[Liblas-commits] hg-main-tree: add VLR support to liblas reader
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Apr 21 16:04:03 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/43b6218838a2
changeset: 611:43b6218838a2
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Apr 21 13:03:56 2011 -0700
description:
diffstat:
 include/libpc/drivers/las/Reader.hpp               |   3 +-
 include/libpc/drivers/las/ReaderBase.hpp           |  64 ++++++++++++++++++++++
 include/libpc/drivers/las/VariableLengthRecord.hpp |  17 +++--
 include/libpc/drivers/liblas/Reader.hpp            |  12 +++-
 src/CMakeLists.txt                                 |   1 +
 src/drivers/las/LasHeaderReader.cpp                |   2 +-
 src/drivers/las/Reader.cpp                         |   2 +-
 src/drivers/las/VariableLengthRecord.cpp           |  18 +++--
 src/drivers/liblas/Reader.cpp                      |  50 ++++++++++++++++-
 test/unit/LiblasReaderTest.cpp                     |  10 +++
 10 files changed, 158 insertions(+), 21 deletions(-)
diffs (truncated from 373 to 300 lines):
diff -r 7115cf9d8b9b -r 43b6218838a2 include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/include/libpc/drivers/las/Reader.hpp	Thu Apr 21 13:03:56 2011 -0700
@@ -39,6 +39,7 @@
 #include <libpc/Stage.hpp>
 #include <libpc/drivers/las/Header.hpp>
+#include <libpc/drivers/las/ReaderBase.hpp>
 namespace libpc
@@ -50,7 +51,7 @@
 class LasHeader;
-class LIBPC_DLL LasReader : public Stage
+class LIBPC_DLL LasReader : public LasReaderBase
 public:
     LasReader(const std::string& filename);
diff -r 7115cf9d8b9b -r 43b6218838a2 include/libpc/drivers/las/ReaderBase.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/drivers/las/ReaderBase.hpp	Thu Apr 21 13:03:56 2011 -0700
@@ -0,0 +1,64 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+*       names of its contributors may be used to endorse or promote
+*       products derived from this software without specific prior
+*       written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_DRIVERS_LAS_READERBASE_HPP
+#define INCLUDED_DRIVERS_LAS_READERBASE_HPP
+#include <libpc/libpc.hpp>
+#include <libpc/Stage.hpp>
+namespace libpc { namespace drivers { namespace las {
+// this class gives the interfaces for the LAS-specific header data access functions -- we use
+// this to make sure that the native las and liblas readers both have the same API
+class LIBPC_DLL LasReaderBase: public Stage
+public:
+    LasReaderBase() : Stage() {}
+    virtual int getMetadataRecordCount() const = 0;
+    virtual const MetadataRecord& getMetadataRecord(int index) const = 0;
+    virtual PointFormat getPointFormat() const = 0;
+    virtual boost::uint8_t getVersionMajor() const = 0;
+    virtual boost::uint8_t getVersionMinor() const = 0;
+} } } // namespaces
+#endif
diff -r 7115cf9d8b9b -r 43b6218838a2 include/libpc/drivers/las/VariableLengthRecord.hpp
--- a/include/libpc/drivers/las/VariableLengthRecord.hpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/include/libpc/drivers/las/VariableLengthRecord.hpp	Thu Apr 21 13:03:56 2011 -0700
@@ -48,14 +48,18 @@
 public:
     // makes a local copy of the bytes buffer, which is a shared ptr among by all copes of the metadata record
-    VariableLengthRecord(boost::uint8_t userId[16],
