[Liblas-commits] hg-main-tree: improved stats collection mechanism
liblas-commits at liblas.org
Thu Aug 18 20:06:47 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/017ef48bc1bd
changeset: 1142:017ef48bc1bd
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Aug 18 17:06:27 2011 -0700
description:
diffstat:
include/pdal/filters/StatsFilter.hpp | 51 +++++++-
src/filters/StatsFilter.cpp | 196 ++++++++++++++++++++++------------
test/unit/StatsFilterTest.cpp | 33 +++--
3 files changed, 184 insertions(+), 96 deletions(-)
diffs (truncated from 376 to 300 lines):
diff -r f449609b8009 -r 017ef48bc1bd include/pdal/filters/StatsFilter.hpp
--- a/include/pdal/filters/StatsFilter.hpp Thu Aug 18 13:33:19 2011 -0700
+++ b/include/pdal/filters/StatsFilter.hpp Thu Aug 18 17:06:27 2011 -0700
@@ -45,6 +45,29 @@
class StatsFilterSequentialIterator;
+class StatsCollector
+public:
+ StatsCollector();
+ void insert(double value);
+ void reset();
+ double minimum() const { return m_minimum; }
+ double maximum() const { return m_maximum; }
+ double average() const { return m_sum / (double)m_count; }
+ boost::uint64_t count() const { return m_count; }
+ boost::property_tree::ptree toPTree() const;
+private:
+ boost::uint64_t m_count;
+ double m_minimum;
+ double m_maximum;
+ double m_sum;
// this is just a pass-thorugh filter, which collects some stats about the points
// that are fed through it
class PDAL_DLL StatsFilter : public Filter
@@ -54,6 +77,7 @@
StatsFilter(Stage& prevStage, const Options&);
StatsFilter(Stage& prevStage);
+ ~StatsFilter();
virtual void initialize();
virtual const Options getDefaultOptions() const;
@@ -72,19 +96,28 @@
void processBuffer(PointBuffer& data) const;
- // clears the counters
+ // returns the stats for field i
+ const StatsCollector& getStats(Dimension::Field field) const;
+ // clears the counters for all fields
void reset();
- void getData(boost::uint64_t& count,
- double& minx, double& miny, double& minz,
- double& maxx, double& maxy, double& maxz,
- double& avgx, double& avgy, double& avgz) const;
+ // return a tree like this:
+ // X:
+ // cout: 100
+ // min: 1.0
+ // max: 100.0
+ // Y:
+ // cout: 100
+ // min: 11.0
+ // max: 110.0
+ boost::property_tree::ptree toStatsPTree() const;
private:
+// the stats are keyed by the field name
// BUG: not threadsafe, these should maybe live in the iterator
- mutable boost::uint64_t m_totalPoints;
- mutable double m_minimumX, m_minimumY, m_minimumZ;
- mutable double m_maximumX, m_maximumY, m_maximumZ;
- mutable double m_sumX, m_sumY, m_sumZ;
+ std::map<Dimension::Field,StatsCollector*> m_stats; // one Stats item per field in the schema
StatsFilter& operator=(const StatsFilter&); // not implemented
StatsFilter(const StatsFilter&); // not implemented
diff -r f449609b8009 -r 017ef48bc1bd src/filters/StatsFilter.cpp
--- a/src/filters/StatsFilter.cpp Thu Aug 18 13:33:19 2011 -0700
+++ b/src/filters/StatsFilter.cpp Thu Aug 18 17:06:27 2011 -0700
@@ -43,6 +43,64 @@
namespace pdal { namespace filters {
+StatsCollector::StatsCollector()
+ : m_count(0)
+ , m_minimum(0.0)
+ , m_maximum(0.0)
+ , m_sum(0.0)
+ return;
+void StatsCollector::reset()
+ m_count = 0;
+ m_minimum = 0.0;
+ m_maximum = 0.0;
+ m_sum = 0.0;
+ return;
+void StatsCollector::insert(double value)
+ if (m_count==0)
+ m_minimum = value;
+ m_maximum = value;
+ m_sum = value;
+ else
+ m_minimum = std::min(m_minimum, value);
+ m_maximum = std::max(m_maximum, value);
+ m_sum += value;
+ ++m_count;
+ return;
+boost::property_tree::ptree StatsCollector::toPTree() const
+ boost::property_tree::ptree tree;
+ tree.put("count", count());
