo;
// int block_id;
// m_statement->Define(&foo);
// m_statement->Define(&block_id);
- sdo_pc_blk* block;
- sdo_pc* pc;
- m_connection->CreateType(&pc);
- m_statement->Define(&pc);
+ m_connection->CreateType(&m_pc);
- while(m_statement->Fetch() )
+ if (m_qtype == QUERY_SDO_PC)
- std::cout << " Block: " << m_statement->GetInteger(&(pc->pc_id)) << std::endl;
+ m_statement->Define(&m_pc);
+ // Unpack SDO_PC object to get at block
+ // table, select that stuff, and unpack the blocks
More information about the Liblas-commits