+    VariableLengthRecord(boost::uint16_t reserved,
+                         boost::uint8_t* userId,   // always 16 bytes
                          boost::uint16_t recordId,
-                         boost::uint16_t recordLenAfterHeader,
-                         boost::uint8_t description[32],
+                         boost::uint8_t* description, // always 32 bytes
                          const boost::uint8_t* bytes, std::size_t len);
     VariableLengthRecord(const VariableLengthRecord&);
+    ~VariableLengthRecord();
-    ~VariableLengthRecord();
+    boost::uint16_t getReserved() const { return m_reserved; }
+    boost::uint8_t* getUserId() const { return (boost::uint8_t*)m_userId; }
+    boost::uint16_t getRecordId() const { return m_recordId; }
+    boost::uint8_t* getDescription() const { return (boost::uint8_t*)m_description; }
     bool operator==(const VariableLengthRecord&) const;
     VariableLengthRecord& operator=(const VariableLengthRecord&);
@@ -64,10 +68,9 @@
 private:
     boost::uint16_t m_reserved;
-    boost::uint8_t m_userId[16];
+    boost::uint8_t* m_userId; // always 16 bytes
     boost::uint16_t m_recordId;
-    boost::uint16_t m_recordLenAfterHeader;
-    boost::uint8_t m_description[32];
+    boost::uint8_t* m_description;  // always 32 bytes
diff -r 7115cf9d8b9b -r 43b6218838a2 include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/include/libpc/drivers/liblas/Reader.hpp	Thu Apr 21 13:03:56 2011 -0700
@@ -37,9 +37,11 @@
+#include <vector>
 #include <libpc/drivers/las/Support.hpp>
 // fwd decls
 namespace liblas
@@ -51,7 +53,7 @@
 class LiblasHeader;
-class LIBPC_DLL LiblasReader : public Stage
+class LIBPC_DLL LiblasReader : public libpc::drivers::las::LasReaderBase
 public:
     LiblasReader(const std::string& filename);
@@ -66,6 +68,9 @@
     boost::uint8_t getVersionMajor() const;
     boost::uint8_t getVersionMinor() const;
+    int LiblasReader::getMetadataRecordCount() const;
+    const MetadataRecord& LiblasReader::getMetadataRecord(int index) const;
     bool supportsIterator (StageIteratorType t) const
         if (t == StageIterator_Sequential ) return true;
@@ -80,6 +85,7 @@
 private:
     void processExternalHeader(::liblas::Reader& externalReader);
     void registerFields(::liblas::Reader& externalReader);
+    MetadataRecord& LiblasReader::getMetadataRecordRef(int index);
     std::string m_filename;
@@ -96,6 +102,8 @@
     ::libpc::drivers::las::PointFormat m_pointFormat;
+    std::vector<MetadataRecord> m_metadataRecords;
     LiblasReader& operator=(const LiblasReader&); // not implemented
     LiblasReader(const LiblasReader&); // not implemented
diff -r 7115cf9d8b9b -r 43b6218838a2 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Thu Apr 21 12:06:35 2011 -0700
+++ b/src/CMakeLists.txt	Thu Apr 21 13:03:56 2011 -0700
@@ -118,6 +118,7 @@
   ${LIBPC_HEADERS_DIR}/drivers/las/Header.hpp
   ${LIBPC_HEADERS_DIR}/drivers/las/Iterator.hpp
   ${LIBPC_HEADERS_DIR}/drivers/las/Reader.hpp
+  ${LIBPC_HEADERS_DIR}/drivers/las/ReaderBase.hpp
   ${LIBPC_HEADERS_DIR}/drivers/las/SummaryData.hpp
   ${LIBPC_HEADERS_DIR}/drivers/las/Support.hpp
   ${LIBPC_HEADERS_DIR}/drivers/las/Writer.hpp
diff -r 7115cf9d8b9b -r 43b6218838a2 src/drivers/las/LasHeaderReader.cpp
