[Liblas-commits] hg-main-tree: start using our little XML thing for
OCI i/o
liblas-commits at liblas.org
Tue Apr 26 12:08:21 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/9f7ff2fde41b
changeset: 655:9f7ff2fde41b
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Apr 26 11:08:16 2011 -0500
description:
start using our little XML thing for OCI i/o
diffstat:
apps/pc2pc.cpp | 88 ++++++++++++++++++++++++++++++---------------------------
1 files changed, 46 insertions(+), 42 deletions(-)
diffs (141 lines):
diff -r f9262c35bb8a -r 9f7ff2fde41b apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Tue Apr 26 11:06:04 2011 -0500
+++ b/apps/pc2pc.cpp Tue Apr 26 11:08:16 2011 -0500
@@ -36,6 +36,8 @@
#include <libpc/drivers/oci/Reader.hpp>
#endif
+#include <boost/property_tree/xml_parser.hpp>
#include "Application.hpp"
using namespace libpc;
@@ -54,8 +56,7 @@
std::string m_inputFile;
std::string m_outputFile;
- std::string m_OracleReadSQL;
- std::string m_OracleWriteSQL;
+ std::string m_xml;
@@ -92,8 +93,9 @@
("input,i", po::value<std::string>(&m_inputFile), "input file name")
("output,o", po::value<std::string>(&m_outputFile), "output file name")
("native", "use native LAS classes (not liblas)")
- ("oracle-writer", "write data into oracle (must edit source to make this work right now)")
- ("oracle-reader", po::value<std::string>(&m_OracleReadSQL), "SQL to select a block table")
+ ("oracle-writer", "Read data from LAS file and write to Oracle")
+ ("oracle-reader", "Read data from Oracle and write LAS file")
+ ("xml", po::value<std::string>(&m_xml)->default_value("log.xml"), "XML file to load process (OCI only right now)")
addOptionSet(file_options);
@@ -130,26 +132,29 @@
libpc::drivers::liblas::LiblasReader reader(m_inputFile);
const boost::uint64_t numPoints = reader.getNumPoints();
+ boost::property_tree::ptree load_tree;
- libpc::Options options = libpc::drivers::oci::GetDefaultOptions();
+ boost::property_tree::read_xml(m_xml, load_tree);
+ boost::property_tree::ptree oracle_options = load_tree.get_child("drivers.oci.writer");
+ libpc::Options options(oracle_options);
boost::property_tree::ptree& tree = options.GetPTree();
- boost::uint32_t capacity = 10000;
- tree.put("capacity", capacity);
- tree.put("overwrite", false);
- tree.put("connection", "lidar/lidar at oracle.hobu.biz/orcl");
- // tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
- tree.put("debug", true);
- tree.put("verbose", true);
- tree.put("scale.x", 0.0000001);
- tree.put("scale.y", 0.0000001);
- tree.put("scale.z", 0.001);
+ boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
libpc::filters::CacheFilter cache(reader, 1, 1024);
libpc::filters::Chipper chipper(cache, capacity);
libpc::drivers::oci::Writer writer(chipper, options);
writer.write(numPoints);
+ boost::property_tree::ptree output_tree;
+ output_tree.put_child(writer.getName(), options.GetPTree());
+ boost::property_tree::write_xml(m_xml, output_tree);
#else
throw configuration_error("libPC not compiled with Oracle support");
#endif
@@ -157,39 +162,38 @@
else if (hasOption("oracle-reader"))
#ifdef LIBPC_HAVE_ORACLE
- boost::property_tree::ptree& tree = options.GetPTree();
- tree.put("capacity", 12);
- // tree.put("select_sql", "select * from output");
- // tree.put("select_sql", "select cloud from hobu where id = 5");
- // tree.put("select_sql", "select cloud from hobu where id = 1");
+ boost::property_tree::ptree oracle_options = load_tree.get_child("drivers.oci.reader");
+ libpc::drivers::oci::Reader reader(options);
+ const boost::uint64_t numPoints = reader.getNumPoints();
+ libpc::drivers::las::LasWriter writer(reader, *ofs);
+ // writer.setPointFormat( 3);
+ writer.write(numPoints);
+ output_tree.put_child(reader.getName(), options.GetPTree());
+ // output_tree.put_child(writer.getName(), )
- if (m_OracleReadSQL.size() == 0) {
- throw libpc_error("Select statement to read OCI data is empty!");
- tree.put("select_sql", m_OracleReadSQL);
- libpc::drivers::oci::Reader reader(options);
- const boost::uint64_t numPoints = reader.getNumPoints();
- libpc::drivers::las::LasWriter writer(reader, *ofs);
- // writer.setPointFormat( 3);
- writer.write(numPoints);
#else
#endif
else
More information about the Liblas-commits
