[Liblas-commits] hg-main-tree: checkpoint -- removing geotiff
support inside srs ...
liblas-commits at liblas.org
Tue Apr 26 17:59:55 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/75cb3fb221b3
changeset: 666:75cb3fb221b3
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Apr 26 14:24:47 2011 -0700
description:
checkpoint -- removing geotiff support inside srs class
Subject: hg-main-tree: I keep forgetting to delete the iters -- bad design?
details: http://hg.libpc.orghg-main-tree/rev/ebb3c7650fc6
changeset: 667:ebb3c7650fc6
date: Tue Apr 26 14:31:12 2011 -0700
description:
Subject: hg-main-tree: moved string trim function into Utils
details: http://hg.libpc.orghg-main-tree/rev/6ec1b8c31da2
changeset: 668:6ec1b8c31da2
date: Tue Apr 26 14:37:02 2011 -0700
description:
Subject: hg-main-tree: isolated out geotiff stuff; 4 fails left
details: http://hg.libpc.orghg-main-tree/rev/bbfc7d7ce05f
changeset: 669:bbfc7d7ce05f
date: Tue Apr 26 14:59:47 2011 -0700
description:
diffstat:
include/libpc/SpatialReference.hpp | 82 ----
include/libpc/Utils.hpp | 2 +
include/libpc/drivers/las/VariableLengthRecord.hpp | 8 +-
libpc_defines.h.in | 13 +
src/CMakeLists.txt | 2 +
src/SpatialReference.cpp | 386 +------------------
src/Utils.cpp | 16 +
src/drivers/las/GeotiffSupport.cpp | 402 +++++++++++++++++++++
src/drivers/las/GeotiffSupport.hpp | 81 ++++
src/drivers/las/VariableLengthRecord.cpp | 60 ++-
test/unit/ReprojectionFilterTest.cpp | 2 +
test/unit/SpatialReferenceTest.cpp | 76 +-
12 files changed, 630 insertions(+), 500 deletions(-)
diffs (truncated from 1568 to 300 lines):
diff -r 1ac969da44f7 -r bbfc7d7ce05f include/libpc/SpatialReference.hpp
--- a/include/libpc/SpatialReference.hpp Tue Apr 26 12:35:27 2011 -0700
+++ b/include/libpc/SpatialReference.hpp Tue Apr 26 14:59:47 2011 -0700
@@ -37,26 +37,7 @@
#include <libpc/libpc.hpp>
-// We have two modes: with GDAL and geotiff, SRS is enabled -- otherwise, it's disabled
-// we use one macro to simplify the control
-#if defined(LIBPC_HAVE_GDAL) && defined(LIBPC_HAVE_LIBGEOTIFF)
-#define LIBPC_SRS_ENABLED
-#endif
#include <boost/property_tree/ptree.hpp>
-#include <boost/shared_ptr.hpp>
-#include <string>
-#include <ostream>
-// Fake out the compiler if we don't have libgeotiff includes already
-#if !defined(__geotiff_h_)
-typedef struct GTIFS *GTIF;
-#endif
-#if !defined(__geo_simpletags_h_)
-typedef struct ST_TIFFS *ST_TIFF;
-#endif
namespace libpc
@@ -70,7 +51,6 @@
eCompoundOK = 2
/// Default constructor.
SpatialReference();
@@ -83,10 +63,6 @@
/// Assignment operator.
SpatialReference& operator=(SpatialReference const& rhs);
- /// Returns a pointer to the internal GTIF*. Only available if
- /// you have libgeotiff linked in.
- void rebuildGTIF();
/// Returns the OGC WKT describing Spatial Reference System.
/// If GDAL is linked, it uses GDAL's operations and methods to determine
@@ -104,23 +80,6 @@
/// \param v - a string containing the WKT string.
void setWKT(std::string const& v);
- /// Sets the vertical coordinate system using geotiff key values.
- /// This operation should normally be done after setting the horizontal
- /// portion of the coordinate system with something like SetWKT(),
- /// SetProj4(), SetGTIF() or SetFromUserInput()
- /// \param verticalCSType - An EPSG vertical coordinate system code,
- /// normally in the range 5600 to 5799, or -1 if one is not available.
