[Liblas-commits] hg: laszip revision number got bumped up
liblas-commits at liblas.org
Tue Feb 1 11:44:51 EST 2011
details: http://hg.liblas.orghg/rev/3f0cf2bdd9ea
changeset: 2837:3f0cf2bdd9ea
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Feb 01 08:44:41 2011 -0800
description:
diffstat:
src/detail/zippoint.cpp | 762 ++++++++++++++++++++++++------------------------
1 files changed, 381 insertions(+), 381 deletions(-)
diffs (truncated from 766 to 300 lines):
diff -r f795eb76dd5f -r 3f0cf2bdd9ea src/detail/zippoint.cpp
--- a/src/detail/zippoint.cpp Mon Jan 31 12:25:13 2011 -0600
+++ b/src/detail/zippoint.cpp Tue Feb 01 08:44:41 2011 -0800
@@ -1,381 +1,381 @@
- * $Id$
- * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose: laszip helper functions for C++ libLAS
- * Author: Michael P. Gerlek (mpg at flaxen.com)
- * Copyright (c) 2010, Michael P. Gerlek
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
- * with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifdef HAVE_LASZIP
-#include <liblas/liblas.hpp>
-#include <liblas/detail/private_utility.hpp>
-#include <liblas/detail/zippoint.hpp>
-// laszip
-#include <laszip/laszip.hpp>
-// std
-#include <vector>
-#include <fstream>
-#include <stdexcept>
-#include <cstdlib> // std::size_t
-#include <cassert>
-namespace liblas { namespace detail {
-static std::string laszip_userid("laszip encoded");
-static boost::uint16_t laszip_recordid = 22204;
-static std::string laszip_description = "encoded for sequential access";
-ZipPoint::ZipPoint(PointFormatName format) :
- m_num_items(0),
- m_items(NULL),
- m_lz_point(NULL),
- m_lz_point_data(NULL),
- m_lz_point_size(0)
- ConstructItems(format);
- return;
-ZipPoint::~ZipPoint()
- m_num_items = 0;
- delete[] m_items;
- m_items = NULL;
- delete[] m_lz_point;
- delete[] m_lz_point_data;
- return;
-void ZipPoint::ConstructItems(PointFormatName format)
- switch (format)
- case ePointFormat0:
- m_num_items = 1;
- m_items = new LASitem[1];
- m_items[0].set(LASitem::POINT10);
- break;
- case ePointFormat1:
- m_num_items = 2;
- m_items = new LASitem[2];
- m_items[1].set(LASitem::GPSTIME11);
- break;
- case ePointFormat2:
- m_num_items = 2;
- m_items[1].set(LASitem::RGB12);
- break;
- case ePointFormat3:
- m_num_items = 3;
- m_items = new LASitem[3];
- m_items[2].set(LASitem::RGB12);
- break;
- case ePointFormat4:
- m_num_items = 3;
- m_items[2].set(LASitem::WAVEPACKET13);
- break;
- default:
- throw liblas_error("Bad point format in header");
- // construct the object that will hold a laszip point
- // compute the point size
- m_lz_point_size = 0;
- for (unsigned int i = 0; i < m_num_items; i++)
- m_lz_point_size += m_items[i].size;
- // create the point data
- unsigned int point_offset = 0;
- m_lz_point = new unsigned char*[m_num_items];
- m_lz_point_data = new unsigned char[m_lz_point_size];
- for (unsigned i = 0; i < m_num_items; i++)
- m_lz_point[i] = &(m_lz_point_data[point_offset]);
- point_offset += m_items[i].size;
- return;
-template<class T>
-static inline boost::uint8_t* PutBytes(boost::uint8_t* p, T d)
- LIBLAS_SWAP_BYTES(d);
- memcpy(p, &d, sizeof(T));
- return p+sizeof(T);
-template<class T>
-static inline boost::uint8_t* GetBytes(boost::uint8_t* p, T& d)
- memcpy(&d, p, sizeof(T));
-void ZipPoint::ConstructVLR(VariableRecord& v) const
- boost::uint16_t record_length_after_header = (boost::uint16_t)(34+6*m_num_items);
- // set the header
