[Liblas-commits] hg-main-tree: VLR work, start of SRS support
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Apr 21 16:41:19 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/bd73165b23f2
changeset: 612:bd73165b23f2
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Apr 21 13:41:10 2011 -0700
description:
diffstat:
 include/libpc/SpatialReference.hpp  |  236 +++++++-
 src/SpatialReference.cpp            |  934 ++++++++++++++++++++++++++++++++++-
 src/drivers/las/LasHeaderReader.cpp |   14 +-
 src/drivers/las/ZipPoint.cpp        |  111 +---
 src/drivers/las/ZipPoint.hpp        |   15 +-
 5 files changed, 1147 insertions(+), 163 deletions(-)
diffs (truncated from 1441 to 300 lines):
diff -r 43b6218838a2 -r bd73165b23f2 include/libpc/SpatialReference.hpp
--- a/include/libpc/SpatialReference.hpp	Thu Apr 21 13:03:56 2011 -0700
+++ b/include/libpc/SpatialReference.hpp	Thu Apr 21 13:41:10 2011 -0700
@@ -1,36 +1,36 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
-* All rights reserved.
-* Redistribution and use in source and binary forms, with or without
-* modification, are permitted provided that the following
-* conditions are met:
-*     * Redistributions of source code must retain the above copyright
-*       notice, this list of conditions and the following disclaimer.
-*     * Redistributions in binary form must reproduce the above copyright
-*       notice, this list of conditions and the following disclaimer in
-*       the documentation and/or other materials provided
-*       with the distribution.
-*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
-*       names of its contributors may be used to endorse or promote
-*       products derived from this software without specific prior
-*       written permission.
-* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
-* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
-* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
-* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
-* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
-* OF SUCH DAMAGE.
+ * Copyright (c) 2009, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
 #ifndef INCLUDED_SPATIALREFERENCE_HPP
 #define INCLUDED_SPATIALREFERENCE_HPP
@@ -68,3 +68,175 @@
 } // namespace libpc
 #endif
+#if 0
+#include <liblas/detail/fwd.hpp>
+#include <liblas/detail/private_utility.hpp>
+#include <liblas/variablerecord.hpp>
+#include <liblas/exception.hpp>
+#include <liblas/capi/las_config.h>
+#include <liblas/export.hpp>
+#include <liblas/external/property_tree/ptree.hpp>
+// std
+#include <stdexcept> // std::out_of_range
+#include <cstdlib> // std::size_t
+#include <string>
+// Fake out the compiler if we don't have libgeotiff includes already
+#if !defined(__geotiff_h_)
+typedef struct GTIFS *GTIF;
+#endif
+#if !defined(__geo_simpletags_h_)
+typedef struct ST_TIFFS *ST_TIFF;
+#endif
+namespace liblas {
+/// Spatial Reference System container for libLAS
+class LAS_DLL SpatialReference
+public:
+    enum WKTModeFlag
+        eHorizontalOnly = 1,
+        eCompoundOK = 2
+    enum GeoVLRType
+        eGeoTIFF = 1,
+        eOGRWKT = 2
+    /// Default constructor.
+    SpatialReference();
+    /// Destructor.
+    /// If libgeotiff is enabled, deallocates libtiff and libgeotiff objects used internally.
+    ~SpatialReference();
+    /// Constructor creating SpatialReference instance from given Variable-Length Record.
+    SpatialReference(std::vector<VariableRecord> const& vlrs);
+    /// Copy constryctor.
+    SpatialReference(SpatialReference const& other);
+    /// Assignment operator.
+    SpatialReference& operator=(SpatialReference const& rhs);
+    /// Returns a pointer to the internal GTIF*.  Only available if
+    /// you have libgeotiff linked in.
+    const GTIF* GetGTIF();
+    void SetGTIF(GTIF* pgtiff, ST_TIFF* ptiff);
+    /// Returns the OGC WKT describing Spatial Reference System.
+    /// If GDAL is linked, it uses GDAL's operations and methods to determine
+    /// the WKT.  If GDAL is not linked, no WKT is returned.
+    /// \param mode_flag May be eHorizontalOnly indicating the WKT will not
+    /// include vertical coordinate system info (the default), or
+    /// eCompoundOK indicating the the returned WKT may be a compound
+    /// coordinate system if there is vertical coordinate system info
+    /// available.
+    std::string GetWKT(WKTModeFlag mode_flag = eHorizontalOnly) const;
+    std::string GetWKT(WKTModeFlag mode_flag, bool pretty) const;
+    /// Sets the SRS using GDAL's OGC WKT. If GDAL is not linked, this
+    /// operation has no effect.
