[Liblas-commits] hg-main-tree: added public initialize() method for
all stages, w...
liblas-commits at liblas.org
Mon Aug 1 19:46:19 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/f170d83eaf4d
changeset: 974:f170d83eaf4d
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Aug 01 16:46:11 2011 -0700
description:
added public initialize() method for all stages, which must be called before any stage operation is done - typically you will do this after the last pipeline stage is constructed
diffstat:
include/pdal/Filter.hpp | 8 +-
include/pdal/MultiFilter.hpp | 8 +-
include/pdal/PipelineManager.hpp | 8 +-
include/pdal/Reader.hpp | 2 +
include/pdal/Stage.hpp | 2 +
include/pdal/StageBase.hpp | 12 ++
include/pdal/StageFactory.hpp | 12 +-
include/pdal/Writer.hpp | 10 +-
include/pdal/drivers/faux/Reader.hpp | 6 +-
include/pdal/drivers/faux/Writer.hpp | 4 +-
include/pdal/drivers/las/Reader.hpp | 4 +-
include/pdal/drivers/las/Writer.hpp | 6 +-
include/pdal/drivers/liblas/Reader.hpp | 3 +-
include/pdal/drivers/liblas/Writer.hpp | 5 +-
include/pdal/drivers/oci/Reader.hpp | 1 +
include/pdal/drivers/oci/Writer.hpp | 5 +-
include/pdal/drivers/qfit/Reader.hpp | 2 +
include/pdal/drivers/terrasolid/Reader.hpp | 2 +
include/pdal/filters/ByteSwapFilter.hpp | 8 +-
include/pdal/filters/CacheFilter.hpp | 8 +-
include/pdal/filters/Chipper.hpp | 4 +-
include/pdal/filters/ColorFilter.hpp | 5 +-
include/pdal/filters/CropFilter.hpp | 8 +-
include/pdal/filters/DecimationFilter.hpp | 7 +-
include/pdal/filters/MosaicFilter.hpp | 3 +-
include/pdal/filters/ReprojectionFilter.hpp | 6 +-
include/pdal/filters/ScalingFilter.hpp | 21 ++--
src/Filter.cpp | 20 ++++-
src/MultiFilter.cpp | 44 +++------
src/PipelineManager.cpp | 9 +-
src/PipelineReader.cpp | 2 +-
src/Reader.cpp | 8 +
src/Stage.cpp | 8 +
src/StageBase.cpp | 33 +++++++-
src/StageFactory.cpp | 12 +-
src/StageIterator.cpp | 5 +
src/Writer.cpp | 23 ++++-
src/drivers/faux/Reader.cpp | 38 +++-----
src/drivers/faux/Writer.cpp | 8 +-
src/drivers/las/Reader.cpp | 6 +-
src/drivers/las/Writer.cpp | 8 +-
src/drivers/liblas/Reader.cpp | 6 +-
src/drivers/liblas/Writer.cpp | 8 +-
src/drivers/oci/Reader.cpp | 6 +
src/drivers/oci/Writer.cpp | 8 +-
src/drivers/qfit/Reader.cpp | 6 +
src/drivers/terrasolid/Reader.cpp | 6 +
src/filters/ByteSwapFilter.cpp | 8 +-
src/filters/CacheFilter.cpp | 8 +-
src/filters/Chipper.cpp | 10 ++-
src/filters/ColorFilter.cpp | 10 +-
src/filters/CropFilter.cpp | 10 +-
src/filters/DecimationFilter.cpp | 10 +-
src/filters/MosaicFilter.cpp | 33 ++----
src/filters/ReprojectionFilter.cpp | 125 +++++++++++++--------------
src/filters/ScalingFilter.cpp | 42 +++-----
test/unit/ByteSwapFilterTest.cpp | 2 +
test/unit/CacheFilterTest.cpp | 4 +-
test/unit/ChipperTest.cpp | 6 +-
test/unit/CropFilterTest.cpp | 2 +-
test/unit/DecimationFilterTest.cpp | 2 +
test/unit/FauxReaderTest.cpp | 10 ++-
test/unit/FauxWriterTest.cpp | 4 +-
test/unit/LasReaderTest.cpp | 13 ++-
test/unit/LasWriterTest.cpp | 11 +-
test/unit/LiblasReaderTest.cpp | 34 +++++--
test/unit/LiblasWriterTest.cpp | 30 +++--
test/unit/MosaicFilterTest.cpp | 3 +-
test/unit/PipelineManagerTest.cpp | 4 +
test/unit/PipelineReaderTest.cpp | 6 +-
test/unit/QFITReaderTest.cpp | 3 +-
test/unit/ReprojectionFilterTest.cpp | 43 +++++++--
test/unit/ScalingFilterTest.cpp | 5 +-
test/unit/SpatialReferenceTest.cpp | 5 +
test/unit/StageFactoryTest.cpp | 15 ++-
test/unit/TerraSolidTest.cpp | 2 +
76 files changed, 559 insertions(+), 335 deletions(-)
diffs (truncated from 2772 to 300 lines):
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/Filter.hpp
--- a/include/pdal/Filter.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/Filter.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -45,14 +45,18 @@
class PDAL_DLL Filter : public Stage
public:
- Filter(const Stage& prevStage, const Options& options);
