[Liblas-commits] hg-main-tree: scales need to default to 1.0, not 0.0 or bad thin...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Aug 5 16:00:38 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/0755f9209963
changeset: 1014:0755f9209963
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Aug 05 10:51:49 2011 -0500
description:
scales need to default to 1.0, not 0.0 or bad things'll happen
Subject: hg-main-tree: common Connect() method that uses the new Options stuff
details:   http://hg.libpc.orghg-main-tree/rev/528982e49875
changeset: 1015:528982e49875
date:      Fri Aug 05 13:33:03 2011 -0500
description:
Subject: hg-main-tree: turn off oracle-write
details:   http://hg.libpc.orghg-main-tree/rev/a811e9658a74
changeset: 1016:a811e9658a74
date:      Fri Aug 05 14:58:54 2011 -0500
description:
Subject: hg-main-tree: Optionsify drivers.oci.writer
details:   http://hg.libpc.orghg-main-tree/rev/8b20a7c44775
changeset: 1017:8b20a7c44775
date:      Fri Aug 05 15:00:06 2011 -0500
description:
Subject: hg-main-tree: bring PDAL's native driver in line with libLAS' for header handling.  LASzip still not working for some reason yet
details:   http://hg.libpc.orghg-main-tree/rev/61a4bd57e21a
changeset: 1018:61a4bd57e21a
date:      Fri Aug 05 15:00:32 2011 -0500
description:
diffstat:
 apps/pc2pc.cpp                                    |  134 ++++++------
 include/pdal/drivers/las/Header.hpp               |   13 +-
 include/pdal/drivers/las/VariableLengthRecord.hpp |    3 +-
 include/pdal/drivers/las/Writer.hpp               |    1 -
 include/pdal/drivers/oci/Reader.hpp               |    1 -
 include/pdal/drivers/oci/Writer.hpp               |   15 +-
 include/pdal/drivers/oci/common.hpp               |    2 +-
 src/drivers/las/Header.cpp                        |   26 ++
 src/drivers/las/LasHeaderWriter.cpp               |   73 ++++---
 src/drivers/las/VariableLengthRecord.cpp          |   11 +
 src/drivers/las/Writer.cpp                        |    9 +-
 src/drivers/oci/Reader.cpp                        |   32 +---
 src/drivers/oci/Writer.cpp                        |  218 ++++++++-------------
 src/drivers/oci/common.cpp                        |   24 +--
 src/filters/ScalingFilter.cpp                     |   12 +-
 15 files changed, 265 insertions(+), 309 deletions(-)
diffs (truncated from 1065 to 300 lines):
diff -r 435254c9c30f -r 61a4bd57e21a apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/apps/pc2pc.cpp	Fri Aug 05 15:00:32 2011 -0500
@@ -137,73 +137,73 @@
         writer.write(numPoints);
-    else if (hasOption("oracle-writer"))
-#ifdef PDAL_HAVE_ORACLE
-        try{
-        pdal::drivers::las::LasReader reader(m_inputFile);
-        const boost::uint64_t numPoints = reader.getNumPoints();
-        boost::property_tree::ptree load_tree;
-        boost::property_tree::read_xml(m_xml, load_tree);
-        boost::property_tree::ptree oracle_options = load_tree.get_child("pdal.drivers.oci.writer");
-        boost::property_tree::ptree las_options = load_tree.get_child("pdal.drivers.las");
-        pdal::OptionsOld options(oracle_options);
-        boost::property_tree::ptree in_srs_options = las_options.get_child("spatialreference");
-        std::string in_wkt = in_srs_options.get<std::string>("userinput");
-        boost::property_tree::ptree out_srs_options = oracle_options.get_child("spatialreference");
-        std::string out_wkt = out_srs_options.get<std::string>("userinput");
-        pdal::SpatialReference in_ref(in_wkt);
-        pdal::SpatialReference out_ref(out_wkt);
-        boost::property_tree::ptree& tree = options.GetPTree();
-        boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
-        double scalex = oracle_options.get<double>("scale.x");
-        double scaley = oracle_options.get<double>("scale.y");
-        double scalez = oracle_options.get<double>("scale.z");
-        double offsetx = oracle_options.get<double>("offset.x");
-        double offsety = oracle_options.get<double>("offset.y");
-        double offsetz = oracle_options.get<double>("offset.z");
-        pdal::filters::CacheFilter cache(reader, 1, capacity);
-        pdal::filters::Chipper chipper(cache, capacity);
-        pdal::filters::ScalingFilter scalingFilter(chipper);
