[Liblas-commits] hg-main-tree: added control of writer to emit compound wkts
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Apr 27 14:48:22 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/8a7143e61209
changeset: 680:8a7143e61209
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Apr 27 11:48:14 2011 -0700
description:
diffstat:
 include/libpc/SpatialReference.hpp                 |   3 ++
 include/libpc/drivers/las/VariableLengthRecord.hpp |   9 ++---
 src/SpatialReference.cpp                           |   8 +++++
 src/drivers/las/LasHeaderWriter.cpp                |   3 +-
 src/drivers/las/LasHeaderWriter.hpp                |   5 +++
 src/drivers/las/VariableLengthRecord.cpp           |   8 ++--
 test/unit/SpatialReferenceTest.cpp                 |  31 +++++++++++++++++++--
 7 files changed, 54 insertions(+), 13 deletions(-)
diffs (208 lines):
diff -r c1b03f8ef183 -r 8a7143e61209 include/libpc/SpatialReference.hpp
--- a/include/libpc/SpatialReference.hpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/include/libpc/SpatialReference.hpp	Wed Apr 27 11:48:14 2011 -0700
@@ -54,6 +54,9 @@
     /// Default constructor.
     SpatialReference();
+    // calls setFromUserInput() with the given string
+    SpatialReference(const std::string& userInput);
     /// Destructor.
     /// If libgeotiff is enabled, deallocates libtiff and libgeotiff objects used internally.
     ~SpatialReference();
diff -r c1b03f8ef183 -r 8a7143e61209 include/libpc/drivers/las/VariableLengthRecord.hpp
--- a/include/libpc/drivers/las/VariableLengthRecord.hpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/include/libpc/drivers/las/VariableLengthRecord.hpp	Wed Apr 27 11:48:14 2011 -0700
@@ -40,9 +40,8 @@
 #include <string>
 #include <vector>
-namespace libpc {
-    class SpatialReference;
+#include <libpc/SpatialReference.hpp>
 namespace libpc { namespace drivers { namespace las {
@@ -85,7 +84,7 @@
     static const int s_headerLength = 54;
     static void setSRSFromVLRs(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
-    static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs);
+    static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs, SpatialReference::WKTModeFlag modeFlag);
     static std::string bytes2string(const boost::uint8_t* bytes, boost::uint32_t len);
@@ -121,7 +120,7 @@
     boost::uint32_t count() const;
     void constructSRS(SpatialReference&) const;
-    void addVLRsFromSRS(const SpatialReference& srs);
+    void addVLRsFromSRS(const SpatialReference& srs, SpatialReference::WKTModeFlag modeFlag);
 private:
    std::vector<VariableLengthRecord> m_list;
diff -r c1b03f8ef183 -r 8a7143e61209 src/SpatialReference.cpp
--- a/src/SpatialReference.cpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/src/SpatialReference.cpp	Wed Apr 27 11:48:14 2011 -0700
@@ -52,6 +52,14 @@
+SpatialReference::SpatialReference(const std::string& s)
+    : m_wkt("")
+    this->setFromUserInput(s);
+    return;
 SpatialReference::SpatialReference(SpatialReference const& rhs)
     : m_wkt(rhs.m_wkt)
diff -r c1b03f8ef183 -r 8a7143e61209 src/drivers/las/LasHeaderWriter.cpp
--- a/src/drivers/las/LasHeaderWriter.cpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/src/drivers/las/LasHeaderWriter.cpp	Wed Apr 27 11:48:14 2011 -0700
@@ -55,6 +55,7 @@
 LasHeaderWriter::LasHeaderWriter(LasHeader& header, std::ostream& ostream)
     : m_header(header)
     , m_ostream(ostream)
+    , m_wktModeFlag(SpatialReference::eCompoundOK)
     return;
@@ -91,7 +92,7 @@
         m_header.getVLRs().remove("LASF_Projection", 34736);
         m_header.getVLRs().remove("LASF_Projection", 34737);
-        m_header.getVLRs().addVLRsFromSRS(m_header.getSpatialReference());
+        m_header.getVLRs().addVLRsFromSRS(m_header.getSpatialReference(), m_wktModeFlag);
diff -r c1b03f8ef183 -r 8a7143e61209 src/drivers/las/LasHeaderWriter.hpp
--- a/src/drivers/las/LasHeaderWriter.hpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/src/drivers/las/LasHeaderWriter.hpp	Wed Apr 27 11:48:14 2011 -0700
@@ -46,6 +46,8 @@
 #include <libpc/libpc.hpp>
 #include <iosfwd>
 class LasHeader;
@@ -56,6 +58,8 @@