- v.SetReserved(0xAABB);
- v.SetUserId(laszip_userid);
- v.SetRecordId(laszip_recordid);
- v.SetRecordLength(record_length_after_header);
- v.SetDescription(laszip_description);
- // the data following the header of the variable length record is
- // U32 compression 4 bytes
- // U8 version_major 1 byte
- // U8 version_minor 1 byte
- // U16 version_revision 2 bytes
- // U32 options 4 bytes
- // U32 num_chunks 4 bytes
- // I64 num_points 8 bytes
- // I64 num_bytes 8 bytes
- // U16 num_items 2 bytes
- // U16 type 2 bytes * num_items
- // U16 size 2 bytes * num_items
- // U16 version 2 bytes * num_items
- // which totals 34+6*num_items
- boost::uint8_t* data = new boost::uint8_t[record_length_after_header];
- boost::uint8_t* p = data;
- // the header doesn't know what kind of compression the zipwriter
- // will be doing, but since we only ever use the default we'll just
- // use that for now
- boost::uint32_t compression_type = LASzip::DEFAULT_COMPRESSION;
- p = PutBytes<boost::uint32_t>(p, compression_type);
- boost::uint8_t version_major = LASZIP_VERSION_MAJOR;
- p = PutBytes<boost::uint8_t>(p, version_major);
- boost::uint8_t version_minor = LASZIP_VERSION_MINOR;
- p = PutBytes<boost::uint8_t>(p, version_minor);
- boost::uint16_t version_revision = LASZIP_VERSION_REVISION;
- p = PutBytes<boost::uint16_t>(p, version_revision);
- boost::uint32_t options = 0;
- p = PutBytes<boost::uint32_t>(p, options);
- boost::uint32_t num_chunks = 1;
- p = PutBytes<boost::uint32_t>(p, num_chunks);
- boost::int64_t num_points = -1;
- p = PutBytes<boost::int64_t>(p, num_points);
- boost::int64_t num_bytes = -1;
- p = PutBytes<boost::int64_t>(p, num_bytes);
- boost::uint16_t num_items = (boost::uint16_t)m_num_items;
- p = PutBytes<boost::uint16_t>(p, num_items);
- for (boost::uint32_t i = 0; i < num_items; i++)
- boost::uint16_t type = (boost::uint16_t)m_items[i].type;
- p = PutBytes<boost::uint16_t>(p, type);
- boost::uint16_t size = (boost::uint16_t)m_items[i].size;
- p = PutBytes<boost::uint16_t>(p, size);
- boost::uint16_t version = (boost::uint16_t)m_items[i].version;
- p = PutBytes<boost::uint16_t>(p, version);
- assert(p == data + record_length_after_header);
- // Ick.
- std::vector<boost::uint8_t> vdata;
- for (boost::uint32_t i=0; i<record_length_after_header; i++)
- vdata.push_back(data[i]);
- v.SetData(vdata);
- if (data != 0)
- delete [] data;
- return;
-bool ZipPoint::ValidateVLR(std::vector<VariableRecord> const& vlrs) const
- std::vector<VariableRecord>::const_iterator it;
- for (it = vlrs.begin(); it != vlrs.end(); ++it)
- VariableRecord const& vlr = *it;
- if (IsZipVLR(vlr))
- return ValidateVLR(vlr);
- // if we didn't find one, but we don't care (for now)
- return true;
-bool ZipPoint::IsZipVLR(const VariableRecord& vlr) const
- if (laszip_userid == vlr.GetUserId(true).c_str() && laszip_recordid == vlr.GetRecordId())
- return true;
- return false;
-bool ZipPoint::ValidateVLR(const VariableRecord& vlr) const
- if (laszip_userid != vlr.GetUserId(true).c_str())
- return false;
- if (laszip_recordid != vlr.GetRecordId())
- return false;
- // note we don't bother validating the Description field
- boost::uint16_t record_length_after_header = vlr.GetRecordLength();
- if (record_length_after_header != 34 + 6 * m_num_items)
- return false;
- const std::vector<boost::uint8_t>& vdata = vlr.GetData();
- data[i] = vdata[i];
More information about the Liblas-commits