-        pdal::filters::ReprojectionFilter reprojectionFilter(scalingFilter, in_ref, out_ref);
-        pdal::filters::DescalingFilter descalingFilter(reprojectionFilter,
-                                                       scalex, offsetx,
-                                                       scaley, offsety,
-                                                       scalez, offsetz);
-        // pdal::filters::ByteSwapFilter swapper(descalingFilter);
-        pdal::drivers::oci::Writer writer(descalingFilter, options);
-        writer.initialize();
-        writer.write(numPoints);
-        boost::property_tree::ptree output_tree;
-        // output_tree.put_child(writer.getName(), options.GetPTree());
-        // boost::property_tree::write_xml(m_xml, output_tree);
-        } catch (pdal::pdal_error& e)
-            std::cerr << "Error writing oracle: " << e.what() << std::endl;
-#else
-        throw configuration_error("PDAL not compiled with Oracle support");
-#endif
+//     else if (hasOption("oracle-writer"))
+// #ifdef PDAL_HAVE_ORACLE
+//         try{
+//         pdal::drivers::las::LasReader reader(m_inputFile);
+//         const boost::uint64_t numPoints = reader.getNumPoints();
+//         boost::property_tree::ptree load_tree;
+//         boost::property_tree::read_xml(m_xml, load_tree);
+//         boost::property_tree::ptree oracle_options = load_tree.get_child("pdal.drivers.oci.writer");
+//         boost::property_tree::ptree las_options = load_tree.get_child("pdal.drivers.las");
+//         pdal::OptionsOld options(oracle_options);
+//         boost::property_tree::ptree in_srs_options = las_options.get_child("spatialreference");
+//         std::string in_wkt = in_srs_options.get<std::string>("userinput");
+//         boost::property_tree::ptree out_srs_options = oracle_options.get_child("spatialreference");
+//         std::string out_wkt = out_srs_options.get<std::string>("userinput");
+//         pdal::SpatialReference in_ref(in_wkt);
+//         pdal::SpatialReference out_ref(out_wkt);
+//         boost::property_tree::ptree& tree = options.GetPTree();
+//         boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
+//         double scalex = oracle_options.get<double>("scale.x");
+//         double scaley = oracle_options.get<double>("scale.y");
+//         double scalez = oracle_options.get<double>("scale.z");
+//         double offsetx = oracle_options.get<double>("offset.x");
+//         double offsety = oracle_options.get<double>("offset.y");
+//         double offsetz = oracle_options.get<double>("offset.z");
+//         pdal::filters::CacheFilter cache(reader, 1, capacity);
+//         pdal::filters::Chipper chipper(cache, capacity);
+//         pdal::filters::ScalingFilter scalingFilter(chipper);
+//         pdal::filters::ReprojectionFilter reprojectionFilter(scalingFilter, in_ref, out_ref);
+//         pdal::filters::DescalingFilter descalingFilter(reprojectionFilter,
+//                                                        scalex, offsetx,
+//                                                        scaley, offsety,
+//                                                        scalez, offsetz);
+//         // pdal::filters::ByteSwapFilter swapper(descalingFilter);
+//         pdal::drivers::oci::Writer writer(descalingFilter, options);
+//         writer.initialize();
+//         writer.write(numPoints);
+//         boost::property_tree::ptree output_tree;
+//         // output_tree.put_child(writer.getName(), options.GetPTree());
+//         // boost::property_tree::write_xml(m_xml, output_tree);
+//         } catch (pdal::pdal_error& e)
+//             std::cerr << "Error writing oracle: " << e.what() << std::endl;
+// #else
+//         throw configuration_error("PDAL not compiled with Oracle support");
+// #endif
     //     else if (hasOption("oracle-reader"))
diff -r 435254c9c30f -r 61a4bd57e21a include/pdal/drivers/las/Header.hpp
--- a/include/pdal/drivers/las/Header.hpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/include/pdal/drivers/las/Header.hpp	Fri Aug 05 15:00:32 2011 -0500
@@ -305,6 +305,8 @@
     const VLRList& getVLRs() const;
     VLRList& getVLRs();
+    std::size_t getVLRBlockSize() const;
     /// Returns a property_tree that contains
     /// all of the header data in a structured format.
