[Liblas-commits] hg: remove '
liblas-commits at liblas.org
Fri Apr 15 12:07:59 EDT 2011
details: http://hg.liblas.orghg/rev/8dc016250ac4
changeset: 2924:8dc016250ac4
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Apr 15 11:07:52 2011 -0500
description:
remove '
diffstat:
schemas/las.xml | 2 +-
1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r b702e41a99b0 -r 8dc016250ac4 schemas/las.xml
--- a/schemas/las.xml Sun Apr 10 21:10:11 2011 -0500
+++ b/schemas/las.xml Fri Apr 15 11:07:52 2011 -0500
@@ -81,7 +81,7 @@
<pc:position>11</pc:position>
<pc:size>1</pc:size>
<pc:name>User Data</pc:name>
- <pc:description>This field may be used at the user's discretion</pc:description>
+ <pc:description>This field may be used at the users discretion</pc:description>
<pc:active>false</pc:active>
</pc:dimension>
<pc:dimension>
More information about the Liblas-commits
