[Liblas-commits] hg-main-tree: add default options for
drivers.oci.writer. Not u...
liblas-commits at liblas.org
Wed Aug 3 12:11:50 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/f14c9ff73183
changeset: 1002:f14c9ff73183
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Aug 03 11:11:49 2011 -0500
description:
add default options for drivers.oci.writer. Not using them yet
diffstat:
src/drivers/oci/Writer.cpp | 134 ++++++++++++++++++++++++++++++++++++++++++--
src/drivers/oci/common.cpp | 1 -
2 files changed, 127 insertions(+), 8 deletions(-)
diffs (182 lines):
diff -r 3d24e634e1c2 -r f14c9ff73183 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp Wed Aug 03 08:50:45 2011 -0500
+++ b/src/drivers/oci/Writer.cpp Wed Aug 03 11:11:49 2011 -0500
@@ -96,6 +96,130 @@
const Options& Writer::s_getDefaultOptions()
static Options options;
+ Option<bool > is3d("is3d", false,"Should we use 3D objects for SDO_PC PC_EXTENT, \
+ BLK_EXTENT, and indexing");
+ Option<bool > solid("solid",false,"Define the point cloud's PC_EXTENT geometry \
+ gtype as (1,1007,3) instead of the normal \
+ (1,1003,3), and use gtype 3008/2008 vs \
+ 3003/2003 for BLK_EXTENT geometry values.");
+ Option<bool > overwrite("overwrite",false,"Wipe the block table and recreate it before loading data");
+ Option<bool > verbose("verbose",false,"Wipe the block table and recreate it before loading data");
+ Option<boost::uint32_t> srid("srid", 0, "The Oracle numerical SRID value to use \
+ for PC_EXTENT, BLK_EXTENT, and indexing");
+ Option<boost::uint32_t> capacity("capacity",
+ 10000,
+ "The block capacity or maximum number of \
+ points a block can contain");
+ Option<boost::uint16_t> stream_output_precision("stream_output_precision",
+ 8,
+ "The number of digits past the decimal place for \
+ outputting floats/doubles to streams. This is used \
+ for creating the SDO_PC object and adding the \
+ index entry to the USER_SDO_GEOM_METADATA for the \
+ block table");
+ Option<boost::int32_t> cloud_id("cloud_id",
+ -1,
+ "The point cloud id that links the point cloud \
+ object to the entries in the block table.");
+ Option<std::string> connection("connection",
+ "Oracle connection string to connect to database");
+ Option<std::string> block_table_name("block_table_name",
+ "output",
+ "The table in which block data for the created SDO_PC will be placed");
+ Option<std::string> block_table_partition_column("block_table_partition_column",
+ "The column name for which 'block_table_partition_value' \
+ will be placed in the 'block_table_name'");
+ Option<boost::int32_t> block_table_partition_value("block_table_partition_value",
+ 0,
+ "Integer value to use to assing partition \
+ IDs in the block table. Used in conjunction \
+ with 'block_table_partition_column'");
+ Option<std::string> base_table_name("base_table_name",
+ "hobu",
+ "The name of the table which will contain the SDO_PC object");
+ Option<std::string> cloud_column_name("cloud_column_name",
+ "CLOUD",
+ "The column name in 'base_table_name' that will hold the SDO_PC object");
+ Option<std::string> base_table_aux_columns("base_table_aux_columns",
+ "Quoted, comma-separated list of columns to \
+ add to the SQL that gets executed as part of \
+ the point cloud insertion into the \
+ 'base_table_name' table");
+ Option<std::string> base_table_aux_values("base_table_aux_values",
+ "Quoted, comma-separated values that correspond \
+ to 'base_table_aux_columns', entries that will \
+ get inserted as part of the creation of the \
+ SDO_PC entry in the 'base_table_name' table");
+ Option<std::string> base_table_boundary_column("base_table_boundary_column",
+ "The SDO_GEOMETRY column in 'base_table_name' in which \
