[Liblas-commits] hg-main-tree: remove OCI-specific stuff from libpc::Options
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Apr 26 09:16:39 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/22692e3985f2
changeset: 651:22692e3985f2
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Apr 26 08:16:36 2011 -0500
description:
diffstat:
 include/libpc/Options.hpp            |   4 +-
 include/libpc/drivers/oci/Reader.hpp |   1 +
 include/libpc/drivers/oci/Writer.hpp |  10 +++-
 src/Options.cpp                      |  82 +-----------------------------------
 src/drivers/oci/Reader.cpp           |   7 ++-
 src/drivers/oci/Writer.cpp           |  41 +++++++++++++----
 src/drivers/oci/common.cpp           |  45 +------------------
 7 files changed, 51 insertions(+), 139 deletions(-)
diffs (truncated from 349 to 300 lines):
diff -r bc05bd220320 -r 22692e3985f2 include/libpc/Options.hpp
--- a/include/libpc/Options.hpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/include/libpc/Options.hpp	Tue Apr 26 08:16:36 2011 -0500
@@ -52,9 +52,7 @@
 public:
     Options();
-    bool IsDebug() const;
-    bool Is3d() const;
-    bool IsSolid() const;
     boost::property_tree::ptree& GetPTree() {return m_tree; }
     boost::property_tree::ptree const& GetPTree() const {return m_tree; }
diff -r bc05bd220320 -r 22692e3985f2 include/libpc/drivers/oci/Reader.hpp
--- a/include/libpc/drivers/oci/Reader.hpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/include/libpc/drivers/oci/Reader.hpp	Tue Apr 26 08:16:36 2011 -0500
@@ -75,6 +75,7 @@
     BlockPtr getBlock() const { return m_block; }
     std::string getQuery() const;
     bool isVerbose() const;
+    bool isDebug() const;
 private:
diff -r bc05bd220320 -r 22692e3985f2 include/libpc/drivers/oci/Writer.hpp
--- a/include/libpc/drivers/oci/Writer.hpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/include/libpc/drivers/oci/Writer.hpp	Tue Apr 26 08:16:36 2011 -0500
@@ -62,6 +62,9 @@
     inline libpc::Bounds<double>  getBounds() const { return m_bounds; }
     inline Connection getConnection() const { return m_connection;}
 protected:
     // this is called once before the loop with the writeBuffer calls
     virtual void writeBegin();
@@ -102,8 +105,13 @@
                       libpc::Bounds<double> const& extent);
     void SetElements(Statement statement,
                      OCIArray* elem_info);
+    bool isVerbose() const;
+    bool is3d() const;
+    bool isSolid() const;
     Stage& m_stage;
-    // filters::Chipper m_chipper;
     Options& m_options;
     libpc::Bounds<double> m_bounds; // Bounds of the entire point cloud
diff -r bc05bd220320 -r 22692e3985f2 src/Options.cpp
--- a/src/Options.cpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/src/Options.cpp	Tue Apr 26 08:16:36 2011 -0500
@@ -35,7 +35,7 @@
 #include <libpc/Options.hpp>
 #include <boost/concept_check.hpp> // ignore_unused_variable_warning
+#include <boost/optional.hpp>
 #include <iostream>
 #include <libpc/exceptions.hpp>
@@ -47,89 +47,9 @@
 Options::Options()
     m_tree.put("is3d", false);
-    m_tree.put("solid", false);
-    m_tree.put("overwrite", false);
-    m_tree.put("debug", false);
-    m_tree.put("verbose", false);
-    m_tree.put("srid", 4269);
-    m_tree.put("capacity", 8000);
-    m_tree.put("precision", 8);
-    m_tree.put("cloud_id", -1);
-    m_tree.put("dimensions", 5);
-    m_tree.put("connection", std::string(""));
-    m_tree.put("block_table_name", std::string("output"));
-    m_tree.put("block_table_partition_column", std::string(""));
-    m_tree.put("block_table_partition_value", boost::int32_t(0));
-    m_tree.put("base_table_name", std::string("hobu"));
-    m_tree.put("cloud_column_name", std::string("cloud"));
-    m_tree.put("header_blob_column_name", std::string(""));
-    m_tree.put("base_table_aux_columns", std::string(""));
-    m_tree.put("base_table_aux_values", std::string(""));
-    m_tree.put("base_table_boundary_column", std::string(""));
-    m_tree.put("base_table_boundary_wkt", std::string(""));
-    m_tree.put("pre_block_sql", std::string(""));
-    m_tree.put("pre_sql", std::string(""));
-    m_tree.put("post_block_sql", std::string(""));
-    m_tree.put("select_sql", std::string(""));
-    m_tree.put("base_table_bounds", libpc::Bounds<double>());
