[Liblas-commits] hg-main-tree: dumb mapping of name -> Dimension::Field for now
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Apr 20 13:19:05 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/cb5d7d50690f
changeset: 602:cb5d7d50690f
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Apr 20 12:18:42 2011 -0500
description:
diffstat:
 include/libpc/drivers/oci/Schema.hpp |   2 +-
 src/drivers/oci/Schema.cpp           |  93 +++++++++++++++++++++++++++++++----
 2 files changed, 83 insertions(+), 12 deletions(-)
diffs (169 lines):
diff -r 1f15fd317a8a -r cb5d7d50690f include/libpc/drivers/oci/Schema.hpp
--- a/include/libpc/drivers/oci/Schema.hpp	Wed Apr 20 11:07:20 2011 -0500
+++ b/include/libpc/drivers/oci/Schema.hpp	Wed Apr 20 12:18:42 2011 -0500
@@ -78,7 +78,7 @@
     void LoadSchema();
     Dimension::DataType GetDimensionType(std::string const& interpretation);
-    Dimension::Field GetDimensionField(std::string const& name, position);
+    Dimension::Field GetDimensionField(std::string const& name, boost::uint32_t position);
 private:
diff -r 1f15fd317a8a -r cb5d7d50690f src/drivers/oci/Schema.cpp
--- a/src/drivers/oci/Schema.cpp	Wed Apr 20 11:07:20 2011 -0500
+++ b/src/drivers/oci/Schema.cpp	Wed Apr 20 12:18:42 2011 -0500
@@ -40,7 +40,7 @@
 #include <iostream>
 #include <list>
 #include <cstdlib>
+#include <map>
 struct XMLDocDeleter
@@ -268,7 +268,7 @@
 void Schema::LoadSchema()
-    std::list<DimensionLayout> layouts;
+    std::map<boost::uint32_t, libpc::Dimension> layouts;
     xmlDocPtr doc = static_cast<xmlDocPtr>(m_doc.get());
     xmlNode* root = xmlDocGetRootElement(doc);
@@ -287,11 +287,6 @@
             dimension = dimension->next;
             continue;
-        // if (strcasecmp((const char*)dimension->name, "dimension"))
-        //     throw schema_error("Children element of PointCloudSchema are not named 'dimension'");
         xmlNode* properties = dimension->children;
@@ -407,6 +402,12 @@
             properties = properties->next;
+        Dimension::DataType t = GetDimensionType(interpretation);
+        Dimension::Field f = GetDimensionField(name, position);
+        Dimension d(f, t);
+        layouts.insert(std::pair<boost::uint32_t, libpc::Dimension>(position, d));
@@ -437,7 +438,7 @@
     if (!strcasecmp(interpretation.c_str(), "uint8_t") ||
         !strcasecmp(interpretation.c_str(), "uint8"))
-        return Dimension::UInt8;
+        return Dimension::Uint8;
     if (!strcasecmp(interpretation.c_str(), "int16_t") ||
         !strcasecmp(interpretation.c_str(), "int16"))
@@ -445,7 +446,7 @@
     if (!strcasecmp(interpretation.c_str(), "uint16_t") ||
         !strcasecmp(interpretation.c_str(), "uint16"))
-        return Dimension::UInt16;
+        return Dimension::Uint16;
     if (!strcasecmp(interpretation.c_str(), "int32_t") ||
@@ -454,7 +455,7 @@
     if (!strcasecmp(interpretation.c_str(), "uint32_t") ||
         !strcasecmp(interpretation.c_str(), "uint32"))
-        return Dimension::UInt32;
+        return Dimension::Uint32;
     if (!strcasecmp(interpretation.c_str(), "int64_t") ||
         !strcasecmp(interpretation.c_str(), "int64"))
@@ -462,7 +463,7 @@
     if (!strcasecmp(interpretation.c_str(), "uint64_t") ||
         !strcasecmp(interpretation.c_str(), "uint64"))
-        return Dimension::UInt64;
+        return Dimension::Uint64;
     if (!strcasecmp(interpretation.c_str(), "float"))
         return Dimension::Float;
@@ -474,4 +475,74 @@
     return Dimension::Undefined;
+Dimension::Field Schema::GetDimensionField(std::string const& name, boost::uint32_t position)
+    if (name.size() == 0)
+        // Yes, this is scary.  What else can we do?  The user didn't give us a
+        // name to map to, so we'll just assume the positions are the same as
+        // our dimension positions
+        for (unsigned int i = 1; i < Dimension::Field_INVALID; ++i)
+            if (i == position)
+                return static_cast<Dimension::Field>(i);
+    if (!strcasecmp(name.c_str(), "X"))
+        return Dimension::Field_X;
+    if (!strcasecmp(name.c_str(), "Y"))
+        return Dimension::Field_Y;
+    if (!strcasecmp(name.c_str(), "Z"))
+        return Dimension::Field_Z;
+    if (!strcasecmp(name.c_str(), "Intensity"))
+        return Dimension::Field_Intensity;
+    if (!strcasecmp(name.c_str(), "Return Number"))
+        return Dimension::Field_ReturnNumber;
+    if (!strcasecmp(name.c_str(), "Number of Returns"))
+        return Dimension::Field_NumberOfReturns;
+    if (!strcasecmp(name.c_str(), "Scan Direction"))
+        return Dimension::Field_ScanDirectionFlag;
+    if (!strcasecmp(name.c_str(), "Flightline Edge"))
+        return Dimension::Field_EdgeOfFlightLine;
+    if (!strcasecmp(name.c_str(), "Classification"))
+        return Dimension::Field_Classification;
+    if (!strcasecmp(name.c_str(), "Scan Angle Rank"))
+        return Dimension::Field_ScanAngleRank;
+    if (!strcasecmp(name.c_str(), "User Data"))
+        return Dimension::Field_UserData;
+    if (!strcasecmp(name.c_str(), "Point Source ID"))
+        return Dimension::Field_PointSourceId;
+    if (!strcasecmp(name.c_str(), "Time"))
+        return Dimension::Field_Time;
+    if (!strcasecmp(name.c_str(), "Red"))
+        return Dimension::Field_Red;
+    if (!strcasecmp(name.c_str(), "Green"))
+        return Dimension::Field_Green;
+    if (!strcasecmp(name.c_str(), "Blue"))
+        return Dimension::Field_Blue;
+    return Dimension::Field_INVALID;
 } } } // namespaces
More information about the Liblas-commits mailing list
