[Liblas-commits] hg-main-tree: comment out the assertion about
making sure we wro...
liblas-commits at liblas.org
Thu Apr 7 14:06:34 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/dc12125afc0f
changeset: 505:dc12125afc0f
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Apr 07 13:04:18 2011 -0500
description:
comment out the assertion about making sure we wrote the right number of points. We don't know that anymore
Subject: hg-main-tree: successfully read 5-fixed-dimension OCI data for the first time
details: http://hg.libpc.orghg-main-tree/rev/68912ea61235
changeset: 506:68912ea61235
date: Thu Apr 07 13:06:22 2011 -0500
description:
diffstat:
include/libpc/drivers/oci/Common.hpp | 13 ++++
include/libpc/drivers/oci/Iterator.hpp | 2 +-
src/Writer.cpp | 2 +-
src/drivers/oci/Iterator.cpp | 104 ++++++++++++++++++++++++++++----
src/drivers/oci/common.cpp | 9 +-
5 files changed, 111 insertions(+), 19 deletions(-)
diffs (250 lines):
diff -r 82cabe497436 -r 68912ea61235 include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp Wed Apr 06 21:19:59 2011 -0500
+++ b/include/libpc/drivers/oci/Common.hpp Thu Apr 07 13:06:22 2011 -0500
@@ -38,6 +38,7 @@
#include <libpc/libpc.hpp>
#include "oci_wrapper.h"
+#include "Endian.hpp"
#include <boost/shared_ptr.hpp>
#include <boost/scoped_ptr.hpp>
@@ -66,6 +67,18 @@
#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
#endif
+struct FiveDimensionOCI
+ double x;
+ double y;
+ double z;
+ double t;
+ double c;
+ uint32_t blk_id;
+ uint32_t pc_id;
enum QueryType
QUERY_SDO_PC,
diff -r 82cabe497436 -r 68912ea61235 include/libpc/drivers/oci/Iterator.hpp
--- a/include/libpc/drivers/oci/Iterator.hpp Wed Apr 06 21:19:59 2011 -0500
+++ b/include/libpc/drivers/oci/Iterator.hpp Thu Apr 07 13:06:22 2011 -0500
@@ -62,7 +62,7 @@
Statement m_statement;
bool m_at_end;
QueryType m_querytype;
- Block* m_block;
+ boost::scoped_ptr<Block> m_block;
OCILobLocator* m_locator;
sdo_pc* m_pc;
diff -r 82cabe497436 -r 68912ea61235 src/Writer.cpp
--- a/src/Writer.cpp Wed Apr 06 21:19:59 2011 -0500
+++ b/src/Writer.cpp Thu Apr 07 13:06:22 2011 -0500
@@ -143,7 +143,7 @@
writeEnd();
- assert(m_actualNumPointsWritten <= m_targetNumPointsToWrite);
+ // assert(m_actualNumPointsWritten <= m_targetNumPointsToWrite);
return m_actualNumPointsWritten;
diff -r 82cabe497436 -r 68912ea61235 src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp Wed Apr 06 21:19:59 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp Thu Apr 07 13:06:22 2011 -0500
@@ -33,6 +33,7 @@
#include <libpc/drivers/oci/Iterator.hpp>
+#include <libpc/Utils.hpp>
#include <liblas/factory.hpp>
@@ -43,19 +44,20 @@
#include <sstream>
#include <map>
+#include <algorithm>
namespace libpc { namespace drivers { namespace oci {
IteratorBase::IteratorBase(const Reader& reader)
: m_at_end(false)
- , m_block(0)
+ , m_block(new Block(reader.getConnection()))
, m_reader(reader)
// oci::Options& options = m_reader.getOptions();
- m_reader.getConnection()->CreateType(&m_pc);
+ // m_reader.getConnection()->CreateType(&m_pc);
m_statement = Statement(m_reader.getConnection()->CreateStatement(m_reader.getQuery().c_str()));
@@ -90,7 +92,86 @@
boost::uint32_t IteratorBase::unpackOracleData(PointBuffer& data)
+ boost::uint32_t capacity = data.getCapacity();
+ boost::uint32_t numPoints = data.getNumPoints();
+ boost::uint32_t space = capacity - numPoints;
+ boost::uint32_t point_position = numPoints;
+ if (m_block->num_points < 0)
+ std::ostringstream oss;
+ oss << "This oracle block has a num_points that is negative (" << m_block->num_points <<")!";
+ throw libpc_error(oss.str());
+ if (space < static_cast<boost::uint32_t>(m_block->num_points))
+ oss << "Not enough space to store this block! The capacity left in the buffer is ";
+ oss << capacity << ", the Oracle block has " << m_block->num_points << " points ";
+ std::cout.setf(std::ios_base::fixed, std::ios_base::floatfield);
+ std::cout.precision(2);
