[Liblas-commits] hg-main-tree: supportsIterator is a const method
liblas-commits at liblas.org
Fri Apr 1 16:48:23 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/a3923ec16e23
changeset: 491:a3923ec16e23
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Apr 01 15:48:01 2011 -0500
description:
Subject: hg-main-tree: move most reading functions into the IteratorBase
details: http://hg.libpc.orghg-main-tree/rev/b2d9c7ff4041
changeset: 492:b2d9c7ff4041
date: Fri Apr 01 15:48:16 2011 -0500
description:
diffstat:
include/libpc/Stage.hpp | 2 +-
include/libpc/drivers/faux/Reader.hpp | 2 +-
include/libpc/drivers/las/Reader.hpp | 2 +-
include/libpc/drivers/liblas/Reader.hpp | 2 +-
include/libpc/drivers/oci/Common.hpp | 31 ++
include/libpc/drivers/oci/Iterator.hpp | 16 +-
include/libpc/drivers/oci/Reader.hpp | 54 +----
include/libpc/filters/CacheFilter.hpp | 2 +-
include/libpc/filters/Chipper.hpp | 2 +-
include/libpc/filters/ColorFilter.hpp | 2 +-
include/libpc/filters/CropFilter.hpp | 2 +-
include/libpc/filters/DecimationFilter.hpp | 2 +-
include/libpc/filters/MosaicFilter.hpp | 2 +-
src/Writer.cpp | 53 +++-
src/drivers/oci/Iterator.cpp | 292 +++++++++++++++++++++++++++-
src/drivers/oci/Reader.cpp | 303 +----------------------------
16 files changed, 391 insertions(+), 378 deletions(-)
diffs (truncated from 1053 to 300 lines):
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/Stage.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -72,7 +72,7 @@
const SpatialReference& getSpatialReference() const;
const Metadata::Array& getMetadata() const;
- virtual bool supportsIterator (StageIteratorType) const { return false; }
+ virtual bool supportsIterator (StageIteratorType) const = 0;
virtual SequentialIterator* createSequentialIterator() const { return NULL; }
virtual RandomIterator* createRandomIterator() const { return NULL; }
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/drivers/faux/Reader.hpp
--- a/include/libpc/drivers/faux/Reader.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/drivers/faux/Reader.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -81,7 +81,7 @@
Mode getMode() const;
- bool supportsIterator (StageIteratorType t)
+ bool supportsIterator (StageIteratorType t) const
if (t == StageIterator_Sequential ) return true;
if (t == StageIterator_Random ) return true;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/drivers/las/Reader.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -59,7 +59,7 @@
const std::string& getFileName() const;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/drivers/liblas/Reader.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -70,7 +70,7 @@
bool hasColorData() const;
bool hasWaveData() const;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/drivers/oci/Common.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -64,6 +64,37 @@
#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
#endif
+enum QueryType
+ QUERY_SDO_PC,
+ QUERY_SDO_PC_BLK,
+ QUERY_BLK_TABLE,
+ QUERY_UNKNOWN
+class Block
+public:
+ Block() {};
+ boost::int32_t obj_id;
+ boost::int32_t blk_id;
+ sdo_geometry* blk_extent;
+ sdo_orgscl_type* blk_domain;
+ double pcblk_min_res;
+ double pcblk_max_res;
+ boost::int32_t num_points;
+ boost::int32_t num_unsorted_points;
+ boost::int32_t pt_sort_dim;
+private:
+ boost::uint32_t m_capacity;
class LIBPC_DLL Options
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/drivers/oci/Iterator.hpp
--- a/include/libpc/drivers/oci/Iterator.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/drivers/oci/Iterator.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -40,12 +40,12 @@
#include <libpc/Iterator.hpp>
#include <libpc/drivers/oci/Common.hpp>
+#include <libpc/drivers/oci/Reader.hpp>
#include <string>
namespace libpc { namespace drivers { namespace oci {
-class Reader;
class IteratorBase
@@ -58,13 +58,25 @@
boost::uint32_t readBuffer(PointBuffer& data);
+ Statement m_statement;
bool m_at_end;
+ QueryType m_querytype;
+ Block* m_block;
+ OCILobLocator* m_locator;
+ sdo_pc* m_pc;
+ sdo_pc_blk* m_block_table_type;
+ std::vector<boost::uint8_t> m_points;
+ boost::uint32_t m_blob_read_byte_size;
