[Liblas-commits] hg-main-tree: added stage-specific stage dumping
to pcinfo
liblas-commits at liblas.org
Thu Aug 18 20:44:47 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/a5c850699fc4
changeset: 1144:a5c850699fc4
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Aug 18 17:44:29 2011 -0700
description:
added stage-specific stage dumping to pcinfo
diffstat:
apps/pcinfo.cpp | 7 +---
include/pdal/Filter.hpp | 4 +++
include/pdal/MultiFilter.hpp | 4 +++
include/pdal/Reader.hpp | 4 +++
include/pdal/Stage.hpp | 3 +-
include/pdal/StageBase.hpp | 1 +
include/pdal/Writer.hpp | 4 +++
include/pdal/drivers/faux/Reader.hpp | 3 ++
include/pdal/drivers/faux/Writer.hpp | 3 ++
include/pdal/drivers/las/Reader.hpp | 3 ++
include/pdal/drivers/las/Writer.hpp | 3 ++
include/pdal/drivers/liblas/Reader.hpp | 3 ++
include/pdal/drivers/liblas/Writer.hpp | 5 +++-
include/pdal/drivers/oci/Reader.hpp | 3 ++
include/pdal/drivers/oci/Writer.hpp | 3 +-
include/pdal/drivers/pipeline/Reader.hpp | 3 ++
include/pdal/drivers/qfit/Reader.hpp | 2 +
include/pdal/drivers/terrasolid/Reader.hpp | 2 +
src/Filter.cpp | 10 +++++++
src/MultiFilter.cpp | 10 +++++++
src/Reader.cpp | 10 +++++++
src/Stage.cpp | 11 ++++++-
src/Writer.cpp | 10 +++++++
src/drivers/faux/Reader.cpp | 10 +++++++
src/drivers/faux/Writer.cpp | 9 ++++++
src/drivers/las/Reader.cpp | 10 +++++++
src/drivers/las/Writer.cpp | 10 +++++++
src/drivers/liblas/Reader.cpp | 9 ++++++
src/drivers/liblas/Writer.cpp | 10 +++++++
src/drivers/oci/Reader.cpp | 9 ++++++
src/drivers/oci/Writer.cpp | 9 ++++++
src/drivers/pipeline/Reader.cpp | 9 ++++++
src/drivers/qfit/Reader.cpp | 8 ++++++
src/drivers/terrasolid/Reader.cpp | 7 +++++
src/filters/StatsFilter.cpp | 16 +++++++----
test/data/apps/pcinfo_stage.txt | 40 +++++++++++++++++++++++++++--
test/unit/StatsFilterTest.cpp | 3 +-
test/unit/pcinfoTest.cpp | 2 +
38 files changed, 251 insertions(+), 21 deletions(-)
diffs (truncated from 644 to 300 lines):
diff -r acc2c512e52c -r a5c850699fc4 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Thu Aug 18 17:06:52 2011 -0700
+++ b/apps/pcinfo.cpp Thu Aug 18 17:44:29 2011 -0700
@@ -206,14 +206,11 @@
void PcInfo::dumpStage(const Stage& stage) const
- const boost::uint64_t numPoints = stage.getNumPoints();
- const SpatialReference& srs = stage.getSpatialReference();
+ boost::property_tree::ptree tree = stage.toPTree();
std::ostream& ostr = m_outputStream ? *m_outputStream : std::cout;
- ostr << "driver type: " << stage.getName() << "\n";
- ostr << numPoints << " points\n";
- ostr << "WKT: " << srs.getWKT() << "\n";
+ boost::property_tree::write_json(ostr, tree);
return;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/Filter.hpp
--- a/include/pdal/Filter.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/Filter.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -51,8 +51,12 @@
const Stage& getPrevStage() const;
+ // for xml serializion of pipelines
virtual boost::property_tree::ptree generatePTree() const;
+ // for dumping
+ virtual boost::property_tree::ptree toPTree() const;
protected:
Stage& getPrevStage();
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/MultiFilter.hpp
--- a/include/pdal/MultiFilter.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/MultiFilter.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -53,8 +53,12 @@
const std::vector<const Stage*> getPrevStages() const;
+ // for dumping
protected:
std::vector<Stage*> m_prevStages;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/Reader.hpp
--- a/include/pdal/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -54,7 +54,11 @@
virtual void initialize();
+ // for dumping
} // namespace pdal
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/Stage.hpp
--- a/include/pdal/Stage.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/Stage.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -76,7 +76,8 @@
virtual StageRandomIterator* createRandomIterator() const { return NULL; }
virtual StageBlockIterator* createBlockIterator() const { return NULL; }
- void dump() const;
+ // for dumping
protected:
// setters for the core properties
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/StageBase.hpp
--- a/include/pdal/StageBase.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/StageBase.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -106,6 +106,7 @@
static std::string s_getDescription() { return description; } \
std::string getDescription() const { return description; }
+ // for dumping
virtual void dump() const;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/Writer.hpp
--- a/include/pdal/Writer.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/Writer.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -65,6 +65,7 @@
// If given number of points is 0, do as many points as the reader supplies to us.
