[Liblas-commits] hg-main-tree: add new defn for compare_no_case
liblas-commits at liblas.org
Fri Apr 22 10:53:02 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/f62cecc435a9
changeset: 615:f62cecc435a9
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Apr 22 09:52:48 2011 -0500
description:
Subject: hg-main-tree: remove extra qualifications
details: http://hg.libpc.orghg-main-tree/rev/612558fc3c34
changeset: 616:612558fc3c34
date: Fri Apr 22 09:52:55 2011 -0500
description:
diffstat:
include/libpc/drivers/liblas/Reader.hpp | 6 +-
include/libpc/drivers/oci/Common.hpp | 7 +-
src/drivers/oci/Reader.cpp | 24 ++++----
src/drivers/oci/Schema.cpp | 94 +++++++++++++++-----------------
src/drivers/oci/Writer.cpp | 4 +-
5 files changed, 67 insertions(+), 68 deletions(-)
diffs (truncated from 373 to 300 lines):
diff -r 61902169d63b -r 612558fc3c34 include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp Thu Apr 21 14:28:58 2011 -0700
+++ b/include/libpc/drivers/liblas/Reader.hpp Fri Apr 22 09:52:55 2011 -0500
@@ -68,8 +68,8 @@
boost::uint8_t getVersionMajor() const;
boost::uint8_t getVersionMinor() const;
- int LiblasReader::getMetadataRecordCount() const;
- const MetadataRecord& LiblasReader::getMetadataRecord(int index) const;
+ int getMetadataRecordCount() const;
+ const MetadataRecord& getMetadataRecord(int index) const;
bool supportsIterator (StageIteratorType t) const
@@ -85,7 +85,7 @@
private:
void processExternalHeader(::liblas::Reader& externalReader);
void registerFields(::liblas::Reader& externalReader);
- MetadataRecord& LiblasReader::getMetadataRecordRef(int index);
+ MetadataRecord& getMetadataRecordRef(int index);
std::string m_filename;
diff -r 61902169d63b -r 612558fc3c34 include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp Thu Apr 21 14:28:58 2011 -0700
+++ b/include/libpc/drivers/oci/Common.hpp Fri Apr 22 09:52:55 2011 -0500
@@ -113,9 +113,12 @@
#ifdef LIBPC_COMPILER_MSVC
-#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#define compare_no_case_n(a,b,n) _strnicmp( (a), (b), (n) )
+#define compare_no_case(a, b) _stricmp( (a), (b) )
#else
-#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#define compare_no_case_n(a,b,n) strncasecmp( (a), (b), (n) )
+#define compare_no_case(a, b) strcasecmp( (a), (b) )
#endif
struct FiveDimensionOCI
diff -r 61902169d63b -r 612558fc3c34 src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp Thu Apr 21 14:28:58 2011 -0700
+++ b/src/drivers/oci/Reader.cpp Fri Apr 22 09:52:55 2011 -0500
@@ -354,9 +354,9 @@
if ( hType == SQLT_NTY)
- if (compare_no_case(szTypeName, "SDO_PC", 6) == 0)
+ if (compare_no_case(szTypeName, "SDO_PC") == 0)
isPCObject = true;
- if (compare_no_case(szTypeName, "SDO_PC_BLK_TYPE", 6) == 0)
+ if (compare_no_case(szTypeName, "SDO_PC_BLK_TYPE") == 0)
isBlockTableType = true;
std::cout << "Field " << szFieldName << " is SQLT_NTY with type name " << szTypeName << std::endl;
@@ -437,52 +437,52 @@
std::string name = to_upper(std::string(szFieldName));
- if (compare_no_case(szFieldName, "OBJ_ID", 6) == 0)
+ if (compare_no_case(szFieldName, "OBJ_ID") == 0)
m_statement->Define(&(block->obj_id));
- if (compare_no_case(szFieldName, "BLK_ID", 6) == 0)
+ if (compare_no_case(szFieldName, "BLK_ID") == 0)
m_statement->Define(&(block->blk_id));
- if (compare_no_case(szFieldName, "BLK_EXTENT", 10) == 0)
+ if (compare_no_case(szFieldName, "BLK_EXTENT") == 0)
m_statement->Define(&(block->blk_extent));