- /// \param citation - a textual description of the vertical coordinate
- /// system or an empty string if nothing is available.
- /// \param verticalDatum - the EPSG vertical datum code, often in the
- /// range 5100 to 5299 - implied by verticalCSType if that is provided, or
- /// -1 if no value is available.
- /// \param verticalUnits - the EPSG vertical units code, often 9001 for Metre.
- void setVerticalCS(boost::int32_t verticalCSType,
- std::string const& citation = std::string(0),
- boost::int32_t verticalDatum = -1,
- boost::int32_t verticalUnits = 9001);
/// Sets the SRS using GDAL's SetFromUserInput function. If GDAL is not linked, this
/// operation has no effect.
/// \param v - a string containing the definition (filename, proj4, wkt, etc).
@@ -143,30 +102,7 @@
boost::property_tree::ptree getPTree() const;
- enum GeotiffKeyType
- Geotiff_KeyType_SHORT=1,
- Geotiff_KeyType_DOUBLE=2,
- Geotiff_KeyType_ASCII=3
- int geotiff_ST_SetKey(int tag, int count, GeotiffKeyType geotiff_key_type, void *data);
- void geotiff_SetTags();
- void geotiff_ResetTags();
- int geotiff_ST_GetKey(int tag, int *count, int *st_key_type, void **data_ptr) const;
private:
- std::string getGTIFFText() const;
- class TiffStuff
- public:
- TiffStuff();
- ~TiffStuff();
- GTIF* m_gtiff;
- ST_TIFF* m_tiff;
- boost::shared_ptr<TiffStuff> m_tiffstuff;
std::string m_wkt;
@@ -175,22 +111,4 @@
} // namespace libpc
-LIBPC_C_START
-#ifdef __geotiff_h_
-#ifdef GEO_NORMALIZE_H_INCLUDED
-char LIBPC_DLL * GTIFGetOGISDefn(GTIF*, GTIFDefn*);
#endif
-int LIBPC_DLL GTIFSetFromOGISDefn(GTIF*, const char*);
-void SetLinearUnitCitation(GTIF* psGTIF, char* pszLinearUOMName);
-#ifdef _OGR_SRS_API_H_INCLUDED
-void SetGeogCSCitation(GTIF* psGTIF, OGRSpatialReference* poSRS, char* angUnitName, int nDatum, short nSpheroid);
-#endif // defined _OGR_SRS_API_H_INCLUDED
-#endif // defined __geotiff_h_
-LIBPC_C_END
-#endif
diff -r 1ac969da44f7 -r bbfc7d7ce05f include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp Tue Apr 26 12:35:27 2011 -0700
+++ b/include/libpc/Utils.hpp Tue Apr 26 14:59:47 2011 -0700
@@ -159,6 +159,8 @@
// if char found, eats it and returns true; otherwise, don't eat it and then return false
static bool eatcharacter(std::istream& s, char x);
+ static std::string trim(const std::string& str);
private:
template<typename T>
static inline char* as_buffer(T& data)
diff -r 1ac969da44f7 -r bbfc7d7ce05f include/libpc/drivers/las/VariableLengthRecord.hpp
--- a/include/libpc/drivers/las/VariableLengthRecord.hpp Tue Apr 26 12:35:27 2011 -0700
+++ b/include/libpc/drivers/las/VariableLengthRecord.hpp Tue Apr 26 14:59:47 2011 -0700
@@ -37,9 +37,7 @@
-#include <libpc/MetadataRecord.hpp>
-#include <iostream>
+#include <string>
#include <vector>
namespace libpc {
@@ -85,8 +83,8 @@
static const int s_headerLength = 54;
- static void setSRSFromVLRs_X(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
- static void setVLRsFromSRS_X(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs);
+ static void setSRSFromVLRs(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
+ static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs);
static std::string bytes2string(boost::uint8_t* bytes, boost::uint32_t len);
diff -r 1ac969da44f7 -r bbfc7d7ce05f libpc_defines.h.in
--- a/libpc_defines.h.in Tue Apr 26 12:35:27 2011 -0700
+++ b/libpc_defines.h.in Tue Apr 26 14:59:47 2011 -0700
@@ -5,6 +5,8 @@
* Note this is a C-style header. Do not use C++ syntax.
