[Liblas-commits] hg-main-tree: dumb fix for memleak
liblas-commits at liblas.org
Mon Aug 15 10:34:18 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/483284c82936
changeset: 1089:483284c82936
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Aug 15 07:34:03 2011 -0700
description:
diffstat:
src/drivers/las/LasHeaderReader.cpp | 7 +++++--
1 files changed, 5 insertions(+), 2 deletions(-)
diffs (25 lines):
diff -r 796b179c92df -r 483284c82936 src/drivers/las/LasHeaderReader.cpp
--- a/src/drivers/las/LasHeaderReader.cpp Mon Aug 15 07:12:43 2011 -0700
+++ b/src/drivers/las/LasHeaderReader.cpp Mon Aug 15 07:34:03 2011 -0700
@@ -342,9 +342,10 @@
std::string description = "";
- boost::scoped_ptr<boost::uint8_t> buf1( new boost::uint8_t[pdal::drivers::las::VariableLengthRecord::s_headerLength]);
+ // BUG: this should be a scoped ptr
+ boost::uint8_t* buf1 = new boost::uint8_t[pdal::drivers::las::VariableLengthRecord::s_headerLength];
Utils::read_n(buf1, m_istream, pdal::drivers::las::VariableLengthRecord::s_headerLength);
- boost::uint8_t* p1 = buf1.get();
+ boost::uint8_t* p1 = buf1;
reserved = Utils::read_field<boost::uint16_t>(p1);
boost::ignore_unused_variable_warning(reserved);
@@ -359,6 +360,8 @@
boost::uint8_t description_data[32];
Utils::read_array_field(p1, description_data, 32);
description = VariableLengthRecord::bytes2string(description_data, 32);
+ delete[] buf1;
boost::uint8_t* data = new boost::uint8_t[recordLenAfterHeader];
More information about the Liblas-commits
