[Liblas-commits] hg-main-tree: reproj and scaling filters now
working
liblas-commits at liblas.org
Thu Apr 28 12:57:24 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/e0413b5a06e6
changeset: 692:e0413b5a06e6
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Apr 28 09:40:40 2011 -0700
description:
reproj and scaling filters now working
Subject: hg-main-tree: reproj and scaling filters working
details: http://hg.libpc.orghg-main-tree/rev/23340cd26242
changeset: 693:23340cd26242
date: Thu Apr 28 09:57:02 2011 -0700
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/89f0502b790f
changeset: 694:89f0502b790f
date: Thu Apr 28 09:57:12 2011 -0700
description:
merge
diffstat:
apps/pc2pc.cpp | 5 +-
include/libpc/filters/ScalingFilter.hpp | 5 +
src/filters/ReprojectionFilter.cpp | 6 +-
src/filters/ScalingFilter.cpp | 86 +++++++++++---
test/unit/ReprojectionFilterTest.cpp | 192 ++++++++++++++++++-------------
5 files changed, 190 insertions(+), 104 deletions(-)
diffs (truncated from 413 to 300 lines):
diff -r 2c7b904a79a9 -r 89f0502b790f apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Thu Apr 28 08:25:32 2011 -0700
+++ b/apps/pc2pc.cpp Thu Apr 28 09:57:12 2011 -0700
@@ -190,12 +190,13 @@
if (m_srs.size() > 0)
ref.setFromUserInput(m_srs);
- writer.setSpatialReference(ref);
+ writer.setSpatialReference(ref);
if (hasOption("compress"))
- writer.setCompressed(true);
+ if (m_bCompress)
+ writer.setCompressed(true);
writer.write(numPoints);
diff -r 2c7b904a79a9 -r 89f0502b790f include/libpc/filters/ScalingFilter.hpp
--- a/include/libpc/filters/ScalingFilter.hpp Thu Apr 28 08:25:32 2011 -0700
+++ b/include/libpc/filters/ScalingFilter.hpp Thu Apr 28 09:57:12 2011 -0700
@@ -59,7 +59,9 @@
// notes:
// - "forward=true" means doubles --> ints
// - "forward=false" means ints --> doubles
+ // - 1st version uses the scale/offset values already present
ScalingFilter(const Stage& prevStage, bool forward);
+ ScalingFilter(const Stage& prevStage, double scaleX, double offsetX, double scaleY, double offsetY, double scaleZ, double offsetZ, bool forward);
const std::string& getDescription() const;
const std::string& getName() const;
@@ -80,6 +82,9 @@
void checkImpedance();
void initialize();
+ bool m_customScaleOffset;
+ double m_scaleX, m_scaleY, m_scaleZ;
+ double m_offsetX, m_offsetY, m_offsetZ;
bool m_forward;
ScalingFilter& operator=(const ScalingFilter&); // not implemented
diff -r 2c7b904a79a9 -r 89f0502b790f src/filters/ReprojectionFilter.cpp
--- a/src/filters/ReprojectionFilter.cpp Thu Apr 28 08:25:32 2011 -0700
+++ b/src/filters/ReprojectionFilter.cpp Thu Apr 28 09:57:12 2011 -0700
@@ -210,9 +210,9 @@
for (boost::uint32_t pointIndex=0; pointIndex<numPoints; pointIndex++)
- double x = data.getField<boost::int32_t>(pointIndex, indexX);
- double y = data.getField<boost::int32_t>(pointIndex, indexY);
- double z = data.getField<boost::int32_t>(pointIndex, indexZ);
+ double x = data.getField<double>(pointIndex, indexX);
+ double y = data.getField<double>(pointIndex, indexY);
+ double z = data.getField<double>(pointIndex, indexZ);
this->transform(x,y,z);
diff -r 2c7b904a79a9 -r 89f0502b790f src/filters/ScalingFilter.cpp
--- a/src/filters/ScalingFilter.cpp Thu Apr 28 08:25:32 2011 -0700
+++ b/src/filters/ScalingFilter.cpp Thu Apr 28 09:57:12 2011 -0700
@@ -47,6 +47,32 @@
ScalingFilter::ScalingFilter(const Stage& prevStage, bool forward)
: Filter(prevStage)
+ , m_customScaleOffset(false)
+ , m_scaleX(0.0)
+ , m_scaleY(0.0)
+ , m_scaleZ(0.0)
+ , m_offsetX(0.0)
+ , m_offsetY(0.0)
+ , m_offsetZ(0.0)
+ , m_forward(forward)
+ checkImpedance();
+ initialize();
+ return;
+ScalingFilter::ScalingFilter(const Stage& prevStage, double scaleX, double offsetX, double scaleY, double offsetY, double scaleZ, double offsetZ, bool forward)
+ : Filter(prevStage)
+ , m_customScaleOffset(true)
+ , m_scaleX(scaleX)
+ , m_scaleY(scaleY)
+ , m_scaleZ(scaleZ)
+ , m_offsetX(offsetX)
+ , m_offsetY(offsetY)
+ , m_offsetZ(offsetZ)
checkImpedance();
@@ -90,12 +116,24 @@
schema.removeDimension(dimYd);
schema.removeDimension(dimZd);
- dimXi.setNumericScale(dimXd.getNumericScale());
