[Liblas-commits] hg-crrel: Read the new 8-dimension full layout
that las2oci writ...
liblas-commits at liblas.org
Wed Apr 20 17:40:54 EDT 2011
details: http://hg.libpc.orghg-crrel/rev/29125c5e887b
changeset: 605:29125c5e887b
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Apr 20 13:53:53 2011 -0500
description:
Read the new 8-dimension full layout that las2oci writes... libPC doesn't write this yet, however
diffstat:
include/libpc/drivers/oci/Common.hpp | 27 +++++-
src/drivers/oci/Iterator.cpp | 61 +++++++++++-
src/drivers/oci/Reader.cpp | 166 ++++++++++++++++++++++++++++++++--
3 files changed, 230 insertions(+), 24 deletions(-)
diffs (truncated from 320 to 300 lines):
diff -r 6e8f75b35eaf -r 29125c5e887b include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp Wed Apr 20 12:32:13 2011 -0500
+++ b/include/libpc/drivers/oci/Common.hpp Wed Apr 20 13:53:53 2011 -0500
@@ -125,8 +125,31 @@
double z;
double t;
double c;
- uint32_t blk_id;
- uint32_t pc_id;
+ boost::uint32_t blk_id;
+ boost::uint32_t pc_id;
+struct EightDimensionOCI
+ double x;
+ double y;
+ double z;
+ double time;
+ double cls;
+ double intensity;
+ boost::int8_t returnNumber;
+ boost::int8_t numberOfReturns;
+ boost::int8_t scanDirFlag;
+ boost::int8_t edgeOfFlightLine;
+ boost::int8_t scanAngleRank;
+ boost::int8_t userData;
+ boost::int16_t pointSourceId;
+ boost::uint16_t red;
+ boost::uint16_t green;
+ boost::uint16_t blue;
+ boost::uint16_t alpha;
diff -r 6e8f75b35eaf -r 29125c5e887b src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp Wed Apr 20 12:32:13 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp Wed Apr 20 13:53:53 2011 -0500
@@ -121,6 +121,21 @@
const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Int32);
const int indexTime = schema.getDimensionIndex(Dimension::Field_Time, Dimension::Double);
const int indexClassification = schema.getDimensionIndex(Dimension::Field_Classification, Dimension::Uint8);
+ const int indexIntensity = schema.getDimensionIndex(Dimension::Field_Intensity, Dimension::Uint16);
+ const int indexReturnNumber = schema.getDimensionIndex(Dimension::Field_ReturnNumber, Dimension::Uint8);
+ const int indexNumberOfReturns = schema.getDimensionIndex(Dimension::Field_NumberOfReturns, Dimension::Uint8);
+ const int indexScanDirectionFlag = schema.getDimensionIndex(Dimension::Field_ScanDirectionFlag, Dimension::Uint8);
+ const int indexEdgeOfFlightLine = schema.getDimensionIndex(Dimension::Field_EdgeOfFlightLine, Dimension::Uint8);
+ const int indexScanAngleRank = schema.getDimensionIndex(Dimension::Field_ScanAngleRank, Dimension::Int8);
+ const int indexUserData = schema.getDimensionIndex(Dimension::Field_UserData, Dimension::Uint8);
+ const int indexPointSourceId = schema.getDimensionIndex(Dimension::Field_PointSourceId, Dimension::Uint16);
+ const int indexRed = schema.getDimensionIndex(Dimension::Field_Red, Dimension::Uint16);
+ const int indexGreen = schema.getDimensionIndex(Dimension::Field_Green, Dimension::Uint16);
+ const int indexBlue = schema.getDimensionIndex(Dimension::Field_Blue, Dimension::Uint16);
const Dimension& dimX = schema.getDimension(indexX);
const Dimension& dimY = schema.getDimension(indexY);
@@ -134,17 +149,33 @@
double offsety = dimY.getNumericOffset();
double offsetz = dimZ.getNumericOffset();
- FiveDimensionOCI* d;
+ EightDimensionOCI* d;
for (boost::uint32_t i = 0; i < static_cast<boost::uint32_t>(m_block->num_points); i++)
- boost::uint32_t byte_position = i*sizeof(FiveDimensionOCI);
+ boost::uint32_t byte_position = i*sizeof(EightDimensionOCI);
- d = (FiveDimensionOCI*)(&(*m_block->chunk)[byte_position]);
+ d = (EightDimensionOCI*)(&(*m_block->chunk)[byte_position]);
SWAP_BE_TO_LE(d->x);
SWAP_BE_TO_LE(d->y);
SWAP_BE_TO_LE(d->z);
- SWAP_BE_TO_LE(d->t);
- SWAP_BE_TO_LE(d->c);
+ SWAP_BE_TO_LE(d->time);
+ SWAP_BE_TO_LE(d->cls);
+ SWAP_BE_TO_LE(d->intensity);
+ SWAP_BE_TO_LE(d->returnNumber);
+ SWAP_BE_TO_LE(d->numberOfReturns);
+ SWAP_BE_TO_LE(d->scanDirFlag);
+ SWAP_BE_TO_LE(d->edgeOfFlightLine);
+ SWAP_BE_TO_LE(d->scanAngleRank);
+ SWAP_BE_TO_LE(d->userData);
+ SWAP_BE_TO_LE(d->pointSourceId);
+ SWAP_BE_TO_LE(d->red);
+ SWAP_BE_TO_LE(d->green);
+ SWAP_BE_TO_LE(d->blue);
+ SWAP_BE_TO_LE(d->alpha);
SWAP_BE_TO_LE(d->blk_id);
SWAP_BE_TO_LE(d->pc_id);
@@ -158,9 +189,23 @@
data.setField(point_position, indexY, y);
data.setField(point_position, indexZ, z);
