[Liblas-commits] hg-main-tree: checkpoint for srs work
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Apr 22 19:01:49 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/8eea8b1fbf27
changeset: 633:8eea8b1fbf27
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Apr 22 15:54:50 2011 -0700
description:
Subject: hg-main-tree: checkpoint for srs work
details:   http://hg.libpc.orghg-main-tree/rev/d13f2673ec17
changeset: 634:d13f2673ec17
date:      Fri Apr 22 16:01:35 2011 -0700
description:
diffstat:
 include/libpc/SpatialReference.hpp                 |   18 +-
 include/libpc/drivers/las/Header.hpp               |    6 +
 include/libpc/drivers/las/Reader.hpp               |    4 +-
 include/libpc/drivers/las/VariableLengthRecord.hpp |    9 +-
 include/libpc/drivers/las/Writer.hpp               |    3 +
 src/SpatialReference.cpp                           |  439 ++++----------------
 src/drivers/las/Header.cpp                         |   11 +
 src/drivers/las/LasHeaderWriter.cpp                |   64 +-
 src/drivers/las/LasHeaderWriter.hpp                |    1 +
 src/drivers/las/Reader.cpp                         |   18 +-
 src/drivers/las/VariableLengthRecord.cpp           |  243 +++++++++++-
 src/drivers/las/Writer.cpp                         |   10 +
 test/unit/SpatialReferenceTest.cpp                 |  330 ++++++++------
 13 files changed, 606 insertions(+), 550 deletions(-)
diffs (truncated from 1569 to 300 lines):
diff -r 8865e3cd1f45 -r d13f2673ec17 include/libpc/SpatialReference.hpp
--- a/include/libpc/SpatialReference.hpp	Fri Apr 22 13:07:51 2011 -0700
+++ b/include/libpc/SpatialReference.hpp	Fri Apr 22 16:01:35 2011 -0700
@@ -44,6 +44,7 @@
 #endif
 #include <boost/property_tree/ptree.hpp>
+#include <boost/shared_ptr.hpp>
 #include <string>
 #include <ostream>
@@ -85,9 +86,7 @@
     /// Returns a pointer to the internal GTIF*.  Only available if
     /// you have libgeotiff linked in.
-    const GTIF* getGTIF();
-    void setGTIF(GTIF* pgtiff, ST_TIFF* ptiff);
+    void rebuildGTIFFromVLRs();
     /// Returns the OGC WKT describing Spatial Reference System.
     /// If GDAL is linked, it uses GDAL's operations and methods to determine
@@ -153,12 +152,19 @@
     int geotiff_ST_SetKey(int tag, int count, GeotiffKeyType geotiff_key_type, void *data);
     void geotiff_SetTags();
     void geotiff_ResetTags();
+    int geotiff_ST_GetKey(int tag, int *count, int *st_key_type, void **data_ptr) const;
 private:
-    // FIXME: Define as shared_ptr<GTIF> with custom deleter to get rid of bloated mem management, unsafe anyway --mloskot
-    GTIF*       m_gtiff;
-    ST_TIFF*    m_tiff;
+    class TiffStuff
+    public:
+        TiffStuff();
+        ~TiffStuff();
+        GTIF*       m_gtiff;
+        ST_TIFF*    m_tiff;
+    boost::shared_ptr<TiffStuff> m_tiffstuff;
     std::string m_wkt;
diff -r 8865e3cd1f45 -r d13f2673ec17 include/libpc/drivers/las/Header.hpp
--- a/include/libpc/drivers/las/Header.hpp	Fri Apr 22 13:07:51 2011 -0700
+++ b/include/libpc/drivers/las/Header.hpp	Fri Apr 22 16:01:35 2011 -0700
@@ -53,6 +53,7 @@
 #include <libpc/Schema.hpp>
 #include <libpc/Vector.hpp>
 #include <libpc/Bounds.hpp>
+#include <libpc/SpatialReference.hpp>
 #include <libpc/drivers/las/Support.hpp>
 #include <libpc/drivers/las/VariableLengthRecord.hpp>
@@ -338,6 +339,9 @@
     const std::vector<VariableLengthRecord>& getVLRs() const;
     std::vector<VariableLengthRecord>& getVLRsRef();
+    void setSpatialReference(const SpatialReference&);
+    const SpatialReference& getSpatialReference() const;
