[Liblas-commits] hg-main-tree: touching SDO_PC.PC_EXTENT without disabling the tr...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Aug 4 12:06:50 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/4291f674c28d
changeset: 1004:4291f674c28d
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu Aug 04 11:02:01 2011 -0500
description:
touching SDO_PC.PC_EXTENT without disabling the trigger will nuke the cloud's blocks.  Add code to temporarily shut this trigger off if enabled when updating the SDO_PC.PC_EXTENT
Subject: hg-main-tree: remove dead code
details:   http://hg.libpc.orghg-main-tree/rev/30b32d488aab
changeset: 1005:30b32d488aab
date:      Thu Aug 04 11:02:16 2011 -0500
description:
remove dead code
diffstat:
 include/pdal/drivers/oci/Writer.hpp |    3 +-
 src/drivers/oci/Reader.cpp          |  176 +-----------------------------------
 src/drivers/oci/Writer.cpp          |   82 ++++++++++++++++-
 3 files changed, 87 insertions(+), 174 deletions(-)
diffs (truncated from 333 to 300 lines):
diff -r 2c68227bc3a5 -r 30b32d488aab include/pdal/drivers/oci/Writer.hpp
--- a/include/pdal/drivers/oci/Writer.hpp	Wed Aug 03 13:52:24 2011 -0500
+++ b/include/pdal/drivers/oci/Writer.hpp	Thu Aug 04 11:02:16 2011 -0500
@@ -106,7 +106,8 @@
     bool isSolid() const;
     boost::int32_t getPCID() const;
     void UpdatePCExtent();
+    std::string ShutOff_SDO_PC_Trigger();
+    void TurnOn_SDO_PC_Trigger(std::string trigger_name);
     pdal::Bounds<double> CalculateBounds(PointBuffer const& buffer);
     Stage& m_stage;
diff -r 2c68227bc3a5 -r 30b32d488aab src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp	Wed Aug 03 13:52:24 2011 -0500
+++ b/src/drivers/oci/Reader.cpp	Thu Aug 04 11:02:16 2011 -0500
@@ -125,6 +125,10 @@
 const Options& Reader::s_getDefaultOptions()
     static Options options;
     return options;
@@ -169,178 +173,6 @@
-void Reader::registerFields()
-    Schema& schema = getSchemaRef();
-    Dimension x(Dimension::Field_X, Dimension::Int32);
-    Dimension y(Dimension::Field_Y, Dimension::Int32);
-    Dimension z(Dimension::Field_Z, Dimension::Int32);
-    boost::property_tree::ptree tree = m_optionsOld.GetPTree();
-    double scalex = tree.get<double>("scale.x");
-    double scaley = tree.get<double>("scale.y");
-    double scalez = tree.get<double>("scale.z");
-    double offsetx = tree.get<double>("offset.x");
-    double offsety = tree.get<double>("offset.y");
-    double offsetz = tree.get<double>("offset.z");
-    x.setNumericScale(scalex);
-    y.setNumericScale(scaley);
-    z.setNumericScale(scalez);
-    x.setNumericOffset(offsetx);
-    y.setNumericOffset(offsety);
-    z.setNumericOffset(offsetz);
-    std::ostringstream text;
-    text << "x coordinate as a long integer.  You must use the scale and "
-         << "offset information of the header to determine the double value.";
-    x.setDescription(text.str());
-    schema.addDimension(x);
-    text.str("");
-    text << "y coordinate as a long integer.  You must use the scale and "
-    y.setDescription(text.str());
-    schema.addDimension(y);
-    text.str("");
-    text << "z coordinate as a long integer.  You must use the scale and "
-    z.setDescription(text.str());
-    schema.addDimension(z);
-    text.str("");
-    Dimension intensity(Dimension::Field_Intensity, Dimension::Uint16);
-    text << "The intensity value is the integer representation of the pulse "
-         "return magnitude. This value is optional and system specific. "
-         "However, it should always be included if available.";
-    intensity.setDescription(text.str());
-    schema.addDimension(intensity);
-    text.str("");
-    Dimension return_no(Dimension::Field_ReturnNumber, Dimension::Uint8); // 3 bits only
-    text << "Return Number: The Return Number is the pulse return number for "
-         "a given output pulse. A given output laser pulse can have many "
