[Liblas-commits] hg-main-tree: LASzip's version has increased to 1.2.0, this mean...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Apr 12 12:41:29 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/d294fc2ebc06
changeset: 534:d294fc2ebc06
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Apr 12 11:37:23 2011 -0500
description:
LASzip's version has increased to 1.2.0, this means updating the test file
Subject: hg-main-tree: move connection to the database at construction time
details:   http://hg.libpc.orghg-main-tree/rev/e46a731703a0
changeset: 535:e46a731703a0
date:      Tue Apr 12 11:38:01 2011 -0500
description:
Subject: hg-main-tree: convenience function to fetch the connection
details:   http://hg.libpc.orghg-main-tree/rev/feb2da09eb36
changeset: 536:feb2da09eb36
date:      Tue Apr 12 11:38:15 2011 -0500
description:
Subject: hg-main-tree: reset the point count to 0 for each readBuffer call
details:   http://hg.libpc.orghg-main-tree/rev/c365c4cee374
changeset: 537:c365c4cee374
date:      Tue Apr 12 11:38:38 2011 -0500
description:
Subject: hg-main-tree: hop out of readImpl before resetting the buffer's count to 0
details:   http://hg.libpc.orghg-main-tree/rev/185d4061a455
changeset: 538:185d4061a455
date:      Tue Apr 12 11:40:43 2011 -0500
description:
Subject: hg-main-tree: lint and operator precedence
details:   http://hg.libpc.orghg-main-tree/rev/cc3eea665e99
changeset: 539:cc3eea665e99
date:      Tue Apr 12 11:41:08 2011 -0500
description:
Subject: hg-main-tree: Start on an OCI test case
details:   http://hg.libpc.orghg-main-tree/rev/2ec6ae0b42f6
changeset: 540:2ec6ae0b42f6
date:      Tue Apr 12 11:41:18 2011 -0500
description:
diffstat:
 include/libpc/drivers/oci/Writer.hpp |    2 +
 src/drivers/oci/Iterator.cpp         |    6 +-
 src/drivers/oci/Writer.cpp           |    7 +-
 src/filters/ChipperIterator.cpp      |    7 +-
 test/data/simple.laz                 |    0
 test/unit/CMakeLists.txt             |   54 +++++++-----
 test/unit/OCITest.cpp                |  149 +++++++++++++++++++++++++++++++++++
 test/unit/support.cpp                |    6 +-
 test/unit/support.hpp                |    1 +
 9 files changed, 201 insertions(+), 31 deletions(-)
diffs (truncated from 336 to 300 lines):
diff -r d7d228219024 -r 2ec6ae0b42f6 include/libpc/drivers/oci/Writer.hpp
--- a/include/libpc/drivers/oci/Writer.hpp	Mon Apr 11 16:30:25 2011 -0500
+++ b/include/libpc/drivers/oci/Writer.hpp	Tue Apr 12 11:41:18 2011 -0500
@@ -61,6 +61,8 @@
     void run(std::ostringstream const& command);
     inline void setBounds(libpc::Bounds<double> bounds) {m_bounds = bounds; }
     inline libpc::Bounds<double>  getBounds() const { return m_bounds; }
+    inline Connection getConnection() const { return m_connection;}
 protected:
     // this is called once before the loop with the writeBuffer calls
     virtual void writeBegin();
diff -r d7d228219024 -r 2ec6ae0b42f6 src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp	Mon Apr 11 16:30:25 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp	Tue Apr 12 11:41:18 2011 -0500
@@ -181,6 +181,10 @@
     // if (getReader().isVerbose())
     //     std::cout << " Existing block has " << m_block->num_points << " points" << std::endl;
+    // should have 37427853
+    // we have 49898796
+    // capacity is 5000  num blocks = 7488
     if (!m_block->num_points)
         // We still have a block of data from the last readBuffer call
@@ -206,7 +210,7 @@
     while (bDidRead)
         boost::uint32_t numReadThisBlock = m_block->num_points;
-        if (numPointsRead + numReadThisBlock > (data.getCapacity() - data.getNumPoints()))
+        if ((numPointsRead + numReadThisBlock) > (data.getCapacity() - data.getNumPoints()))
             // We're done.  We still have more data, but the
             // user is going to have to request another buffer.
