[Liblas-commits] hg-main-tree: fix up options so they actually work
liblas-commits at liblas.org
Wed Apr 27 11:58:37 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/83d65a4a4707
changeset: 674:83d65a4a4707
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Apr 27 10:58:33 2011 -0500
description:
fix up options so they actually work :)
diffstat:
apps/pc2pc.cpp | 4 ++--
1 files changed, 2 insertions(+), 2 deletions(-)
diffs (17 lines):
diff -r 85ab89e394f0 -r 83d65a4a4707 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Wed Apr 27 10:52:52 2011 -0500
+++ b/apps/pc2pc.cpp Wed Apr 27 10:58:33 2011 -0500
@@ -94,11 +94,11 @@
file_options->add_options()
("input,i", po::value<std::string>(&m_inputFile), "input file name")
("output,o", po::value<std::string>(&m_outputFile), "output file name")
- ("output,o", po::value<std::string>(&m_outputFile), "output file name")
("native", "use native LAS classes (not liblas)")
("oracle-writer", "Read data from LAS file and write to Oracle")
+ ("oracle-reader", "Read data from Oracle and write to LAS")
("a_srs", po::value<std::string>(&m_srs)->default_value(""), "Assign output coordinate system")
- ("compress", po::value<bool>(&m_bCompress)->default_value(false),"Compress output data if available")
+ ("compress", po::value<bool>(&m_bCompress)->zero_tokens()->implicit_value(true),"Compress output data if available")
("xml", po::value<std::string>(&m_xml)->default_value("log.xml"), "XML file to load process (OCI only right now)")
More information about the Liblas-commits
