[Liblas-commits] hg-1.6: defer all laszip validation to the laszip library itself
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Apr 4 10:30:21 EDT 2011
details:   http://hg.liblas.orghg-1.6/rev/e0ae15027f61
changeset: 2859:e0ae15027f61
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Mar 25 08:33:57 2011 -0700
description:
diffstat:
 src/detail/zippoint.cpp |  93 +------------------------------------------------
 1 files changed, 1 insertions(+), 92 deletions(-)
diffs (103 lines):
diff -r 0058891eaee5 -r e0ae15027f61 src/detail/zippoint.cpp
--- a/src/detail/zippoint.cpp	Mon Mar 07 11:42:38 2011 -0600
+++ b/src/detail/zippoint.cpp	Fri Mar 25 08:33:57 2011 -0700
@@ -279,98 +279,7 @@
     if (laszip_recordid != vlr.GetRecordId())
         return false;
-    // note we don't bother validating the Description field
-    boost::uint16_t record_length_after_header = vlr.GetRecordLength();
-    if (record_length_after_header != 34 + 6 * m_num_items)
-        return false;
-    boost::uint8_t* data = new boost::uint8_t[record_length_after_header];
-    boost::uint8_t* p = data;
-    const std::vector<boost::uint8_t>& vdata = vlr.GetData();
-    for (boost::uint32_t i=0; i<record_length_after_header; i++)
-        data[i] = vdata[i];
-    // the data following the header of the variable length record is
-    //     U32  compression        4 bytes
-    //     U8   version_major      1 byte
-    //     U8   version_minor      1 byte
-    //     U16  version_revision   2 bytes
-    //     U32  options            4 bytes
-    //     U32  num_chunks         4 bytes
-    //     I64  num_points         8 bytes
-    //     I64  num_bytes          8 bytes
-    //     U16  num_items          2 bytes
-    //        U16 type                2 bytes * num_items
-    //        U16 size                2 bytes * num_items
-    //        U16 version             2 bytes * num_items
-    // which totals 34+6*num_items
-    // the header doesn't know what kind of compression the zipwriter
-    // will be doing, but since we only ever use the default we'll just
-    // use that for now
-    boost::uint32_t compression_type = 0;
-    p = GetBytes<boost::uint32_t>(p, compression_type);
-    if (compression_type != LASzip::DEFAULT_COMPRESSION)
-        return false;
-    boost::uint8_t version_major = 0;
-    p = GetBytes<boost::uint8_t>(p, version_major);
-    if (version_major != LASZIP_VERSION_MAJOR)
-        return false;
-    boost::uint8_t version_minor = 0;
-    p = GetBytes<boost::uint8_t>(p, version_minor);
-    if (version_minor != LASZIP_VERSION_MINOR)
-        return false;
-    boost::uint16_t version_revision = 0;
-    p = GetBytes<boost::uint16_t>(p, version_revision);
-    if (version_revision > LASZIP_VERSION_REVISION)
-        return false;
-    boost::uint32_t options = 0;
-    p = GetBytes<boost::uint32_t>(p, options);
-    if (options != 0)
-        return false;
-    boost::uint32_t num_chunks = 0;
-    p = GetBytes<boost::uint32_t>(p, num_chunks);
-    if (num_chunks != 1)
-        return false;
-    boost::int64_t num_points = 0;
-    p = GetBytes<boost::int64_t>(p, num_points);
-    if (num_points != -1)  // BUG: or allow it to match header
-        return false;
-    boost::int64_t num_bytes = 0;
-    p = GetBytes<boost::int64_t>(p, num_bytes);
-    if (num_bytes != -1)  // BUG: or allow it to match header
-        return false;
-    boost::uint16_t num_items = 0;
-    p = GetBytes<boost::uint16_t>(p, num_items);
-    if (num_items != (boost::uint16_t)m_num_items)
-        return false;
-    for (boost::uint32_t i = 0; i < num_items; i++)
-        boost::uint16_t type = 0;
-        p = GetBytes<boost::uint16_t>(p, type);
-        if (type != (boost::uint16_t)m_items[i].type)
-            return false;
-        boost::uint16_t size = 0;
-        p = GetBytes<boost::uint16_t>(p, size);
-        if (size != (boost::uint16_t)m_items[i].size)
-            return false;
-        boost::uint16_t version = 0;
-        p = GetBytes<boost::uint16_t>(p, version);
-        if (version != (boost::uint16_t)m_items[i].version)
-            return false;
-    assert(p == data + record_length_after_header);
-    if (data != 0 )
-        delete[] data;
+    // (all validation checking is now done inside the liblas library)
     return true;
More information about the Liblas-commits mailing list
