[Liblas-commits] hg-main-tree: fix guid writing
liblas-commits at liblas.org
Fri Apr 15 20:45:35 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/f2f593d38000
changeset: 589:f2f593d38000
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Apr 15 17:45:28 2011 -0700
description:
fix guid writing
diffstat:
src/drivers/las/LasHeaderReader.cpp | 14 ++++--
src/drivers/las/LasHeaderWriter.cpp | 24 +++++++++--
test/unit/LasWriterTest.cpp | 72 ++++++++++++++++++------------------
3 files changed, 64 insertions(+), 46 deletions(-)
diffs (154 lines):
diff -r 6b7e65622763 -r f2f593d38000 src/drivers/las/LasHeaderReader.cpp
--- a/src/drivers/las/LasHeaderReader.cpp Fri Apr 15 16:40:12 2011 -0700
+++ b/src/drivers/las/LasHeaderReader.cpp Fri Apr 15 17:45:28 2011 -0700
@@ -44,6 +44,7 @@
#include <libpc/Utils.hpp>
#include <libpc/drivers/las/Header.hpp>
+#include <boost/uuid/uuid_io.hpp>
#include <boost/concept_check.hpp> // ignore_unused_variable_warning
@@ -90,11 +91,14 @@
m_header.SetReserved(n2);
// 4-7. Project ID
- uint8_t d16[16];
- Utils::read_n(d16, m_istream, sizeof(d16));
- boost::uuids::uuid u;
- memcpy(&u, d16, 16);
- m_header.SetProjectId(u);
+ boost::uint8_t d[16];
+ Utils::read_n(d, m_istream, 16);
+ boost::uuids::uuid u;
+ for (int i=0; i<16; i++)
+ u.data[i] = d[i];
+ m_header.SetProjectId(u);
// 8. Version major
Utils::read_n(n1, m_istream, sizeof(n1));
diff -r 6b7e65622763 -r f2f593d38000 src/drivers/las/LasHeaderWriter.cpp
--- a/src/drivers/las/LasHeaderWriter.cpp Fri Apr 15 16:40:12 2011 -0700
+++ b/src/drivers/las/LasHeaderWriter.cpp Fri Apr 15 17:45:28 2011 -0700
@@ -43,6 +43,7 @@
#include "LasHeaderWriter.hpp"
namespace libpc { namespace drivers { namespace las {
@@ -183,11 +184,24 @@
// 3-6. GUID data
- uint8_t d16[16] = { 0 };
- boost::uuids::uuid g = m_header.GetProjectId();
- memcpy(d16,g.data,16);
- Utils::write_n(m_ostream, d16, 16);
+ boost::uuids::uuid u = m_header.GetProjectId();
+ // BUG: this following is to maintain compatability with the liblas driver
+ // I have no idea why I need to do this.
+ d[0] = u.data[3];
+ d[1] = u.data[2];
+ d[2] = u.data[1];
+ d[3] = u.data[0];
+ d[4] = u.data[5];
+ d[5] = u.data[4];
+ d[6] = u.data[7];
+ d[7] = u.data[6];
+ for (int i=8; i<16; i++)
+ d[i] = u.data[i];
+ Utils::write_n(m_ostream, d, 16);
// 7. Version major
n1 = m_header.GetVersionMajor();
assert(1 == n1);
diff -r 6b7e65622763 -r f2f593d38000 test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Fri Apr 15 16:40:12 2011 -0700
+++ b/test/unit/LasWriterTest.cpp Fri Apr 15 17:45:28 2011 -0700
@@ -87,42 +87,42 @@
-BOOST_AUTO_TEST_CASE(test_simple_laz)
- // remove file from earlier run, if needed
- Utils::deleteFile("temp.las");
- libpc::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
- std::ostream* ofs = Utils::createFile("temp.laz");
- const boost::uint64_t numPoints = reader.getNumPoints();
- // need to scope the writer, so that's it dtor can use the stream
- libpc::drivers::las::LasWriter writer(reader, *ofs);
- writer.setCompressed(true);
- writer.setDate(0, 0);
- writer.setPointFormat(::libpc::drivers::las::PointFormat3);
- writer.setSystemIdentifier("");
- writer.setGeneratingSoftware("TerraScan");
- writer.write(numPoints);
- Utils::closeFile(ofs);
- //bool filesSame = Support::compare_files("temp.laz", Support::datapath("simple.laz"));
- //BOOST_CHECK(filesSame);
- //if (filesSame)
- Utils::deleteFile("temp.laz");
- return;
+//BOOST_AUTO_TEST_CASE(test_simple_laz)
+// // remove file from earlier run, if needed
+// Utils::deleteFile("temp.las");
+// libpc::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
+// std::ostream* ofs = Utils::createFile("temp.laz");
+// const boost::uint64_t numPoints = reader.getNumPoints();
+// // need to scope the writer, so that's it dtor can use the stream
+// libpc::drivers::las::LasWriter writer(reader, *ofs);
+// writer.setCompressed(true);
+// writer.setDate(0, 0);
+// writer.setPointFormat(::libpc::drivers::las::PointFormat3);
+// writer.setSystemIdentifier("");
+// writer.setGeneratingSoftware("TerraScan");
+// writer.write(numPoints);
+// Utils::closeFile(ofs);
+// bool filesSame = Support::compare_files("temp.laz", Support::datapath("simple.laz"));
+// BOOST_CHECK(filesSame);
+// if (filesSame)
+// Utils::deleteFile("temp.laz");
+// return;
static void test_a_format(const std::string& refFile, boost::uint8_t majorVersion, boost::uint8_t minorVersion, int pointFormat)
More information about the Liblas-commits
