[Liblas-commits] hg-main-tree: clean up err mssg
liblas-commits at liblas.org
Tue Aug 2 16:49:28 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/c4deed5860fb
changeset: 994:c4deed5860fb
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Aug 02 13:48:51 2011 -0700
description:
clean up err mssg
Subject: hg-main-tree: add read-scale-reproj-descale-write test for hobu
details: http://hg.libpc.orghg-main-tree/rev/42aad86c4ce1
changeset: 995:42aad86c4ce1
date: Tue Aug 02 13:49:18 2011 -0700
description:
diffstat:
src/filters/ScalingFilter.cpp | 8 +++---
test/data/pipeline_write2.xml | 35 ++++++++++++++++++++++++++
test/unit/PipelineReaderTest.cpp | 47 +++++++++++++++++++++++++++++++++++-
test/unit/ReprojectionFilterTest.cpp | 17 ++----------
test/unit/Support.cpp | 10 +++++++
test/unit/Support.hpp | 2 +
6 files changed, 100 insertions(+), 19 deletions(-)
diffs (223 lines):
diff -r 9a6cd83d3a90 -r 42aad86c4ce1 src/filters/ScalingFilter.cpp
--- a/src/filters/ScalingFilter.cpp Tue Aug 02 13:57:31 2011 -0500
+++ b/src/filters/ScalingFilter.cpp Tue Aug 02 13:49:18 2011 -0700
@@ -152,11 +152,11 @@
if (!schema.hasDimension(dimXd) || !schema.hasDimension(dimYd) || !schema.hasDimension(dimZd))
- throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as doubles (forward direction)");
+ throw impedance_invalid("Descaling filter requires X,Y,Z dimensions as doubles");
if (schema.hasDimension(dimXi) || schema.hasDimension(dimYi) || schema.hasDimension(dimZi))
- throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as ints not be initially present (forward direction)");
+ throw impedance_invalid("Descaling filter requires X,Y,Z dimensions as ints not be initially present");
schema.removeDimension(dimXd);
@@ -203,11 +203,11 @@
// ints --> doubles
if (!schema.hasDimension(dimXi) || !schema.hasDimension(dimYi) || !schema.hasDimension(dimZi))
- throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as int32s (reverse direction)");
+ throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as int32s");
if (schema.hasDimension(dimXd) || schema.hasDimension(dimYd) || schema.hasDimension(dimZd))
- throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as int32s not be initially present (reverse direction)");
+ throw impedance_invalid("Scaling filter requires X,Y,Z dimensions as int32s not be initially present");
if (m_customScaleOffset)
diff -r 9a6cd83d3a90 -r 42aad86c4ce1 test/data/pipeline_write2.xml
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/test/data/pipeline_write2.xml Tue Aug 02 13:49:18 2011 -0700
@@ -0,0 +1,35 @@
+<?xml version="1.0" encoding="utf-8"?>
+<WriterPipeline>
+ <Writer>
+ <Type>drivers.las.writer</Type>
+ <Option>
+ <Name>filename</Name>
+ <Value>out2.las</Value>
+ <Description>junk junk junk</Description>
+ </Option>
+ <Filter>
+ <Type>filters.descaling</Type>
+ <Filter>
+ <Type>filters.reprojection</Type>
+ <Option>
+ <Name>out_srs</Name>
+ <Value>EPSG:4326</Value>
+ </Option>
+ <Filter>
+ <Type>filters.scaling</Type>
+ <Reader>
+ <Type>drivers.las.reader</Type>
+ <Option>
+ <Value>utm15.las</Value>
+ </Option>
+ </Reader>
+ </Filter>
+ </Filter>
+ </Filter>
+ </Writer>
+</WriterPipeline>
diff -r 9a6cd83d3a90 -r 42aad86c4ce1 test/unit/PipelineReaderTest.cpp
--- a/test/unit/PipelineReaderTest.cpp Tue Aug 02 13:57:31 2011 -0500
+++ b/test/unit/PipelineReaderTest.cpp Tue Aug 02 13:49:18 2011 -0700
@@ -41,6 +41,7 @@
#include <pdal/FileUtils.hpp>
#include <pdal/PointBuffer.hpp>
#include <pdal/StageIterator.hpp>
+#include <pdal/drivers/las/Reader.hpp>
using namespace pdal;
@@ -88,7 +89,7 @@
BOOST_CHECK(np == 1065);
- FileUtils::deleteFile("out.las");
+ FileUtils::deleteFile(Support::datapath("out.las"));
return;
@@ -159,4 +160,48 @@
return;
+BOOST_AUTO_TEST_CASE(PipelineReaderTest_test4)
+ FileUtils::deleteFile("out2.las");
+ PipelineManager manager;
+ PipelineReader reader(manager);
