[Liblas-commits] hg-main-tree: add some parser helpers
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Apr 26 13:21:43 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/71a846b47171
changeset: 658:71a846b47171
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Apr 26 10:19:21 2011 -0700
description:
Subject: hg-main-tree: start of Bounds oper>> parser
details:   http://hg.libpc.orghg-main-tree/rev/9adef0eb972d
changeset: 659:9adef0eb972d
date:      Tue Apr 26 10:19:53 2011 -0700
description:
Subject: hg-main-tree: tests for Bounds, Range parsers -- currently doesn't build
details:   http://hg.libpc.orghg-main-tree/rev/6d17c3f91248
changeset: 660:6d17c3f91248
date:      Tue Apr 26 10:21:21 2011 -0700
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/fa451382042d
changeset: 661:fa451382042d
date:      Tue Apr 26 10:21:33 2011 -0700
description:
merge
diffstat:
 apps/pc2pc.cpp                  |   88 +++++++++++++------------
 include/libpc/Bounds.hpp        |    5 +
 include/libpc/Range.hpp         |    7 +-
 include/libpc/Utils.hpp         |    7 ++
 src/Bounds.cpp                  |   48 +++++++++++++-
 src/CMakeLists.txt              |    1 +
 src/Range.cpp                   |   70 ++++++++++++++++++++
 src/Utils.cpp                   |   20 +++++
 src/drivers/las/SummaryData.cpp |    2 +-
 src/drivers/oci/Writer.cpp      |  136 ++++++++++++++++++++++++++++++++++++++-
 src/drivers/oci/common.cpp      |    2 +-
 test/unit/BoundsTest.cpp        |   35 ++++++++++
 test/unit/RangeTest.cpp         |   31 +++++++-
 13 files changed, 396 insertions(+), 56 deletions(-)
diffs (truncated from 710 to 300 lines):
diff -r 5e725be08a10 -r fa451382042d apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Tue Apr 26 10:20:32 2011 -0500
+++ b/apps/pc2pc.cpp	Tue Apr 26 10:21:33 2011 -0700
@@ -36,6 +36,8 @@
 #include <libpc/drivers/oci/Reader.hpp>
 #endif
+#include <boost/property_tree/xml_parser.hpp>
 #include "Application.hpp"
 using namespace libpc;
@@ -54,8 +56,7 @@
     std::string m_inputFile;
     std::string m_outputFile;
-    std::string m_OracleReadSQL;
-    std::string m_OracleWriteSQL;
+    std::string m_xml;
@@ -92,8 +93,9 @@
         ("input,i", po::value<std::string>(&m_inputFile), "input file name")
         ("output,o", po::value<std::string>(&m_outputFile), "output file name")
         ("native", "use native LAS classes (not liblas)")
-        ("oracle-writer", "write data into oracle (must edit source to make this work right now)")
-        ("oracle-reader", po::value<std::string>(&m_OracleReadSQL), "SQL to select a block table")
+        ("oracle-writer", "Read data from LAS file and write to Oracle")
+        ("oracle-reader", "Read data from Oracle and write LAS file")
+        ("xml", po::value<std::string>(&m_xml)->default_value("log.xml"), "XML file to load process (OCI only right now)")
     addOptionSet(file_options);
@@ -130,26 +132,29 @@
         libpc::drivers::liblas::LiblasReader reader(m_inputFile);
         const boost::uint64_t numPoints = reader.getNumPoints();
+        boost::property_tree::ptree load_tree;
-        libpc::Options options = libpc::drivers::oci::GetDefaultOptions();
+        boost::property_tree::read_xml(m_xml, load_tree);
+        boost::property_tree::ptree oracle_options = load_tree.get_child("drivers.oci.writer");
+        libpc::Options options(oracle_options);
         boost::property_tree::ptree& tree = options.GetPTree();
-        boost::uint32_t capacity = 10000;
-        tree.put("capacity", capacity);
-        tree.put("overwrite", false);
-        tree.put("connection", "lidar/lidar at oracle.hobu.biz/orcl");
-        // tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
-        tree.put("debug", true);
-        tree.put("verbose", true);
-        tree.put("scale.x", 0.0000001);
-        tree.put("scale.y", 0.0000001);
-        tree.put("scale.z", 0.001);
+        boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
         libpc::filters::CacheFilter cache(reader, 1, 1024);
         libpc::filters::Chipper chipper(cache, capacity);
         libpc::drivers::oci::Writer writer(chipper, options);
         writer.write(numPoints);
+        boost::property_tree::ptree output_tree;
+        output_tree.put_child(writer.getName(), options.GetPTree());
+        boost::property_tree::write_xml(m_xml, output_tree);
 #else
         throw configuration_error("libPC not compiled with Oracle support");
 #endif
@@ -157,39 +162,38 @@
         else if (hasOption("oracle-reader"))
     #ifdef LIBPC_HAVE_ORACLE
-            boost::property_tree::ptree& tree = options.GetPTree();
