[Liblas-commits] hg-main-tree: vs2010 fix
liblas-commits at liblas.org
Thu Apr 21 12:58:53 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/5213399a1889
changeset: 607:5213399a1889
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Apr 21 09:58:37 2011 -0700
description:
vs2010 fix
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/cb3c36807a97
changeset: 608:cb3c36807a97
date: Thu Apr 21 09:58:49 2011 -0700
description:
merge
diffstat:
apps/pc2pc.cpp | 2 +-
src/drivers/oci/Schema.cpp | 95 ++++++++++++++++++++++++---------------------
2 files changed, 51 insertions(+), 46 deletions(-)
diffs (251 lines):
diff -r 29125c5e887b -r cb3c36807a97 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Wed Apr 20 13:53:53 2011 -0500
+++ b/apps/pc2pc.cpp Thu Apr 21 09:58:49 2011 -0700
@@ -136,7 +136,7 @@
boost::uint32_t capacity = 10000;
tree.put("capacity", capacity);
- tree.put("overwrite", true);
+ tree.put("overwrite", false);
tree.put("connection", "lidar/lidar at oracle.hobu.biz/orcl");
// tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
tree.put("debug", true);
diff -r 29125c5e887b -r cb3c36807a97 src/drivers/oci/Schema.cpp
--- a/src/drivers/oci/Schema.cpp Wed Apr 20 13:53:53 2011 -0500
+++ b/src/drivers/oci/Schema.cpp Thu Apr 21 09:58:49 2011 -0700
@@ -42,6 +42,11 @@
#include <cstdlib>
#include <map>
+#ifdef LIBPC_COMPILER_MSVC
+#pragma warning(disable:4996) // "strcmpi is deprecated"
+#endif
struct XMLDocDeleter
template <typename T>
@@ -275,7 +280,7 @@
// print_element_names(root);
- if (strcasecmp((const char*)root->name, "PointCloudSchema"))
+ if (strcmpi((const char*)root->name, "PointCloudSchema"))
throw schema_error("First node of document was not named 'PointCloudSchema'");
xmlNode* dimension = root->children;
@@ -308,7 +313,7 @@
continue;
- if (!strcasecmp((const char*)properties->name, "name"))
+ if (!strcmpi((const char*)properties->name, "name"))
xmlChar* n = xmlNodeListGetString(doc, properties->children, 1);
if (!n) throw schema_error("Unable to fetch name!");
@@ -317,7 +322,7 @@
std::cout << "Dimension name: " << name << std::endl;
- if (!strcasecmp((const char*)properties->name, "size"))
+ if (!strcmpi((const char*)properties->name, "size"))
if (!n) throw schema_error("Unable to fetch size!");
@@ -331,7 +336,7 @@
std::cout << "Dimension size: " << size << std::endl;
- if (!strcasecmp((const char*)properties->name, "position"))
+ if (!strcmpi((const char*)properties->name, "position"))
if (!n) throw schema_error("Unable to fetch position!");
@@ -344,14 +349,14 @@
position = static_cast<boost::uint32_t>(p);
std::cout << "Dimension position: " << position << std::endl;
- if (!strcasecmp((const char*)properties->name, "description"))
+ if (!strcmpi((const char*)properties->name, "description"))
if (!n) throw schema_error("Unable to fetch description!");
description = std::string((const char*)n);
xmlFree(n);
- if (!strcasecmp((const char*)properties->name, "interpretation"))
+ if (!strcmpi((const char*)properties->name, "interpretation"))
if (!n) throw schema_error("Unable to fetch interpretation!");
@@ -359,7 +364,7 @@
xmlFree(n);
- if (!strcasecmp((const char*)properties->name, "minimum"))
+ if (!strcmpi((const char*)properties->name, "minimum"))
xmlChar* n = xmlGetProp(properties, (const xmlChar*) "value");
if (!n) throw schema_error("Unable to fetch minimum value!");
@@ -369,7 +374,7 @@
std::cout << "Dimension minimum: " << minimum << std::endl;
- if (!strcasecmp((const char*)properties->name, "maximum"))
+ if (!strcmpi((const char*)properties->name, "maximum"))
if (!n) throw schema_error("Unable to fetch maximum value!");
@@ -379,7 +384,7 @@
std::cout << "Dimension maximum: " << maximum << std::endl;
- if (!strcasecmp((const char*)properties->name, "offset"))
+ if (!strcmpi((const char*)properties->name, "offset"))
if (!n) throw schema_error("Unable to fetch offset value!");
@@ -388,7 +393,7 @@
xmlFree(n);
std::cout << "Dimension offset: " << offset << std::endl;
- if (!strcasecmp((const char*)properties->name, "scale"))
+ if (!strcmpi((const char*)properties->name, "scale"))
if (!n) throw schema_error("Unable to fetch scale value!");
