[Liblas-commits] hg-main-tree: only try to set the srs if we have
one
liblas-commits at liblas.org
Wed Apr 27 15:32:08 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/b6eb4612a26e
changeset: 684:b6eb4612a26e
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Apr 27 14:31:54 2011 -0500
description:
only try to set the srs if we have one
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/4e0890c40838
changeset: 685:4e0890c40838
date: Wed Apr 27 14:32:02 2011 -0500
description:
merge
diffstat:
apps/pc2pc.cpp | 7 +-
apps/pcinfo.cpp | 8 +-
include/libpc/SpatialReference.hpp | 3 +
include/libpc/drivers/las/VariableLengthRecord.hpp | 9 +-
include/libpc/filters/ScalingFilter.hpp | 84 +++++++++
include/libpc/filters/ScalingFilterIterator.hpp | 62 ++++++
src/CMakeLists.txt | 4 +
src/SpatialReference.cpp | 8 +
src/Utils.cpp | 5 +-
src/drivers/las/LasHeaderWriter.cpp | 3 +-
src/drivers/las/LasHeaderWriter.hpp | 5 +
src/drivers/las/Reader.cpp | 2 +
src/drivers/las/VariableLengthRecord.cpp | 8 +-
src/filters/ScalingFilter.cpp | 188 +++++++++++++++++++++
src/filters/ScalingFilterIterator.cpp | 72 ++++++++
test/data/1.0_0.las | 0
test/data/1.0_0_nosrs.las | 0
test/data/1.0_1.las | 0
test/data/1.0_1_nosrs.las | 0
test/data/1.1_0.las | 0
test/data/1.1_0_nosrs.las | 0
test/data/1.1_1.las | 0
test/data/1.1_1_nosrs.las | 0
test/data/1.2_0.las | 0
test/data/1.2_0_nosrs.las | 0
test/data/1.2_1.las | 0
test/data/1.2_1_nosrs.las | 0
test/data/1.2_2.las | 0
test/data/1.2_2_nosrs.las | 0
test/data/1.2_3.las | 0
test/data/1.2_3_nosrs.las | 0
test/unit/LasWriterTest.cpp | 6 +-
test/unit/LiblasWriterTest.cpp | 22 +-
test/unit/SpatialReferenceTest.cpp | 31 +++-
test/unit/Support.cpp | 4 +
35 files changed, 498 insertions(+), 33 deletions(-)
diffs (truncated from 821 to 300 lines):
diff -r 28435427ec55 -r 4e0890c40838 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Wed Apr 27 10:54:30 2011 -0700
+++ b/apps/pc2pc.cpp Wed Apr 27 14:32:02 2011 -0500
@@ -187,8 +187,11 @@
if (hasOption("a_srs"))
libpc::SpatialReference ref;
- ref.setFromUserInput(m_srs);
- writer.setSpatialReference(ref);
+ if (m_srs.size() > 0)
+ ref.setFromUserInput(m_srs);
+ writer.setSpatialReference(ref);
if (hasOption("compress"))
diff -r 28435427ec55 -r 4e0890c40838 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Wed Apr 27 10:54:30 2011 -0700
+++ b/apps/pcinfo.cpp Wed Apr 27 14:32:02 2011 -0500
@@ -111,12 +111,14 @@
return 1;
- boost::uint64_t numPoints = reader->getNumPoints();
+ const boost::uint64_t numPoints = reader->getNumPoints();
+ const SpatialReference& srs = reader->getSpatialReference();
+ std::cout << numPoints << " points\n";
+ std::cout << "WKT: " << srs.getWKT() << "\n";
delete reader;
- std::cout << numPoints << " points\n";
return 0;
diff -r 28435427ec55 -r 4e0890c40838 include/libpc/SpatialReference.hpp
--- a/include/libpc/SpatialReference.hpp Wed Apr 27 10:54:30 2011 -0700
+++ b/include/libpc/SpatialReference.hpp Wed Apr 27 14:32:02 2011 -0500
@@ -54,6 +54,9 @@
/// Default constructor.
SpatialReference();
+ // calls setFromUserInput() with the given string
+ SpatialReference(const std::string& userInput);
/// Destructor.
/// If libgeotiff is enabled, deallocates libtiff and libgeotiff objects used internally.
