[Liblas-commits] hg-main-tree: refactoring support functions
liblas-commits at liblas.org
Fri Apr 15 17:14:37 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/ad5cad8c99ab
changeset: 572:ad5cad8c99ab
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Apr 15 14:00:25 2011 -0700
description:
Subject: hg-main-tree: added IDE grouping
details: http://hg.libpc.orghg-main-tree/rev/04d4c9344434
changeset: 573:04d4c9344434
date: Fri Apr 15 14:14:19 2011 -0700
description:
added IDE grouping
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/a21269125167
changeset: 574:a21269125167
date: Fri Apr 15 14:14:28 2011 -0700
description:
merge
diffstat:
include/libpc/drivers/oci/Schema.hpp | 72 +++++++++++++
src/CMakeLists.txt | 5 +-
src/drivers/oci/Schema.cpp | 61 +++++++++++
test/unit/CMakeLists.txt | 45 +++++++-
test/unit/ChipperTest.cpp | 4 +-
test/unit/LiblasReaderTest.cpp | 143 ++++++---------------------
test/unit/LiblasWriterTest.cpp | 12 +-
test/unit/OCITest.cpp | 6 +-
test/unit/Support.cpp | 181 +++++++++++++++++++++++++++++++++++
test/unit/Support.hpp | 80 +++++++++++++++
test/unit/TestConfig.cpp | 54 ++++++++++
test/unit/TestConfig.hpp | 48 +++++++++
test/unit/main.cpp | 7 +-
test/unit/support.cpp | 106 --------------------
test/unit/support.hpp | 58 -----------
15 files changed, 589 insertions(+), 293 deletions(-)
diffs (truncated from 1297 to 300 lines):
diff -r a2c06e450ba2 -r a21269125167 include/libpc/drivers/oci/Schema.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/drivers/oci/Schema.hpp Fri Apr 15 14:14:28 2011 -0700
@@ -0,0 +1,72 @@
+* Copyright (c) 2011, Howard Butler, hobu.inc at gmail.com
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_DRIVERS_OCI_SCHEMA_HPP
+#define INCLUDED_DRIVERS_OCI_SCHEMA_HPP
+#include <libpc/libpc.hpp>
+#include <libpc/drivers/oci/Common.hpp>
+#include <libpc/drivers/oci/Reader.hpp>
+#include <string>
+#include <libxml/parser.h>
+#include <libxml/xmlschemas.h>
+namespace libpc { namespace drivers { namespace oci {
+class Schema
+public:
+ Schema();
+ ~Schema();
+private:
+ Schema& operator=(const Schema&); // not implemented
+ Schema(const Schema&); // not implemented;
+} } } // namespaces
+#endif
diff -r a2c06e450ba2 -r a21269125167 src/CMakeLists.txt
--- a/src/CMakeLists.txt Fri Apr 15 14:49:00 2011 -0500
+++ b/src/CMakeLists.txt Fri Apr 15 14:14:28 2011 -0700
@@ -175,6 +175,7 @@
${LIBPC_HEADERS_DIR}/drivers/oci/Iterator.hpp
${LIBPC_HEADERS_DIR}/drivers/oci/oci_wrapper.h
${LIBPC_HEADERS_DIR}/drivers/oci/Common.hpp
+ ${LIBPC_HEADERS_DIR}/drivers/oci/Schema.hpp
set (LIBPC_DRIVERS_OCI_CPP
@@ -183,6 +184,7 @@
./drivers/oci/Reader.cpp
./drivers/oci/Iterator.cpp
./drivers/oci/Writer.cpp
+ ./drivers/oci/Schema.cpp
FOREACH(file ${LIBPC_DRIVERS_OCI_HPP})
@@ -348,7 +350,8 @@
${GEOTIFF_LIBRARY}
${GDAL_LIBRARY}
${LASZIP_LIBRARY}
- ${Boost_LIBRARIES})
+ ${Boost_LIBRARIES}
+ ${LIBXML2_LIBRARIES})
set_target_properties(${LIBPC_LIB_NAME}
diff -r a2c06e450ba2 -r a21269125167 src/drivers/oci/Schema.cpp
+++ b/src/drivers/oci/Schema.cpp Fri Apr 15 14:14:28 2011 -0700
@@ -0,0 +1,61 @@
+* OF SUCH DAMAGE.