-    m_tree.put("blob_read_byte_size", boost::uint32_t(2000));
-    m_tree.put("point_schema_override", "");
-    boost::property_tree::ptree scales;
-    scales.put("x", double(0.01));
-    scales.put("y", double(0.01));
-    scales.put("z", double(0.01));
-    boost::property_tree::ptree offsets;
-    offsets.put("x", double(0.0));
-    offsets.put("y", double(0.0));
-    offsets.put("z", double(0.0));
-    m_tree.add_child("scale", scales);
-    m_tree.add_child("offset", offsets);
-bool Options::IsDebug() const
-    bool debug = false;
-    try
-        debug = m_tree.get<bool>("debug");
-    catch (boost::property_tree::ptree_bad_path const& e) {
-      ::boost::ignore_unused_variable_warning(e);
-    return debug;
-bool Options::Is3d() const
-    bool is3d = false;
-    try
-        is3d = m_tree.get<bool>("is3d");
-    return is3d;
-bool Options::IsSolid() const
-    bool IsSolid = false;
-    try
-        IsSolid = m_tree.get<bool>("solid");
-    return IsSolid;
 std::ostream& operator<<(std::ostream& ostr, const Options& /*options*/)
diff -r bc05bd220320 -r 22692e3985f2 src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/src/drivers/oci/Reader.cpp	Tue Apr 26 08:16:36 2011 -0500
@@ -88,6 +88,11 @@
     return m_options.GetPTree().get<bool>("verbose");
+bool Reader::isDebug() const
+    return m_options.GetPTree().get<bool>("debug");
 std::string Reader::getQuery() const
     return m_options.GetPTree().get<std::string>("select_sql");
@@ -95,7 +100,7 @@
 void Reader::Debug()
-    bool debug = m_options.IsDebug();
+    bool debug = isDebug();
     CPLPopErrorHandler();
diff -r bc05bd220320 -r 22692e3985f2 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Tue Apr 26 08:16:36 2011 -0500
@@ -111,7 +111,7 @@
         // if we failed, let's try dropping the spatial index for the block_table_name
         oss.str("");
-        if (m_options.IsDebug())
+        if (isDebug())
             std::cout << "Dropping index " << block_table_name
                       << "_cloud_idx for block_table_name"
                       << std::endl;
@@ -154,16 +154,37 @@
     run(oss);
+bool Writer::isVerbose() const
+    return m_options.GetPTree().get<bool>("verbose");
+bool Writer::isDebug() const
+bool Writer::is3d() const
+    return m_options.GetPTree().get<bool>("is3d");
+bool Writer::isSolid() const
+    return m_options.GetPTree().get<bool>("solid");
 void Writer::CreateBlockIndex()
     std::ostringstream oss;
     std::string block_table_name = m_options.GetPTree().get<std::string>("block_table_name");
-    bool is3d = m_options.Is3d();
+    bool bUse3d = is3d();
     oss << "CREATE INDEX "<< block_table_name << "_cloud_idx on "
         << block_table_name << "(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX";
-    if (is3d)
+    if (bUse3d)
         oss <<" PARAMETERS('sdo_indx_dims=3')";
@@ -187,7 +208,7 @@
     boost::uint32_t srid = tree.get<boost::uint32_t>("srid");
     boost::uint32_t precision = tree.get<boost::uint32_t>("precision");
-    bool bUse3d = m_options.Is3d();
@@ -370,7 +391,7 @@
+    if (isDebug())
         std::cout << "running "<< filename << " ..." <<std::endl;
     run(oss);
@@ -380,7 +401,7 @@
 long Writer::GetGType()
     boost::property_tree::ptree  tree = m_options.GetPTree();
-    bool bUse3d = tree.get<bool>("is3d");
     bool bUseSolidGeometry = tree.get<bool>("solid");
     long gtype = 0;
     if (bUse3d) {
@@ -405,7 +426,7 @@
 std::string Writer::CreatePCElemInfo()
     std::ostringstream s_eleminfo;
@@ -453,7 +474,7 @@
     boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
     boost::uint32_t dimensions = tree.get<boost::uint32_t>("dimensions");
     bool bHaveSchemaOverride = (point_schema_override.size() > 0);
@@ -792,7 +813,7 @@
     statement->AddElement(elem_info, 1);
-    bool bUseSolidGeometry = m_options.IsSolid();
+    bool bUseSolidGeometry = isSolid();
     if (bUseSolidGeometry == true) {
         //"(1,1007,3)";
         statement->AddElement(elem_info, 1007);
@@ -987,7 +1008,7 @@
 void Writer::Debug()
diff -r bc05bd220320 -r 22692e3985f2 src/drivers/oci/common.cpp
--- a/src/drivers/oci/common.cpp	Mon Apr 25 21:12:51 2011 -0500
+++ b/src/drivers/oci/common.cpp	Tue Apr 26 08:16:36 2011 -0500
@@ -92,49 +92,8 @@
More information about the Liblas-commits mailing list