     //void to_rst(std::ostream& os) const;
     //void to_xml(std::ostream& os) const;
     //void to_json(std::ostream& os) const;
@@ -392,6 +396,8 @@
     std::vector<VariableLengthRecord> m_vlrs;
+    SpatialReference m_spatialReference;
     LasHeader& operator=(const LasHeader&); // nope
     LasHeader(const LasHeader&); // nope
diff -r 8865e3cd1f45 -r d13f2673ec17 include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp	Fri Apr 22 13:07:51 2011 -0700
+++ b/include/libpc/drivers/las/Reader.hpp	Fri Apr 22 16:01:35 2011 -0700
@@ -81,9 +81,9 @@
     boost::uint8_t getVersionMajor() const;
     boost::uint8_t getVersionMinor() const;
-    const SpatialReference& getSpatialReference() const;
+    boost::uint64_t getPointDataOffset() const;
-    boost::uint64_t getPointDataOffset() const;
+    const std::vector<VariableLengthRecord>& getVLRs() const;
 protected:
     const LasHeader& getLasHeader() const { return m_lasHeader; }
diff -r 8865e3cd1f45 -r d13f2673ec17 include/libpc/drivers/las/VariableLengthRecord.hpp
--- a/include/libpc/drivers/las/VariableLengthRecord.hpp	Fri Apr 22 13:07:51 2011 -0700
+++ b/include/libpc/drivers/las/VariableLengthRecord.hpp	Fri Apr 22 16:01:35 2011 -0700
@@ -66,8 +66,15 @@
     boost::uint16_t getRecordId() const { return m_recordId; }
     boost::uint8_t* getDescription() const { return (boost::uint8_t*)m_description; }
-    static void setSRS(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
+    static void setSRSFromVLRs(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
+    static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs);
     bool VariableLengthRecord::isGeoVLR() const;
+    enum GeoVLRType
+        eGeoTIFF = 1,
+        eOGRWKT = 2
+    static void clearVLRs(GeoVLRType eType, std::vector<VariableLengthRecord>& vlrs);
     bool compareUserId(const std::string& str) const;
diff -r 8865e3cd1f45 -r d13f2673ec17 include/libpc/drivers/las/Writer.hpp
--- a/include/libpc/drivers/las/Writer.hpp	Fri Apr 22 13:07:51 2011 -0700
+++ b/include/libpc/drivers/las/Writer.hpp	Fri Apr 22 16:01:35 2011 -0700
@@ -71,6 +71,8 @@
     // default false
     void setCompressed(bool);
 protected:
     // this is called once before the loop with the writeBuffer calls
     virtual void writeBegin();
@@ -89,6 +91,7 @@
     SummaryData m_summaryData;
     LASzipper* m_zipper;
     ZipPoint* m_zipPoint;
     LasWriter& operator=(const LasWriter&); // not implemented
     LasWriter(const LasWriter&); // not implemented
diff -r 8865e3cd1f45 -r d13f2673ec17 src/SpatialReference.cpp
--- a/src/SpatialReference.cpp	Fri Apr 22 13:07:51 2011 -0700
+++ b/src/SpatialReference.cpp	Fri Apr 22 16:01:35 2011 -0700
@@ -74,39 +74,12 @@
 namespace libpc
-SpatialReference::SpatialReference()
+SpatialReference::TiffStuff::TiffStuff()
     : m_gtiff(0)
     , m_tiff(0)
-    assert(0 == m_gtiff);
-    assert(0 == m_tiff);
-SpatialReference::SpatialReference(SpatialReference const& other)
-    : m_gtiff(0)
-    , m_tiff(0)
-    , m_wkt(other.m_wkt)
-    ////////////////////////////////////////////////////////////SetVLRs(other.GetVLRs());
-    getGTIF();
-SpatialReference& SpatialReference::operator=(SpatialReference const& rhs)
-    if (&rhs != this)
-        ////////////////////////////////////////////////SetVLRs(rhs.GetVLRs());
-        getGTIF();
-        m_wkt = rhs.m_wkt;
-    return *this;
-SpatialReference::~SpatialReference()
+SpatialReference::TiffStuff::~TiffStuff()
 #ifdef LIBPC_SRS_ENABLED
     if (m_gtiff != 0)
@@ -122,18 +95,41 @@
 #endif
-void SpatialReference::setGTIF(GTIF* pgtiff, ST_TIFF* ptiff)