+ to insert the WKT in 'base_table_boundary_wkt' representing \
+ a boundary for the SDO_PC object. Note this is not \
+ the same as the 'base_table_bounds', which is just \
+ a bounding box that is placed on the SDO_PC object itself.");
+ Option<std::string> base_table_boundary_wkt("base_table_boundary_wkt",
+ "WKT, in the form of a string or a file location, to insert \
+ into the SDO_GEOMTRY column defined by 'base_table_boundary_column'");
+ Option<std::string> pre_block_sql("pre_block_sql",
+ "SQL, in the form of a string or file location, that is executed \
+ after the SDO_PC object has been created but before the block \
+ data in 'block_table_name' are inserted into the database");
+ Option<std::string> pre_sql("pre_sql",
+ before the SDO_PC object is created.");
+ Option<std::string> post_block_sql("post_block_sql",
+ after the block data in 'block_table_name' have been inserted");
+ Option<pdal::Bounds<double> > base_table_bounds("base_table_bounds",
+ Bounds<double>(),
+ "A bounding box, given in the Oracle SRID specified in 'srid' \
+ to set on the PC_EXTENT object of the SDO_PC. If none is specified, \
+ the cumulated bounds of all of the block data are used.");
+ options.add(is3d);
+ options.add(solid);
+ options.add(overwrite);
+ options.add(verbose);
+ options.add(srid);
+ options.add(capacity);
+ options.add(stream_output_precision);
+ options.add(cloud_id);
+ options.add(connection);
+ options.add(block_table_name);
+ options.add(block_table_partition_column);
+ options.add(block_table_partition_value);
+ options.add(base_table_name);
+ options.add(cloud_column_name);
+ options.add(base_table_aux_columns);
+ options.add(base_table_aux_values);
+ options.add(base_table_boundary_column);
+ options.add(base_table_boundary_wkt);
+ options.add(pre_block_sql);
+ options.add(pre_sql);
+ options.add(post_block_sql);
+ options.add(base_table_bounds);
return options;
@@ -489,14 +613,14 @@
std::string cloud_column_name = to_upper(tree.get<std::string>("cloud_column_name"));
std::string base_table_aux_columns = tree.get<std::string>("base_table_aux_columns");
std::string base_table_aux_values = tree.get<std::string>("base_table_aux_values");
- std::string header_blob_column_name = tree.get<std::string>("header_blob_column_name");
std::string base_table_boundary_column = tree.get<std::string>("base_table_boundary_column");
std::string base_table_boundary_wkt = tree.get<std::string>("base_table_boundary_wkt");
boost::uint32_t srid = tree.get<boost::uint32_t>("srid");
boost::uint32_t precision = tree.get<boost::uint32_t>("precision");
boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
- boost::uint32_t dimensions = tree.get<boost::uint32_t>("dimensions");
bool bUse3d = is3d();
@@ -523,10 +647,6 @@
nSchemaPos++;
int nPos = nSchemaPos; // Bind column position
- // if (!header_blob_column_name.empty()){
- // columns << "," << header_blob_column_name;
- // values <<", :" << nPos;
if (!base_table_boundary_column.empty()){
columns << "," << base_table_boundary_column;
@@ -594,7 +714,7 @@
s_geom << "))";
+ boost::uint32_t dimensions = 8;
oss << "declare\n"
" pc_id NUMBER := :"<<nPCPos<<";\n"
diff -r 3d24e634e1c2 -r f14c9ff73183 src/drivers/oci/common.cpp
--- a/src/drivers/oci/common.cpp Wed Aug 03 08:50:45 2011 -0500
+++ b/src/drivers/oci/common.cpp Wed Aug 03 11:11:49 2011 -0500
@@ -59,7 +59,6 @@
tree.put("capacity", 8000);
tree.put("precision", 8);
tree.put("cloud_id", -1);
- tree.put("dimensions", 8);
tree.put("connection", std::string(""));
tree.put("block_table_name", std::string("output"));
tree.put("block_table_partition_column", std::string(""));
More information about the Liblas-commits