private:
const Reader& m_reader;
IteratorBase& operator=(const IteratorBase&); // not implemented
- IteratorBase(const IteratorBase&); // not implemented};
+ IteratorBase(const IteratorBase&); // not implemented;
+ void doBlockTableDefine();
+ QueryType describeQueryType() const;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/drivers/oci/Reader.hpp
--- a/include/libpc/drivers/oci/Reader.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/drivers/oci/Reader.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -47,28 +47,7 @@
-class Block
-public:
- Block() {};
- boost::int32_t obj_id;
- boost::int32_t blk_id;
- sdo_geometry* blk_extent;
- sdo_orgscl_type* blk_domain;
- double pcblk_min_res;
- double pcblk_max_res;
- boost::int32_t num_points;
- boost::int32_t num_unsorted_points;
- boost::int32_t pt_sort_dim;
-private:
- boost::uint32_t m_capacity;
class LIBPC_DLL Reader : public libpc::Stage
@@ -79,29 +58,20 @@
const std::string& getName() const;
return false;
- enum QueryType
- QUERY_SDO_PC,
- QUERY_SDO_PC_BLK,
- QUERY_BLK_TABLE,
- QUERY_UNKNOWN
libpc::SequentialIterator* createSequentialIterator() const;
Connection getConnection () const { return m_connection;}
Options& getOptions() const { return m_options; }
- sdo_pc* getPCObject() const { return m_pc; }
- sdo_pc_blk* getPCBlockObject() const { return m_block_table_type; }
- Block* getBlock() const { return m_block_table; }
- bool fetchNext() const;
+ std::string getQuery() const;
+ bool isVerbose() const;
private:
Reader& operator=(const Reader&); // not implemented
@@ -111,21 +81,11 @@
void Debug();
void registerFields();
void fetchPCFields();
- QueryType describeQueryType();
- void doBlockTableDefine();
+ // void doBlockTableDefine();
Options& m_options;
Connection m_connection;
- Statement m_statement;
- bool m_verbose;
- QueryType m_qtype;
- sdo_pc* m_pc;
- sdo_pc_blk* m_block_table_type;
- Block* m_block_table;
- OCILobLocator* m_locator;
- std::vector<boost::uint8_t> m_points;
- boost::uint32_t m_blob_read_byte_size;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/filters/CacheFilter.hpp
--- a/include/libpc/filters/CacheFilter.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/filters/CacheFilter.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -89,7 +89,7 @@
boost::uint64_t& numCacheInsertMisses,
boost::uint64_t& numCacheInsertHits) const;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/filters/Chipper.hpp
--- a/include/libpc/filters/Chipper.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/filters/Chipper.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -167,7 +167,7 @@
const std::string& getName() const ;
return false;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/filters/ColorFilter.hpp
--- a/include/libpc/filters/ColorFilter.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/filters/ColorFilter.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -62,7 +62,7 @@
void getColor(float value, boost::uint8_t& red, boost::uint8_t& green, boost::uint8_t& blue) const;
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/filters/CropFilter.hpp
--- a/include/libpc/filters/CropFilter.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/filters/CropFilter.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -59,7 +59,7 @@
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/filters/DecimationFilter.hpp
--- a/include/libpc/filters/DecimationFilter.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/filters/DecimationFilter.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -57,7 +57,7 @@
diff -r 1747c2f81b4a -r b2d9c7ff4041 include/libpc/filters/MosaicFilter.hpp
--- a/include/libpc/filters/MosaicFilter.hpp Fri Apr 01 13:53:59 2011 -0500
+++ b/include/libpc/filters/MosaicFilter.hpp Fri Apr 01 15:48:16 2011 -0500
@@ -59,7 +59,7 @@
const std::vector<const Stage*>& getPrevStages() const;
if (t == StageIterator_Random) return false; // BUG: could be true
diff -r 1747c2f81b4a -r b2d9c7ff4041 src/Writer.cpp
--- a/src/Writer.cpp Fri Apr 01 13:53:59 2011 -0500
+++ b/src/Writer.cpp Fri Apr 01 15:48:16 2011 -0500
@@ -79,7 +79,20 @@
More information about the Liblas-commits