     boost::property_tree::ptree GetPTree() const;
@@ -319,10 +321,10 @@
     void setSpatialReference(const SpatialReference&);
     const SpatialReference& getSpatialReference() const;
-    //void to_rst(std::ostream& os) const;
-    //void to_xml(std::ostream& os) const;
-    //void to_json(std::ostream& os) const;
+    void SetHeaderPadding(boost::uint32_t v);
+    boost::uint32_t GetHeaderPadding() const;
 private:
     typedef Vector<double> PointScales;
     typedef Vector<double> PointOffsets;
@@ -365,7 +367,8 @@
     PointScales m_scales;
     PointOffsets m_offsets;
     bool m_isCompressed;
+    boost::uint32_t m_headerPadding;
     PointFormat m_pointFormat;
     Bounds<double> m_bounds;
diff -r 435254c9c30f -r 61a4bd57e21a include/pdal/drivers/las/VariableLengthRecord.hpp
--- a/include/pdal/drivers/las/VariableLengthRecord.hpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/include/pdal/drivers/las/VariableLengthRecord.hpp	Fri Aug 05 15:00:32 2011 -0500
@@ -80,7 +80,8 @@
     const boost::uint8_t* getBytes() const;
     std::size_t getLength() const;
+    std::size_t getTotalSize() const;
     static const int s_headerLength = 54;
     static void setSRSFromVLRs(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
diff -r 435254c9c30f -r 61a4bd57e21a include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/include/pdal/drivers/las/Writer.hpp	Fri Aug 05 15:00:32 2011 -0500
@@ -93,7 +93,6 @@
     SpatialReference m_spatialReference;
 #ifdef PDAL_HAVE_LASZIP
-    boost::scoped_ptr<LASzip> m_zip;
     boost::scoped_ptr<LASzipper> m_zipper;
     boost::scoped_ptr<ZipPoint> m_zipPoint;
 #endif
diff -r 435254c9c30f -r 61a4bd57e21a include/pdal/drivers/oci/Reader.hpp
--- a/include/pdal/drivers/oci/Reader.hpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/include/pdal/drivers/oci/Reader.hpp	Fri Aug 05 15:00:32 2011 -0500
@@ -85,7 +85,6 @@
     QueryType describeQueryType() const;
     BlockPtr defineBlock() const;
     Schema fetchSchema(sdo_pc* pc);
-    Connection Connect();
     Connection m_connection;
     Statement m_statement;
diff -r 435254c9c30f -r 61a4bd57e21a include/pdal/drivers/oci/Writer.hpp
--- a/include/pdal/drivers/oci/Writer.hpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/include/pdal/drivers/oci/Writer.hpp	Fri Aug 05 15:00:32 2011 -0500
@@ -53,7 +53,6 @@
 public:
     Writer(Stage& prevStage, const Options&);
-    Writer(Stage& prevStage, OptionsOld& options);
     ~Writer();
     virtual void initialize();
@@ -82,7 +81,7 @@
     void CreateBlockIndex();
     void CreateBlockTable();
     void CreateSDOEntry();
-    void CreatePCEntry(std::vector<boost::uint8_t> const* header_data);
+    void CreatePCEntry();
     long GetGType();
     std::string CreatePCElemInfo();
     bool BlockTableExists();
@@ -99,9 +98,13 @@
                       pdal::Bounds<double> const& extent);
     void SetElements(Statement statement,
                      OCIArray* elem_info);
-    bool isVerbose() const;
-    bool isDebug() const;
+    template<typename T> T getDefaultedOption(std::string const& option_name) const
+        T default_value = Writer::s_getDefaultOptions().getOption<T>(option_name).getValue();
+        return getOptions().getValueOrDefault<T>(option_name, default_value);
     bool is3d() const;
     bool isSolid() const;
     boost::int32_t getPCID() const;
@@ -111,12 +114,12 @@
     pdal::Bounds<double> CalculateBounds(PointBuffer const& buffer);
     Stage& m_stage;
-    OptionsOld& m_optionsOld;
     pdal::Bounds<double> m_bounds; // Bounds of the entire point cloud
     bool m_verbose;
     bool m_doCreateIndex;
     Bounds<double> m_pcExtent;
+    int m_pc_id;
 }}} // namespace pdal::driver::oci
diff -r 435254c9c30f -r 61a4bd57e21a include/pdal/drivers/oci/common.hpp
--- a/include/pdal/drivers/oci/common.hpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/include/pdal/drivers/oci/common.hpp	Fri Aug 05 15:00:32 2011 -0500
@@ -171,7 +171,7 @@
 typedef boost::shared_ptr<Block> BlockPtr;
-PDAL_DLL Connection Connect(pdal::OptionsOld const& options);
+PDAL_DLL Connection Connect(pdal::Options const& options, bool debug, int verbosity);
 std::string to_upper(std::string const& input);
diff -r 435254c9c30f -r 61a4bd57e21a src/drivers/las/Header.cpp
--- a/src/drivers/las/Header.cpp	Fri Aug 05 09:34:30 2011 -0500
+++ b/src/drivers/las/Header.cpp	Fri Aug 05 15:00:32 2011 -0500
@@ -363,6 +363,16 @@
     return m_bounds.getMinimum(2);
+boost::uint32_t LasHeader::GetHeaderPadding() const
+    return m_headerPadding;
+void LasHeader::SetHeaderPadding( boost::uint32_t v)
+    m_headerPadding = v;
 void LasHeader::SetMax(double x, double y, double z)
     // m_extent = Bounds(m_extent.min(0), m_extent.min(1), m_extent.max(0), m_extent.max(1), m_extent.min(2), m_extent.max(2));
@@ -422,6 +432,7 @@
More information about the Liblas-commits mailing list