-         "returns, and they must be marked in sequence of return. The first "
-         "return will have a Return Number of one, the second a Return "
-         "Number of two, and so on up to five returns.";
-    return_no.setDescription(text.str());
-    schema.addDimension(return_no);
-    text.str("");
-    Dimension no_returns(Dimension::Field_NumberOfReturns, Dimension::Uint8); // 3 bits only
-    text << "Number of Returns (for this emitted pulse): The Number of Returns "
-         "is the total number of returns for a given pulse. For example, "
-         "a laser data point may be return two (Return Number) within a "
-         "total number of five returns.";
-    no_returns.setDescription(text.str());
-    schema.addDimension(no_returns);
-    text.str("");
-    Dimension scan_dir(Dimension::Field_ScanDirectionFlag, Dimension::Uint8); // 1 bit only
-    text << "The Scan Direction Flag denotes the direction at which the "
-         "scanner mirror was traveling at the time of the output pulse. "
-         "A bit value of 1 is a positive scan direction, and a bit value "
-         "of 0 is a negative scan direction (where positive scan direction "
-         "is a scan moving from the left side of the in-track direction to "
-         "the right side and negative the opposite). ";
-    scan_dir.setDescription(text.str());
-    schema.addDimension(scan_dir);
-    text.str("");
-    Dimension edge(Dimension::Field_EdgeOfFlightLine, Dimension::Uint8); // 1 bit only
-    text << "The Edge of Flight Line data bit has a value of 1 only when "
-         "the point is at the end of a scan. It is the last point on "
-         "a given scan line before it changes direction.";
-    edge.setDescription(text.str());
-    schema.addDimension(edge);
-    text.str("");
-    Dimension classification(Dimension::Field_Classification, Dimension::Uint8);
-    text << "Classification in LAS 1.0 was essentially user defined and optional. "
-         "LAS 1.1 defines a standard set of ASPRS classifications. In addition, "
-         "the field is now mandatory. If a point has never been classified, this "
-         "byte must be set to zero. There are no user defined classes since "
-         "both point format 0 and point format 1 supply 8 bits per point for "
-         "user defined operations. Note that the format for classification is a "
-         "bit encoded field with the lower five bits used for class and the "
-         "three high bits used for flags.";
-    classification.setDescription(text.str());
-    schema.addDimension(classification);
-    text.str("");
-    Dimension scan_angle(Dimension::Field_ScanAngleRank, Dimension::Int8);
-    text << "The Scan Angle Rank is a signed one-byte number with a "
-         "valid range from -90 to +90. The Scan Angle Rank is the "
-         "angle (rounded to the nearest integer in the absolute "
-         "value sense) at which the laser point was output from the "
-         "laser system including the roll of the aircraft. The scan "
-         "angle is within 1 degree of accuracy from +90 to ñ90 degrees. "
-         "The scan angle is an angle based on 0 degrees being nadir, "
-         "and ñ90 degrees to the left side of the aircraft in the "
-         "direction of flight.";
-    scan_angle.setDescription(text.str());
-    schema.addDimension(scan_angle);
-    text.str("");
-    Dimension user_data(Dimension::Field_UserData, Dimension::Uint8);
-    text << "This field may be used at the userís discretion";
-    user_data.setDescription(text.str());
-    schema.addDimension(user_data);
-    text.str("");
-    Dimension point_source_id(Dimension::Field_PointSourceId, Dimension::Uint16);
-    text << "This value indicates the file from which this point originated. "
-         "Valid values for this field are 1 to 65,535 inclusive with zero "