- data.setField(point_position, indexTime, d->t);
- data.setField(point_position, indexClassification, static_cast<boost::uint8_t>(d->c));
+ data.setField(point_position, indexTime, d->time);
+ data.setField(point_position, indexClassification, static_cast<boost::uint8_t>(d->cls));
+ data.setField<boost::int16_t>(point_position, indexIntensity, static_cast<boost::int16_t>(d->intensity));
+ data.setField<boost::int8_t>(point_position, indexReturnNumber, d->returnNumber);
+ data.setField<boost::int8_t>(point_position, indexNumberOfReturns, d->numberOfReturns);
+ data.setField<boost::int8_t>(point_position, indexScanDirectionFlag, d->scanDirFlag);
+ data.setField<boost::int8_t>(point_position, indexEdgeOfFlightLine, d->edgeOfFlightLine);
+ data.setField<boost::int8_t>(point_position, indexScanAngleRank, d->scanAngleRank);
+ data.setField<boost::int8_t>(point_position, indexUserData, d->userData);
+ data.setField<boost::uint16_t>(point_position, indexPointSourceId, d->pointSourceId);
+ data.setField<boost::uint16_t>(point_position, indexRed, d->red);
+ data.setField<boost::uint16_t>(point_position, indexGreen, d->green);
+ data.setField<boost::uint16_t>(point_position, indexBlue, d->blue);
point_position++;
data.setNumPoints(point_position);
diff -r 6e8f75b35eaf -r 29125c5e887b src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp Wed Apr 20 12:32:13 2011 -0500
+++ b/src/drivers/oci/Reader.cpp Wed Apr 20 13:53:53 2011 -0500
@@ -121,9 +121,9 @@
Schema& schema = getSchemaRef();
- Dimension xDim(Dimension::Field_X, Dimension::Int32);
- Dimension yDim(Dimension::Field_Y, Dimension::Int32);
- Dimension zDim(Dimension::Field_Z, Dimension::Int32);
+ Dimension x(Dimension::Field_X, Dimension::Int32);
+ Dimension y(Dimension::Field_Y, Dimension::Int32);
+ Dimension z(Dimension::Field_Z, Dimension::Int32);
boost::property_tree::ptree tree = m_options.GetPTree();
double scalex = tree.get<double>("scale.x");
@@ -134,19 +134,155 @@
double offsety = tree.get<double>("offset.y");
double offsetz = tree.get<double>("offset.z");
- xDim.setNumericScale(scalex);
- yDim.setNumericScale(scaley);
- zDim.setNumericScale(scalez);
- xDim.setNumericOffset(offsetx);
- yDim.setNumericOffset(offsety);
- zDim.setNumericOffset(offsetz);
+ x.setNumericScale(scalex);
+ y.setNumericScale(scaley);
+ z.setNumericScale(scalez);
+ x.setNumericOffset(offsetx);
+ y.setNumericOffset(offsety);
+ z.setNumericOffset(offsetz);
- schema.addDimension(xDim);
- schema.addDimension(yDim);
- schema.addDimension(zDim);
- schema.addDimension(Dimension(Dimension::Field_Time, Dimension::Double));
- schema.addDimension(Dimension(Dimension::Field_Classification, Dimension::Uint8));
+ std::ostringstream text;
+ text << "x coordinate as a long integer. You must use the scale and "
+ << "offset information of the header to determine the double value.";
+ x.setDescription(text.str());
+ schema.addDimension(x);
+ text.str("");
+ text << "y coordinate as a long integer. You must use the scale and "
+ y.setDescription(text.str());
+ schema.addDimension(y);
+ text.str("");
+ text << "z coordinate as a long integer. You must use the scale and "
+ z.setDescription(text.str());
+ schema.addDimension(z);
+ text.str("");
+ Dimension intensity(Dimension::Field_Intensity, Dimension::Uint16);
+ text << "The intensity value is the integer representation of the pulse "
+ "return magnitude. This value is optional and system specific. "
+ "However, it should always be included if available.";
+ intensity.setDescription(text.str());
+ schema.addDimension(intensity);
+ text.str("");
+ Dimension return_no(Dimension::Field_ReturnNumber, Dimension::Uint8); // 3 bits only
+ text << "Return Number: The Return Number is the pulse return number for "
+ "a given output pulse. A given output laser pulse can have many "
+ "returns, and they must be marked in sequence of return. The first "
+ "return will have a Return Number of one, the second a Return "
+ "Number of two, and so on up to five returns.";
+ return_no.setDescription(text.str());
+ schema.addDimension(return_no);
+ text.str("");
+ Dimension no_returns(Dimension::Field_NumberOfReturns, Dimension::Uint8); // 3 bits only
+ text << "Number of Returns (for this emitted pulse): The Number of Returns "
+ "is the total number of returns for a given pulse. For example, "
+ "a laser data point may be return two (Return Number) within a "