+ Filter(Stage& prevStage, const Options& options);
+ virtual void initialize();
const Stage& getPrevStage() const;
virtual boost::property_tree::ptree generatePTree() const;
protected:
- const Stage& m_prevStage;
+ Stage& getPrevStage();
+ Stage& m_prevStage;
private:
Filter& operator=(const Filter&); // not implemented
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/MultiFilter.hpp
--- a/include/pdal/MultiFilter.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/MultiFilter.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -47,14 +47,16 @@
public:
// entries may not be null
// vector.size() must be > 0
- MultiFilter(const std::vector<const Stage*>& prevStages, const Options& options);
+ MultiFilter(const std::vector<Stage*>& prevStages, const Options& options);
- const std::vector<const Stage*>& getPrevStages() const;
+ const std::vector<const Stage*> getPrevStages() const;
protected:
- std::vector<const Stage*> m_prevStages;
+ std::vector<Stage*> m_prevStages;
private:
MultiFilter& operator=(const MultiFilter&); // not implemented
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/PipelineManager.hpp
--- a/include/pdal/PipelineManager.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/PipelineManager.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -59,9 +59,9 @@
// Use these to manually add stages into the pipeline manager.
Reader* addReader(const std::string& type, const Options&);
- Filter* addFilter(const std::string& type, const Stage& prevStage, const Options&);
- MultiFilter* addMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStages, const Options&);
- Writer* addWriter(const std::string& type, const Stage& prevStage, const Options&);
+ Filter* addFilter(const std::string& type, Stage& prevStage, const Options&);
+ MultiFilter* addMultiFilter(const std::string& type, const std::vector<Stage*>& prevStages, const Options&);
+ Writer* addWriter(const std::string& type, Stage& prevStage, const Options&);
// returns true iff the pipeline endpoint is a writer
bool isWriterPipeline() const;
@@ -70,7 +70,7 @@
Writer* getWriter() const;
// return the pipeline reader endpoint (or NULL, if not a reader pipeline)
- const Stage* getStage() const;
+ Stage* getStage() const;
// for writer pipelines, this convenience function calls getWriter()->write() so that
// the user doesn't even need to know anything about the Writer class
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/Reader.hpp
--- a/include/pdal/Reader.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/Reader.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -52,6 +52,8 @@
Reader(const Options& options);
virtual ~Reader();
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/Stage.hpp
--- a/include/pdal/Stage.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/Stage.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -58,6 +58,8 @@
Stage(const Options& options);
virtual ~Stage();
// core properties of all stages
const Schema& getSchema() const;
virtual boost::uint64_t getNumPoints() const;
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/StageBase.hpp
--- a/include/pdal/StageBase.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/StageBase.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -50,6 +50,17 @@
public:
StageBase(const Options& options);
+ virtual ~StageBase();
+ // This function is for derived stages to perform "static" validation, e.g. bad Option arguments.
+ // It will recursively call initialize() on all previous stages.
+ // Users must call this after the last stage in the pipeline has been consturcted.
+ // It is not illegal to call this twice for a stage, but that doesn't mean you should.
+ // Derived stages should feel free to provide their own implementations. Remeber to call initialize() on
+ // the parent class before your own class-specific code.
+ // This function will throw when errors are found.
