[Liblas-commits] hg-main-tree: added run_command(),
for quick unit tests of cmd l...
liblas-commits at liblas.org
Thu Aug 11 21:00:30 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/ba0f4011686e
changeset: 1057:ba0f4011686e
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Aug 11 18:00:00 2011 -0700
description:
added run_command(), for quick unit tests of cmd line apps
Subject: hg-main-tree: stubs for cmd line tests
details: http://hg.libpc.orghg-main-tree/rev/8dc1ec49b08e
changeset: 1058:8dc1ec49b08e
date: Thu Aug 11 18:00:15 2011 -0700
description:
diffstat:
test/unit/CMakeLists.txt | 3 ++
test/unit/Support.cpp | 45 ++++++++++++++++++++++++++++++++++++++++
test/unit/Support.hpp | 5 ++++
test/unit/SupportTest.cpp | 18 ++++++++++++++++
test/unit/pc2pcTest.cpp | 49 ++++++++++++++++++++++++++++++++++++++++++++
test/unit/pcinfoTest.cpp | 49 ++++++++++++++++++++++++++++++++++++++++++++
test/unit/pcpipelineTest.cpp | 49 ++++++++++++++++++++++++++++++++++++++++++++
7 files changed, 218 insertions(+), 0 deletions(-)
diffs (265 lines):
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Thu Aug 11 16:52:42 2011 -0700
+++ b/test/unit/CMakeLists.txt Thu Aug 11 18:00:15 2011 -0700
@@ -12,6 +12,9 @@
endif()
SET(PDAL_UNITTEST_TEST_SRC
+ pc2pcTest.cpp
+ pcinfoTest.cpp
+ pcpipelineTest.cpp
BoundsTest.cpp
ByteSwapFilterTest.cpp
CacheFilterTest.cpp
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/Support.cpp
--- a/test/unit/Support.cpp Thu Aug 11 16:52:42 2011 -0700
+++ b/test/unit/Support.cpp Thu Aug 11 18:00:15 2011 -0700
@@ -311,3 +311,48 @@
BOOST_CHECK_CLOSE(p.getMaximum(1), q.getMaximum(1), 1);
BOOST_CHECK_CLOSE(p.getMaximum(2), q.getMaximum(2), 1);
+// http://www.codepedia.com/1/CppStringReplace
+static std::string replaceAll(std::string result,
+ const std::string& replaceWhat,
+ const std::string& replaceWithWhat)
+ while(1)
+ const int pos = result.find(replaceWhat);
+ if (pos==-1) break;
+ result.replace(pos,replaceWhat.size(),replaceWithWhat);
+ return result;
+int Support::run_command(const std::string& rawcmd, std::string& output)
+ const int maxbuf = 4096;
+ char buf[maxbuf];
+ const std::string cmd = replaceAll(rawcmd, "/", "\\");
+ output = "";
+ FILE* fp = _popen(cmd.c_str(), "r");
+ while (!feof(fp))
+ if (fgets(buf, maxbuf, fp) == NULL)
+ if (feof(fp)) break;
+ if (ferror(fp))
+ throw std::runtime_error("error executing command");
+ output += buf;
+ int stat = _pclose(fp);
+ return stat;
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/Support.hpp
--- a/test/unit/Support.hpp Thu Aug 11 16:52:42 2011 -0700
+++ b/test/unit/Support.hpp Thu Aug 11 18:00:15 2011 -0700
@@ -96,6 +96,11 @@
static void check_p710_p711_p712(const pdal::PointBuffer& data, const pdal::Schema& schema);
static void compareBounds(const pdal::Bounds<double>& p, const pdal::Bounds<double>& q);
+ // executes "cmd" via popen, copying stdout into output and returning the status code
+ // note: under windows, all "/" characrters in cmd will be converted to "\\" for you
+ static int run_command(const std::string& cmd, std::string& output);
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/SupportTest.cpp
--- a/test/unit/SupportTest.cpp Thu Aug 11 16:52:42 2011 -0700
+++ b/test/unit/SupportTest.cpp Thu Aug 11 18:00:15 2011 -0700
@@ -207,4 +207,22 @@
return;
+BOOST_AUTO_TEST_CASE(test_run_command)
+ //const char* cmd = "../../bin/Debug/pcinfo ../data/simple.las";
+ // amazingly, this command works under both dos *and* unix shells
+ const char* cmd = "echo foo";
+ std::string output;
+ const int stat = Support::run_command(cmd, output);
+ BOOST_CHECK_EQUAL(output.substr(0, 3), "foo");
+ BOOST_CHECK_EQUAL(stat, 0);
+ return;
BOOST_AUTO_TEST_SUITE_END()
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/pc2pcTest.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/test/unit/pc2pcTest.cpp Thu Aug 11 18:00:15 2011 -0700
@@ -0,0 +1,49 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include <boost/test/unit_test.hpp>
+#include <iostream>
+#include <sstream>
+#include <string>
+BOOST_AUTO_TEST_SUITE(pc2pcTest)
+BOOST_AUTO_TEST_CASE(pc2pcTest_test1)
+ return;
+BOOST_AUTO_TEST_SUITE_END()
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/pcinfoTest.cpp
+++ b/test/unit/pcinfoTest.cpp Thu Aug 11 18:00:15 2011 -0700
@@ -0,0 +1,49 @@
+* OF SUCH DAMAGE.
+#include <sstream>
+#include <string>
+BOOST_AUTO_TEST_SUITE(pcinfoTest)
+BOOST_AUTO_TEST_CASE(pcinfoTest_1)
+ return;
diff -r f6000aa849f7 -r 8dc1ec49b08e test/unit/pcpipelineTest.cpp
+++ b/test/unit/pcpipelineTest.cpp Thu Aug 11 18:00:15 2011 -0700
@@ -0,0 +1,49 @@
+* OF SUCH DAMAGE.
+#include <sstream>
+#include <string>
+BOOST_AUTO_TEST_SUITE(pcpipelineTest)
+BOOST_AUTO_TEST_CASE(pcpipelineTest_1)
+ return;
More information about the Liblas-commits