- if (compare_no_case(szFieldName, "BLK_DOMAIN", 10) == 0)
+ if (compare_no_case(szFieldName, "BLK_DOMAIN") == 0)
m_statement->Define(&(block->blk_domain));
- if (compare_no_case(szFieldName, "PCBLK_MIN_RES", 13) == 0)
+ if (compare_no_case(szFieldName, "PCBLK_MIN_RES") == 0)
m_statement->Define(&(block->pcblk_min_res));
- if (compare_no_case(szFieldName, "PCBLK_MAX_RES", 13) == 0)
+ if (compare_no_case(szFieldName, "PCBLK_MAX_RES") == 0)
m_statement->Define(&(block->pcblk_max_res));
- if (compare_no_case(szFieldName, "NUM_POINTS", 10) == 0)
+ if (compare_no_case(szFieldName, "NUM_POINTS") == 0)
m_statement->Define(&(block->num_points));
- if (compare_no_case(szFieldName, "NUM_UNSORTED_POINTS", 19) == 0)
+ if (compare_no_case(szFieldName, "NUM_UNSORTED_POINTS") == 0)
m_statement->Define(&(block->num_unsorted_points));
- if (compare_no_case(szFieldName, "PT_SORT_DIM", 11) == 0)
+ if (compare_no_case(szFieldName, "PT_SORT_DIM") == 0)
m_statement->Define(&(block->pt_sort_dim));
- if (compare_no_case(szFieldName, "POINTS", 6) == 0)
+ if (compare_no_case(szFieldName, "POINTS") == 0)
std::cout << "Defined POINTS as BLOB" << std::endl;
m_statement->Define( &(block->locator) );
diff -r 61902169d63b -r 612558fc3c34 src/drivers/oci/Schema.cpp
--- a/src/drivers/oci/Schema.cpp Thu Apr 21 14:28:58 2011 -0700
+++ b/src/drivers/oci/Schema.cpp Fri Apr 22 09:52:55 2011 -0500
@@ -44,10 +44,6 @@
#include <string.h>
-#ifdef LIBPC_COMPILER_MSVC
-#pragma warning(disable:4996) // "strcmpi is deprecated"
-#endif
struct XMLDocDeleter
@@ -282,7 +278,7 @@
// print_element_names(root);
- if (strcmpi((const char*)root->name, "PointCloudSchema"))
+ if (compare_no_case((const char*)root->name, "PointCloudSchema"))
throw schema_error("First node of document was not named 'PointCloudSchema'");
xmlNode* dimension = root->children;
@@ -315,7 +311,7 @@
continue;
- if (!strcmpi((const char*)properties->name, "name"))
+ if (!compare_no_case((const char*)properties->name, "name"))
xmlChar* n = xmlNodeListGetString(doc, properties->children, 1);
if (!n) throw schema_error("Unable to fetch name!");
@@ -324,7 +320,7 @@
std::cout << "Dimension name: " << name << std::endl;
- if (!strcmpi((const char*)properties->name, "size"))
+ if (!compare_no_case((const char*)properties->name, "size"))
if (!n) throw schema_error("Unable to fetch size!");
@@ -338,7 +334,7 @@
std::cout << "Dimension size: " << size << std::endl;
- if (!strcmpi((const char*)properties->name, "position"))
+ if (!compare_no_case((const char*)properties->name, "position"))
if (!n) throw schema_error("Unable to fetch position!");
@@ -351,14 +347,14 @@
position = static_cast<boost::uint32_t>(p);
std::cout << "Dimension position: " << position << std::endl;
- if (!strcmpi((const char*)properties->name, "description"))
+ if (!compare_no_case((const char*)properties->name, "description"))
if (!n) throw schema_error("Unable to fetch description!");
description = std::string((const char*)n);
xmlFree(n);
- if (!strcmpi((const char*)properties->name, "interpretation"))
+ if (!compare_no_case((const char*)properties->name, "interpretation"))
if (!n) throw schema_error("Unable to fetch interpretation!");
@@ -366,7 +362,7 @@
xmlFree(n);
- if (!strcmpi((const char*)properties->name, "minimum"))
+ if (!compare_no_case((const char*)properties->name, "minimum"))
xmlChar* n = xmlGetProp(properties, (const xmlChar*) "value");