+SpatialReference::SpatialReference()
+    : m_tiffstuff(new TiffStuff())
+    , m_wkt("")
-    m_gtiff = (GTIF*)pgtiff;
-    m_tiff = (ST_TIFF*)ptiff;
-    ////////////////////////////////////////ResetVLRs();
-    m_gtiff = 0;
-    m_tiff = 0;
+    return;
-const GTIF* SpatialReference::getGTIF()
+SpatialReference::SpatialReference(SpatialReference const& other)
+    , m_wkt(other.m_wkt)
+    rebuildGTIFFromVLRs();
+SpatialReference& SpatialReference::operator=(SpatialReference const& rhs)
+    if (&rhs != this)
+        this->m_tiffstuff = rhs.m_tiffstuff;
+        //////////////////////////////////////////////rebuildGTIFFromVLRs();
+        m_wkt = rhs.m_wkt;
+    return *this;
+SpatialReference::~SpatialReference()
+    return;
+void SpatialReference::rebuildGTIFFromVLRs()
 #ifndef LIBPC_SRS_ENABLED
     return 0;
@@ -142,78 +138,41 @@
     // If we already have m_gtiff and m_tiff, that is because we have
     // already called GetGTIF once before.  VLRs ultimately drive how the
     // SpatialReference is defined, not the GeoTIFF keys.
-    if (m_tiff != 0 )
+    if (m_tiffstuff->m_tiff != 0 )
-        ST_Destroy(m_tiff);
-        m_tiff = 0;
+        ST_Destroy(m_tiffstuff->m_tiff);
+        m_tiffstuff->m_tiff = 0;
-    if (m_gtiff != 0 )
+    if (m_tiffstuff->m_gtiff != 0 )
-        GTIFFree(m_gtiff);
-        m_gtiff = 0;
+        GTIFFree(m_tiffstuff->m_gtiff);
+        m_tiffstuff->m_gtiff = 0;
-    m_tiff = ST_Create();
-    std::string const uid("LASF_Projection");
-    ////////////// Nothing is going to happen here if we don't have any VLRs describing
-    ////////////// SRS information on the SpatialReference.
-    ////////////for (uint16_t i = 0; i < m_vlrs.size(); ++i)
-    ////////////    VariableRecord record = m_vlrs[i];
-    ////////////    std::vector<uint8_t> data = record.GetData();
-    ////////////    if (uid == record.GetUserId(true).c_str() && 34735 == record.GetRecordId())
-    ////////////        int count = data.size()/sizeof(int16_t);
-    ////////////        short *data_s = (short *) &(data[0]);
+    m_tiffstuff->m_tiff = ST_Create();
+    //////// here it used to read in the VLRs ////////
-    ////////////        // discard invalid "zero" geotags some software emits.
-    ////////////        while( count > 4
-    ////////////               && data_s[count-1] == 0
-    ////////////               && data_s[count-2] == 0
-    ////////////               && data_s[count-3] == 0
-    ////////////               && data_s[count-4] == 0 )
-    ////////////            count -= 4;
-    ////////////            data_s[3] -= 1;
-    ////////////        ST_SetKey(m_tiff, record.GetRecordId(), count, STT_SHORT, data_s);
-    ////////////    if (uid == record.GetUserId(true).c_str() && 34736 == record.GetRecordId())
-    ////////////        int count = data.size() / sizeof(double);
-    ////////////        ST_SetKey(m_tiff, record.GetRecordId(), count, STT_DOUBLE, &(data[0]));
-    ////////////    if (uid == record.GetUserId(true).c_str() && 34737 == record.GetRecordId())
-    ////////////        int count = data.size()/sizeof(uint8_t);
-    ////////////        ST_SetKey(m_tiff, record.GetRecordId(), count, STT_ASCII, &(data[0]));
-    m_gtiff = GTIFNewSimpleTags(m_tiff);
-    if (!m_gtiff)
+    m_tiffstuff->m_gtiff = GTIFNewSimpleTags(m_tiffstuff->m_tiff);
+    if (!m_tiffstuff->m_gtiff)
         throw std::runtime_error("The geotiff keys could not be read from VLR records");
-    return m_gtiff;
+    return;
 #endif
More information about the Liblas-commits mailing list