+ const Schema& schema = data.getSchema();
+ const int indexX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Int32);
+ const int indexY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Int32);
+ const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Int32);
+ const int indexTime = schema.getDimensionIndex(Dimension::Field_Time, Dimension::Double);
+ const int indexClassification = schema.getDimensionIndex(Dimension::Field_Classification, Dimension::Uint8);
+ const Dimension& dimX = schema.getDimension(indexX);
+ const Dimension& dimY = schema.getDimension(indexY);
+ const Dimension& dimZ = schema.getDimension(indexZ);
+ double scalex = dimX.getNumericScale();
+ double scaley = dimY.getNumericScale();
+ double scalez = dimZ.getNumericScale();
+ double offsetx = dimX.getNumericOffset();
+ double offsety = dimY.getNumericOffset();
+ double offsetz = dimZ.getNumericOffset();
+ FiveDimensionOCI* d;
+ for (boost::uint32_t i = 0; i < static_cast<boost::uint32_t>(m_block->num_points); i++)
+ boost::uint32_t byte_position = i*sizeof(FiveDimensionOCI);
+ d = (FiveDimensionOCI*)(&(*m_block->chunk)[byte_position]);
+ SWAP_BE_TO_LE(d->x);
+ SWAP_BE_TO_LE(d->y);
+ SWAP_BE_TO_LE(d->z);
+ SWAP_BE_TO_LE(d->t);
+ SWAP_BE_TO_LE(d->c);
+ SWAP_BE_TO_LE(d->blk_id);
+ SWAP_BE_TO_LE(d->pc_id);
+ // std::cout << "sizeof(FiveDimensionOCI): " << sizeof(FiveDimensionOCI) << " position: " << position << " i: " << i
+ // << " x: " << d->x << " y: " << d->y << " z: " << d->z << std::endl;
+ boost::int32_t x = static_cast<boost::int32_t>(
+ Utils::sround((d->x - offsetx) / scalex));
+ boost::int32_t y = static_cast<boost::int32_t>(
+ Utils::sround((d->y - offsety) / scaley));
+ boost::int32_t z = static_cast<boost::int32_t>(
+ Utils::sround((d->z - offsetz) / scalez));
+ data.setField(point_position, indexX, x);
+ data.setField(point_position, indexY, y);
+ data.setField(point_position, indexZ, z);
+ data.setField(point_position, indexTime, d->t);
+ data.setField(point_position, indexClassification, static_cast<boost::uint8_t>(d->c));
+ point_position++;
+ data.setNumPoints(point_position);
return 0;
@@ -122,7 +203,7 @@
bDidRead = true;
std::cout << "we already had points in our cache, using those" << std::endl;
+ unpackOracleData(data);
@@ -146,7 +227,7 @@
break;
- boost::uint32_t nAmountRead;
+ boost::uint32_t nAmountRead = 0;
boost::uint32_t blob_length = m_statement->GetBlobLength(m_locator);
@@ -156,20 +237,18 @@
m_block->chunk->resize(blob_length);
- // std::vector<boost::uint8_t> chunk;
- // if (chunk.size() < blob_length)
- // chunk.resize(blob_length);
std::cout << " m_block->chunk->size() : " << m_block->chunk->size()<< std::endl;
bool read_all_data = m_statement->ReadBlob( m_locator,
(void*)(&(*m_block->chunk)[0]),
- m_block->chunk->size(),
+ m_block->chunk->size() ,
&nAmountRead);
if (!read_all_data) throw libpc_error("Did not read all blob data!");
std::cout << "nAmountRead: " << nAmountRead << " m_block->chunk->size() : " << m_block->chunk->size()<< std::endl;
bDidRead = m_statement->Fetch();
if (!bDidRead)
@@ -338,10 +417,7 @@
signed short nScale = 0;
char szTypeName[OWNAME];
- if (!m_block)
- m_block = new Block(m_reader.getConnection());
- m_block->num_points = 0;
diff -r 82cabe497436 -r 68912ea61235 src/drivers/oci/common.cpp
--- a/src/drivers/oci/common.cpp Wed Apr 06 21:19:59 2011 -0500
+++ b/src/drivers/oci/common.cpp Thu Apr 07 13:06:22 2011 -0500
@@ -145,10 +145,13 @@
Block::~Block()
+ m_connection->DestroyType(&blk_domain);
+ m_connection->DestroyType(&blk_extent->sdo_elem_info);
m_connection->DestroyType(&blk_extent->sdo_ordinates);
- m_connection->DestroyType(&blk_extent->sdo_elem_info);
- m_connection->DestroyType(&blk_extent);
- m_connection->DestroyType(&blk_domain);
+ // FIXME: For some reason having the dtor destroy this
+ // causes a segfault
+ // m_connection->DestroyType(&blk_extent);
std::string to_upper(const std::string& input)
More information about the Liblas-commits