+ tree.put("minimum", minimum());
+ tree.put("maximum", maximum());
+ tree.put("average", average());
+ return tree;
StatsFilter::StatsFilter(Stage& prevStage, const Options& options)
: pdal::Filter(prevStage, options)
@@ -58,11 +116,28 @@
+StatsFilter::~StatsFilter()
+ Schema::Dimensions dims = getSchema().getDimensions();
+ for (Schema::DimensionsIter iter = dims.begin(); iter != dims.end(); ++iter)
+ const Dimension& dim = *iter;
+ StatsCollector* stats = m_stats[dim.getField()];
+ delete stats;
+ m_stats.erase(dim.getField());
void StatsFilter::initialize()
Filter::initialize();
- reset();
+ const Schema::Dimensions dims = getSchema().getDimensions();
+ for (Schema::DimensionsCIter iter = dims.begin(); iter != dims.end(); ++iter)
+ m_stats[dim.getField()] = new StatsCollector();
return;
@@ -77,43 +152,19 @@
void StatsFilter::reset()
- m_totalPoints = 0;
+ m_stats[dim.getField()]->reset();
- m_minimumX = 0.0;
- m_minimumY = 0.0;
- m_minimumZ = 0.0;
- m_maximumX = 0.0;
- m_maximumY = 0.0;
- m_maximumZ = 0.0;
- m_sumX = 0.0;
- m_sumY = 0;
- m_sumZ = 0;
- return;
-void StatsFilter::getData(boost::uint64_t& count,
+const StatsCollector& StatsFilter::getStats(Dimension::Field field) const
- minx = m_minimumX;
- miny = m_minimumY;
- minz = m_minimumZ;
- maxx = m_maximumX;
- maxy = m_maximumY;
- maxz = m_maximumZ;
- avgx = m_sumX / (double)m_totalPoints;
- avgy = m_sumY / (double)m_totalPoints;
- avgz = m_sumZ / (double)m_totalPoints;
- count = m_totalPoints;
- return;
+ const StatsCollector* s = m_stats.find(field)->second;
+ return *s;
@@ -124,46 +175,23 @@
const SchemaLayout& schemaLayout = data.getSchemaLayout();
const Schema& schema = schemaLayout.getSchema();
- const int indexX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Double);
- const int indexY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Double);
- const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Double);
+ const int indexX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Int32);
+ const int indexY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Int32);
+ const int indexZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Int32);
+ StatsCollector& statsX = *(m_stats.find(Dimension::Field_X)->second);
+ StatsCollector& statsY = *(m_stats.find(Dimension::Field_Y)->second);
+ StatsCollector& statsZ = *(m_stats.find(Dimension::Field_Z)->second);
for (boost::uint32_t pointIndex=0; pointIndex<numPoints; pointIndex++)
- const double x = data.getField<double>(pointIndex, indexX);
- const double y = data.getField<double>(pointIndex, indexY);
- const double z = data.getField<double>(pointIndex, indexZ);
+ const double x = data.getField<boost::int32_t>(pointIndex, indexX);
+ const double y = data.getField<boost::int32_t>(pointIndex, indexY);
+ const double z = data.getField<boost::int32_t>(pointIndex, indexZ);
- if (m_totalPoints==0)
- m_minimumX = x;
- m_minimumY = y;
- m_minimumZ = z;
- m_maximumX = x;
- m_maximumY = y;
- m_maximumZ = z;
- m_sumX = x;
- m_sumY = y;
- m_sumZ = z;
- else
- m_minimumX = std::min(m_minimumX, x);
- m_minimumY = std::min(m_minimumY, y);
- m_minimumZ = std::min(m_minimumZ, z);
- m_maximumX = std::max(m_maximumX, x);
- m_maximumY = std::max(m_maximumY, y);
- m_maximumZ = std::max(m_maximumZ, z);
- m_sumX += x;
- m_sumY += y;
- m_sumZ += z;
- ++m_totalPoints;
+ statsX.insert(x);
+ statsY.insert(y);
+ statsZ.insert(z);
data.setNumPoints(pointIndex+1);
@@ -177,4 +205,28 @@
return new StatsFilterSequentialIterator(*this);
+boost::property_tree::ptree StatsFilter::toStatsPTree() const
More information about the Liblas-commits
