[Liblas-commits] hg-main-tree: use proper comparator elsewhere too
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Aug 11 16:33:47 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/e13709a23060
changeset: 1045:e13709a23060
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Aug 11 13:32:41 2011 -0700
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/c81e7da692b6
changeset: 1046:c81e7da692b6
date:      Thu Aug 11 13:32:54 2011 -0700
description:
merge
diffstat:
 src/drivers/las/Writer.cpp            |    2 --
 test/data/laszip/laszip-generated.laz |    0
 test/unit/FileUtilsTest.cpp           |    4 ++--
 test/unit/LasReaderTest.cpp           |    2 +-
 test/unit/LasWriterTest.cpp           |   17 +++++++++--------
 test/unit/LiblasWriterTest.cpp        |   26 +++++++++++++-------------
 6 files changed, 25 insertions(+), 26 deletions(-)
diffs (185 lines):
diff -r a1fdabfec72d -r c81e7da692b6 src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp	Thu Aug 11 13:31:17 2011 -0700
+++ b/src/drivers/las/Writer.cpp	Thu Aug 11 13:32:54 2011 -0700
@@ -90,8 +90,6 @@
     Writer::initialize();
-    m_spatialReference = getPrevStage().getSpatialReference();
     m_streamManager.open();
     try
diff -r a1fdabfec72d -r c81e7da692b6 test/data/laszip/laszip-generated.laz
Binary file test/data/laszip/laszip-generated.laz has changed
diff -r a1fdabfec72d -r c81e7da692b6 test/unit/FileUtilsTest.cpp
--- a/test/unit/FileUtilsTest.cpp	Thu Aug 11 13:31:17 2011 -0700
+++ b/test/unit/FileUtilsTest.cpp	Thu Aug 11 13:32:54 2011 -0700
@@ -132,11 +132,11 @@
     // test absolute case
     const std::string a = FileUtils::getDirectory(drive + "/a/b/foo.txt");
-    BOOST_CHECK(a == drive+"/a/b");
+    BOOST_CHECK_EQUAL(a, drive+"/a/b");
     // test relative case
     const std::string b = FileUtils::getDirectory("a/b/foo.txt");
-    BOOST_CHECK(b == "a/b");
+    BOOST_CHECK_EQUAL(b, "a/b");
     return;
diff -r a1fdabfec72d -r c81e7da692b6 test/unit/LasReaderTest.cpp
--- a/test/unit/LasReaderTest.cpp	Thu Aug 11 13:31:17 2011 -0700
+++ b/test/unit/LasReaderTest.cpp	Thu Aug 11 13:32:54 2011 -0700
@@ -177,7 +177,7 @@
 BOOST_AUTO_TEST_CASE(test_random_laz)
-    pdal::drivers::las::LasReader reader(Support::datapath("1.2-with-color.laz"));
+    pdal::drivers::las::LasReader reader(Support::datapath("laszip/laszip-generated.laz"));
     BOOST_CHECK(reader.getDescription() == "Las Reader");
     reader.initialize();
diff -r a1fdabfec72d -r c81e7da692b6 test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp	Thu Aug 11 13:31:17 2011 -0700
+++ b/test/unit/LasWriterTest.cpp	Thu Aug 11 13:32:54 2011 -0700
@@ -93,40 +93,41 @@
 BOOST_AUTO_TEST_CASE(LasWriterTest_test_simple_laz)
     // remove file from earlier run, if needed
-    FileUtils::deleteFile("temp.laz");
+    FileUtils::deleteFile("laszip/LasWriterTest_test_simple_laz.laz");
-    pdal::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
+    pdal::drivers::las::LasReader reader(Support::datapath("laszip/basefile.las"));
-    std::ostream* ofs = FileUtils::createFile("temp.laz");
+    std::ostream* ofs = FileUtils::createFile(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"));
         const boost::uint64_t numPoints = reader.getNumPoints();
         // need to scope the writer, so that's it dtor can use the stream
         pdal::drivers::las::LasWriter writer(reader, ofs);
-        writer.initialize();
         writer.setCompressed(true);
         writer.setDate(0, 0);
         writer.setPointFormat(::pdal::drivers::las::PointFormat3);
         writer.setSystemIdentifier("");
         writer.setGeneratingSoftware("TerraScan");
+        writer.initialize();
         writer.write(numPoints);
     FileUtils::closeFile(ofs);
-        pdal::drivers::las::LasReader reader("temp.laz");
+        pdal::drivers::las::LasReader reader(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"));
-    bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color.laz"));
+    bool filesSame = Support::compare_files(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"), Support::datapath("laszip/laszip-generated.laz"));
     BOOST_CHECK(filesSame);
     if (filesSame)
+        FileUtils::deleteFile("LasWriterTest_test_simple_laz.laz");
     return;
diff -r a1fdabfec72d -r c81e7da692b6 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp	Thu Aug 11 13:31:17 2011 -0700
+++ b/test/unit/LiblasWriterTest.cpp	Thu Aug 11 13:32:54 2011 -0700
@@ -53,11 +53,11 @@
 BOOST_AUTO_TEST_CASE(LiblasWriterTest_test_simple_las)
-    FileUtils::deleteFile("temp.las");
+    FileUtils::deleteFile("LiblasWriterTest_test_simple_las.las");
     LiblasReader reader(Support::datapath("1.2-with-color.las"));
-    std::ostream* ofs = FileUtils::createFile("temp.las");
+    std::ostream* ofs = FileUtils::createFile("LiblasWriterTest_test_simple_las.las");
@@ -78,12 +78,12 @@
-    bool filesSame = Support::compare_files("temp.las", Support::datapath("simple.las"));
+    bool filesSame = Support::compare_files("LiblasWriterTest_test_simple_las.las", Support::datapath("simple.las"));
     if (filesSame)
     return;
@@ -92,9 +92,9 @@
 BOOST_AUTO_TEST_CASE(LiblasWriterTest_test_options)
+    FileUtils::deleteFile("LiblasWriterTest_test_options.las");
-    Option<std::string> opt("filename", "temp.las");
+    Option<std::string> opt("filename", "LiblasWriterTest_test_options.las");
     Options opts(opt);
@@ -116,12 +116,12 @@
+    bool filesSame = Support::compare_files("LiblasWriterTest_test_options.las", Support::datapath("simple.las"));
     if (filesSame)
     return;
@@ -131,11 +131,11 @@
 BOOST_AUTO_TEST_CASE(LiblasWriterTest_test_simple_laz)
+    FileUtils::deleteFile("laszip/LiblasWriterTest_test_simple_laz.las");
-    LiblasReader reader(Support::datapath("1.2-with-color.las"));
+    LiblasReader reader(Support::datapath("laszip/basefile.las"));
+    std::ostream* ofs = FileUtils::createFile("laszip/LiblasWriterTest_test_simple_laz.laz");
@@ -155,12 +155,12 @@
+    bool filesSame = Support::compare_files("laszip/LiblasWriterTest_test_simple_laz.laz", Support::datapath("laszip/laszip-generated.laz"));
     if (filesSame)
+        FileUtils::deleteFile("laszip/LiblasWriterTest_test_simple_laz.laz");
     return;
More information about the Liblas-commits mailing list