@@ -432,43 +437,43 @@
- if (!strcasecmp(interpretation.c_str(), "int8_t") ||
- !strcasecmp(interpretation.c_str(), "int8"))
+ if (!strcmpi(interpretation.c_str(), "int8_t") ||
+ !strcmpi(interpretation.c_str(), "int8"))
return Dimension::Int8;
- if (!strcasecmp(interpretation.c_str(), "uint8_t") ||
- !strcasecmp(interpretation.c_str(), "uint8"))
+ if (!strcmpi(interpretation.c_str(), "uint8_t") ||
+ !strcmpi(interpretation.c_str(), "uint8"))
return Dimension::Uint8;
- if (!strcasecmp(interpretation.c_str(), "int16_t") ||
- !strcasecmp(interpretation.c_str(), "int16"))
+ if (!strcmpi(interpretation.c_str(), "int16_t") ||
+ !strcmpi(interpretation.c_str(), "int16"))
return Dimension::Int16;
- if (!strcasecmp(interpretation.c_str(), "uint16_t") ||
- !strcasecmp(interpretation.c_str(), "uint16"))
+ if (!strcmpi(interpretation.c_str(), "uint16_t") ||
+ !strcmpi(interpretation.c_str(), "uint16"))
return Dimension::Uint16;
- if (!strcasecmp(interpretation.c_str(), "int32_t") ||
- !strcasecmp(interpretation.c_str(), "int32"))
+ if (!strcmpi(interpretation.c_str(), "int32_t") ||
+ !strcmpi(interpretation.c_str(), "int32"))
return Dimension::Int32;
- if (!strcasecmp(interpretation.c_str(), "uint32_t") ||
- !strcasecmp(interpretation.c_str(), "uint32"))
+ if (!strcmpi(interpretation.c_str(), "uint32_t") ||
+ !strcmpi(interpretation.c_str(), "uint32"))
return Dimension::Uint32;
- if (!strcasecmp(interpretation.c_str(), "int64_t") ||
- !strcasecmp(interpretation.c_str(), "int64"))
+ if (!strcmpi(interpretation.c_str(), "int64_t") ||
+ !strcmpi(interpretation.c_str(), "int64"))
return Dimension::Int64;
- if (!strcasecmp(interpretation.c_str(), "uint64_t") ||
- !strcasecmp(interpretation.c_str(), "uint64"))
+ if (!strcmpi(interpretation.c_str(), "uint64_t") ||
+ !strcmpi(interpretation.c_str(), "uint64"))
return Dimension::Uint64;
- if (!strcasecmp(interpretation.c_str(), "float"))
+ if (!strcmpi(interpretation.c_str(), "float"))
return Dimension::Float;
- if (!strcasecmp(interpretation.c_str(), "double"))
+ if (!strcmpi(interpretation.c_str(), "double"))
return Dimension::Double;
@@ -490,55 +495,55 @@
- if (!strcasecmp(name.c_str(), "X"))
+ if (!strcmpi(name.c_str(), "X"))
return Dimension::Field_X;
- if (!strcasecmp(name.c_str(), "Y"))
+ if (!strcmpi(name.c_str(), "Y"))
return Dimension::Field_Y;
- if (!strcasecmp(name.c_str(), "Z"))
+ if (!strcmpi(name.c_str(), "Z"))
return Dimension::Field_Z;
- if (!strcasecmp(name.c_str(), "Intensity"))
+ if (!strcmpi(name.c_str(), "Intensity"))
return Dimension::Field_Intensity;
- if (!strcasecmp(name.c_str(), "Return Number"))
+ if (!strcmpi(name.c_str(), "Return Number"))
return Dimension::Field_ReturnNumber;
- if (!strcasecmp(name.c_str(), "Number of Returns"))
+ if (!strcmpi(name.c_str(), "Number of Returns"))
return Dimension::Field_NumberOfReturns;
- if (!strcasecmp(name.c_str(), "Scan Direction"))
+ if (!strcmpi(name.c_str(), "Scan Direction"))
return Dimension::Field_ScanDirectionFlag;
- if (!strcasecmp(name.c_str(), "Flightline Edge"))
+ if (!strcmpi(name.c_str(), "Flightline Edge"))
return Dimension::Field_EdgeOfFlightLine;
- if (!strcasecmp(name.c_str(), "Classification"))
+ if (!strcmpi(name.c_str(), "Classification"))
return Dimension::Field_Classification;
- if (!strcasecmp(name.c_str(), "Scan Angle Rank"))
+ if (!strcmpi(name.c_str(), "Scan Angle Rank"))
return Dimension::Field_ScanAngleRank;
- if (!strcasecmp(name.c_str(), "User Data"))
+ if (!strcmpi(name.c_str(), "User Data"))
return Dimension::Field_UserData;
- if (!strcasecmp(name.c_str(), "Point Source ID"))
+ if (!strcmpi(name.c_str(), "Point Source ID"))
return Dimension::Field_PointSourceId;
- if (!strcasecmp(name.c_str(), "Time"))
+ if (!strcmpi(name.c_str(), "Time"))
return Dimension::Field_Time;
- if (!strcasecmp(name.c_str(), "Red"))
+ if (!strcmpi(name.c_str(), "Red"))
return Dimension::Field_Red;
- if (!strcasecmp(name.c_str(), "Green"))
+ if (!strcmpi(name.c_str(), "Green"))
return Dimension::Field_Green;
- if (!strcasecmp(name.c_str(), "Blue"))
+ if (!strcmpi(name.c_str(), "Blue"))
return Dimension::Field_Blue;
More information about the Liblas-commits