-         "being used for a special case discussed below. The numerical value "
-         "corresponds to the File Source ID from which this point originated. "
-         "Zero is reserved as a convenience to system implementers. A Point "
-         "Source ID of zero implies that this point originated in this file. "
-         "This implies that processing software should set the Point Source "
-         "ID equal to the File Source ID of the file containing this point "
-         "at some time during processing. ";
-    point_source_id.setDescription(text.str());
-    schema.addDimension(point_source_id);
-    text.str("");
-    Dimension t(Dimension::Field_Time, Dimension::Double);
-    text << "The GPS Time is the double floating point time tag value at "
-        "which the point was acquired. It is GPS Week Time if the "
-        "Global Encoding low bit is clear and Adjusted Standard GPS "
-        "Time if the Global Encoding low bit is set (see Global Encoding "
-        "in the Public Header Block description).";
-    t.setDescription(text.str());
-    schema.addDimension(t);
-    text.str("");
-    Dimension red(Dimension::Field_Red, Dimension::Uint16);
-    text << "The red image channel value associated with this point";
-    red.setDescription(text.str());
-    schema.addDimension(red);
-    text.str("");
-    Dimension green(Dimension::Field_Green, Dimension::Uint16);
-    text << "The green image channel value associated with this point";
-    green.setDescription(text.str());
-    schema.addDimension(green);
-    text.str("");
-    Dimension blue(Dimension::Field_Blue, Dimension::Uint16);
-    text << "The blue image channel value associated with this point";
-    blue.setDescription(text.str());
-    schema.addDimension(blue);
-    text.str("");
-    return;
 Reader::~Reader()
diff -r 2c68227bc3a5 -r 30b32d488aab src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Wed Aug 03 13:52:24 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Thu Aug 04 11:02:16 2011 -0500
@@ -850,13 +850,15 @@
 void Writer::writeEnd(boost::uint64_t actualNumPointsWritten)
+    m_connection->Commit();
     if (m_doCreateIndex)
         CreateSDOEntry();
         CreateBlockIndex();
     // Update extent of SDO_PC entry
     UpdatePCExtent();
@@ -1302,6 +1304,71 @@
     return true;
+std::string Writer::ShutOff_SDO_PC_Trigger()
+    boost::property_tree::ptree&  tree = m_optionsOld.GetPTree();
+    std::string base_table_name = to_upper(tree.get<std::string>("base_table_name"));
+    std::string cloud_column_name = to_upper(tree.get<std::string>("cloud_column_name"));
+    std::ostringstream oss;
+    char szTrigger[OWNAME] = "";
+    char szStatus[OWNAME] = "";
+    oss << "select trigger_name, status from all_triggers where table_name = '" << base_table_name << "' AND TRIGGER_NAME like upper('%%MDTNPC_%%') ";
+    Statement statement = Statement(m_connection->CreateStatement(oss.str().c_str()));
+    statement->Define(szTrigger);
+    statement->Define(szStatus);
+    statement->Execute();
+    std::cout << "Trigger: " << szTrigger << " status: " << szStatus << std::endl;
+    // Yes, we're assuming there's only one trigger that met these criteria.
+    if (!strlen(szStatus))
+        // No rows returned, no trigger exists
+        return std::string("");
+    if (compare_no_case(szStatus, "ENABLED") == 0)
+        oss.str("");
+        oss << "ALTER TRIGGER " << szTrigger << " DISABLE ";
+        statement = Statement(m_connection->CreateStatement(oss.str().c_str()));
+        return std::string(szTrigger);
+    } else
+void Writer::TurnOn_SDO_PC_Trigger(std::string trigger_name)
+    if (!trigger_name.size()) return;
+    oss << "ALTER TRIGGER " << trigger_name << " ENABLE ";
 void Writer::UpdatePCExtent()
@@ -1330,7 +1397,14 @@
More information about the Liblas-commits mailing list
