[Liblas-commits] hg-main-tree: improve file diff functions
liblas-commits at liblas.org
Thu Aug 11 19:48:56 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/49ea48054001
changeset: 1051:49ea48054001
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Aug 11 15:53:52 2011 -0700
description:
Subject: hg-main-tree: add ability to diff two files, but exclude certain regions of the file
details: http://hg.libpc.orghg-main-tree/rev/79705964aba5
changeset: 1052:79705964aba5
date: Thu Aug 11 16:22:36 2011 -0700
description:
Subject: hg-main-tree: add special dir for unit test output files to live in
details: http://hg.libpc.orghg-main-tree/rev/7fd10a5c1b88
changeset: 1053:7fd10a5c1b88
date: Thu Aug 11 16:41:12 2011 -0700
description:
Subject: hg-main-tree: use the new Support::temppath feature
details: http://hg.libpc.orghg-main-tree/rev/ab86e0f7d54f
changeset: 1054:ab86e0f7d54f
date: Thu Aug 11 16:47:43 2011 -0700
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/4f3f0edf1584
changeset: 1055:4f3f0edf1584
date: Thu Aug 11 16:47:55 2011 -0700
description:
merge
diffstat:
src/PipelineReader.cpp | 6 +-
test/data/misc/data1.dat | 1 +
test/data/misc/data1.txt | 3 +
test/data/misc/data2.dat | 1 +
test/data/misc/data2.txt | 3 +
test/data/misc/data3.dat | 1 +
test/data/misc/data3.txt | 5 +
test/data/misc/data4a.dat | 1 +
test/data/misc/data4b.dat | 1 +
test/data/pipeline_readcomments.xml | 18 +++
test/data/pipeline_writecomments.xml | 26 ++++
test/temp/README.txt | 1 +
test/unit/CMakeLists.txt | 1 +
test/unit/LasWriterTest.cpp | 18 +-
test/unit/LiblasWriterTest.cpp | 26 ++--
test/unit/PipelineReaderTest.cpp | 9 +
test/unit/Support.cpp | 131 ++++++++++++++++++---
test/unit/Support.hpp | 21 +++-
test/unit/SupportTest.cpp | 210 +++++++++++++++++++++++++++++++++++
19 files changed, 435 insertions(+), 48 deletions(-)
diffs (truncated from 780 to 300 lines):
diff -r b0027041eb7a -r 4f3f0edf1584 src/PipelineReader.cpp
--- a/src/PipelineReader.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/src/PipelineReader.cpp Thu Aug 11 16:47:55 2011 -0700
@@ -449,7 +449,8 @@
m_inputXmlFile = filename;
boost::property_tree::ptree tree;
- boost::property_tree::xml_parser::read_xml(filename, tree);
+ boost::property_tree::xml_parser::read_xml(filename, tree,
+ boost::property_tree::xml_parser::no_comments);
boost::optional<boost::property_tree::ptree> opt( tree.get_child_optional("WriterPipeline") );
if (!opt.is_initialized())
@@ -472,7 +473,8 @@
boost::optional<boost::property_tree::ptree> opt( tree.get_child_optional("ReaderPipeline") );
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data1.dat
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/test/data/misc/data1.dat Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,1 @@
+abcde
\ No newline at end of file
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data1.txt
+++ b/test/data/misc/data1.txt Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,3 @@
+The quick brown fox
+jumped over
+the lazy dog.
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data2.dat
+++ b/test/data/misc/data2.dat Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,1 @@
+abcdf
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data2.txt
+++ b/test/data/misc/data2.txt Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,3 @@
+jumped o'er
+the lazy dog.
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data3.dat
+++ b/test/data/misc/data3.dat Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,1 @@
+abc
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data3.txt
+++ b/test/data/misc/data3.txt Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,5 @@
+jumped over
+the lazy dog.
+Oh, that
+lazy dog.
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data4a.dat
+++ b/test/data/misc/data4a.dat Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,1 @@
+abcdefghijklmnopqrstuvwxyz
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/misc/data4b.dat
+++ b/test/data/misc/data4b.dat Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,1 @@
+abcDEFGhijklmnopqrstuvw**z
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/pipeline_readcomments.xml
+++ b/test/data/pipeline_readcomments.xml Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,18 @@
+<?xml version="1.0"?>
+<ReaderPipeline>
+ <Filter>
+ <Type>filters.crop</Type>
+ <Option>
+ <Name>bounds</Name>
+ <Value>([0,1000000],[0,1000000],[0,1000000])</Value>
+ </Option>
+ <Reader>
+ <Type>drivers.las.reader</Type>
+ <Option>
+ <Name>filename</Name>
+ <Value>1.2-with-color.las</Value>
+ </Option>
+ <!-- This is a comment -->
+ </Reader>
+ </Filter>
+</ReaderPipeline>
diff -r b0027041eb7a -r 4f3f0edf1584 test/data/pipeline_writecomments.xml
+++ b/test/data/pipeline_writecomments.xml Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,26 @@
+<?xml version="1.0" encoding="utf-8"?>
+<WriterPipeline>
+ <Writer>
+ <Type>drivers.las.writer</Type>
+ <Option>
+ <Value>out.las</Value>
+ <Description>junk junk junk</Description>
+ </Option>
+ <Filter>
+ <Option>
+ </Option>
+ <Reader>
+ <Option>
+ </Option>
+ </Reader>
+ </Filter>
+ </Writer>
+</WriterPipeline>
diff -r b0027041eb7a -r 4f3f0edf1584 test/temp/README.txt
+++ b/test/temp/README.txt Thu Aug 11 16:47:55 2011 -0700
@@ -0,0 +1,1 @@
+The unit tests write files into this directory. This directory must exist.