+    /// \param v - a string containing the WKT string.
+    void SetWKT(std::string const& v);
+    /// Sets the vertical coordinate system using geotiff key values.
+    /// This operation should normally be done after setting the horizontal
+    /// portion of the coordinate system with something like SetWKT(),
+    /// SetProj4(), SetGTIF() or SetFromUserInput()
+    /// \param verticalCSType - An EPSG vertical coordinate system code,
+    /// normally in the range 5600 to 5799, or -1 if one is not available.
+    /// \param citation - a textual description of the vertical coordinate
+    /// system or an empty string if nothing is available.
+    /// \param verticalDatum - the EPSG vertical datum code, often in the
+    /// range 5100 to 5299 - implied by verticalCSType if that is provided, or
+    /// -1 if no value is available.
+    /// \param verticalUnits - the EPSG vertical units code, often 9001 for Metre.
+    void SetVerticalCS(boost::int32_t verticalCSType,
+                       std::string const& citation = std::string(0),
+                       boost::int32_t verticalDatum = -1,
+                       boost::int32_t verticalUnits = 9001);
+    /// Sets the SRS using GDAL's SetFromUserInput function. If GDAL is not linked, this
+    /// \param v - a string containing the definition (filename, proj4, wkt, etc).
+    void SetFromUserInput(std::string const& v);
+    /// Returns the Proj.4 string describing the Spatial Reference System.
+    /// the Proj.4 string -- otherwise, if libgeotiff is linked, it uses
+    /// that.  Note that GDAL's operations are much more mature and
+    /// support more coordinate systems and descriptions.
+    std::string GetProj4() const;
+    /// Sets the Proj.4 string describing the Spatial Reference System.
+    /// \param v - a string containing the Proj.4 string.
+    void SetProj4(std::string const& v);
+    /// Set the LASVLRs for the SpatialReference.  SetVLRs will only copy
+    /// VLR records that pertain to the GeoTIFF keys, and extraneous
+    /// VLR records will not be copied.
+    /// \param vlrs - A list of VLRs that contains VLRs describing GeoTIFF keys
+    void SetVLRs(std::vector<VariableRecord> const& vlrs);
+    /// Add a VLR representing GeoTIFF keys to the SRS
+    void AddVLR(VariableRecord const& vlr);
+    /// Return a copy of the LASVLRs that SpatialReference maintains
+    std::vector<VariableRecord> GetVLRs() const;
+    void ClearVLRs( GeoVLRType eType );
+    liblas::property_tree::ptree GetPTree() const;
+private:
+    // FIXME: Define as shared_ptr<GTIF> with custom deleter to get rid of bloated mem management, unsafe anyway --mloskot
+    GTIF*       m_gtiff;
+    ST_TIFF*    m_tiff;
+    std::string m_wkt;
+    std::vector<VariableRecord> m_vlrs;
+    bool IsGeoVLR(VariableRecord const& vlr) const;
+    std::string GetGTIFFText() const;
+    /// Reset the VLRs of the SpatialReference using the existing GTIF* and ST_TIF*
+    /// Until this method is called,
+    /// the SpatialReference will only contain a SRS description using the VLRs
+    /// that it was first instantiated with.  SetWKT and SetProj4 can
+    /// be used to change the GTIF*
+    void ResetVLRs();
+} // namespace liblas
+LAS_C_START
+#if defined(__geotiff_h_)
+#if defined(GEO_NORMALIZE_H_INCLUDED)
+char LAS_DLL * GTIFGetOGISDefn(GTIF*, GTIFDefn*);
+#endif
+int  LAS_DLL   GTIFSetFromOGISDefn(GTIF*, const char*);
+void SetLinearUnitCitation(GTIF* psGTIF, char* pszLinearUOMName);
+#if defined(_OGR_SRS_API_H_INCLUDED)
+void SetGeogCSCitation(GTIF* psGTIF, OGRSpatialReference* poSRS, char* angUnitName, int nDatum, short nSpheroid);
+#endif // defined _OGR_SRS_API_H_INCLUDED
+#endif // defined __geotiff_h_
+LAS_C_END
+#endif
diff -r 43b6218838a2 -r bd73165b23f2 src/SpatialReference.cpp
--- a/src/SpatialReference.cpp	Thu Apr 21 13:03:56 2011 -0700
+++ b/src/SpatialReference.cpp	Thu Apr 21 13:41:10 2011 -0700
@@ -1,36 +1,36 @@
-* OF SUCH DAMAGE.
More information about the Liblas-commits mailing list