diff -r d7d228219024 -r 2ec6ae0b42f6 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Mon Apr 11 16:30:25 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Tue Apr 12 11:41:18 2011 -0500
@@ -52,6 +52,9 @@
     , m_doCreateIndex(false)
+    Debug();
+    m_connection = Connect(m_options);
     return;
@@ -599,9 +602,7 @@
     // Set up debugging info
-    Debug();
-    m_connection = Connect(m_options);
     if (m_options.GetPTree().get<bool>("overwrite"))
diff -r d7d228219024 -r 2ec6ae0b42f6 src/filters/ChipperIterator.cpp
--- a/src/filters/ChipperIterator.cpp	Mon Apr 11 16:30:25 2011 -0500
+++ b/src/filters/ChipperIterator.cpp	Tue Apr 12 11:41:18 2011 -0500
@@ -60,13 +60,12 @@
     // We will read from our previous stage until we get that amount (or
     // until the previous stage runs out of points).
-    assert(buffer.getNumPoints() == 0);
     if (m_currentBlockId == m_chipper.GetBlockCount())
         return 0; // we're done.
+    buffer.setNumPoints(0);
     filters::chipper::Block const& block = m_chipper.GetBlock(m_currentBlockId);
     std::size_t numPointsThisBlock = block.GetIDs().size();
     m_currentPointCount = m_currentPointCount + numPointsThisBlock;
diff -r d7d228219024 -r 2ec6ae0b42f6 test/data/simple.laz
Binary file test/data/simple.laz has changed
diff -r d7d228219024 -r 2ec6ae0b42f6 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt	Mon Apr 11 16:30:25 2011 -0500
+++ b/test/unit/CMakeLists.txt	Tue Apr 12 11:41:18 2011 -0500
@@ -8,33 +8,43 @@
 SET(LIBPC_UNIT_TEST libpc_test)
 SET(LIBPC_UNIT_TEST_SRC
-	BoundsTest.cpp
+    BoundsTest.cpp
     CacheFilterTest.cpp
-	ChipperTest.cpp
-	ColorTest.cpp
-	ColorFilterTest.cpp
-	ConfigTest.cpp
-	CropFilterTest.cpp
-	DecimationFilterTest.cpp
-	DimensionLayoutTest.cpp
-	DimensionTest.cpp
-	FauxReaderTest.cpp
-	FauxWriterTest.cpp
-	LiblasReaderTest.cpp
-	LiblasWriterTest.cpp
-	MosaicFilterTest.cpp
-	PointBufferCacheTest.cpp
-	PointBufferTest.cpp
-	RangeTest.cpp
-	SchemaLayoutTest.cpp
-	SchemaTest.cpp
-	SignallerTest.cpp
-	UtilsTest.cpp
-	VectorTest.cpp
+    ChipperTest.cpp
+    ColorTest.cpp
+    ColorFilterTest.cpp
+    ConfigTest.cpp
+    CropFilterTest.cpp
+    DecimationFilterTest.cpp
+    DimensionLayoutTest.cpp
+    DimensionTest.cpp
+    FauxReaderTest.cpp
+    FauxWriterTest.cpp
+    LiblasReaderTest.cpp
+    LiblasWriterTest.cpp
+    MosaicFilterTest.cpp
+    PointBufferCacheTest.cpp
+    PointBufferTest.cpp
+    RangeTest.cpp
+    SchemaLayoutTest.cpp
+    SchemaTest.cpp
+    SignallerTest.cpp
+    UtilsTest.cpp
+    VectorTest.cpp
     support.cpp
     support.hpp
     main.cpp)
+if (WITH_ORACLE)
+    set(LIBPC_OCI_TEST_CPP OCITest.cpp)
+    FOREACH(file ${LIBPC_OCI_TEST_CPP})
+            SET(LIBPC_UNIT_TEST_SRC "${LIBPC_UNIT_TEST_SRC};${file}" CACHE INTERNAL "source files for test")
+    ENDFOREACH(file)
+endif (WITH_ORACLE)
 INCLUDE_DIRECTORIES(
     ../../include
diff -r d7d228219024 -r 2ec6ae0b42f6 test/unit/OCITest.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/test/unit/OCITest.cpp	Tue Apr 12 11:41:18 2011 -0500
@@ -0,0 +1,149 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+*       names of its contributors may be used to endorse or promote