-            tree.put("capacity", 12);
-            // tree.put("select_sql", "select * from output");
-            // tree.put("select_sql", "select cloud from hobu where id = 5");
-            // tree.put("select_sql", "select cloud from hobu where id = 1");
+        boost::property_tree::ptree oracle_options = load_tree.get_child("drivers.oci.reader");
+        libpc::drivers::oci::Reader reader(options);
+        const boost::uint64_t numPoints = reader.getNumPoints();
+        libpc::drivers::las::LasWriter writer(reader, *ofs);
+        // writer.setPointFormat( 3);
+        writer.write(numPoints);
+        output_tree.put_child(reader.getName(), options.GetPTree());
+        // output_tree.put_child(writer.getName(), )
-            if (m_OracleReadSQL.size() == 0) {
-                throw libpc_error("Select statement to read OCI data is empty!");
-            tree.put("select_sql", m_OracleReadSQL);
-            libpc::drivers::oci::Reader reader(options);
-            const boost::uint64_t numPoints = reader.getNumPoints();
-            libpc::drivers::las::LasWriter writer(reader, *ofs);
-            // writer.setPointFormat( 3);
-            writer.write(numPoints);
     #else
     #endif
     else
diff -r 5e725be08a10 -r fa451382042d include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp	Tue Apr 26 10:20:32 2011 -0500
+++ b/include/libpc/Bounds.hpp	Tue Apr 26 10:21:33 2011 -0700
@@ -426,6 +426,7 @@
 template<class T>
 std::ostream& operator<<(std::ostream& ostr, const Bounds<T>& bounds)
@@ -440,6 +441,10 @@
     return ostr;
+extern LIBPC_DLL std::istream& operator>>(std::istream& istr, Bounds<double>& bounds);
 } // namespace libpc
 // Needed for C++ DLL exports
diff -r 5e725be08a10 -r fa451382042d include/libpc/Range.hpp
--- a/include/libpc/Range.hpp	Tue Apr 26 10:20:32 2011 -0500
+++ b/include/libpc/Range.hpp	Tue Apr 26 10:21:33 2011 -0700
@@ -188,13 +188,18 @@
 template<class T>
 std::ostream& operator<<(std::ostream& ostr, const Range<T>& range)
-    ostr << "[" << range.getMinimum() << " .. " << range.getMaximum() << "]";
+    ostr << "[" << range.getMinimum() << " , " << range.getMaximum() << "]";
     return ostr;
+extern LIBPC_DLL std::istream& operator>>(std::istream& istr, Range<double>& range);
 #endif
diff -r 5e725be08a10 -r fa451382042d include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp	Tue Apr 26 10:20:32 2011 -0500
+++ b/include/libpc/Utils.hpp	Tue Apr 26 10:21:33 2011 -0700
@@ -152,6 +152,13 @@
     static char* getenv(const char* env);
     static int putenv(const char* env);
+    // aid to operator>> parsers
+    static void eatwhitespace(std::istream& s);
+    // if char found, eats it and returns true; otherwise, don't eat it and then return false
+    static bool eatcharacter(std::istream& s, char x);
 private:
     template<typename T>
     static inline char* as_buffer(T& data)
diff -r 5e725be08a10 -r fa451382042d src/Bounds.cpp
--- a/src/Bounds.cpp	Tue Apr 26 10:20:32 2011 -0500
+++ b/src/Bounds.cpp	Tue Apr 26 10:21:33 2011 -0700
@@ -34,5 +34,51 @@
 #include <libpc/Bounds.hpp>
+#include <libpc/Range.hpp>
+#include <libpc/Utils.hpp>
+#include <libpc/exceptions.hpp>
-// (no code here, everything is in the header)
+namespace libpc
+std::istream& operator>>(std::istream& istr, Bounds<double>& bounds)
+    Bounds<double>::RangeVector v;
+    char c;
+    Utils::eatwhitespace(istr);
+    if (!Utils::eatcharacter(istr,'('))
+        throw libpc_error("Bounds parser failed");
+    bool done = false;
+    while (!done)
+        Range<double> r;
+        istr >> r;
+        if ((c = (char)istr.peek()) == ',')
+            done = false;
+        else if ((c = (char)istr.peek()) == ')')
+            done = true;
+        else
+    if (!Utils::eatcharacter(istr,')'))
+    Bounds<double> xxx(v);
+    bounds = xxx;
+    return istr;
+} // namespace
diff -r 5e725be08a10 -r fa451382042d src/CMakeLists.txt
--- a/src/CMakeLists.txt	Tue Apr 26 10:20:32 2011 -0500
+++ b/src/CMakeLists.txt	Tue Apr 26 10:21:33 2011 -0700
@@ -69,6 +69,7 @@
   PointBuffer.cpp
   PointBufferCache.cpp
   Options.cpp
+  Range.cpp
   Schema.cpp
   SchemaLayout.cpp
   Signaller.cpp
diff -r 5e725be08a10 -r fa451382042d src/Range.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/src/Range.cpp	Tue Apr 26 10:21:33 2011 -0700
@@ -0,0 +1,70 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+*       names of its contributors may be used to endorse or promote
+*       products derived from this software without specific prior
+*       written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
More information about the Liblas-commits mailing list