boost::uint64_t write(boost::uint64_t targetNumPointsToWrite=0);
@@ -72,6 +73,9 @@
const SpatialReference& getSpatialReference() const;
void setSpatialReference(const SpatialReference&);
+ // for dumping
protected:
// this is called once before the loop with all the writeBuffer calls
virtual void writeBegin(boost::uint64_t targetNumPointsToWrite) = 0;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/faux/Reader.hpp
--- a/include/pdal/drivers/faux/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/faux/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -99,6 +99,9 @@
// this is called by the stage's iterator
boost::uint32_t processBuffer(PointBuffer& data, boost::uint64_t index) const;
+ // for dumping
private:
Bounds<double> m_bounds;
boost::uint64_t m_numPoints;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/faux/Writer.hpp
--- a/include/pdal/drivers/faux/Writer.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/faux/Writer.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -70,6 +70,9 @@
double getAvgY() const { return m_averageY; }
double getAvgZ() const { return m_averageZ; }
+ // for dumping
private:
double m_minimumX;
double m_minimumY;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/las/Reader.hpp
--- a/include/pdal/drivers/las/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/las/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -94,6 +94,9 @@
bool isCompressed() const;
+ // for dumping
protected:
const LasHeader& getLasHeader() const { return m_lasHeader; }
LasHeader& getLasHeaderRef() { return m_lasHeader; }
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/las/Writer.hpp
--- a/include/pdal/drivers/las/Writer.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/las/Writer.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -88,6 +88,9 @@
// default false
void setCompressed(bool);
+ // for dumping
protected:
virtual void writeBegin(boost::uint64_t targetNumPointsToWrite);
virtual boost::uint32_t writeBuffer(const PointBuffer&);
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/liblas/Reader.hpp
--- a/include/pdal/drivers/liblas/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/liblas/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -88,6 +88,9 @@
pdal::StageSequentialIterator* createSequentialIterator() const;
pdal::StageRandomIterator* createRandomIterator() const;
+ // for dumping
private:
void processExternalHeader(::liblas::Reader& externalReader);
void registerFields(::liblas::Reader& externalReader);
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/liblas/Writer.hpp
--- a/include/pdal/drivers/liblas/Writer.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/liblas/Writer.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -88,7 +88,10 @@
void setHeaderPadding(boost::uint32_t const& v);
+ // for dumping
protected:
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/oci/Reader.hpp
--- a/include/pdal/drivers/oci/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/oci/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -75,6 +75,9 @@
CloudPtr getCloud() const;
std::string getQuery() const;
+ // for dumping
private:
Reader& operator=(const Reader&); // not implemented
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/oci/Writer.hpp
--- a/include/pdal/drivers/oci/Writer.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/oci/Writer.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -64,7 +64,8 @@
inline Connection getConnection() const { return m_connection;}
+ // for dumping
protected:
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/pipeline/Reader.hpp
--- a/include/pdal/drivers/pipeline/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/pipeline/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -63,6 +63,9 @@
+ // for dumping
private:
std::string m_filename;
boost::scoped_ptr<PipelineManager> m_manager;
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/qfit/Reader.hpp
--- a/include/pdal/drivers/qfit/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/qfit/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -153,6 +153,8 @@
boost::uint32_t processBuffer(PointBuffer& PointBuffer, std::istream& stream, boost::uint64_t numPointsLeft) const;
+ // for dumping
protected:
inline QFIT_Format_Type getFormat() const { return m_format; }
diff -r acc2c512e52c -r a5c850699fc4 include/pdal/drivers/terrasolid/Reader.hpp
--- a/include/pdal/drivers/terrasolid/Reader.hpp Thu Aug 18 17:06:52 2011 -0700
+++ b/include/pdal/drivers/terrasolid/Reader.hpp Thu Aug 18 17:44:29 2011 -0700
@@ -165,6 +165,8 @@
+ // for dumping
protected:
inline TERRASOLID_Format_Type getFormat() const { return m_format; }
diff -r acc2c512e52c -r a5c850699fc4 src/Filter.cpp
--- a/src/Filter.cpp Thu Aug 18 17:06:52 2011 -0700
+++ b/src/Filter.cpp Thu Aug 18 17:44:29 2011 -0700
@@ -93,4 +93,14 @@
+boost::property_tree::ptree Filter::toPTree() const
+ boost::property_tree::ptree tree = Stage::toPTree();
+ // (nothing to add for a Filter)
+ return tree;
} // namespace pdal
diff -r acc2c512e52c -r a5c850699fc4 src/MultiFilter.cpp
--- a/src/MultiFilter.cpp Thu Aug 18 17:06:52 2011 -0700
+++ b/src/MultiFilter.cpp Thu Aug 18 17:44:29 2011 -0700
@@ -107,4 +107,14 @@
+boost::property_tree::ptree MultiFilter::toPTree() const
+ tree.add("NumPrevStages", getPrevStages().size());
+ return tree;
} // namespace pdal
diff -r acc2c512e52c -r a5c850699fc4 src/Reader.cpp
--- a/src/Reader.cpp Thu Aug 18 17:06:52 2011 -0700
+++ b/src/Reader.cpp Thu Aug 18 17:44:29 2011 -0700
@@ -74,4 +74,14 @@
+boost::property_tree::ptree Reader::toPTree() const
More information about the Liblas-commits
