[Liblas-commits] hg-main-tree: remove extra writing of buffer
overrun data
liblas-commits at liblas.org
Tue Apr 12 16:11:52 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/2b9203550cf5
changeset: 546:2b9203550cf5
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Apr 12 15:11:31 2011 -0500
description:
remove extra writing of buffer overrun data
diffstat:
src/drivers/oci/Iterator.cpp | 9 +--------
1 files changed, 1 insertions(+), 8 deletions(-)
diffs (26 lines):
diff -r 72d80c69e12e -r 2b9203550cf5 src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp Tue Apr 12 14:30:30 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp Tue Apr 12 15:11:31 2011 -0500
@@ -178,13 +178,7 @@
bool bDidRead = false;
- // if (getReader().isVerbose())
- // std::cout << " Existing block has " << m_block->num_points << " points" << std::endl;
- // should have 37427853
- // we have 49898796
- // capacity is 5000 num blocks = 7488
if (!m_block->num_points)
// We still have a block of data from the last readBuffer call
@@ -204,7 +198,6 @@
if (m_at_end) return 0;
bDidRead = true;
- unpackOracleData(data);
while (bDidRead)
More information about the Liblas-commits
