[Liblas-commits] hg-main-tree: update the header's bounds
liblas-commits at liblas.org
Thu Apr 28 11:25:40 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/2c7b904a79a9
changeset: 690:2c7b904a79a9
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Apr 28 08:25:32 2011 -0700
description:
diffstat:
include/libpc/filters/ReprojectionFilter.hpp | 1 +
src/filters/ReprojectionFilter.cpp | 23 ++++++++++++++++
test/unit/ReprojectionFilterTest.cpp | 38 +++++++++++++++++++++++----
3 files changed, 56 insertions(+), 6 deletions(-)
diffs (104 lines):
diff -r e13e73cec6b8 -r 2c7b904a79a9 include/libpc/filters/ReprojectionFilter.hpp
--- a/include/libpc/filters/ReprojectionFilter.hpp Wed Apr 27 16:21:56 2011 -0700
+++ b/include/libpc/filters/ReprojectionFilter.hpp Thu Apr 28 08:25:32 2011 -0700
@@ -73,6 +73,7 @@
void processBuffer(PointBuffer& data) const;
private:
+ void updateBounds();
void checkImpedance();
void initialize();
void transform(double& x, double& y, double& z) const;
diff -r e13e73cec6b8 -r 2c7b904a79a9 src/filters/ReprojectionFilter.cpp
--- a/src/filters/ReprojectionFilter.cpp Wed Apr 27 16:21:56 2011 -0700
+++ b/src/filters/ReprojectionFilter.cpp Thu Apr 28 08:25:32 2011 -0700
@@ -91,6 +91,29 @@
initialize();
+ updateBounds();
+ return;
+void ReprojectionFilter::updateBounds()
+ const Bounds<double>& oldBounds = getBounds();
+ double minx = oldBounds.getMinimum(0);
+ double miny = oldBounds.getMinimum(1);
+ double minz = oldBounds.getMinimum(2);
+ double maxx = oldBounds.getMaximum(0);
+ double maxy = oldBounds.getMaximum(1);
+ double maxz = oldBounds.getMaximum(2);
+ transform(minx, miny, minz);
+ transform(maxx, maxy, maxz);
+ Bounds<double> newBounds(minx, miny, minz, maxx, maxy, maxz);
+ setBounds(newBounds);
return;
diff -r e13e73cec6b8 -r 2c7b904a79a9 test/unit/ReprojectionFilterTest.cpp
--- a/test/unit/ReprojectionFilterTest.cpp Wed Apr 27 16:21:56 2011 -0700
+++ b/test/unit/ReprojectionFilterTest.cpp Thu Apr 28 08:25:32 2011 -0700
@@ -49,6 +49,17 @@
BOOST_AUTO_TEST_SUITE(ReprojectionFilterTest)
+static void compareBounds(const libpc::Bounds<double>& p, const libpc::Bounds<double>& q)
+ BOOST_CHECK_CLOSE(p.getMinimum(0), q.getMinimum(0), 1);
+ BOOST_CHECK_CLOSE(p.getMinimum(1), q.getMinimum(1), 1);
+ BOOST_CHECK_CLOSE(p.getMinimum(2), q.getMinimum(2), 1);
+ BOOST_CHECK_CLOSE(p.getMaximum(0), q.getMaximum(0), 1);
+ BOOST_CHECK_CLOSE(p.getMaximum(1), q.getMaximum(1), 1);
+ BOOST_CHECK_CLOSE(p.getMaximum(2), q.getMaximum(2), 1);
static void getPoint(const libpc::PointBuffer& data, boost::uint32_t pointIndex, double& x, double& y, double& z)
using namespace libpc;
@@ -132,17 +143,32 @@
delete iter2;
+ const double preX = 470692.447538;
+ const double preY = 4602888.904642;
+ const double preZ = 16.000000;
+ const double postX = -93.351563;
+ const double postY = 41.577148;
+ const double postZ = 16.000000;
+ // note this file has only 1 points, so yes, the extent's mins and maxes are the same
+ const libpc::Bounds<double> oldBounds_ref(preX, preY, preZ, preX, preY, preZ);
+ const libpc::Bounds<double> newBounds_ref(postX, postY, postZ, postX, postY, postZ);
+ const libpc::Bounds<double>& oldBounds = reader1.getBounds();
+ const libpc::Bounds<double>& newBounds = descalingFilter.getBounds();
+ compareBounds(oldBounds_ref, oldBounds);
+ compareBounds(newBounds_ref, newBounds);
double x1, x2, y1, y2, z1, z2;
getPoint(data1, 0, x1, y1, z1);
getPoint(data2, 0, x2, y2, z2);
- BOOST_CHECK_CLOSE(x1, 470692.44, 1);
- BOOST_CHECK_CLOSE(y1, 4602888.90, 1);
- BOOST_CHECK_CLOSE(z1, 16, 1);
+ BOOST_CHECK_CLOSE(x1, preX, 1);
+ BOOST_CHECK_CLOSE(y1, preY, 1);
+ BOOST_CHECK_CLOSE(z1, preZ, 1);
- BOOST_CHECK_CLOSE(x2, -93.35156259, 1);
-////// BOOST_CHECK_CLOSE(y2, 41.57714839, 1); // BUG: I get 90
-////// BOOST_CHECK_CLOSE(z2, 16, 1); // BUG: I get 0 (no idea what this is supposed to be, not in liblas test)
+ BOOST_CHECK_CLOSE(x2, postX, 1);
+////// BOOST_CHECK_CLOSE(y2, postY, 1); // BUG: I get 90
+////// BOOST_CHECK_CLOSE(z2, postZ, 1); // BUG: I get 0 (no idea what this is supposed to be, not in liblas test)
////////out_hdr->SetScale(0.00000001, 0.00000001, 0.01);
More information about the Liblas-commits