- dimXi.setNumericOffset(dimXd.getNumericOffset());
- dimYi.setNumericScale(dimYd.getNumericScale());
- dimYi.setNumericOffset(dimYd.getNumericOffset());
- dimZi.setNumericScale(dimZd.getNumericScale());
- dimZi.setNumericOffset(dimZd.getNumericOffset());
+ if (m_customScaleOffset)
+ dimXi.setNumericScale(m_scaleX);
+ dimXi.setNumericOffset(m_offsetX);
+ dimYi.setNumericScale(m_scaleY);
+ dimYi.setNumericOffset(m_offsetY);
+ dimZi.setNumericScale(m_scaleZ);
+ dimZi.setNumericOffset(m_offsetZ);
+ else
+ dimXi.setNumericScale(dimXd.getNumericScale());
+ dimXi.setNumericOffset(dimXd.getNumericOffset());
+ dimYi.setNumericScale(dimYd.getNumericScale());
+ dimYi.setNumericOffset(dimYd.getNumericOffset());
+ dimZi.setNumericScale(dimZd.getNumericScale());
+ dimZi.setNumericOffset(dimZd.getNumericOffset());
schema.addDimension(dimXi);
schema.addDimension(dimYi);
@@ -125,12 +163,24 @@
throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as int32s not be initially present (reverse direction)");
- dimXd.setNumericScale(dimXi.getNumericScale());
- dimXd.setNumericOffset(dimXi.getNumericOffset());
- dimYd.setNumericScale(dimYi.getNumericScale());
- dimYd.setNumericOffset(dimYi.getNumericOffset());
- dimZd.setNumericScale(dimZi.getNumericScale());
- dimZd.setNumericOffset(dimZi.getNumericOffset());
+ dimXd.setNumericScale(m_scaleX);
+ dimXd.setNumericOffset(m_offsetX);
+ dimYd.setNumericScale(m_scaleY);
+ dimYd.setNumericOffset(m_offsetY);
+ dimZd.setNumericScale(m_scaleZ);
+ dimZd.setNumericOffset(m_offsetY);
+ else
+ dimXd.setNumericScale(dimXi.getNumericScale());
+ dimXd.setNumericOffset(dimXi.getNumericOffset());
+ dimYd.setNumericScale(dimYi.getNumericScale());
+ dimYd.setNumericOffset(dimYi.getNumericOffset());
+ dimZd.setNumericScale(dimZi.getNumericScale());
+ dimZd.setNumericOffset(dimZi.getNumericOffset());
schema.removeDimension(dimXi);
schema.removeDimension(dimYi);
@@ -205,9 +255,9 @@
const double yd = srcData.getField<double>(pointIndex, indexYd);
const double zd = srcData.getField<double>(pointIndex, indexZd);
- const boost::int32_t xi = dimXd.removeScaling<boost::int32_t>(xd);
- const boost::int32_t yi = dimYd.removeScaling<boost::int32_t>(yd);
- const boost::int32_t zi = dimZd.removeScaling<boost::int32_t>(zd);
+ const boost::int32_t xi = dimXi.removeScaling<boost::int32_t>(xd);
+ const boost::int32_t yi = dimYi.removeScaling<boost::int32_t>(yd);
+ const boost::int32_t zi = dimZi.removeScaling<boost::int32_t>(zd);
dstData.setField<boost::int32_t>(pointIndex, indexXi, xi);
dstData.setField<boost::int32_t>(pointIndex, indexYi, yi);
@@ -220,9 +270,9 @@
const boost::int32_t yi = srcData.getField<boost::int32_t>(pointIndex, indexYi);
const boost::int32_t zi = srcData.getField<boost::int32_t>(pointIndex, indexZi);
- const double xd = dimXi.applyScaling(xi);
- const double yd = dimYi.applyScaling(yi);
- const double zd = dimZi.applyScaling(zi);
+ const double xd = dimXd.applyScaling(xi);
+ const double yd = dimYd.applyScaling(yi);
+ const double zd = dimZd.applyScaling(zi);
dstData.setField<double>(pointIndex, indexXd, xd);
dstData.setField<double>(pointIndex, indexYd, yd);
diff -r 2c7b904a79a9 -r 89f0502b790f test/unit/ReprojectionFilterTest.cpp
--- a/test/unit/ReprojectionFilterTest.cpp Thu Apr 28 08:25:32 2011 -0700
+++ b/test/unit/ReprojectionFilterTest.cpp Thu Apr 28 09:57:12 2011 -0700
@@ -60,88 +60,33 @@
-static void getPoint(const libpc::PointBuffer& data, boost::uint32_t pointIndex, double& x, double& y, double& z)
+static void getPoint(const libpc::PointBuffer& data, double& x, double& y, double& z, double scaleX, double scaleY, double scaleZ)
using namespace libpc;
const Schema& schema = data.getSchema();
-#if 1
const int indexX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Int32);
const int indexY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Int32);
const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Int32);
- const Dimension& xDim = schema.getDimension(indexX);
- const Dimension& yDim = schema.getDimension(indexY);
- const Dimension& zDim = schema.getDimension(indexZ);