+ bool isInitialized() const;
const Options& getOptions() const;
@@ -111,6 +122,7 @@
Options& getOptions();
private:
+ bool m_initialized;
Options m_options;
bool m_debug;
boost::uint8_t m_verbose;
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/StageFactory.hpp
--- a/include/pdal/StageFactory.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/StageFactory.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -72,9 +72,9 @@
public:
typedef Reader* ReaderCreator(const Options&);
- typedef Filter* FilterCreator(const Stage& prevStage, const Options&);
- typedef MultiFilter* MultiFilterCreator(const std::vector<const Stage*>& prevStages, const Options&);
- typedef Writer* WriterCreator(const Stage& prevStage, const Options&);
+ typedef Filter* FilterCreator(Stage& prevStage, const Options&);
+ typedef MultiFilter* MultiFilterCreator(const std::vector<Stage*>& prevStages, const Options&);
+ typedef Writer* WriterCreator(Stage& prevStage, const Options&);
typedef std::map<std::string, ReaderCreator*> ReaderCreatorList;
typedef std::map<std::string, FilterCreator*> FilterCreatorList;
@@ -85,9 +85,9 @@
StageFactory();
Reader* createReader(const std::string& type, const Options& options);
- Filter* createFilter(const std::string& type, const Stage& prevStage, const Options& options);
- MultiFilter* createMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStages, const Options& options);
- Writer* createWriter(const std::string& type, const Stage& prevStage, const Options& options);
+ Filter* createFilter(const std::string& type, Stage& prevStage, const Options& options);
+ MultiFilter* createMultiFilter(const std::string& type, const std::vector<Stage*>& prevStages, const Options& options);
+ Writer* createWriter(const std::string& type, Stage& prevStage, const Options& options);
void registerReader(const std::string& type, ReaderCreator* f);
void registerFilter(const std::string& type, FilterCreator* f);
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/Writer.hpp
--- a/include/pdal/Writer.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/Writer.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -50,9 +50,11 @@
class PDAL_DLL Writer : public StageBase
public:
- Writer(const Stage& prevStage, const Options& options);
+ Writer(Stage& prevStage, const Options& options);
virtual ~Writer() {}
// size of the PointBuffer buffer to use
void setChunkSize(boost::uint32_t);
boost::uint32_t getChunkSize() const;
@@ -65,6 +67,8 @@
+ const Stage& getPrevStage() const;
protected:
// this is called once before the loop with the writeBuffer calls
virtual void writeBegin() = 0;
@@ -75,14 +79,14 @@
// called once, after the writeBuffer calls
virtual void writeEnd() = 0;
- const Stage& getPrevStage() const;
// these two are valid for use after writeBegin has been called
boost::uint64_t m_actualNumPointsWritten;
boost::uint64_t m_targetNumPointsToWrite;
private:
boost::uint32_t m_chunkSize;
static const boost::uint32_t s_defaultChunkSize;
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/drivers/faux/Reader.hpp
--- a/include/pdal/drivers/faux/Reader.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/drivers/faux/Reader.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -79,6 +79,8 @@
Reader(const Bounds<double>&, boost::uint64_t numPoints, Mode mode);
Reader(const Bounds<double>&, boost::uint64_t numPoints, Mode mode, const std::vector<Dimension>& dimensions);
Mode getMode() const;
@@ -97,12 +99,10 @@
boost::uint32_t processBuffer(PointBuffer& data, boost::uint64_t index) const;
private:
- void initialize();
- void initialize(const std::vector<Dimension>& dimensions);
Bounds<double> m_bounds;
boost::uint64_t m_numPoints;
Mode m_mode;
+ std::vector<Dimension> m_dimensions;
Reader& operator=(const Reader&); // not implemented
Reader(const Reader&); // not implemented
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/drivers/faux/Writer.hpp
--- a/include/pdal/drivers/faux/Writer.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/drivers/faux/Writer.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -54,7 +54,9 @@
DECLARE_STATICS
public:
- Writer(const Stage& prevStage, const Options&);
+ Writer(Stage& prevStage, const Options&);
// retrieve the summary info
double getMinX() const { return m_minimumX; }
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/drivers/las/Reader.hpp
--- a/include/pdal/drivers/las/Reader.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/drivers/las/Reader.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -61,6 +61,8 @@
LasReader(const Options&);
LasReader(const std::string& filename);
const std::string& getFileName() const;
bool supportsIterator (StageIteratorType t) const
@@ -98,8 +100,6 @@
MetadataRecord& getMetadataRecordRef(int index);
private:
std::string m_filename;
LasHeader m_lasHeader;
std::vector<MetadataRecord> m_metadataRecords;
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/drivers/las/Writer.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -56,10 +56,12 @@
DECLARE_STATICS
public:
- LasWriter(const Stage& prevStage, const Options&);
+ LasWriter(Stage& prevStage, const Options&);
LasWriter(Stage& prevStage, std::ostream*);
~LasWriter();
void setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion);
void setPointFormat(PointFormat);
void setDate(boost::uint16_t dayOfYear, boost::uint16_t year);
@@ -88,8 +90,6 @@
virtual void writeEnd();
private:
OStreamManager m_streamManager;
diff -r aed3e9b3938f -r f170d83eaf4d include/pdal/drivers/liblas/Reader.hpp
--- a/include/pdal/drivers/liblas/Reader.hpp Sat Jul 30 16:53:37 2011 -0700
+++ b/include/pdal/drivers/liblas/Reader.hpp Mon Aug 01 16:46:11 2011 -0700
@@ -62,6 +62,8 @@
LiblasReader(const std::string& filename);
~LiblasReader();
::pdal::drivers::las::PointFormat getPointFormat() const;
@@ -86,7 +88,6 @@
pdal::StageRandomIterator* createRandomIterator() const;
private:
More information about the Liblas-commits