+ reader.readWriterPipeline(Support::datapath("pipeline_write2.xml"));
+ Writer* writerStage = manager.getWriter();
+ writerStage->initialize();
+ const boost::uint64_t np = writerStage->write();
+ BOOST_CHECK(np == 1);
+ const double preX = 470692.447538;
+ const double preY = 4602888.904642;
+ const double preZ = 16.000000;
+ const double postX = -93.351563;
+ const double postY = 41.577148;
+ const double postZ = 16.000000;
+ pdal::drivers::las::LasReader reader(Support::datapath("utm15.las"));
+ reader.initialize();
+ const pdal::Bounds<double>& bounds = reader.getBounds();
+ const pdal::Bounds<double> ref(preX, preY, preZ, preX, preY, preZ);
+ Support::compareBounds(bounds, ref);
+ pdal::drivers::las::LasReader reader(Support::datapath("out2.las"));
+ const pdal::Bounds<double> ref(postX, postY, postZ, postX, postY, postZ);
+ FileUtils::deleteFile(Support::datapath("out2.las"));
+ return;
BOOST_AUTO_TEST_SUITE_END()
diff -r 9a6cd83d3a90 -r 42aad86c4ce1 test/unit/ReprojectionFilterTest.cpp
--- a/test/unit/ReprojectionFilterTest.cpp Tue Aug 02 13:57:31 2011 -0500
+++ b/test/unit/ReprojectionFilterTest.cpp Tue Aug 02 13:49:18 2011 -0700
@@ -49,17 +49,6 @@
BOOST_AUTO_TEST_SUITE(ReprojectionFilterTest)
-static void compareBounds(const pdal::Bounds<double>& p, const pdal::Bounds<double>& q)
- BOOST_CHECK_CLOSE(p.getMinimum(0), q.getMinimum(0), 1);
- BOOST_CHECK_CLOSE(p.getMinimum(1), q.getMinimum(1), 1);
- BOOST_CHECK_CLOSE(p.getMinimum(2), q.getMinimum(2), 1);
- BOOST_CHECK_CLOSE(p.getMaximum(0), q.getMaximum(0), 1);
- BOOST_CHECK_CLOSE(p.getMaximum(1), q.getMaximum(1), 1);
- BOOST_CHECK_CLOSE(p.getMaximum(2), q.getMaximum(2), 1);
static void getPoint(const pdal::PointBuffer& data, double& x, double& y, double& z, double scaleX, double scaleY, double scaleZ)
@@ -129,7 +118,7 @@
// note this file has only 1 points, so yes, the extent's mins and maxes are the same
const pdal::Bounds<double> oldBounds_ref(preX, preY, preZ, preX, preY, preZ);
const pdal::Bounds<double>& oldBounds = reader.getBounds();
- compareBounds(oldBounds_ref, oldBounds);
+ Support::compareBounds(oldBounds_ref, oldBounds);
double x=0, y=0, z=0;
getPoint(data, x, y, z, 0.01, 0.01, 0.01);
@@ -164,7 +153,7 @@
const pdal::Bounds<double> newBounds_ref(postX, postY, postZ, postX, postY, postZ);
const pdal::Bounds<double>& newBounds = descalingFilter.getBounds();
- compareBounds(newBounds_ref, newBounds);
+ Support::compareBounds(newBounds_ref, newBounds);
@@ -202,7 +191,7 @@
diff -r 9a6cd83d3a90 -r 42aad86c4ce1 test/unit/Support.cpp
--- a/test/unit/Support.cpp Tue Aug 02 13:57:31 2011 -0500
+++ b/test/unit/Support.cpp Tue Aug 02 13:49:18 2011 -0700
@@ -216,3 +216,13 @@
Support::check_pN(data, schema, 2, 638598.880000, 851445.370000, 422.150000);
+void Support::compareBounds(const pdal::Bounds<double>& p, const pdal::Bounds<double>& q)
+ BOOST_CHECK_CLOSE(p.getMinimum(0), q.getMinimum(0), 1);
+ BOOST_CHECK_CLOSE(p.getMinimum(1), q.getMinimum(1), 1);
+ BOOST_CHECK_CLOSE(p.getMinimum(2), q.getMinimum(2), 1);
+ BOOST_CHECK_CLOSE(p.getMaximum(0), q.getMaximum(0), 1);
+ BOOST_CHECK_CLOSE(p.getMaximum(1), q.getMaximum(1), 1);
+ BOOST_CHECK_CLOSE(p.getMaximum(2), q.getMaximum(2), 1);
diff -r 9a6cd83d3a90 -r 42aad86c4ce1 test/unit/Support.hpp
--- a/test/unit/Support.hpp Tue Aug 02 13:57:31 2011 -0500
+++ b/test/unit/Support.hpp Tue Aug 02 13:49:18 2011 -0700
@@ -37,6 +37,7 @@
// support functions for unit testing
+#include <pdal/Bounds.hpp>
#include <boost/cstdint.hpp>
namespace pdal
@@ -75,6 +76,7 @@
static void check_p355_p356_p357(const pdal::PointBuffer& data, const pdal::Schema& schema);
static void check_p710_p711_p712(const pdal::PointBuffer& data, const pdal::Schema& schema);
+ static void compareBounds(const pdal::Bounds<double>& p, const pdal::Bounds<double>& q);
More information about the Liblas-commits