--- a/src/drivers/las/LasHeaderReader.cpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/src/drivers/las/LasHeaderReader.cpp	Thu Apr 21 13:03:56 2011 -0700
@@ -352,7 +352,7 @@
     boost::uint8_t* data = new boost::uint8_t[recordLenAfterHeader];
     Utils::read_n(data, m_istream, recordLenAfterHeader);
-    VariableLengthRecord vlr(userId, recordId, recordLenAfterHeader, description, data, recordLenAfterHeader);
+    VariableLengthRecord vlr(reserved, userId, recordId, description, data, recordLenAfterHeader);
     m_header.getVLRsRef().push_back(vlr);
diff -r 7115cf9d8b9b -r 43b6218838a2 src/drivers/las/Reader.cpp
--- a/src/drivers/las/Reader.cpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/src/drivers/las/Reader.cpp	Thu Apr 21 13:03:56 2011 -0700
@@ -45,7 +45,7 @@
 LasReader::LasReader(const std::string& filename)
-    : Stage()
+    : LasReaderBase()
     , m_filename(filename)
     std::istream* str = Utils::openFile(m_filename);
diff -r 7115cf9d8b9b -r 43b6218838a2 src/drivers/las/VariableLengthRecord.cpp
--- a/src/drivers/las/VariableLengthRecord.cpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/src/drivers/las/VariableLengthRecord.cpp	Thu Apr 21 13:03:56 2011 -0700
@@ -39,17 +39,18 @@
-VariableLengthRecord::VariableLengthRecord(boost::uint8_t userId[16],
+VariableLengthRecord::VariableLengthRecord(boost::uint16_t reserved,
     : MetadataRecord(bytes, len)
-    , m_reserved(0)
+    , m_reserved(reserved)
     , m_recordId(recordId)
-    , m_recordLenAfterHeader(recordLenAfterHeader)
+    m_userId = new boost::uint8_t[16];
     memcpy(m_userId, userId, 16);
+    m_description = new boost::uint8_t[32];
     memcpy(m_description, description, 32);
     return;
@@ -59,9 +60,10 @@
     : MetadataRecord(vlr)
     , m_reserved(vlr.m_reserved)
     , m_recordId(vlr.m_recordId)
-    , m_recordLenAfterHeader(vlr.m_recordLenAfterHeader)
     memcpy(m_userId, vlr.m_userId, 16);
     memcpy(m_description, vlr.m_description, 32);
     return;
@@ -69,6 +71,8 @@
 VariableLengthRecord::~VariableLengthRecord()
+    delete[] m_userId;
+    delete[] m_description;
     return;
@@ -79,7 +83,6 @@
     m_reserved = vlr.m_reserved;
     m_recordId = vlr.m_recordId;
-    m_recordLenAfterHeader = vlr.m_recordLenAfterHeader;
@@ -92,7 +95,6 @@
     if (m_reserved != vlr.m_reserved) return false;
     if (m_recordId != vlr.m_recordId) return false;
-    if (m_recordLenAfterHeader != vlr.m_recordLenAfterHeader) return false;
     for (int i=0; i<16; i++)
         if (m_userId[i] != vlr.m_userId[i]) return false;
diff -r 7115cf9d8b9b -r 43b6218838a2 src/drivers/liblas/Reader.cpp
--- a/src/drivers/liblas/Reader.cpp	Thu Apr 21 12:06:35 2011 -0700
+++ b/src/drivers/liblas/Reader.cpp	Thu Apr 21 13:03:56 2011 -0700
@@ -35,14 +35,17 @@
 #include <libpc/drivers/liblas/Reader.hpp>
 #include <liblas/factory.hpp>
+#include <liblas/variablerecord.hpp>
 #include <libpc/exceptions.hpp>
 #include <libpc/drivers/liblas/Iterator.hpp>
+#include <libpc/drivers/las/VariableLengthRecord.hpp>
 namespace libpc { namespace drivers { namespace liblas {
 LiblasReader::LiblasReader(const std::string& filename)
-    : Stage()
+    : LasReaderBase()
     , m_versionMajor(0)
     , m_versionMinor(0)
More information about the Liblas-commits mailing list