+#include <libpc/drivers/oci/Schema.hpp>
+#include <libpc/exceptions.hpp>
+#include <libpc/Utils.hpp>
+#include <sstream>
+#include <map>
+#include <algorithm>
+Schema::Schema()
+ LIBXML_TEST_VERSION
+ return;
+Schema::~Schema()
diff -r a2c06e450ba2 -r a21269125167 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Fri Apr 15 14:49:00 2011 -0500
+++ b/test/unit/CMakeLists.txt Fri Apr 15 14:14:28 2011 -0700
@@ -7,7 +7,7 @@
SET(LIBPC_UNIT_TEST libpc_test)
-SET(LIBPC_UNIT_TEST_SRC
+SET(LIBPC_UNITTEST_TEST_SRC
BoundsTest.cpp
CacheFilterTest.cpp
ChipperTest.cpp
@@ -31,27 +31,60 @@
SignallerTest.cpp
UtilsTest.cpp
VectorTest.cpp
- support.cpp
- support.hpp
- main.cpp)
+SET(LIBPC_UNITTEST_TEST_INC
+SET(LIBPC_UNITTEST_CONFIG_SRC
+ Support.cpp
+ TestConfig.cpp
+ main.cpp
+SET(LIBPC_UNITTEST_CONFIG_INC
+ Support.hpp
+ TestConfig.hpp
if (WITH_ORACLE)
set(LIBPC_OCI_TEST_CPP OCITest.cpp)
FOREACH(file ${LIBPC_OCI_TEST_CPP})
- SET(LIBPC_UNIT_TEST_SRC "${LIBPC_UNIT_TEST_SRC};${file}" CACHE INTERNAL "source files for test")
+ SET(LIBPC_UNITTEST_TEST_SRC "${LIBPC_UNITTEST_TEST_SRC};${file}" CACHE INTERNAL "source files for test")
ENDFOREACH(file)
endif (WITH_ORACLE)
+set(LIBPC_UNITTEST_SOURCES "")
+FOREACH(file ${LIBPC_UNITTEST_TEST_SRC})
+ SET(LIBPC_UNITTEST_SOURCES "${LIBPC_UNITTEST_SOURCES};${file}" CACHE INTERNAL "source files for test")
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_UNITTEST_TEST_INC})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_UNITTEST_CONFIG_SRC})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_UNITTEST_CONFIG_INC})
+ENDFOREACH(file)
+source_group("Header Files" FILES ${LIBPC_UNITTEST_TEST_INC})
+source_group("Header Files\\config" FILES ${LIBPC_UNITTEST_CONFIG_INC})
+source_group("Source Files" FILES ${LIBPC_UNITTEST_TEST_SRC})
+source_group("Source Files\\config" FILES ${LIBPC_UNITTEST_CONFIG_SRC})
INCLUDE_DIRECTORIES(
../../include
${GDAL_INCLUDE_DIR}
${GEOTIFF_INCLUDE_DIR})
-ADD_EXECUTABLE(${LIBPC_UNIT_TEST} ${LIBPC_UNIT_TEST_SRC} )
+ADD_EXECUTABLE(${LIBPC_UNIT_TEST} ${LIBPC_UNITTEST_SOURCES})
set_target_properties(${LIBPC_UNIT_TEST} PROPERTIES COMPILE_DEFINITIONS LIBPC_DLL_IMPORT)
diff -r a2c06e450ba2 -r a21269125167 test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp Fri Apr 15 14:49:00 2011 -0500
+++ b/test/unit/ChipperTest.cpp Fri Apr 15 14:14:28 2011 -0700
@@ -39,7 +39,7 @@
#include <libpc/drivers/liblas/Writer.hpp>
#include <libpc/drivers/liblas/Reader.hpp>
-#include "support.hpp"
+#include "Support.hpp"
using namespace libpc;
using namespace libpc::drivers::liblas;
@@ -49,7 +49,7 @@
BOOST_AUTO_TEST_CASE(test_construction)
- LiblasReader reader(TestConfig::g_data_path + "1.2-with-color.las");
+ LiblasReader reader(Support::datapath("1.2-with-color.las"));
const boost::uint64_t num_points = reader.getNumPoints();
diff -r a2c06e450ba2 -r a21269125167 test/unit/LiblasReaderTest.cpp
--- a/test/unit/LiblasReaderTest.cpp Fri Apr 15 14:49:00 2011 -0500
+++ b/test/unit/LiblasReaderTest.cpp Fri Apr 15 14:14:28 2011 -0700
@@ -40,7 +40,7 @@
#include <libpc/SchemaLayout.hpp>
#include <libpc/filters/CacheFilter.hpp>
@@ -50,88 +50,9 @@
BOOST_AUTO_TEST_SUITE(LiblasReaderTest)
-#define Compare(x,y) BOOST_CHECK(Utils::compare_approx((x),(y),0.001));
-static void check_pN(const PointBuffer& data, const Schema& schema,
- size_t index,
- double xref, double yref, double zref)
- int offsetX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Int32);
- int offsetY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Int32);
- int offsetZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Int32);
- boost::int32_t x0raw = data.getField<boost::int32_t>(index, offsetX);
- boost::int32_t y0raw = data.getField<boost::int32_t>(index, offsetY);
- boost::int32_t z0raw = data.getField<boost::int32_t>(index, offsetZ);
- double x0 = schema.getDimension(offsetX).applyScaling<boost::int32_t>(x0raw);
More information about the Liblas-commits