~SpatialReference();
diff -r 28435427ec55 -r 4e0890c40838 include/libpc/drivers/las/VariableLengthRecord.hpp
--- a/include/libpc/drivers/las/VariableLengthRecord.hpp Wed Apr 27 10:54:30 2011 -0700
+++ b/include/libpc/drivers/las/VariableLengthRecord.hpp Wed Apr 27 14:32:02 2011 -0500
@@ -40,9 +40,8 @@
#include <string>
#include <vector>
-namespace libpc {
- class SpatialReference;
+#include <libpc/SpatialReference.hpp>
namespace libpc { namespace drivers { namespace las {
@@ -85,7 +84,7 @@
static const int s_headerLength = 54;
static void setSRSFromVLRs(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
- static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs);
+ static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs, SpatialReference::WKTModeFlag modeFlag);
static std::string bytes2string(const boost::uint8_t* bytes, boost::uint32_t len);
@@ -121,7 +120,7 @@
boost::uint32_t count() const;
void constructSRS(SpatialReference&) const;
- void addVLRsFromSRS(const SpatialReference& srs);
+ void addVLRsFromSRS(const SpatialReference& srs, SpatialReference::WKTModeFlag modeFlag);
private:
std::vector<VariableLengthRecord> m_list;
diff -r 28435427ec55 -r 4e0890c40838 include/libpc/filters/ScalingFilter.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/filters/ScalingFilter.hpp Wed Apr 27 14:32:02 2011 -0500
@@ -0,0 +1,84 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_FILTERS_SCALINGFILTER_HPP
+#define INCLUDED_FILTERS_SCALINGFILTER_HPP
+#include <libpc/libpc.hpp>
+#include <boost/shared_ptr.hpp>
+#include <libpc/Filter.hpp>
+namespace libpc
+ class PointBuffer;
+namespace libpc { namespace filters {
+class ScalingFilterSequentialIterator;
+class LIBPC_DLL ScalingFilter : public Filter
+public:
+ ScalingFilter(const Stage& prevStage);
+ const std::string& getDescription() const;
+ const std::string& getName() const;
+ bool supportsIterator (StageIteratorType t) const
+ if (t == StageIterator_Sequential ) return true;
+ return false;
+ libpc::SequentialIterator* createSequentialIterator() const;
+ libpc::RandomIterator* createRandomIterator() const { return NULL; }
+ void processBuffer(PointBuffer& data) const;
+private:
+ void checkImpedance();
+ void initialize();
+ ScalingFilter& operator=(const ScalingFilter&); // not implemented
+ ScalingFilter(const ScalingFilter&); // not implemented
+} } // namespaces
+#endif
diff -r 28435427ec55 -r 4e0890c40838 include/libpc/filters/ScalingFilterIterator.hpp
+++ b/include/libpc/filters/ScalingFilterIterator.hpp Wed Apr 27 14:32:02 2011 -0500
@@ -0,0 +1,62 @@
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_FILTERS_SCALINGFILTERITERATOR_HPP
+#define INCLUDED_FILTERS_SCALINGFILTERITERATOR_HPP
+#include <libpc/filters/ScalingFilter.hpp>
+#include <libpc/FilterIterator.hpp>
+class ScalingFilterSequentialIterator : public libpc::FilterSequentialIterator
+public:
+ ScalingFilterSequentialIterator(const ScalingFilter& filter);
+private:
+ boost::uint64_t skipImpl(boost::uint64_t);
+ boost::uint32_t readImpl(PointBuffer&);
+ bool atEndImpl() const;
+ const ScalingFilter& m_scalingFilter;
+} } // namespaces
+#endif
diff -r 28435427ec55 -r 4e0890c40838 src/CMakeLists.txt
--- a/src/CMakeLists.txt Wed Apr 27 10:54:30 2011 -0700
+++ b/src/CMakeLists.txt Wed Apr 27 14:32:02 2011 -0500
@@ -246,6 +246,8 @@
${LIBPC_HEADERS_DIR}/filters/MosaicFilterIterator.hpp
${LIBPC_HEADERS_DIR}/filters/ReprojectionFilter.hpp
${LIBPC_HEADERS_DIR}/filters/ReprojectionFilterIterator.hpp
+ ${LIBPC_HEADERS_DIR}/filters/ScalingFilter.hpp
+ ${LIBPC_HEADERS_DIR}/filters/ScalingFilterIterator.hpp
set (LIBPC_FILTERS_CPP
@@ -263,6 +265,8 @@
./filters/MosaicFilterIterator.cpp
./filters/ReprojectionFilter.cpp
./filters/ReprojectionFilterIterator.cpp
+ ./filters/ScalingFilter.cpp
+ ./filters/ScalingFilterIterator.cpp
FOREACH(file ${LIBPC_FILTERS_HPP})
diff -r 28435427ec55 -r 4e0890c40838 src/SpatialReference.cpp
--- a/src/SpatialReference.cpp Wed Apr 27 10:54:30 2011 -0700
+++ b/src/SpatialReference.cpp Wed Apr 27 14:32:02 2011 -0500
@@ -52,6 +52,14 @@
+SpatialReference::SpatialReference(const std::string& s)
+ : m_wkt("")
+ this->setFromUserInput(s);
+ return;
SpatialReference::SpatialReference(SpatialReference const& rhs)
: m_wkt(rhs.m_wkt)
diff -r 28435427ec55 -r 4e0890c40838 src/Utils.cpp
--- a/src/Utils.cpp Wed Apr 27 10:54:30 2011 -0700
+++ b/src/Utils.cpp Wed Apr 27 14:32:02 2011 -0500
@@ -143,7 +143,10 @@
bool Utils::deleteFile(const std::string& file)
- return boost::filesystem::remove(file);
+ if (!fileExists(file))
+ return false;
+ return boost::filesystem::remove(file);
diff -r 28435427ec55 -r 4e0890c40838 src/drivers/las/LasHeaderWriter.cpp
--- a/src/drivers/las/LasHeaderWriter.cpp Wed Apr 27 10:54:30 2011 -0700
+++ b/src/drivers/las/LasHeaderWriter.cpp Wed Apr 27 14:32:02 2011 -0500
@@ -55,6 +55,7 @@
LasHeaderWriter::LasHeaderWriter(LasHeader& header, std::ostream& ostream)
: m_header(header)
, m_ostream(ostream)
+ , m_wktModeFlag(SpatialReference::eCompoundOK)
More information about the Liblas-commits