+#ifndef LIBPC_DEFINES_H
+#define LIBPC_DEFINES_H
* version settings
@@ -55,3 +57,14 @@
#cmakedefine LIBPC_COMPILER_VC8
#cmakedefine LIBPC_COMPILER_GCC
#cmakedefine LIBPC_COMPILER_CLANG
+ * We have two modes: with GDAL and geotiff, SRS is enabled -- otherwise, it's disabled
+ * we use one macro to simplify the control
+#if defined(LIBPC_HAVE_GDAL) && defined(LIBPC_HAVE_LIBGEOTIFF)
+#define LIBPC_SRS_ENABLED
+#endif
+#endif
diff -r 1ac969da44f7 -r bbfc7d7ce05f src/CMakeLists.txt
--- a/src/CMakeLists.txt Tue Apr 26 12:35:27 2011 -0700
+++ b/src/CMakeLists.txt Tue Apr 26 14:59:47 2011 -0700
@@ -115,6 +115,7 @@
set (LIBPC_DRIVERS_LAS_HPP
+ ./drivers/las/GeotiffSupport.hpp
./drivers/las/LasHeaderReader.hpp
./drivers/las/LasHeaderWriter.hpp
./drivers/las/ZipPoint.hpp
@@ -129,6 +130,7 @@
set (LIBPC_DRIVERS_LAS_CPP
+ ./drivers/las/GeotiffSupport.cpp
./drivers/las/Header.cpp
./drivers/las/Iterator.cpp
./drivers/las/LasHeaderReader.cpp
diff -r 1ac969da44f7 -r bbfc7d7ce05f src/SpatialReference.cpp
--- a/src/SpatialReference.cpp Tue Apr 26 12:35:27 2011 -0700
+++ b/src/SpatialReference.cpp Tue Apr 26 14:59:47 2011 -0700
@@ -32,80 +32,28 @@
* OF SUCH DAMAGE.
-#include <libpc/libpc.hpp>
+#include <libpc/SpatialReference.hpp>
-// GDAL OSR
+// gdal
#ifdef LIBPC_HAVE_GDAL
-#include <ogr_srs_api.h>
-#include <cpl_port.h>
-#include <geo_normalize.h>
-#include <geovalues.h>
#include <ogr_spatialref.h>
-#include <gdal.h>
-#include <xtiffio.h>
-#include <cpl_multiproc.h>
+#include <cpl_conv.h>
#endif
-// GeoTIFF
-#ifdef LIBPC_HAVE_LIBGEOTIFF
-#include <geotiff.h>
-#include <geo_simpletags.h>
-#endif
-#include <libpc/SpatialReference.hpp>
-// boost
-#include <boost/concept_check.hpp>
-#include <boost/cstdint.hpp>
-// std
-#include <stdexcept>
-#include <string>
-#include <vector>
-#ifdef LIBPC_HAVE_GDAL
-# include "cpl_conv.h"
-#endif
+#include <libpc/Utils.hpp>
namespace libpc
-SpatialReference::TiffStuff::TiffStuff()
- : m_gtiff(0)
- , m_tiff(0)
-SpatialReference::TiffStuff::~TiffStuff()
-#ifdef LIBPC_SRS_ENABLED
- if (m_gtiff != 0)
- GTIFFree(m_gtiff);
- m_gtiff = 0;
- if (m_tiff != 0)
- ST_Destroy(m_tiff);
- m_tiff = 0;
-#endif
SpatialReference::SpatialReference()
- : m_tiffstuff(new TiffStuff())
- , m_wkt("")
+ : m_wkt("")
return;
SpatialReference::SpatialReference(SpatialReference const& rhs)
- : m_tiffstuff(rhs.m_tiffstuff)
- , m_wkt(rhs.m_wkt)
+ : m_wkt(rhs.m_wkt)
return;
More information about the Liblas-commits