+ "total number of five returns.";
+ no_returns.setDescription(text.str());
+ schema.addDimension(no_returns);
+ text.str("");
+ Dimension scan_dir(Dimension::Field_ScanDirectionFlag, Dimension::Uint8); // 1 bit only
+ text << "The Scan Direction Flag denotes the direction at which the "
+ "scanner mirror was traveling at the time of the output pulse. "
+ "A bit value of 1 is a positive scan direction, and a bit value "
+ "of 0 is a negative scan direction (where positive scan direction "
+ "is a scan moving from the left side of the in-track direction to "
+ "the right side and negative the opposite). ";
+ scan_dir.setDescription(text.str());
+ schema.addDimension(scan_dir);
+ text.str("");
+ Dimension edge(Dimension::Field_EdgeOfFlightLine, Dimension::Uint8); // 1 bit only
+ text << "The Edge of Flight Line data bit has a value of 1 only when "
+ "the point is at the end of a scan. It is the last point on "
+ "a given scan line before it changes direction.";
+ edge.setDescription(text.str());
+ schema.addDimension(edge);
+ text.str("");
+ Dimension classification(Dimension::Field_Classification, Dimension::Uint8);
+ text << "Classification in LAS 1.0 was essentially user defined and optional. "
+ "LAS 1.1 defines a standard set of ASPRS classifications. In addition, "
+ "the field is now mandatory. If a point has never been classified, this "
+ "byte must be set to zero. There are no user defined classes since "
+ "both point format 0 and point format 1 supply 8 bits per point for "
+ "user defined operations. Note that the format for classification is a "
+ "bit encoded field with the lower five bits used for class and the "
+ "three high bits used for flags.";
+ classification.setDescription(text.str());
+ schema.addDimension(classification);
+ text.str("");
+ Dimension scan_angle(Dimension::Field_ScanAngleRank, Dimension::Int8);
+ text << "The Scan Angle Rank is a signed one-byte number with a "
+ "valid range from -90 to +90. The Scan Angle Rank is the "
+ "angle (rounded to the nearest integer in the absolute "
+ "value sense) at which the laser point was output from the "
+ "laser system including the roll of the aircraft. The scan "
+ "angle is within 1 degree of accuracy from +90 to ñ90 degrees. "
+ "The scan angle is an angle based on 0 degrees being nadir, "
+ "and ñ90 degrees to the left side of the aircraft in the "
+ "direction of flight.";
+ scan_angle.setDescription(text.str());
+ schema.addDimension(scan_angle);
+ text.str("");
+ Dimension user_data(Dimension::Field_UserData, Dimension::Uint8);
+ text << "This field may be used at the userÃs discretion";
+ user_data.setDescription(text.str());
+ schema.addDimension(user_data);
+ text.str("");
+ Dimension point_source_id(Dimension::Field_PointSourceId, Dimension::Uint16);
+ text << "This value indicates the file from which this point originated. "
+ "Valid values for this field are 1 to 65,535 inclusive with zero "
+ "being used for a special case discussed below. The numerical value "
+ "corresponds to the File Source ID from which this point originated. "
+ "Zero is reserved as a convenience to system implementers. A Point "
+ "Source ID of zero implies that this point originated in this file. "
+ "This implies that processing software should set the Point Source "
+ "ID equal to the File Source ID of the file containing this point "
+ "at some time during processing. ";
+ point_source_id.setDescription(text.str());
+ schema.addDimension(point_source_id);
+ text.str("");
+ Dimension t(Dimension::Field_Time, Dimension::Double);
+ text << "The GPS Time is the double floating point time tag value at "
+ "which the point was acquired. It is GPS Week Time if the "
+ "Global Encoding low bit is clear and Adjusted Standard GPS "
+ "Time if the Global Encoding low bit is set (see Global Encoding "
+ "in the Public Header Block description).";
+ t.setDescription(text.str());
+ schema.addDimension(t);
+ text.str("");
+ Dimension red(Dimension::Field_Red, Dimension::Uint16);
+ text << "The red image channel value associated with this point";
+ red.setDescription(text.str());
+ schema.addDimension(red);
+ text.str("");
+ Dimension green(Dimension::Field_Green, Dimension::Uint16);
+ text << "The green image channel value associated with this point";
+ green.setDescription(text.str());
+ schema.addDimension(green);
More information about the Liblas-commits