if (!n) throw schema_error("Unable to fetch minimum value!");
@@ -376,7 +372,7 @@
std::cout << "Dimension minimum: " << minimum << std::endl;
- if (!strcmpi((const char*)properties->name, "maximum"))
+ if (!compare_no_case((const char*)properties->name, "maximum"))
if (!n) throw schema_error("Unable to fetch maximum value!");
@@ -386,7 +382,7 @@
std::cout << "Dimension maximum: " << maximum << std::endl;
- if (!strcmpi((const char*)properties->name, "offset"))
+ if (!compare_no_case((const char*)properties->name, "offset"))
if (!n) throw schema_error("Unable to fetch offset value!");
@@ -395,7 +391,7 @@
xmlFree(n);
std::cout << "Dimension offset: " << offset << std::endl;
- if (!strcmpi((const char*)properties->name, "scale"))
+ if (!compare_no_case((const char*)properties->name, "scale"))
if (!n) throw schema_error("Unable to fetch scale value!");
@@ -439,43 +435,43 @@
- if (!strcmpi(interpretation.c_str(), "int8_t") ||
- !strcmpi(interpretation.c_str(), "int8"))
+ if (!compare_no_case(interpretation.c_str(), "int8_t") ||
+ !compare_no_case(interpretation.c_str(), "int8"))
return Dimension::Int8;
- if (!strcmpi(interpretation.c_str(), "uint8_t") ||
- !strcmpi(interpretation.c_str(), "uint8"))
+ if (!compare_no_case(interpretation.c_str(), "uint8_t") ||
+ !compare_no_case(interpretation.c_str(), "uint8"))
return Dimension::Uint8;
- if (!strcmpi(interpretation.c_str(), "int16_t") ||
- !strcmpi(interpretation.c_str(), "int16"))
+ if (!compare_no_case(interpretation.c_str(), "int16_t") ||
+ !compare_no_case(interpretation.c_str(), "int16"))
return Dimension::Int16;
- if (!strcmpi(interpretation.c_str(), "uint16_t") ||
- !strcmpi(interpretation.c_str(), "uint16"))
+ if (!compare_no_case(interpretation.c_str(), "uint16_t") ||
+ !compare_no_case(interpretation.c_str(), "uint16"))
return Dimension::Uint16;
- if (!strcmpi(interpretation.c_str(), "int32_t") ||
- !strcmpi(interpretation.c_str(), "int32"))
+ if (!compare_no_case(interpretation.c_str(), "int32_t") ||
+ !compare_no_case(interpretation.c_str(), "int32"))
return Dimension::Int32;
- if (!strcmpi(interpretation.c_str(), "uint32_t") ||
- !strcmpi(interpretation.c_str(), "uint32"))
+ if (!compare_no_case(interpretation.c_str(), "uint32_t") ||
+ !compare_no_case(interpretation.c_str(), "uint32"))
return Dimension::Uint32;
- if (!strcmpi(interpretation.c_str(), "int64_t") ||
- !strcmpi(interpretation.c_str(), "int64"))
+ if (!compare_no_case(interpretation.c_str(), "int64_t") ||
+ !compare_no_case(interpretation.c_str(), "int64"))
return Dimension::Int64;
- if (!strcmpi(interpretation.c_str(), "uint64_t") ||
- !strcmpi(interpretation.c_str(), "uint64"))
+ if (!compare_no_case(interpretation.c_str(), "uint64_t") ||
+ !compare_no_case(interpretation.c_str(), "uint64"))
return Dimension::Uint64;
- if (!strcmpi(interpretation.c_str(), "float"))
+ if (!compare_no_case(interpretation.c_str(), "float"))
return Dimension::Float;
- if (!strcmpi(interpretation.c_str(), "double"))
+ if (!compare_no_case(interpretation.c_str(), "double"))
return Dimension::Double;
@@ -497,55 +493,55 @@
- if (!strcmpi(name.c_str(), "X"))
+ if (!compare_no_case(name.c_str(), "X"))
return Dimension::Field_X;
- if (!strcmpi(name.c_str(), "Y"))
+ if (!compare_no_case(name.c_str(), "Y"))
return Dimension::Field_Y;
- if (!strcmpi(name.c_str(), "Z"))
+ if (!compare_no_case(name.c_str(), "Z"))
return Dimension::Field_Z;
More information about the Liblas-commits