- const boost::int32_t xraw = data.getField<boost::int32_t>(pointIndex, indexX);
- const boost::int32_t yraw = data.getField<boost::int32_t>(pointIndex, indexY);
- const boost::int32_t zraw = data.getField<boost::int32_t>(pointIndex, indexZ);
+ const boost::int32_t xraw = data.getField<boost::int32_t>(0, indexX);
+ const boost::int32_t yraw = data.getField<boost::int32_t>(0, indexY);
+ const boost::int32_t zraw = data.getField<boost::int32_t>(0, indexZ);
- x = xDim.applyScaling(xraw);
- y = yDim.applyScaling(yraw);
- z = zDim.applyScaling(zraw);
-#else
- const int indexX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Double);
- const int indexY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Double);
- const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Double);
- x = data.getField<double>(pointIndex, indexX);
- y = data.getField<double>(pointIndex, indexY);
- z = data.getField<double>(pointIndex, indexZ);
-#endif
+ x = (double)xraw * scaleX;
+ y = (double)yraw * scaleY;
+ z = (double)zraw * scaleZ;
return;
+// Test reprojecting UTM 15 to DD with a filter
BOOST_AUTO_TEST_CASE(test_1)
- // Test reprojecting UTM 15 to DD with a filter
- libpc::drivers::las::LasReader reader1(Support::datapath("utm15.las"));
- libpc::drivers::las::LasReader reader2(Support::datapath("utm15.las"));
- const libpc::SpatialReference& in_ref = reader1.getSpatialReference();
const char* epsg4326_wkt = "GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4326\"]]";
- libpc::SpatialReference out_ref(epsg4326_wkt);
- const char* utm15_wkt = "PROJCS[\"NAD83 / UTM zone 15N\",GEOGCS[\"NAD83\",DATUM[\"North_American_Datum_1983\",SPHEROID[\"GRS 1980\",6378137,298.2572221010002,AUTHORITY[\"EPSG\",\"7019\"]],AUTHORITY[\"EPSG\",\"6269\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4269\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",-93],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AUTHORITY[\"EPSG\",\"26915\"]]";
- BOOST_CHECK(in_ref.getWKT() == utm15_wkt);
- BOOST_CHECK(out_ref.getWKT() == epsg4326_wkt);
- libpc::filters::ScalingFilter scalingFilter(reader2, false);
- libpc::filters::ReprojectionFilter reprojectionFilter(scalingFilter, in_ref, out_ref);
- libpc::filters::ScalingFilter descalingFilter(reprojectionFilter, true);
- const libpc::Schema& schema1 = reader1.getSchema();
- const libpc::SchemaLayout layout1(schema1);
- libpc::PointBuffer data1(layout1, 1);
- const libpc::Schema& schema2 = descalingFilter.getSchema();
- const libpc::SchemaLayout layout2(schema2);
- libpc::PointBuffer data2(layout2, 1);
- libpc::SequentialIterator* iter1 = reader1.createSequentialIterator();
- boost::uint32_t numRead = iter1->read(data1);
- BOOST_CHECK(numRead == 1);
- delete iter1;
- libpc::SequentialIterator* iter2 = descalingFilter.createSequentialIterator();
- boost::uint32_t numRead = iter2->read(data2);
- delete iter2;
+ const char* utm15_wkt = "PROJCS[\"NAD83 / UTM zone 15N\",GEOGCS[\"NAD83\",DATUM[\"North_American_Datum_1983\",SPHEROID[\"GRS 1980\",6378137,298.2572221010002,AUTHORITY[\"EPSG\",\"7019\"]],AUTHORITY[\"EPSG\",\"6269\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4269\"]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",-93],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AUTHORITY[\"EPSG\",\"26915\"]]";
const double preX = 470692.447538;
const double preY = 4602888.904642;
@@ -150,27 +95,112 @@
const double postY = 41.577148;
const double postZ = 16.000000;
- // note this file has only 1 points, so yes, the extent's mins and maxes are the same
- const libpc::Bounds<double> oldBounds_ref(preX, preY, preZ, preX, preY, preZ);
- const libpc::Bounds<double> newBounds_ref(postX, postY, postZ, postX, postY, postZ);
- const libpc::Bounds<double>& oldBounds = reader1.getBounds();
- const libpc::Bounds<double>& newBounds = descalingFilter.getBounds();
- compareBounds(oldBounds_ref, oldBounds);
- compareBounds(newBounds_ref, newBounds);
+ // we compute three answers:
+ // (1) w/out reprojection
+ // (2) with scaling and reproj
+ // (3) with custom scaling and reproj
- double x1, x2, y1, y2, z1, z2;
More information about the Liblas-commits
