[Liblas-commits] hg-main-tree: use exceptions, not status codes,
for simpler cont...
liblas-commits at liblas.org
Tue Aug 16 15:13:11 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/46e987465d22
changeset: 1113:46e987465d22
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Aug 16 12:12:56 2011 -0700
description:
use exceptions, not status codes, for simpler control flow
diffstat:
apps/Application.cpp | 75 +++++++++++++++++++++++++++++----------------------
apps/Application.hpp | 30 +++++++++++++++++---
apps/pc2pc.cpp | 15 ++++------
apps/pcinfo.cpp | 19 +++++-------
apps/pcpipeline.cpp | 12 +++----
5 files changed, 87 insertions(+), 64 deletions(-)
diffs (truncated from 336 to 300 lines):
diff -r 2739a27fb75e -r 46e987465d22 apps/Application.cpp
--- a/apps/Application.cpp Tue Aug 16 11:47:54 2011 -0700
+++ b/apps/Application.cpp Tue Aug 16 12:12:56 2011 -0700
@@ -54,8 +54,40 @@
return;
+// this just wraps ALL the code in total catch block
int Application::run()
+ int status = 1;
+ try
+ status = innerRun();
+ catch (pdal::pdal_error e)
+ const std::string s("Caught PDAL exception: ");
+ printError(s + e.what());
+ status = 1;
+ catch (std::exception e)
+ const std::string s("Caught exception: ");
+ status = 1;
+ catch (...)
+ printError("Caught unknown exception");
+ status = 1;
+ return status;
+int Application::innerRun()
// add -h, -v, etc
addBasicOptionSet();
@@ -78,35 +110,22 @@
return 0;
- // do any user-level sanity checking
- bool happy = validateOptions();
- if (!happy)
+ try
+ // do any user-level sanity checking
+ validateOptions();
+ catch (app_usage_error e)
+ printError(e.what());
outputHelp();
return 1;
boost::timer timer;
- // call derived function
- int status = 0;
+ int status = execute();
- try
- status = execute();
- catch (std::exception e)
- const std::string s(e.what());
- runtimeError("Caught exception: " + s);
- status = 1;
- catch (...)
- runtimeError("Caught unknown exception");
- status = 1;
if (status == 0 && hasOption("timer"))
const double t = timer.elapsed();
@@ -117,16 +136,9 @@
-void Application::usageError(const std::string& err)
+void Application::printError(const std::string& err)
- std::cout << "Usage error: " << err << std::endl;
- std::cout << std::endl;
-void Application::runtimeError(const std::string& err)
- std::cout << "Error: " << err << std::endl;
+ std::cout << err << std::endl;
@@ -234,8 +246,7 @@
catch (boost::program_options::unknown_option e)
- usageError("unknown option: " + e.get_option_name());
- exit(1);
+ throw app_usage_error("unknown option: " + e.get_option_name());
po::notify(m_variablesMap);
diff -r 2739a27fb75e -r 46e987465d22 apps/Application.hpp
--- a/apps/Application.hpp Tue Aug 16 11:47:54 2011 -0700
+++ b/apps/Application.hpp Tue Aug 16 12:12:56 2011 -0700
@@ -35,6 +35,7 @@
#ifndef INCLUDED_APPLICATION_HPP
#define INCLUDED_APPLICATION_HPP
+#include <pdal/exceptions.hpp>
#include <iosfwd>
@@ -48,8 +49,26 @@
#endif
+class app_usage_error : public pdal::pdal_error
+public:
+ app_usage_error(std::string const& msg)
+ : pdal_error(msg)
+class app_runtime_error : public pdal::pdal_error
+public:
+ app_runtime_error(std::string const& msg)
+ : pdal_error(msg)
-// The pplication base class gives us these common options:
+// The application base class gives us these common options:
// --help / -h
// --verbose / -v
// --version
@@ -66,10 +85,11 @@
virtual void addOptions() = 0;
// implement this, to do sanity checking of cmd line
- // return false if the user gave us bad options
- virtual bool validateOptions() { return true; }
+ // will throw if the user gave us bad options
+ virtual void validateOptions() {}
// implement this, to do your actual work
+ // it will be wrapped in a global catch try/block for you
virtual int execute() = 0;
protected:
@@ -79,10 +99,10 @@
bool isDebug() const;
boost::uint8_t getVerboseLevel() const;
bool hasOption(const std::string& name);
- void usageError(const std::string&);
- void runtimeError(const std::string&);
+ void printError(const std::string&);
private:
+ int innerRun();
void parseOptions();
void outputHelp();
void outputVersion();
diff -r 2739a27fb75e -r 46e987465d22 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Tue Aug 16 11:47:54 2011 -0700
+++ b/apps/pc2pc.cpp Tue Aug 16 12:12:56 2011 -0700
@@ -62,7 +62,7 @@
private:
void addOptions();
- bool validateOptions();
+ void validateOptions();
std::string m_inputFile;
std::string m_outputFile;
@@ -79,21 +79,19 @@
-bool Application_pc2pc::validateOptions()
+void Application_pc2pc::validateOptions()
if (!hasOption("input"))
- usageError("--input/-i required");
- return false;
+ throw app_usage_error("--input/-i required");
if (!hasOption("output"))
- usageError("--output/-o required");
- return false;
+ throw app_usage_error("--output/-o required");
- return true;
+ return;
@@ -118,8 +116,7 @@
if (!FileUtils::fileExists(m_inputFile))
- runtimeError("file not found: " + m_inputFile);
- return 1;
+ throw app_runtime_error("file not found: " + m_inputFile);
std::ostream* ofs = FileUtils::createFile(m_outputFile);
diff -r 2739a27fb75e -r 46e987465d22 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Tue Aug 16 11:47:54 2011 -0700
+++ b/apps/pcinfo.cpp Tue Aug 16 12:12:56 2011 -0700
@@ -56,7 +56,7 @@
private:
void addOptions();
void readOnePoint();
void readAllPoints();
@@ -73,18 +73,18 @@
, m_inputFile("")
, m_pointNumber(0)
+ return;
-bool PcInfo::validateOptions()
+void PcInfo::validateOptions()
- usageError("input file name required");
- return false;
+ throw app_usage_error("input file name required");
- return true;
+ return;
@@ -129,8 +129,7 @@
const boost::uint32_t numRead = iter->read(data);
if (numRead != 1)
- runtimeError("problem reading point number " + m_pointNumber);
- return;
+ throw app_runtime_error("problem reading point number " + m_pointNumber);
std::cout << "Read point " << m_pointNumber << "\n";
@@ -165,16 +164,14 @@
if (!pdal::FileUtils::fileExists(m_inputFile))
- return 1;
std::string driver = AppSupport::inferReaderDriver(m_inputFile);
if (driver == "")
- runtimeError("Cannot determine file type of " + m_inputFile);
- return 1;
+ throw app_runtime_error("Cannot determine file type of " + m_inputFile);
if (hasOption("liblas") && driver == "drivers.las.reader")
diff -r 2739a27fb75e -r 46e987465d22 apps/pcpipeline.cpp
--- a/apps/pcpipeline.cpp Tue Aug 16 11:47:54 2011 -0700
+++ b/apps/pcpipeline.cpp Tue Aug 16 12:12:56 2011 -0700
@@ -54,7 +54,7 @@
More information about the Liblas-commits