diff -r b0027041eb7a -r 4f3f0edf1584 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Thu Aug 11 15:48:12 2011 -0500
+++ b/test/unit/CMakeLists.txt Thu Aug 11 16:47:55 2011 -0700
@@ -47,6 +47,7 @@
SpatialReferenceTest.cpp
StageFactoryTest.cpp
StreamManagerTest.cpp
+ SupportTest.cpp
TerraSolidTest.cpp
UtilsTest.cpp
VectorTest.cpp
diff -r b0027041eb7a -r 4f3f0edf1584 test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/test/unit/LasWriterTest.cpp Thu Aug 11 16:47:55 2011 -0700
@@ -57,7 +57,7 @@
pdal::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
- std::ostream* ofs = FileUtils::createFile("temp.las");
+ std::ostream* ofs = FileUtils::createFile(Support::temppath("temp.las"));
// need to scope the writer, so that's it dtor can use the stream
@@ -78,12 +78,12 @@
FileUtils::closeFile(ofs);
- bool filesSame = Support::compare_files("temp.las", Support::datapath("simple.las"));
+ bool filesSame = Support::compare_files(Support::temppath("temp.las"), Support::datapath("simple.las"));
BOOST_CHECK(filesSame);
if (filesSame)
- FileUtils::deleteFile("temp.las");
+ FileUtils::deleteFile(Support::temppath("temp.las"));
return;
@@ -97,7 +97,7 @@
pdal::drivers::las::LasReader reader(Support::datapath("laszip/basefile.las"));
- std::ostream* ofs = FileUtils::createFile(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"));
+ std::ostream* ofs = FileUtils::createFile(Support::temppath("LasWriterTest_test_simple_laz.laz"));
const boost::uint64_t numPoints = reader.getNumPoints();
@@ -119,16 +119,16 @@
- pdal::drivers::las::LasReader reader(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"));
+ pdal::drivers::las::LasReader reader(Support::temppath("LasWriterTest_test_simple_laz.laz"));
- bool filesSame = Support::compare_files(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"),
+ bool filesSame = Support::compare_files(Support::temppath("LasWriterTest_test_simple_laz.laz"),
Support::datapath("laszip/laszip-generated.laz"));
if (filesSame)
- FileUtils::deleteFile(Support::datapath("laszip/LasWriterTest_test_simple_laz.laz"));
+ FileUtils::deleteFile(Support::temppath("LasWriterTest_test_simple_laz.laz"));
return;
@@ -142,7 +142,7 @@
pdal::drivers::las::LasReader reader(Support::datapath("1.2_3.las"));
@@ -174,7 +174,7 @@
//if (filesSame)
return;
diff -r b0027041eb7a -r 4f3f0edf1584 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp Thu Aug 11 15:48:12 2011 -0500
+++ b/test/unit/LiblasWriterTest.cpp Thu Aug 11 16:47:55 2011 -0700
@@ -57,7 +57,7 @@
LiblasReader reader(Support::datapath("1.2-with-color.las"));
- std::ostream* ofs = FileUtils::createFile("LiblasWriterTest_test_simple_las.las");
+ std::ostream* ofs = FileUtils::createFile(Support::temppath("LiblasWriterTest_test_simple_las.las"));
@@ -78,12 +78,12 @@
- bool filesSame = Support::compare_files("LiblasWriterTest_test_simple_las.las", Support::datapath("simple.las"));
+ bool filesSame = Support::compare_files(Support::temppath("LiblasWriterTest_test_simple_las.las"), Support::datapath("simple.las"));
if (filesSame)
- FileUtils::deleteFile("LiblasWriterTest_test_simple_las.las");
+ FileUtils::deleteFile(Support::temppath("LiblasWriterTest_test_simple_las.las"));
return;
@@ -94,7 +94,7 @@
// remove file from earlier run, if needed
FileUtils::deleteFile(Support::datapath("LiblasWriterTest_test_options.las"));
- Option<std::string> opt("filename", Support::datapath("LiblasWriterTest_test_options.las"));
+ Option<std::string> opt("filename", Support::temppath("LiblasWriterTest_test_options.las"));
Options opts(opt);
@@ -116,13 +116,13 @@
writer.write(numPoints);
- bool filesSame = Support::compare_files(Support::datapath("LiblasWriterTest_test_options.las"),
+ bool filesSame = Support::compare_files(Support::temppath("LiblasWriterTest_test_options.las"),
if (filesSame)
- FileUtils::deleteFile(Support::datapath("LiblasWriterTest_test_options.las"));
+ FileUtils::deleteFile(Support::temppath("LiblasWriterTest_test_options.las"));
return;
@@ -132,11 +132,11 @@
BOOST_AUTO_TEST_CASE(LiblasWriterTest_test_simple_laz)
- FileUtils::deleteFile(Support::datapath("laszip/LiblasWriterTest_test_simple_laz.laz"));
+ FileUtils::deleteFile(Support::temppath("LiblasWriterTest_test_simple_laz.laz"));
LiblasReader reader(Support::datapath("laszip/basefile.las"));
- std::ostream* ofs = FileUtils::createFile(Support::datapath("laszip/LiblasWriterTest_test_simple_laz.laz"));
+ std::ostream* ofs = FileUtils::createFile(Support::temppath("LiblasWriterTest_test_simple_laz.laz"));
@@ -156,13 +156,13 @@
- bool filesSame = Support::compare_files(Support::datapath("laszip/LiblasWriterTest_test_simple_laz.laz"),
+ bool filesSame = Support::compare_files(Support::temppath("LiblasWriterTest_test_simple_laz.laz"),
if (filesSame)
return;
More information about the Liblas-commits