     LasHeaderWriter(LasHeader& header, std::ostream&);
     void write();
+    // default is eCompoundOK
+    void setWktModeFlag(SpatialReference::WKTModeFlag);
 private:
     void WriteLAS10PadSignature();
@@ -64,6 +68,7 @@
     LasHeader& m_header; // note this is not const
     std::ostream& m_ostream;
+    SpatialReference::WKTModeFlag m_wktModeFlag;
     LasHeaderWriter& operator=(const LasHeaderWriter&); // nope
     LasHeaderWriter(const LasHeaderWriter&); // nope
diff -r c1b03f8ef183 -r 8a7143e61209 src/drivers/las/VariableLengthRecord.cpp
--- a/src/drivers/las/VariableLengthRecord.cpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/src/drivers/las/VariableLengthRecord.cpp	Wed Apr 27 11:48:14 2011 -0700
@@ -317,7 +317,7 @@
-void VariableLengthRecord::setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs)
+void VariableLengthRecord::setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs, SpatialReference::WKTModeFlag modeFlag)
 #ifdef LIBPC_SRS_ENABLED
@@ -337,7 +337,7 @@
     GeotiffSupport geotiff;
-        const std::string wkt = srs.getWKT(SpatialReference::eCompoundOK, false);
+        const std::string wkt = srs.getWKT(modeFlag, false);
         geotiff.setWkt(wkt);
@@ -603,9 +603,9 @@
-void VLRList::addVLRsFromSRS(const SpatialReference& srs)
+void VLRList::addVLRsFromSRS(const SpatialReference& srs, SpatialReference::WKTModeFlag modeFlag)
-    VariableLengthRecord::setVLRsFromSRS(srs, m_list);
+    VariableLengthRecord::setVLRsFromSRS(srs, m_list, modeFlag);
 } } } // namespaces
diff -r c1b03f8ef183 -r 8a7143e61209 test/unit/SpatialReferenceTest.cpp
--- a/test/unit/SpatialReferenceTest.cpp	Wed Apr 27 11:15:35 2011 -0700
+++ b/test/unit/SpatialReferenceTest.cpp	Wed Apr 27 11:48:14 2011 -0700
@@ -155,7 +155,7 @@
     ref.setFromUserInput(code);
     std::vector<libpc::drivers::las::VariableLengthRecord> vlrs;
-    libpc::drivers::las::VariableLengthRecord::setVLRsFromSRS(ref, vlrs);
+    libpc::drivers::las::VariableLengthRecord::setVLRsFromSRS(ref, vlrs, libpc::SpatialReference::eCompoundOK);
     BOOST_CHECK(vlrs.size() == boost::uint32_t(4));
     BOOST_CHECK(vlrs[0].getLength() == boost::uint32_t(64));
@@ -178,7 +178,7 @@
         BOOST_CHECK(vlrs.size() == 4);
         BOOST_CHECK(vlrs[0].getLength() == boost::uint32_t(96));
@@ -200,6 +200,31 @@
+BOOST_AUTO_TEST_CASE(test_vertical_datum_notcompound)
+    const std::string wkt = "COMPD_CS[\"WGS 84 + VERT_CS\",GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]],VERT_CS[\"NAVD88 height\",VERT_DATUM[\"North American Vertical Datum 1988\",2005,AUTHORITY[\"EPSG\",\"5103\"],EXTENSION[\"PROJ4_GRIDS\",\"g2003conus.gtx\"]],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"Up\",UP],AUTHORITY[\"EPSG\",\"5703\"]]]";
+    const libpc::SpatialReference srs(wkt);
+    std::vector<libpc::drivers::las::VariableLengthRecord> vlrs_compound;
+    std::vector<libpc::drivers::las::VariableLengthRecord> vlrs_horizonly;
+    libpc::drivers::las::VariableLengthRecord::setVLRsFromSRS(srs, vlrs_compound, libpc::SpatialReference::eCompoundOK);
+    libpc::drivers::las::VariableLengthRecord::setVLRsFromSRS(srs, vlrs_horizonly, libpc::SpatialReference::eHorizontalOnly);
+    BOOST_CHECK(vlrs_compound.size() == 4);
+    BOOST_CHECK(vlrs_horizonly.size() == 4);
+    BOOST_CHECK(vlrs_compound[0].getLength() == 96);
+    BOOST_CHECK(vlrs_compound[1].getLength() == 16);
+    BOOST_CHECK(vlrs_compound[2].getLength() == 21);
+    BOOST_CHECK(vlrs_compound[3].getLength() == 511);
+    BOOST_CHECK(vlrs_horizonly[0].getLength() == 64);
+    BOOST_CHECK(vlrs_horizonly[1].getLength() == 16);
+    BOOST_CHECK(vlrs_horizonly[2].getLength() == 7);
+    BOOST_CHECK(vlrs_horizonly[3].getLength() == 511);
+    return;
 // Try writing a compound coordinate system to file and ensure we get back
 // WKT with the geoidgrids (from the WKT VLR).
 BOOST_AUTO_TEST_CASE(test_vertical_datums)
@@ -267,7 +292,7 @@
         libpc::drivers::las::VariableLengthRecord::clearVLRs(libpc::drivers::las::VariableLengthRecord::eGeoTIFF, vlrs);
         BOOST_CHECK(vlrs.size() == 1);
More information about the Liblas-commits mailing list