+*       products derived from this software without specific prior
+*       written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include <boost/test/unit_test.hpp>
+#include <boost/cstdint.hpp>
+#include <boost/property_tree/ptree.hpp>
+#include <libpc/drivers/oci/Reader.hpp>
+#include <libpc/drivers/oci/Writer.hpp>
+#include <libpc/drivers/oci/Common.hpp>
+#include <libpc/drivers/liblas/Reader.hpp>
+#include <libpc/filters/CacheFilter.hpp>
+#include <libpc/filters/Chipper.hpp>
+#include <libpc/drivers/faux/Reader.hpp>
+#include <libpc/drivers/faux/Writer.hpp>
+#include "support.hpp"
+using namespace libpc;
+using namespace libpc::drivers::oci;
+Options GetOptions()
+    Options options;
+    boost::property_tree::ptree& tree = options.GetPTree();
+    tree.put("capacity", 333);
+    tree.put("overwrite", false);
+    tree.put("connection", TestConfig::g_oracle_connection);
+    tree.put("debug", true);
+    tree.put("verbose", true);
+    tree.put("scale.x", 0.0000001);
+    tree.put("scale.y", 0.0000001);
+    tree.put("scale.z", 0.001);
+    tree.put("block_table_name", "LIBPC_TEST_BLOCKS");
+    tree.put("base_table_name", "LIBPC_TEST_BASE");
+    tree.put("select_sql", "SELECT * FROM LIBPC_TEST_BLOCKS");
+    return options;
+void RunSQL(Connection connection, std::string sql)
+    Statement statement = Statement(connection->CreateStatement(sql.c_str()));
+    statement->Execute();
+BOOST_AUTO_TEST_SUITE(OCITest)
+BOOST_AUTO_TEST_CASE(initialize)
+    Options options = GetOptions();
+    Connection connection = Connect(options);
+    std::string base_table_name = options.GetPTree().get<std::string>("base_table_name");
+    std::string create_pc_table("CREATE TABLE " + base_table_name +" (id number, CLOUD SDO_PC, DESCRIPTION VARCHAR2(20), HEADER BLOB, BOUNDARY SDO_GEOMETRY)");
+    RunSQL(connection, create_pc_table);
+    std::string block_table_name = options.GetPTree().get<std::string>("block_table_name");
+    std::string create_block_table = "CREATE TABLE " + block_table_name + " AS SELECT * FROM MDSYS.SDO_PC_BLK_TABLE";
+    RunSQL(connection, create_block_table);
+BOOST_AUTO_TEST_CASE(test_writer)
+    libpc::drivers::liblas::LiblasReader reader(TestConfig::g_data_path +  "1.2-with-color.las");
+    boost::uint32_t capacity = GetOptions().GetPTree().get<boost::uint32_t>("capacity");
+    libpc::filters::CacheFilter cache(reader, 1, 1024);
+    libpc::filters::Chipper chipper(cache, capacity);
+    libpc::drivers::oci::Writer writer(chipper, options);
+    BOOST_CHECK_MESSAGE(writer.getConnection().get(), "Unable to connect to Oracle" );
+    writer.write(0);
+BOOST_AUTO_TEST_CASE(test_reader)
+    libpc::drivers::oci::Reader reader(options);
+    const boost::uint64_t numPoints = reader.getNumPoints();
+    libpc::drivers::faux::Writer writer(reader);
+    writer.write(0);
+BOOST_AUTO_TEST_CASE(clean_up)
+    libpc::drivers::oci::Options options = GetOptions();
+    std::string drop_base_table = "DROP TABLE " + base_table_name;
+    std::string drop_block_table = "DROP TABLE " + block_table_name;
+    RunSQL(connection, drop_base_table);
+    RunSQL(connection, drop_block_table);
More information about the Liblas-commits mailing list
